09G Transmission Adaption Problem
jdreid
California, USA
C?ID=349997
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRZ71K99M0xxxxx   Mileage: 200150km-124367miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 M    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9203
   Revision: G6H02---    Serial number: VWX7Z0HN2431AD
   Coding: 0000075
   VCID: 38292B354E583907321-806C
Readiness: 0000 0100
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000072
   VCID: 7DA7FA2121FADC2FA17-8028
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Revision: 00H45001
   Coding: 113B400D492A0000880E02E6921E00413000
   Shop #: WSC 36555 002 104857
   VCID: 7EA5FD2D20FCC737B8D-802A
                    Fault Status: 00100011
                    Reset counter: 100
                    Mileage: 200084 km
                    Count: 12800
                    Count: 83
                    Count: 50184
                    Reset counter: 100
                    Mileage: 200084 km
                    Count: 12800
                    Count: 67
                    Count: 50184
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EB350ED8F907F21-802C
   Revision: 00H54000    Serial number: 00000001126957
   Coding: 14058E234004100007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 123 12345
   VCID: 323D191DA824D3570C5-8066
   Component: Wischer 111108 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Reset counter: 103
                    Mileage: 200087 km
                    Voltage: 10.50 V
   Revision: 00000000    Serial number: AUZ4Z7H0474413
   Coding: 0000100
   VCID: 33331C19573EDA5F073-8066
                    Fault Frequency: 9
                    Reset counter: 57
                    Mileage: 200012 km
                    Time: 23:05:21
   Revision: 05034000    Serial number: 003B6M07MLDJ
   Coding: 0013889
   VCID: 6C81C7654A8045A7069-8038
   Subsystem 2 - Serial number: 6332MSME41145001U
   Subsystem 3 - Serial number: 6342MSME3F645540E
   Subsystem 4 - Serial number: 6351HSME184928504
   Subsystem 5 - Serial number: 6361HSME184970478
   Subsystem 6 - Serial number: 63727SME19085068/
   Subsystem 7 - Serial number: 63827SME19084108Z
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010021
   VCID: 03538CD9471EAADFD73-8056
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0HN2431AD
   Coding: 0023203
   VCID: 3C2137257A601527D69-8068
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 220908F2000138
   Coding: ED807F070003021002
   Shop #: WSC 11111 123 12345
   VCID: 35372201594AC46F297-8060
   Component: IMMO            3HL 1222
   Revision: 72009005    Serial number: 00000766589028
   Coding: 0001205
   VCID: 6FBBD0697B96BEBF23B-803A
                    Fault Status: 01111000
                    Reset counter: 64
                    Mileage: 190135 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 64
                    Mileage: 190135 km
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A0D017D80F49B97B45-807E
                    Fault Status: 00101101
                    Reset counter: 110
                    Mileage: 200084 km
                    Time: 17:17:05
                    Voltage: 14.00 V
                        DU
                    Temperature: 35.0°C
                    RPM: 688 /min
                    Speed: 9.0 km/h
                    Speed: 9.0 km/h
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 04518FC54210ADE7EE9-8050
   Revision: 72009005    Serial number: 08100814090904
   Coding: 0001204
   VCID: 70B9D31566A8A1473A1-8024
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2R7301947
   Coding: 1600040004000A
   Shop #: WSC 00081 790 00120
   VCID: 46D555CD38AC5FF7B0D-8012
7 Faults Found:
00856 - Radio Antenna
                    Fault Status: 00100111
                    Reset counter: 57
                    Mileage: 191377 km
                    Time: 07:30:31
00532 - Supply Voltage B+
                    Reset counter: 45
                    Mileage: 15 km
                    Date: 2003.14.26
                    Time: 05:20:26
                    Reset counter: 45
                    Mileage: 14 km
                    Date: 2003.14.26
                    Time: 08:20:45
                    Fault Status: 00101011
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
   Revision: 12006001    Serial number: 00000003626568
   Coding: 0001168
   VCID: 76B5E50D04CC8F77E0D-8022
   Coding: 0100100
                    Reset counter: 3
                    Mileage: 199154 km
                    Time: 14:14:37
00625 - Vehicle Speed Signal
                    Reset counter: 102
                    Mileage: 200087 km
                    Time: 11:22:28
   Revision: 12006001    Serial number: 00000003588487
   Coding: 0001168
   VCID: 77ABE80903C6F67FFBB-8022
So I swapped transmission solenoids for my 2009 VW Jetta 2.5L, and followed the relearn procedure to re-adapt my transmission. Everything was working fine until I tried to Reset everything to Factory Default Settings, which in result caused my transmission to flare in the 3-4 gear transition. Does anyone know the proper way to re-adapt a 09G Transmission that flares?
Also, I'm using the default soft coding for the transmission again which is now 0000840.
Please explain exactly what you did when you "tried to Reset everything to Factory Default Settings".
jdreid
California, USA
C?ID=349997
So what I did is go under the Engine 01 Tab in VCDS and selected Adaptation. And performed a Default Reset which told me in order to perform it was to save channel "000".
jdreid
California, USA
C?ID=349997
jdreid
California, USA
C?ID=349997
Trans adaptation isn't done in engine ecu 0x01-10-000 nein!
0x01-04-060 & 063 for TV + kickdown
In TCU....
It is done in basic settings 0x02-04-001 & 002 for ADP + kickdown
Trans is 0x02
See wiki
http://wiki.ross-tech.com/wiki/index.php/6-Speed_Automatic_Transmission_(09G)
Time to JPPSG and RTFB!
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Yeah I've done it in the Trans - 02 section, but how do you know if it really did anything? If anything really got re-adapted? I've done it that way a couple of times with no DTC codes present, and successfully taken the vehicle for a test drive and still no resolution. The 3-4 shift flare just remains.
Maybe that isn't your issue and you are missing a mechanical tolerance or fluid level inaccuracy?
09G Is typically a real steamer, no?
jdreid
California, USA
C?ID=349997
Yeah but before I did the Reset Procedure in the Engine - 01 Category my shifts adapted after driving awhile. I just don't know why its taking longer to adapt this time. The 09G Transmission is very complicated to understand.
Not really complicated at all, it's just a POS as history of VAG automatics live up to in general, no?
SSP Steamer DOG PILE 291 for your pleasure?
http://www.volkspage.net/technik/ssp/ssp/SSP_291_d1.pdf
Golftwincharged
Guyana
C?ID=320847
try hard resetting tcm with pulling fuse, and do the process over again with vcds, test drive for a few more times and repeat, until it gets better and better, 09G requires patience and many tries, make sure the fluid level is correct, adapt the trans with correct driving steps, and maybe you can fix your abs sensors in the mean time all may inter-relate with average speed readings, just a suggestion.
jdreid
California, USA
C?ID=349997
You know the whole time I was driving my car with its stock solenoids (OEM), I didn't even have a 15Amp fuse powering the TCM. It wasn't until I replaced my solenoids with the incorrect large canisters, to try to fix my shifting problem is when I put the TCM fuse in. And once I added that fuse my car relearned its adaptation shortly after driving it. But now since I took out the large canisters and replaced them with my small canisters (OEM) the car is taking longer to re-adapt the 3-4 gear flare.
And by the way, the ABS light was due to me having the car in gear while on jack stands. Also, what steps/procedure did you take into relearning your shift patterns for your 09G transmission?
My Steps
1st - Unplug 15Amp Fuse, when car is off and wait a min.
2nd - Plug fuse back in, and reset learned values under Auto Trans (2).
3rd - Take vehicle for a drive until shift flare fades out.
But the shifting flares never seemed to go away yet. Any suggestions?
Golftwincharged
Guyana
C?ID=320847
driving 20% throttle until all gears are selected , then coast until gears downshift and comes to a complete stop within 30 seconds, try this like 10 million times, and increase throttle over period of time, if you still having shift problems ;
k2 solenoid , VB pressure related, try adjusting the k2 solenoid, k2 may need to increase pressure by turning counter clock-wise,
jdreid
California, USA
C?ID=349997
Thanks for your help! After carefully adjusting the K2 Solenoid Pressure Valve a full turn and a half (1.5 turn), I can now say the flare is completely gone. I'm still going to drive it around more to get the 3-4 gear transition to a completely smooth transition.
