Results 1 to 4 of 4
Thread: Coding out error message on reverse light bulbs Audi a1
    Nov 2016
    I would like to fit led reverse light bulbs,
    I've tried a few canbus ones, still show error / bulb out..... I would like to know if I can disable the error warning with vcds?? ... Audi a1 2011
    Please post a full unedited VCDS Auto-Scan of your A1 so we can see how your A1 is configured.
    Nov 2016
    Friday,05,July,2019,18:01:53:07086
    VCDS Version: 19.6.0.6 (x64)
    VIN: WAUZZZ8X5CB039627   License Plate: A1 61 PLATE TDI
    Mileage: 219220km-136216mi   Repair Order:
    Chassis Type: 8X-AU21 (8U0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
    VIN: WAUZZZ8X5CB039627   Mileage: 219220km-136216miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
       Component: R4 1.6l TDI   H63 9978
       Revision: --H63---    Serial number:
       Coding: 00114016030501080000
       Shop #: WSC 00046 790 00000
       ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
       ROD: EV_ECM16TDI02103L906023KG.rod
       VCID: 7F0710B2E6E6D2B7EC-802A
    10116 - Fuel Rail/System Pressure
              P0087 00 [096] - Too Low
                        Mileage: 218826 km
                        Date: 2019.05.14
                        Time: 17:31:09
                        Engine speed: 1911.75 /min
                        Vehicle speed: 102 km/h
                        Coolant temperature: 95 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 14.456 V
                        Unlearning counter according OBD: 27
                        Fuel high pressure: actual value-FUP_FIL: 72.083 MPa
                        Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
                        Fuel level-FTL_CAN: 14 l
                        Fuel temperature-TFU: 62 °C
                        Fuel Metering Valve-VCV: 19.775 %
                        Fuel Pressure Regulator Valve-PCV: 38.029 %
                        Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 79931.641 kPa
    10117 - Fuel Pressure Regulation Valve 2 Control Difference
              P229B 00 [104] - Pressure too High
                        Fault Frequency: 60
                        Mileage: 213452 km
                        Date: 2018.11.19
                        Time: 13:18:55
                        Engine speed: 892.75 /min
                        Normed load value: 27.5 %
                        Vehicle speed: 3 km/h
                        Coolant temperature: 58 °C
                        Intake air temperature: 19 °C
                        Voltage terminal 30: 14.118 V
                        Unlearning counter according OBD: 15
                        Fuel high pressure: actual value-FUP_FIL: 48.187 MPa
                        Engine status-SF_ENG_STATE: PL
                        Fuel temperature-TFU: 6 °C
                        Fuel Metering Valve-VCV: 27.116 %
                        Fuel Pressure Regulator Valve-PCV: 0.000 %
                        Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 31555.176 kPa
    Readiness: 0 1 0 0 0
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
       Component: ESP8.2i front H07 0001
       Revision: --------
       Coding: 330448E9437000BBCC2B12E4C2D800920C00
       Shop #: WSC 00046 000 00000
       VCID: 7F0710B2EAE6D2B7EC-802A
       Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
       Component: J255 Klima Manuell  0140
       Revision: 0000707S    Serial number: 03030005858844
       VCID: 346D0F9E5720C1EF41-8060
                        Reset counter: 162
                        Mileage: 218708 km
                        Date: 2019.05.12
                        Time: 07:55:43
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
       Component: BCM PQ35  M   110 0655
       Revision: 00110 AE
       Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045
       VCID: 4085534ED3986D4FD5-8014
       Subsystem 1 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
       Component: Airbag10.41   H04 0008
       Revision: --------    Serial number: 003JJ0039CR6
       Coding: 30314539303330303034554A305238583053
       ASAM Dataset: EV_Airba1041BPAAU210 001015
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 48954B6EF3A8550F1D-801C
       Serial number: 3554VRB40570M8GC60TN
       Serial number: 3575HRB405J0OPMG2OOP
       Serial number: 3585HRB40510N3MG8OFP
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB405B0MFP6I0U8
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
       Revision: FF010016    Serial number: 20110913100937
       Coding: 1184004000
       VCID: 39733EAAB8423C8792-806C
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Component: E221 - MFL  H08 0009
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
       Component: KOMBI_MEDIUM  H03 0179
       Coding: 41DE00
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
       VCID: 4085534EDB986D4FD5-8014
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
       Component: GAT 4CAN 1L M H10 0044
       Revision: 1P040023    Serial number: 2341P119180144
       Coding: FBCF005A000100010153
       Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
       Component: J367-BDM  H07 0171
       Serial number: 00000000007100549523
       Serial number: 11278001482021200181
       Component: IMMO          H03 0179
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
       Component: TSG FA        H09 0409
       Coding: 011E02200101000100
       VCID: 4E997D7619CC8B3F57-801A
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11251
       Shop #: WSC 00046
       VCID: 2F6700F2EA06E2373C-807A
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
       Component: TSG BF        H09 0409
       VCID: 4D9B7A7A14CAB0272E-8018
    02123 - Door Warning Light / Entry Light
                        Fault Status: 00101100
                        Reset counter: 165
                        Mileage: 218732 km
                        Date: 2019.05.13
                        Time: 18:00:59
       Part No SW: 8X0 035 183 E    HW: 8X0 035 183 C
       Component: RMC Cnct      H51 0775
       Coding: 01010001008051070023000103010000010000
       VCID: 39733EAAB0423C8792-806C
       Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9462IW0B0139570
    End-------------------------(Elapsed Time: 02:41)--------------------------
  4. Likes Uwe liked this post
    Nov 2016
    Quote Originally Posted by vw754 View Post
                        Mileage: 218826 km
                        Date: 2019.05.14
                        Time: 17:31:09
                        Fault Frequency: 60
                        Mileage: 213452 km
                        Date: 2018.11.19
                        Time: 13:18:55
       Revision: --------
                        Reset counter: 162
                        Mileage: 218708 km
                        Date: 2019.05.12
                        Time: 07:55:43
       Revision: 00110 AE
       Coding: 1184004000
       Coding: 41DE00
       Coding: 000002
       Coding: 11251
       Shop #: WSC 00046
                        Reset counter: 165
                        Mileage: 218732 km
                        Date: 2019.05.13
                        Time: 18:00:59
    ANYONE?????
