Results 1 to 10 of 13
Thread: Tiguan MK2 - Close Power Liftgate with Remote
    Jul 2019
    Hey,
    Wondering if anyone was able to figure out what to change to be able to close the power liftgate with the remote from more than 5 feet away.
    Im aware this a "safety feature" but they should have made it changeable, being able to open the liftgate from 30 ft away and only close it from 5ft is very annoying. Defeats the purpose of having it on the remote at all.
    2019 SEL 5 Passenger, no third row.
    Thanks,
    Tom
    Dec 2016
    Amsterdam
    Admaps of 05, 09 and the tailgate control unit?
    Current:
  3. Likes calvotj liked this post
    Jul 2019
    Ill take a look at 05 and 09. I checked the tailgate unit, didn't see anything in there really. Thanks for the tip.
    Dec 2016
    DE
    An adpmap of 09 would be really helpful.
    Jul 2019
    Just exported maps.
    Here is 05
    ;SW:3Q0-959-435-L   HW:3Q0-959-435-L ---  Acc/Start Auth.
    ;Component:VWKESSYMQB    037 1204, Coding:132C0C0723
    ;EV_KessyHellaMQBAB,004046,EV_KessyHellaMQBAB_004_VW37.rod
    ;Sunday,21,July,2019,11:39:34:31057
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: C3C6DF4E4AEC095744-8096
    IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
    IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
    IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
    IDE03251-Stop release for start-stop function,According to function requirements ,1
    IDE04159-Deactivation of start-stop function,not active ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE10844-Control module rear lid opening: duration status query,4960 ms,1
    IDE10845-Control module rear lid opening: vehicle type,FE ,1
    ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
    ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
    ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
    ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
    ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
    ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,activated ,1
    ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
    ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
    ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
    ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
    ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
    ENG126956-ENG126976-Byte9_VIP-active_vip,not activated ,1
    ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
    ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
    ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
    ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
    ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
    ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
    ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
    ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
    ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
    ENG105462-CAN-timeout service-key message,260 ms,1
    ENG105634-Correction value LED dimming,1.0 ,1
    ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
    ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
    ENG126961-deactivation_time_vip_slidingdoor,15 s,1
    ENG126960-Debounce_time_detection,500 ms,2
    ENG126959-Debounce_time_driver_presence,200 ms,1
    ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
    ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
    ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
    ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
    ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
    ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
    ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
    ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
    ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
    ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
    ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
    ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
    ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
    ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
    ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
    ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
    ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
    ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
    ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
    ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
    ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
    ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
    ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
    ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
    ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
    ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
    ENG105825-Diagnostic: wait time after power on,500 ms,1
    ENG126943-Display_duration_emergency_off,3000 ms,1
    ENG126944-Display_duration_error_mode_2_SPN,10 s,1
    ENG126941-Display_duration_please_engage_P,10 s,1
    ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
    ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
    ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
    ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
    ENG126950-duration_ZAT_debounce,50 ms,1
    ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,10 %,9
    ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
    ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,7.00 s,9
    ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,20 ,9
    ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,50 %,9
    ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,400 ms,9
    ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
    ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,04 ,5
    ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,02 ,5
    ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,220 mV/m,5
    ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,40 mV/m,5
    ENG126966-environment_scan_cyclic_step1,700 ms,1
    ENG126967-environment_scan_cyclic_step2,2000 ms,1
    ENG126965-environment_scan_duration_step1,300 min,1
    ENG126971-environment_scan_duration_step2,24 H,1
    ENG126969-environment_scan_level_bem,2 ,1
    ENG126968-environment_scan_responselevel_reduction,500 ,1
    ENG126970-environment_scan_startdelay_time,5 s,1
    ENG126958-Ignition_For_Immobilizer,Default ,1
    ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
    ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
    ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
    ENG107052-Interior scan: opening threshold sliding roof,1 %,1
    ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
    ENG107054-Interior scan: Speed - threshold,20 km/h,1
    ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
    ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
    ENG98656-internal,0 B,1
    ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
    ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
    ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
    ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
    ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
    ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
    ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
    ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
    ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
    ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
    ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
    ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
    ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
    ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
    ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
    ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
    ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
    ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
    ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
    ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
    ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
    ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
    ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
    ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
    ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
    ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
    ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
    ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
    ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
    ENG107592-MCTX Pause,1 B,1
    ENG107593-MCTX pause for Go / Key Minder,20 ms,1
    ENG107594-MCTX pause for Go authentification,14 B,1
    ENG107595-MCTX settling phase,10 B,1
    ENG129013-min_receptiontime_vit,0 ms,1
    ENG126945-min_time_for_Terminal_50_request,200 ms,1
    ENG244880-Minimum_holdtime_ak,500 ms,1
    ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
    ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
    ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
    ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
    ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
    ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
    ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
    ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
    ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
    ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
    ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
    ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
    ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
    ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
    ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
    ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
    ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
    ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
    ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
    ENG108309-Proximity Sensor: max. signal-length,120 s,1
    ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
    ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
    ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
    ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
    ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
    ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
    ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
    ENG108317-Proximity Sensor: SP_X2,10 min,1
    ENG108318-Proximity Sensor: SP_X3,1 ,1
    ENG108319-Proximity Sensor: SP_X4,80 ,1
    ENG108320-Proximity Sensor: SP_X5,1 ,1
    ENG108321-Proximity Sensor: SP_X6,30 min,1
    ENG108322-Proximity Sensor: SP_X7,1 ,1
    ENG108323-Proximity Sensor: Time Power On,1960 ms,1
    ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
    ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
    ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
    ENG120045-Reduced current for transponder-ID request,0 Step,1
    ENG126939-rpm_threshold_engine_runnning,100 /min,1
    ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
    ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
    ENG108577-Scan Procedure: Number of Repeats,1 ,1
    ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
    ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
    ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
    ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
    ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
    ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
    ENG108586-ScanProcedure: Timeout Response,100 ms,1
    ENG126963-settime_trigger_entry_vehicle,500 ms,1
    ENG126962-settime_trigger_exit_vehicle,500 ms,1
    ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
    ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
    ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
    ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
    ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
    ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
    ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
    ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
    ENG129025-ENG142122-sonstiges_byte2-sad_existing,activated ,1
    ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
    ENG244883-Speed_ threshold_for_start_request_plausibilisation,10 km/h,1
    ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
    ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
    ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
    ENG109053-Standard dimming value ZAT,80 %,1
    ENG126938-Terminal_15_adaption_body_control_module,Default ,1
    ENG126946-Terminal_S_Timeout,30 min,1
    ENG102207-Time Sensor Power Off Group 2,3600 min,1
    ENG129027-Time_frame_VIP_kick_forecast,5 ,1
    ENG126942-time_to_drive_cycle_detection,1.00 s,1
    ENG126947-time_to_ignore_ignition_trigger,35 s,1
    ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
    ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
    ENG126949-time_ZAT_actuation_detection,3000 ms,1
    ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
    ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
    ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
    ENG129019-timeout_convenience_coverage_limiting,75 s,1
    ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
    ENG244884-Toggle_offtime_other_doorhandle,2.00 s,1
    ENG244885-Toggle_offtime_same_doorhandle,2.00 s,1
    ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
    ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
    ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
    ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
    ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
    ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
    ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
    ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
    ENG120047-ZAT init value,0 %,1
    ENG110364-ZAT nominal voltage,13.0 V,1
    ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
    ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
    ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
    ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
    ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
    ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
    ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
    ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
    ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
    ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
    ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
    ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
    Jul 2019
    Here is 09.
    ;SW:5Q0-937-087-BA   HW:5Q0-937-087-BA ---  Cent. Elect.
    ;Component:BCM PQ37BOSCH 036 0265, Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BodyContrModul1UDSBosc,019001,EV_BCMBOSCH_019_VW37.rod
    ;Sunday,21,July,2019,11:41:40:31057
    ;VCID: FBB667AE729CB1974C-80AE
    IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
    IDE01550-Service position,178.999822 °,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
    IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
    IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
    IDE05143-MAS02985-Writing parameter-Value,130 ,5
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
    IDE05144-Read parameter address,FE 00 00 ,3
    IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 12 06 9A 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 13 07 9A 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
    IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,21.00 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,21.00 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,49.00 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,48.00 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,49.00 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,48.00 °C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
    IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start,installed ,8
    IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
    IDE07356-Position during interval mode,40.999959 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,DISKRET ,9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
    IDE10298-Alternating park position 1,19.999980 °,2
    IDE10299-Alternating park position 2,34.999965 °,2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %,256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
    IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber,not active ,3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
    IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
    IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
    IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
    IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
    IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
    IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
    IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
    IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
    IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
    IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
    IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
    IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
    IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
    IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
    IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
    IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
    IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
    IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
    IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
    IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
    IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
    MAS05055-lower turn position,42.999957 °,2
    MAS05056-upper turn position,178.999822 °,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2512 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
    ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
    ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
    ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
    ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
    ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
    ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
    ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Not deactivated ,6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
    ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,48 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,47 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,13 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,13 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,minimize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Nebellicht links ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Blinken links aktiv (beide Phasen) ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,minimize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Nebellicht rechts ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Blinken rechts aktiv (beide Phasen) ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
    ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
    ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
    ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
    ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
    ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
    ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
    ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
    ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
    ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
    ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
    ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
    ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
    ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
    ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
    ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
    ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
    ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
    ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
    ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
    ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
    ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
    ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
    ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
    ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
    ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
    ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
    ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
    ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
    ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
    ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
    ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
    ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
    ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
    ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
    ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
    ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
    ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
    ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
    ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
    ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
    ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
    ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
    ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
    ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
    ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
    ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
    ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
    ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
    ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
    ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
    ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
    ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
    ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
    ENG122979-ENG141954-Networking-A/C electronics,installed ,8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
    ENG122979-ENG99457-Networking-Head area heater,not installed ,8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
    ENG122979-ENG141969-Networking-UGDO,not installed ,8
    ENG124714-ENG142044-OCU-DWA_push,active ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
    ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
    ENG124714-OCU-,installed ,8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,800 ms,10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
    ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
    ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
    ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
    ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
    ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
    ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
    ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
    ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
    ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
    ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
    ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
    ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
    ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
    ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
    ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
    ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
    ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
    ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
    ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
    ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
    ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
    ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
    ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
    ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
    ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
    ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
    ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
    ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
    ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
    ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
    ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
    ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
    ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
    ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
    ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
    ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
    ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
    ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
    ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,not active ,3
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
    ENG141681-ENG246991-ZV Komfort-pa_Two_Keys,not active ,8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
  8. Likes Uwe liked this post
    Jul 2019
    Here is 6D
    ;SW:5Q0-959-107-P   HW:5Q0-959-107-J ---  Trunk Elect.
    ;Component:HDSG-Modul    H13 0266, Coding:0A08
    ;EV_DeckLidCONTIAU736,001016,EV_DeckLidCONTIAU736_VW37.rod
    ;Sunday,21,July,2019,11:44:56:31057
    ;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    ;VCID: C5C2C15644D837676A-8090
    IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
    IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
    IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
    IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
    IDE00001-MAS10735-Production mode-Calibration,not active ,3
    IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
    IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
    IDE02158-Program opening stop,1534 ,2
    IDE03435-Detection area upper,20 ,2
    IDE03776-Offset for maximum programmable opening stop,10 ,2
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,4 min,2
    IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,1 ,4
    IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,287 ,4
    IDE09511-Minimum opening height of tailgate,200 ,2
    IDE09512-Deactivation of tailgate,active ,1
    IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
    IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
    IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
    IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
    IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
    IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
    IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
    IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
    IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
    IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
    IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
    IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
    IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
    IDE09520-Offset for opening height after basic setting,0 ,2
    IDE10408-Opening height in production mode,60 %,2
    IDE10695-Dectivation of the luggage compartment cover,not active ,1
    IDE10703-Luggage compartment cover: tolerance of the block counter,0 ,2
    IDE10704-Luggage compartment cover: maximum no. of block drives,0 ,2
    IDE10705-Luggage compartment cover: number bloom drives,0 ,2
    IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0 ,4
    IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
    IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0 ,4
    IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0 ,4
    IDE10708-Luggage compartment cover: adjust. track tolerance,0 ,2
    IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
    ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,active ,2
    ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
    ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
    ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
    ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
    ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
    ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
    ENG131232-MAS08212-Ausstattungen aktivieren-Engine 2,active ,2
    ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
    ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,active ,2
  10. #8
    Jul 2019
    Hopefully you guys can make some sense out of this.
    Thanks,
    Tom
  11. #9
    Dec 2016
    Amsterdam
    I don't really remember if my Tiguan has the same behavior. I couldn't find any obvious differences in values in trunk related channels.
    While searching however, I found these two channels in your 09 unit:
    Based on the channel description, these are definitely related to the behavior we're talking about here.
    Current:
  12. Likes Uwe, jyoung8607 liked this post
  13. #10
    Very nice, Tommy!
    "Reichweitenbegrenzung fuer Servoheck schliessen" = "Distance limiting for Servo Hatch Closing"
  14. Likes somedude liked this post
