Results 1 to 10 of 17
Thread: B6 Passat Discover Media Retrofit
    Jan 2019
    The Netherlands
    Smile B6 Passat Discover Media Retrofit
    Bumping this threat.
    Retrofitted also Discover Media in my B6 passat 2008
    All works fine, only the issue with readablillity of the screen at day.
    Brightness is highest.
    Now I found in adaptation maps the possibillity to change value for
    Dimming_Ambient Illimination Information control unit X1 u/t X3
    Dimming_Ambient Illimination Information control unit Y1 u/t Y3
    Dimming Illumination for Display Unit X1 u/t X6
    Dimming Illumination for Display Unit Y1 u/t Y6
    Is this also the behaviour for dimming at day or only with lights on?
    Or is Xx for daytime and Yx for nighttime?
    Jan 2019
    The Netherlands
    good evening.
    Today I connected my VCP cable to my B6 2008 Passat with Discover Media PQ system.
    Only one fault is still in module 5F of the DM.
    This fault says
    Break / short to ground. Lamp OFF status unknown.
    This same fault I find in the Gen.3 climatronic unit and occasionally in my B7 Gateway.
    Any way to solve this question?
    A 2008 B6 is quite different than a 2012 NMS, so split from this thread.
    Mar 2015
    Australia
    You need to check what the extended UDS error message is. That's just a generic fault 'break/short to ground'.
    It's likely an SVM fault in the Discover unit, and a databus missing message in the climatronics. If so nothing to worry about doesn't affect anything.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
    Quote Originally Posted by dieseltje View Post
    Today I connected my VCP cable...
    Posting a VCDS Auto-Scan might be a good idea
  6. Likes Uwe, dieseltje liked this post
    Jan 2019
    The Netherlands
    I don't have troubles with settings in VCDS. Only the Error in climatronic and Discover Media, where everybody is telling me to ignore it, seems to have a connection with the brightness of the temperature figures and the brightness of the Discover Media Screen (during day time).
    As I understand, the B7 BCM has some extra Canbus signals that should support brightness of screens via lightsensor input.
    My suspicion is somewhat confirmed by the scan with VCP where the same fault says "Break / short to ground. Lamp OFF status unknown"
    I have retrofitted in my 2008 B6, B7 Gateway, B7 CMM, B7 coulor cluster, Discover Media dab+ and 3rd Generation Climatronic unit.
       Part No SW: 35D 907 044 B    HW: 35D 907 044 B
       Component: Climatronic   H03 0303
       Revision: 00001K02
       Coding: 0600004A02
       ROD: EV_ACClimaBHBVW411_VW46.rod
       VCID: 2649DC71592F0D7FCB-8072
    13701424 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 14
                        Reset counter: 15
                        Mileage: 376448 km
                        Date: 2019.06.07
                        Time: 14:32:46
       Part No SW: 7N0 907 530 BC    HW: 1K0 907 951
       Component: J533  Gateway H41 1663
       Revision:   H41       Serial number: 260112F2002064
       Coding: 462006
       VCID: 72E1F021AD6721DF97-8026
    03175 - Invalid Data Set
                        Reset counter: 15
                        Mileage: 376451 km
                        Date: 2019.06.07
                        Time: 15:32:33
       Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
       Component: MU-S-ND-ER    H22 0245
       Serial number: VWZAZ2R8029459
       Coding: 027302010000000011111105018808001F0106D4002001008F
       ROD: EV_MUStd4CTSAT_VW46.rod
       VCID: 2143CF6D3001EA47BE-8074
       Subsystem 1 - Part No SW: 5NA 919 866 R    HW: -----------
       Component: ECE AS 19/20  --- 1115
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 15
                        Mileage: 376448 km
                        Date: 2019.06.07
                        Time: 14:32:48
                        Voltage terminal 30: 11.9 V
                        BAP-BAP_Function_ID: 02
    Passat B6 2.0 TDI CR DSG Tuned by Cardrik Tuning
    Any reason why you've posted an edited VCDS Auto-Scan? The full Auto-Scan often shows important other details/information.
  9. Likes dieseltje liked this post
  10. #8
    Jan 2019
    The Netherlands
    I was at work didn't have my home laptop with me.
    Saturday,08,June,2019,08:19:10:51200
    VCDS Version: 19.6.0.2
    Dealer/Shop Name: Haarsma
    VIN: WVWZZZ3CZ8E231165   License Plate: xxxxxx
    Mileage: 376480km-233933mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 19 25 36 42 44 46 47 4F 52
              53 5F 62 69 72
    VIN: WVWZZZ3CZ8E231165   Mileage: 376480km-233933miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 CN    HW: 03L 907 309
       Component: R4 2,0L EDC F001AG  6220
       Revision: --H01---    Serial number: VWZCZ000000000
       Coding: 0000078
       Shop #: WSC 66565 257 00032
       VCID: 73EFF525127D28D79C-8026
       Part No SW: 02E 300 050 D    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 1464
       Revision:    51112    Serial number: 00000902190468
       VCID: 132F95A532BD88D73C-8046
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 698 109 E    HW: 3C0 614 109 AF
       Component: J104    C4 440 V3   0017
       Revision: --025---    Serial number: 00000104023403
       Coding: 0024854
       VCID: 2C5D2E598FC3372F1D-8078
       Revision: 00001K02
       Coding: 0600004A02
    9473393 - Motor for Right Temperature Flap
              B108D 71 [008] - Actuator stuck
                        Reset counter: 55
                        Mileage: 376455 km
                        Date: 2019.06.07
                        Time: 15:57:05
              U1111 00 [009] - -
                        Fault Frequency: 14
                        Reset counter: 15
                        Mileage: 376448 km
                        Date: 2019.06.07
                        Time: 14:32:46
       Revision: 00H54000    Serial number: 01000008249495
       Coding: F5888F3510041A1147000F000F00000080195D436400010C000000000000
       VCID: 71E3FF2D68611AC76E-8024
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 070308 003  0205
       Coding: 00049077
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     150408 046  0204
       Coding: 00995365
       Shop #: WSC 12345
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 56D 919 475 A    HW: 56D 919 475
       Component: PARKHILFE 8K  H02 0006
       Revision: --------    Serial number: 35821333801492
       Coding: 318101
       ASAM Dataset: EV_EPHVA18VW4110000 001007
       ROD: EV_EPHVA18VW4110000.rod
       VCID: 336F35259AFD68D75C-8066
    Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
       Part No SW: 3C0 907 567 M    HW: 3AA 907 567
       Component: AC201  RDW A    036 0243
       Revision: 00036000    Serial number: 00000000507894
       Coding: 0010000
       VCID: 356B0B3D5C8976E772-8060
       Revision: 00000000    Serial number: 24011201770002
       Coding: 030180
       VCID: 2757D17556251477F0-8072
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__005 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DP7DDMR3
       Coding: 0012341
       Shop #: WSC 05311 000 00000
       VCID: 3B7F1D057AADA09784-806E
       Subsystem 1 - Serial number: 6333FTS679040708
       Subsystem 2 - Serial number: 6343FTS643870708
       Subsystem 3 - Serial number: 6353ETS6T8U1TVNP
       Subsystem 4 - Serial number: 6363ETS6VSJ1TVNP
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AH    HW: 3C0 953 549 AH
       Component: J0527               0030
       Revision: 00035000    Serial number: 3C0953507
       Coding: 0201822
       VCID: 72E1F0216D6721DF97-8026
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000131
       Part No SW: 3C8 920 880 T    HW: 3C8 920 880 T
       Component: KOMBI         H04 1008
       Coding: 160D000000
       VCID: 3D7B131DACB9AEA7BA-8068
       Coding: 462006
                        Reset counter: 15
                        Mileage: 376451 km
                        Date: 2019.06.07
                        Time: 15:32:33
       Part No SW: 3AA 959 433 F    HW: 3AA 959 433 E
       Component:    IMMO         042 0429
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 43138 001 1048576
       VCID: 3C7D1E197FA3A7AF8D-8068
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760     HW: 3C8 959 760
       Component: J810                0801
       Revision: 00002000    Serial number: 00000000000000
       Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
       Component: TUER-SG FT    002 0321
       Revision: 12101005    Serial number: 0000886354
       Coding: 0011F7
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0307
       Serial number: 00000000331050
       Coding: 0000D0
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.135 H08 1901
       Component:    KSG PQ47 ELV 042 0714
       Coding: 1891020051034E7F00021C1F7008CFCE707801
       Part No SW: 3C0 035 456 J    HW: 3C0 035 456 J
       Component: DSP 10 Kanal
       Revision: 00H05001    Serial number: 75815000315901
       VCID: 2757D17596251477F0-8072
       Component: EZE_2         H41 1663
       Coding: 00000009
       VCID: 6FE7F955BE550C3778-803A
       Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0004
       Component: TUER-SG BT    002 0533
       Revision: 14110009    Serial number: 0006086936
       Coding: 0011F6
       VCID: 36690C31898F7DFF7B-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0307
       Serial number: 00000000340928
       Coding: 0000D0
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   008       Serial number: 00000000055708
       Coding: 0000057
       Shop #: WSC 12346 987 64321
       VCID: 2855D2499B3B1B0FF9-807C
              U1111 00 [009] - -
                        Reset counter: 15
                        Mileage: 376448 km
                        Date: 2019.06.07
                        Time: 14:32:48
       Part No SW: 1K0 907 383 D    HW: 1K0 907 383 B
       Component: Anhaenger     H16 0070
       Revision: 3A002001    Serial number: 00000110888610
       Coding: 0100000200000000
       Shop #: WSC 05314 000 00000
       VCID: 2E59245179DF453F33-807A
    End-------------------------(Elapsed Time: 03:30)--------------------------
  11. #9
    Mar 2015
    Australia
    This is the climatronics fault with ext UDS:
    Part No SW: 3AD 907 044 G HW: 3AD 907 044 G
    Component: Climatronic H03 0404
    Coding: 0039050004
    Shop #: WSC 12345 123 61029
    VCID: 372BD5178FC3E79F63E-8062
    U1111 00 [009] - -
    [Steuergerät für Bordnetz - kein Signal/Kommunikation]
    It can't communicate with the BCM because I don't have one. I still have CECM Bordnetz, same as you.
    So it might be possible that this is related, although it doesn't cause issues with the version of climatronics panel that I have (a different part number to yours).
  12. Likes downtime, dieseltje liked this post
  13. #10
    Jan 2019
    The Netherlands
    My Issue is not that I have this fault, but I suspect that this fault is part of the missing message of dimming signal screen DM and visibility of the figures on the climatronics during (sunny) daytime.
    It looks like the dimming signal is inverse, more light, less visibility on screen and climatronic.
    Are here guys, who can pick up this signal to do some reverse engineering and make the dimming signal suitable for this setup?
