Results 1 to 6 of 6
Thread: 2006 D3 S8 V10 Lean Codes please help
    Jul 2017
    Scarborough, UK
    Hello folks,
    I have been trying to resolve a rough idling and misfire issue with my S8 for AGES.
    After much figuring out the following jobs are completed and Fault codes present. any guidance would be greatly appreciated.
    Completed previously (engine related): two years ago: all filters, coil packs and platinum plugs, both MAF sensors, vacuum lines, Secondary Air valves and blower.
    Completed recently: fuel filter, carbon clean with all new gaskets, inlet manifold still ok - not touched, all fuel injectors serviced/replaced, new upstream lambda sensors Bank 2 and bank 4. Vacuum lines replaced, VCDS all green results on Readiness screen.
    Present engine fault codes:
    Bank 1; System too Lean at Idle P2187 - 004
    Bank 3; Mixture Regulation; Bank 3; Range 1 P1081 - 004 - Lean Limit Exceeded - MIL ON
    Bank 4; Mixture Regulation; Bank 4; Range 1 P1085 - 004 - Lean Limit Exceeded
    Comments: The MIL only comes ON after aggressive acceleration. long drives over a couple days has no Fault codes stored.
    The crankcase vacuum is tremendous - I cannot remove the Oil filler cap with the engine at Idle. Is this normal?
    I only apply Castrol Edge 5w 30 fully synthetic and replace this oil annually despite minimum mileage<4k / annum.
    Fuel is only 98 Octane (shell).
    Here is the recent VCDS Logfile:
    Sunday,21,July,2019,13:16:06:60735
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZ4E67N003566   License Plate: AD06 YMC
    Mileage: 218050km-135489mi   Repair Order: TOO LEAN
    Chassis Type: 4E (4L0)
    Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1D 1E 28 34 36 37
              38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
    VIN: WAUZZZ4E67N003566   Mileage: 218050km-135489miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    1D-Driver Ident. -- Status: OK 0000
    57-TV Tuner -- Status: Malfunction 0010
    77-Telephone -- Status: Not registered 0011
       Part No SW: 4E0 910 552     HW: 4E0 907 552
       Component: 5.2L V10/4V FSI    ª0060
       Revision: 5AH11---    Serial number: AUX3Z0F5397064
       Coding: 01060003190F0160
       Shop #: WSC 54321 123 12345
       VCID: 5F98AA22BB334F0F93F-800A
    008583 - Bank 1; System too Lean at Idle
                   P2187 - 004 -
                        Mileage: 218042 km
                        Date: 2019.07.21
                        Time: 11:18:04
                        RPM: 669 /min
                        Load: 21.6 %
                        Temperature: 102.0°C
                        Temperature: 33.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.351 V
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                        Mileage: 218059 km
                        Temperature: 107.0°C
                        Temperature: 50.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 12.065 V
    Readiness: 0000 1001
       Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
       Component: AG6 09E 5,2 FSI RdW 0020
       Revision: --H01---    Serial number:        0087677
       Shop #: WSC 02313 785 00200
       VCID: 2B000EF2BF0BE3AF4F7-807E
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
       Component: ESP 5.7 allrad  H46 0500
       Coding: 0001627
       Shop #: WSC 02313 000 00000
       VCID: 2412E5CED2D52CD78ED-8070
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 K
       Component:     FBS AUDID3  H10 0190
       Revision: 01904910    Serial number: AUX3Z0F5397064
       Coding: 0412672
       Shop #: WSC 02311 785 00200
       VCID: 58EA813EDE1DB837D25-800C
       Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
       Component: Sitzmemory BFS H02  0010
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 4063328
    Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
       Part No SW: 4E0 910 731 G    HW: 4E0 035 729 A
       Component: Interfacebox    H43 2830
       Revision: 00000000    Serial number: 300FZ067568958
       Shop #: WSC 00000 000 08192
       VCID: 2514F8CAD9EFD5DF993-8070
       Subsystem 1 - Part No: 4E0 910 611
       Component: E0380 BedienteilH03 0040
       Subsystem 2 - Serial number: 00000000013248
       Subsystem 3 - Serial number: 0130.06.060000000100010002ÿ
       Subsystem 4 - Serial number: 010002ÿ
       Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
       Component: KLIMAAUTOMAT    017 0450
       Revision: 00000032    Serial number: 00000000100165
       Coding: 0123001
       VCID: 1C62DD2EEAA5141736D-8048
    6 Faults Found:
    00714 - Centre Right Vent Positioning Motor (V111)
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Reset counter: 230
                        Mileage: 218016 km
                        Date: 2019.07.20
                        Time: 19:22:06
                        Voltage: 11.90 V
                        Temperature: 25.0°C
                        (no units): 196.0
                        (no units): 195.0
                        Temperature: 52.0°C
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 229
                        Mileage: 218016 km
                        Date: 2019.07.20
                        Time: 19:22:08
                        Temperature: 45.0°C
    01858 - Air Outlet Sensor; Right Center (G348)
                        Reset counter: 229
                        Mileage: 218016 km
                        Date: 2019.07.20
                        Time: 19:22:08
    00065 - Rear Left Footwell Heater (Z42)
                        Reset counter: 229
                        Mileage: 218016 km
                        Date: 2019.07.20
                        Time: 19:22:09
                        Voltage: 11.90 V
    00066 - Rear Right Footwell Heater (Z43)
                        Reset counter: 229
                        Mileage: 218016 km
                        Date: 2019.07.20
                        Time: 19:22:09
                        Voltage: 11.90 V
    00565 - Rear A/C Control Head (Climatronic) (E265)
                013 - Check DTC Memory
                        Fault Status: 00000100
                        Reset counter: 232
                        Mileage: 202614 km
                        Date: 2017.02.07
                        Time: 00:04:19
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
       Component: ILM Fahrer      H15 0230
       Coding: 0133121
       VCID: 36362F867449AE47209-8062
       Subsystem 1 - Part No: 4E2 910 113 B
       Component: Wischer WWS D3  H50 0420
       Coding: 00000035
       Shop #: WSC 02313
       Coding: 04336190
       Shop #: WSC 02313
    Address 11: Engine II        Labels: Redir Fail!
       Shop #: WSC 00673 210 83197
    004225 - Mixture Regulation; Bank 3; Range 1
                        Fault Status: 11100100
                        Mileage: 218034 km
                        Date: 2019.07.21
                        Time: 10:30:47
                        RPM: 668 /min
                        Load: 14.1 %
                        Temperature: 99.0°C
                        Temperature: 30.0°C
                        Voltage: 14.351 V
    004229 - Mixture Regulation; Bank 4; Range 1
                        Mileage: 218046 km
                        Date: 2019.07.21
                        Time: 11:37:55
                        RPM: 642 /min
                        Load: 18.0 %
                        Temperature: 93.0°C
                        Temperature: 45.0°C
                        Voltage: 13.589 V
    Address 15: Airbags        Labels: 4E0-910-655-94.lbl
       Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
       Component:    Airbag 9.41  H13 3710
       Revision: 91H13371    Serial number: 0037P000LLTK
       Coding: 0431707
       VCID: 2708F2C2A3E3C7CFABF-8072
       Subsystem 1 - Serial number: 63328RB40149CA9BY
       Subsystem 2 - Serial number: 63428RB40149CA87U
       Subsystem 3 - Serial number: 63528RB40149CA45P
       Subsystem 4 - Serial number: 63628RB40149CB2BV
       Subsystem 5 - Serial number: 63729RB4015FE7D50
       Subsystem 6 - Serial number: 63829RB4015FE7BF9
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549
       Component: Lenksäulenmodul H14 0040
       Coding: 0112141
       VCID: 6594B8CA996F15DF593-8030
       Component: Lenkradmodul    H06 0030
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 951 E    HW: 4E0 920 951 E
       Component: KOMBIINSTR. VDO H82 0520
       Revision: D03         Serial number: AUDID3F5000060
       Coding: 0048813
       Shop #: WSC 00586 210 91538
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B0661581CD
       Coding: F5F5DFFF50661E
       Shop #: WSC 00751 210 93636
       VCID: 6C82CDEE7A85249706D-8038
                        Reset counter: 229
                        Mileage: 218016 km
                        Date: 2019.07.20
                        Time: 19:21:36
    Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
       Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
       Component: FPI_1           H01 0020
       Revision: 01000102    Serial number: 28062006210124
       VCID: 1F18EA22FBB30F0FD3F-804A
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7207631
       VCID: 1B60DE32EFAB132F3F7-804E
       Part No SW: 4E0 910 158     HW: 4E0 919 158 D
       Component: KLIMA-STG. FOND 017 0230
       Revision: 00000019    Serial number: 00000000042851
       Coding: 0000000
       VCID: 619CACDA8D4779FFA5B-8034
    01866 - Rear Right Air Outlet Motor Position Sensor (G350)
                007 - Short to Ground
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
       Component: LUFTFDR.-CDC    H06 6310
       Coding: 0015510
       Shop #: WSC 00409 210 01865
       VCID: 2A0E0BF6B0F1FAA7B41-807E
       Component: Sitzmemory FS  H02  0010
       Coding: 4063342
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
       Component: MNS ECE         H48 1060
       Revision: 00000000    Serial number: 364F 067572668
       VCID: 3B203EB24F6B732FDF7-806E
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H04 0090
       Serial number: 00000617100155
       Coding: 0232912
       VCID: 1D64D02AF1BF1D1FC13-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 802 B
       Component: Türsteuer.FS BRM003 0100
       Coding: 0032623
       VCID: 201AE9DEC6CD30F7EA5-8074
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
       Component: Komfortgeraet   H07 0010
       Revision: 00100007    Serial number:  W040606290218
       Coding: 0005885
       Component: Heckdeckel      H06 0060
       Component: Neigungssensor  H05 0020
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 P    HW: 4E0 035 223 F
       Component: DSP-High D3     H02 0070
       Revision: PROD_01     Serial number: 00000000002235
       Coding: 0000027
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
       Component: ILM Beifahrer   H11 0070
       Revision:             Serial number: 00000000000507
       Coding: 0010111
       VCID: 1E66D726FCB90607D89-804A
       Subsystem 1 - Part No: 4E0 910 511
       Component: UGDO HL ECE     H06 0050
       Subsystem 2 - Serial number: 0253439TJ8EZ06
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 801 B
       Component: Türsteuer.BF BRM003 0100
       Coding: 0032623
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
       Component: EPB  A32C0220   H02 0220
       Revision: A32C0220
       Coding: 0000731
       Shop #: WSC 31414 210 01865
       Coding: 0000018
       VCID: 290CF4FAB5F7F1BFBDB-807C
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
       Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
       Component: TUNER EU/US/RDW H42 0570
       Revision: 00000000    Serial number: 396FM067541201
    Address 57: TV Tuner        Labels: None
       Part No SW: 4E0 910 148 A    HW: 4E0 919 148
       Component: R0078 TVhybridTuner 0280
       Revision: R0H05000    Serial number: 76300700388801
       Coding: 0000003
       VCID: 211CECDACDC739FFE5B-8074
    02283 - Video Connection to Output [End Unit]
                        Fault Status: 00101010
                        Fault Frequency: 20
                        Reset counter: 14
                        Mileage: 217812 km
                        Date: 2019.07.13
                        Time: 17:04:41
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0550
       Revision: 00000000    Serial number: 00000000011975
       Shop #: WSC 00235 210 81345
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  31070881DK
       Coding: 34453039313531303541205641303331303730383831444B
       Shop #: WSC 00586 210 83216
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
       Component: Türsteuer.HL BRM003 0100
       Coding: 0032623
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
       Component: Reifendruck 3   H05
       Revision: 00050340    Serial number: 00000900046144
       Coding: 0212329
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000606230355
       Shop #: WSC 12336 024 394758
    Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
       Part No SW: 4E0 910 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J6610DB
       Coding: 1021302
       VCID: 5CE29D2EAA255417F6D-8008
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
       Component: Türsteuer.HR BRM005 0180
       Coding: 0032623
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
       Component: Parkhilfe 8-Kan H12 0040
       Revision: 00H12000    Serial number: 08720617900335
       Coding: 0321008
       VCID: 2310E6D2D7DB2BEFF77-8076
       Part No SW: 4E0 910 336 H    HW: 4E0 862 335
       Component: Handyvorb2      H00 0700
       Coding: 0000000
    00532 - Supply Voltage B+
                        Reset counter: 164
                        Mileage: 126176 km
                        Date: 2009.11.30
                        Time: 16:24:33
                        Reset counter: 164
                        Mileage: 126176 km
                        Date: 2009.11.30
                        Time: 16:24:33
                        Reset counter: 11
                        Mileage: 101820 km
                        Date: 2009.04.30
                        Time: 16:04:29
    End----------(Elapsed Time: 02:23, VBatt start/end: 12.3V/12.3V)-----------
    Address 01: DTCs cleared
    Control Module Part Number: 4E0 910 552     HW: 4E0 907 552
      Component and/or Version: 5.2L V10/4V FSI    ª0060
               Software Coding: 01060003190F0160
                Work Shop Code: WSC 00673 210 83197
                        Mileage: 218034 km
                        Date: 2019.07.21
                        Time: 10:30:47
                        RPM: 668 /min
                        Load: 14.1 %
                        Temperature: 99.0°C
                        Temperature: 30.0°C
                        Voltage: 14.351 V
                        Mileage: 218046 km
                        Date: 2019.07.21
                        Time: 11:37:55
                        RPM: 642 /min
                        Load: 18.0 %
                        Temperature: 93.0°C
                        Temperature: 45.0°C
                        Voltage: 13.589 V
    Address 11: DTCs cleared
    Jul 2014
    Yorkshire
    no.................
  3. Likes Jack@European_Parts, Uwe, PetrolDave liked this post
    Nope........... recheck your work and correct PCV!
    ALL BANKS System too Lean at Idle or Idle offset
    Possible Causes
    • Injectors leak/blocked
    • Air Intake Multiplicative leak for any possible leak after MAF or TV
    • Exhaust Leak
    • Fuel filter blocked or Lift/Transfer pump faulty to HPP
    • HPP damaged or mechanical clearance ware issue
    • Inadequately operating or blocked PCV
    • OXS sensor or circuits for ECU faulty from FOD damage
    Possible Solutions
    • Check Mass Air Flow Sensor (G70)
    • Check Injector(s)
    • Check ALL Fuel Pumps
    • Check Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    • Check for PCV function
    • Correct all FOD!
    Jul 2017
    Scarborough, UK
    Thanks, so the high vacuum is not normal.
    I have also noticed the PCV is buzzing wildly at idle.
    I’ll remove and replace with a new PCV unit AGAIN...
    Thanks loads
    Ps. What is FOD?
    Thanks loads
    Jul 2017
    Scarborough, UK
    Hi, today a fitted another new PCV oil separator and also vacuum tested the fuel tank breather solenoid valve N80 (tested ok). Started the engine and I am now able to remove the oil filler cap with engine idling (well I couldn’t before). So it just goes to prove that cheaper parts on EBay £32 compared to the better £80 Bosch part makes one hell of a difference in quality and function.
    Next step - check VCDS for Lean operation after completing my recovery from retinal detachment surgery, hopefully early next week.
    Thanks again folks!
    Cheers,
  8. Likes Uwe, Jack@European_Parts, PetrolDave liked this post
