Results 1 to 7 of 7
Thread: Jetta 16/AJ : Power folding mirrors / Mirror dip reverse
    Jul 2019
    Morocco
    I own an imported US Jetta. (ODIS : DELA 2.0 tdi SCR / 110 kw - ELSA : 2.0 HL 110 TDIM6F 163x42 DELA PFN - VCDS : AJ163). I got the premium trim (the higheat here on the ones that came with hallogen headlights), not to be confused with the US market premium though (for instance, I don't have MFD on my instruments cluster).
    I've done a lot of sucssesfull tweaks using VCDS. (That I will share on the forums once I make sure no one posted them already, to avoid redundance)
    Now, on my Jetta, I have OEM electrical mirrors, they are heated too. But not power foldable (on my door knob i only have 4 switch positions : 0, R, L, Heating, no power folding).
    I wanted to do some tweaks like the mirror dip while reversing, almost all tutorials point to door electronics adresses, which, as you'll notice on my auto-save, are not present. Does it mean I don't have door modules even though I have heated electric mirrors (and yes I don't have seats memory).
    I want to install power folding mirrors, so what will be the way to go :
    1- Just VCDS ? I'll post whatever may "help you help me" on the matter, am I missing something ? (Can Gateaway installation list ? Some slave sub module ? Anything)
    2- VCDS and modules and knobs and whatnot combined installations and coding. If that is the way to go, then what exactly do I need to buy and install, references ?
    3- Aftermarket stuff, like motors on the already present OEM mirrors. Is that even an option (I mean, there is a bunch of "questionable universal kits" ?
    English is not my first language, apologies for mistakes made.
    PS : This is my first car, my first post, and the first time I used VCDS. The telematics fault code is just the 3 buttons dialer and will be dealt with, just disregard it.
    Monday,15,July,2019,02:49:17:44035
    VIN: 3VW3A7AJ6GM******   License Plate: *******
    Mileage: 3340km-2075mi   Repair Order:
    Chassis Type: AJ-VW36 (7E0)
    Scan: 01 03 04 05 08 09 15 17 19 25 2B 44 47 5F 75
    VIN: 3VW3A7AJ6GM******   Mileage: 3340km-2075miles
    Address 01: Engine (J623-DELA)       Labels: None
       Part No SW: 04L 906 016 MC    HW: 04L 907 309 K
       Component: R4 2.0l TDI   H20 4450
       Revision: 8AH20---
       Coding: 01190012042410095000
       Shop #: WSC 20200 993 00000
       ASAM Dataset: EV_ECM20TDI01104L906016MC 004002
       ROD: EV_ECM20TDI01104L906016MC.rod
       VCID: 76B5E6E9E84DFD87E05-8022
       Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
       Component: ESP MK60EC1   H46 0174
       Revision: 00H46001
       Coding: A14B400C492300FC850F02E7921C004221100012
       Shop #: WSC 00066 000 00000
       VCID: 74B1DCE1FEB1EF97DE1-8020
       Revision: 00092000    Serial number: 0368374703
       Coding: 030C0C
       Shop #: WSC 00066 000 00018
       VCID: 372B2BEDAFC7448F3B3-8062
       Part No SW: 1K8 907 044 Q    HW: 1K8 907 044 Q
       Component: Climatronic   H05 0304
       Revision: 00001K03
       Coding: 0050019002
       Shop #: WSC 00066 000 00318
       VCID: 3D2739C58DFB6EDFE1F-8068
       Part No SW: 7E0 937 189     HW: 7E0 937 189
       Component: BCM PQ25 MMI3 H80 0733
       Revision: BA080001    Serial number: 18003183150699
       Coding: 7B994B3B08AB0B000939268024C886C52D86700E60842170B0A0500B2844
       Shop #: WSC 18930 003 1048576
       VCID: 71BFD5F581A3DABF357-8024
       Component: RLS 270515 05  54  0403
       Coding: 02300A
       Subsystem 2 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  006 5461
       Serial number: 14102585150618081238
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  006 5461
       Serial number: 14102584150612144508
       Coding: 820000
       Subsystem 4 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
       Component: J245 PS41.402  H03 0004
       Serial number: 0000FST0009097P00000
       Coding: 180000
       Subsystem 5 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
       Component: E221__MFL-TAT  H04 0019
       Serial number: 1701510224300841AD1B
       Coding: 280000
       Subsystem 6 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Component: J388__TSG_HL  006 5460
       Serial number: 14102587150620190552
       Coding: 800000
       Subsystem 7 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Component: J389__TSG_HR  006 5460
       Serial number: 14102586150619145341
       Coding: 800000
    Address 15: Airbags (J234)       Labels:* 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    001 0207
       Serial number: 003RXM0077R/
       Coding: 8CCCF000000000005000001AC20800000065
       Shop #: WSC 55286 001 1048576
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411_VW32.rod
       VCID: 6393AFBD4BDF782FB7B-8036
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH00000000000328SCD
       Coding: 303146
       Subsystem 2 - Part No SW: -----------    HW: 480 000 505 15
       Serial number: 357000000008F255241E
       Subsystem 3 - Part No SW: -----------    HW: 480 000 505 15
       Serial number: 35800000000CB155241E
       Subsystem 4 - Part No SW: -----------    HW: 480 021 305 15
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001C519BDF22B44D
       Subsystem 5 - Part No SW: -----------    HW: 480 021 305 15
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001BB19BDF2553FQ
       Subsystem 6 - Part No SW: -----------    HW: 480 020 605 15
       Component: FrontSensor_D  000 0189
       Serial number: 3550001AD19BDF23730F
       Subsystem 7 - Part No SW: -----------    HW: 480 020 605 15
       Component: FrontSensor_P  000 0189
       Serial number: 3560001AD19BDF21B2BS
       Part No SW: 5C6 920 955     HW: 5C6 920 955
       Component: KOMBI         H04 1007
       Coding: 170A010000
       Shop #: WSC 36656 002 1048576
       VCID: 6C81C481A6013757061-8038
       Part No SW: 7E0 909 901     HW: 7E0 937 189
       Component: GW-K-CAN TP20 H80 0733
       Revision: BA080001
       Coding: 102203
       VCID: 6889B891B2791B77629-803C
       Component: IMMO          H04 1007
       Coding: 000007
       Shop #: WSC 00066 790 00318
       VCID: 6A8DC299ACF5296774D-803E
       Revision: 00000000    Serial number: 15000125678002
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 303910F14AA993B77A9-8064
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 392F2DD5955352FFCD7-806C
       Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
       Component: KonzernAmp10K H08 6831
       Revision: --------    Serial number: EAA098C0058171
       VCID: 2809F8917279DB77A29-807C
       Part No SW: 5C0 035 684     HW: 5C0 035 684
       Component: MU-S-NS-US    H21 0241
       Serial number: VWZAZ2R0260771
       Coding: 02630102AA00000051110003001808001F0100D400200105C6
       Shop #: WSC 62743 001 1048576
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 629DAAB954C57127BCD-8036
       Subsystem 1 - Part No SW: 5NA 919 866 N    HW: -----------
       Component: MRM3 2019/20  --- 1115
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0156
       Serial number: 000003554140539
       Coding: 02630102C24232007F1606000000
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_OCULow 002009
       ROD: EV_OCULow_002.rod
       VCID: 1471BC61DEF14F977E1-8040
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
              [roofline module open load]
                        Reset counter: 181
                        Mileage: 3255 km
                        Date: 2019.07.13
                        Time: 13:13:12
    End----------(Elapsed Time: 01:32, VBatt start/end: 14.2V/14.1V)-----------
  2. Likes Uwe liked this post
  3. #2
    Jul 2019
    Morocco
    Nothing ?
    VW Jetta 2016 U.S Imported (Country dependant Trim)
    2.0 HL 110Kw TDIM6F 163x42 DELA (16/AJ)
    Jul 2014
    Tallinn, Estonia
    From older threads asking about mirror dip on PQ25/26 platforms, it was deemed not doable because the feature isn't there on that platform. If your Jetta was the PR-AW1 model, it would use the PQ36 platform, which has front door controllers as dedicated modules, which do support mirror dip.
  5. Likes Uwe, MotorEldia liked this post
    Jul 2019
    Morocco
    Thank you for this major element of answer siLC.
    Can you indicate some of the said old threads on the matter ?
    As I said, mirror dip is just part of what I'm trying to achieve, power folding mirrors being the main upgrade I am looking for.
    I don't know about the platform or the modules, but when I enter Centr. Elec. module, it shows "BCM PQ25 MMI3...etc". So maybe I am on PQ25 afterall (maybe not I don't know). Let's suppose I am, can't those missing door modules (if they are missing, because as I said, I have electrically controlled heated mirrors) be installed on my doors so that I can install power folding mirrors afterwards ?
    Looking for insights from experienced members of the forum. Help.
    Jul 2019
    Morocco
    Edit : Some other module says "PQ35" on VCDS. will edit after and give you exact details once I can diagnose the car. Is there a certain way to know exactly what platform I am on ?
    Aug 2016
    The Hague, NL
    7E0 = PQ25. Sorry to say it won't work.
  9. Likes MotorEldia liked this post
  10. #7
    Jul 2019
    Morocco
    Thank you for your insight iichel. The component I was referring to showing as "ELV-PQ35 H21 0240" is the 2B-Steer. Col. Lock.
    Not sure what that mean but...meh ? A PQ25 platform with PQ35 components ? Or am I being wrong here ? And that's the only component I noticed a PQ35 mention on it. Maybe there are others (not necessarily PQ35, but not PQ25 specific items either, you never know with those dealers...).
    But anyway, you are saying power folding mirror on this "PQ25" is a no no. Is there a way to add hardware (salvaged or ordered) and wire things up and activate them via coding (I'm thinking door modules, wiring, a mirror knob with folding position and the power folding mirrors themselves) ?
