Results 1 to 5 of 5
Thread: 03 golf trans code 65280
    Oct 2014
    Time for me to ask the experts again.
    I got a strange transmission code on this golf, I haven't been able to find any info about it anywhere.
    The transmission is slipping. I'm gonna check the fluid now but...
    I'm kinda thinking tcm. Any thoughts?
    Friday,19,December,2014,14:59:47:23951
    VCDS Version: 14.10.0.0
    Data version: 20141022
    VIN: 9BWGK61J434040197   License Plate: 03 GOLF 2.0
    Mileage: 186440km-115848mi   Repair Order:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: 9BWGK61J434040197   Mileage: 186440km-115848miles
    Address 01: Engine        Labels: 06A-906-032-AVH.lbl
       Part No: 06A 906 032 MD
       Component: 2.0l R4/2V      G   4623
       Coding: 00003
       VCID: 6CDCCCCB1CD67841A33-5102
       9BWGK61J434040197     VWZ7Z0B5999026
    16795 - Secondary Air Injection System
                P0411 - 35-00 - Incorrect Flow Detected
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 MG
       Component: AG4 Getriebe 01M    5020
       Coding: 00000
       VCID: 01028D7F0B548529605-095A
    65280 - Development code 1
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0022530
       Shop #: WSC 00000 785 00200
       VCID: 346C14AB5466E081BB3-5102
       Part No: 1C0 909 605 F
       Component: 08 AIRBAG VW61 0202 0003
       Coding: 12344
       Shop #: WSC 00001
       VCID: 2756F3E7C5B09B190E1-50E6
    00532 - Supply Voltage B+
       Part No: 1J0 920 906 K
       Component: KOMBI+WEGFAHRSP VDO V07
       Coding: 07232
       Shop #: WSC 05072
       VCID: 306418BBF07EDCA1DFB-50E6
       Part No: 6N0 909 901
       Coding: 00006
       VCID: 70E4D8BB30FE9CA19FB-50E6
       Part No: 1C0 959 799 C
       Component: 8C Komfortgerát HLO 0003
       Coding: 00258
       VCID: 377623A715100B999E1-4AE6
       Component: 8C Tőrsteuer.FS KLO 0002
       Component: 8C Tőrsteuer.BF KLO 0002
       Component: 17 Tőrsteuer.HL KLO 0202
       Component: 8C Tőrsteuer.HR KLO 0002
    00912 - Window Regulator Switch; Front Left (E40)
                27-00 - Implausible Signal
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180
       Component:    Radio ZSW        0012
       Coding: 00031
       VCID: 5DBA910FD76C01C924D-50E6
    00856 - Radio Antenna
                36-00 - Open Circuit
    End-------------------------(Elapsed Time: 05:28)--------------------------
    I didn't get into it yet but is there a quick answer for the airbag codes as well?
    The secondary air code is what it is, broken air tubes, the radio code is a broke off antennae, and all the locks and windows work so not worried about that.
    Thanks ahead of time.
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by VolkyTek View Post
    This is a weird code...
       Coding: 00000
    I asked the Googles and found evidence that might be an error. The description for DTC 65280 might be "Data Bus Powertrain ABS Control Module Hardware defective". I think the "Development code 1" text may belong to DTC 65281 instead. However, we'll need Ross-Tech to confirm that.
    Jason
    Why do you think that's an error, Jason? I'm pretty dang confident the factory tool would show "Entwicklungscode 1"
    I wonder if there's a test plan for it though. Y'all can bump this on Monday if nobody else has come up with anything.
    Stoke on Trent, England
    That's a strange code which I have.
    VAG Error Code: 65280
    Fault Location:
    Controller Area Network (CAN) Data Bus, Anti-Lock Braking System (ABS) - Defective
    Possible Cause:
    AntiLock Braking System (ABS) trouble code(s) stored.
    Wiring/Connector(s).
    Matching resistor in Engine Control Module (ECM).
    There are a lot of Development error codes.
    http://translate.google.co.uk/transl...ml&prev=search
    New User Keith
    Cincinnati, OH
    I don't know, I only guess, hence the "might" and the deferral to Ross-Tech.
    It looks like Keithuk found the same reference I did.
    Jason
