Results 1 to 6 of 6
Thread: Transmission won't adapt 255 error
    Feb 2018
    Egypt
    Hello guys,
    In order to find out why my gearbox is horrible I ran the basic settings for the transmission (Using the HEX-V2) - stuck on 255/192 https://ibb.co/SwM02jr"
    no idea what it means but i guess it's something wrong with the mechatronic unit and of course because there's no fault codes the dealer claim that everything I experience is normal for this drivetrain guess i'm stuck with this lemon forever...
    Any idea why the transmission won't adapt?
    here's the AutoScan :
    Sunday,21,July,2019,17:50:30:52234
    VIN: WVWZZZ6RZFY279292   License Plate:
    Mileage: 43383km-26956mi   Repair Order:
    Chassis Type: 6R-VW26 (6C0)
    Scan: 01 02 03 08 09 15 17 19 44 5F
    VIN: WVWZZZ6RZFY279292   Mileage: 43383km-26956miles
    Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
       Component: R4 1.2l TFS   H21 9314
       Revision: R4H21---
       Coding: 01250012230411080000
       Shop #: WSC 10690 730 00000
       ASAM Dataset: EV_ECM12TFS01104E906027BB 001010
       ROD: EV_ECM12TFS01104E906027BB.rod
       VCID: 6597B1D1E5ED068F59F-8030
       CAN Converter 01:
       Part No SW: 0CW 300 048 S    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 6560
       Revision: 00043014    Serial number: CU501502095372
       Shop #: WSC 00788 648 00255
       ROD: EV_TCMDQ200021_VW26.rod
       VCID: 4CC164756647D7C7661-8018
       Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0003
       Serial number: 08506601150219
       Coding: 21DD2885892A33C9111610720053841491CC88080005CB098F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
       VCID: 33331F891BB9A83F07B-8066
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
       Component: AC Manuell    H03 0108
       Serial number:  1502131B-0320
       Coding: 200000011000100000
       ROD: EV_ACManueKMMValeoPQ26.rod
       VCID: 1D67D9318D3D0E4FC1F-8048
    1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
              B10F0 00 [008] - -
                        Reset counter: 88
                        Mileage: 43054 km
                        Date: 2019.07.06
                        Time: 20:15:18
                        Voltage terminal 30: 14.3 V
                        Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 B    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H07 0065
       Serial number: 001098078832
       Coding: 000018404253007B4B844000400703881000580251010000000000000000
       ASAM Dataset: EV_BCMA0 004008
       ROD: EV_MQBA0.rod
       VCID: 2F3B13F9F7918CDF633-807A
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  003 8612
       Serial number: KU0KU003021550345083
       Coding: 0400A0
       Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  003 8612
       Serial number: KU0KU026011550268194
       Coding: 1400A0
       Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
       Component: J388__TSG_HL  003 8611
       Serial number: KU0KU006021550374267
       Coding: 0400A0
       Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
       Component: J389__TSG_HR  003 8611
       Serial number: KU0KU005021550363798
       Coding: 1400A0
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
       Component: VW20Airbag01B 001 0330
       Revision: --------    Serial number: 003LM0095C5Y
       Coding: 88C0C000000000005C0000CA000800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 313F1581E1A59A2F757-8064
       Subsystem 1 - Part No SW: -----------    HW: 410 820 202 15
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00A518F2600529E
       Subsystem 2 - Part No SW: -----------    HW: 410 820 202 15
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00A519B7D32D37-
       Subsystem 3 - Part No SW: -----------    HW: 442 151 202 15
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00B718F262641BE
       Subsystem 4 - Part No SW: -----------    HW: 442 151 202 15
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00B718F2624926E
       Part No SW: 6C0 920 740 A    HW: 6C0 920 740 A
       Component: KOMBI         211 0290
       Coding: 0704090821800808000000001000000000000000
       VCID: 2019E0C5BA4F23A7EA9-8074
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H07 0065
       Revision: --------    Serial number: 001098078832
       Coding: 03010004370A560070000000000000010001010000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: EV_GatewA0Lear_001_VW26.rod
       Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
       Serial number: 0491504303300520AB1B
       Coding: 240000
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 62052J12292821572744
       Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  312 3211
       Serial number: PF330640
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 323D1A8DE4A3A1370CD-8066
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
       Component: MU-E--ER      820 6230
       Serial number: 20111400010772
       Coding: 02620000BE00000041110001000130001F0000840000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001017
       ROD: EV_MUEnt4CGen2LGE_VW26.rod
       VCID: 2A0D02EDCC73E9F7B4D-807E
    End----------(Elapsed Time: 00:42, VBatt start/end: 12.1V/12.0V)-----------
    Similar stories for like kind alliances in tech?
    https://www.autoblog.com/2019/07/11/...er-production/
    Component: GSG DQ200-MQB H43 6560 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< This firmware level?
    Have you checked TSB's because isn't there a firmware update for this trans?
    Feb 2018
    Egypt
    I'll ask the dealer if there's any firmware updates available but it won't solve the
    Adapting issues - something is faulty
    Well isn't that the point, if a controller needed a firmware update, than that would imply the mechanics of the component controlled were less than accurately controlled & could of most likely damaged it, right?
    Feb 2018
    Egypt
    Sure I agree but at the dealer, they don't get this logic. no ECU fault = CAR IS FINE.
    I'm actually tired of booking my car for their "investigations" but I got no choice.
    Thank you mate I'll report back
    Jun 2016
    Guyana
    what do you refer to as horrible? what are the symptoms you're having? update to 6561 firmware , not necessary the mech unit has an issue, the clutch and engagement bearings can also relate to unsuccessful basic settings , this 0CW is the updated version of the 0AM, plenty of dry clutch related issues..
  7. Likes Uwe liked this post
