Results 1 to 3 of 3
Thread: 2003 Audi C5 RS6 ABS Bleeding
    Verified VCDS-Lite User
    May 2019
    I've been trying to bleed the ABS pump unsuccessfully, and am hoping that someone will be able help or offer some advice. I have rerplaced the ABS Module and the ABS Pump. The module has taken the long coding without any problems and I can bleed the brakes with a pressure bleeder absolutley fine. Howerver as soon as the engine is running the pedal goes soft. The brakes worked perfectly prior to changing the pump and Module so I think the brake "Hardware" is all ok.
    When I access the abs module, I can successfully login using code 40168 and read message blocks etc. But when I try to run the output test it just starts and finishes within 2 seconds and noting else happens.
    Thanks in advance
    Gareth
    Here is a full scan:
    Workshop Code: 000 00000
    Self-Diagnosis Log Saturday, 20 July 2019, 11:19:06:41419
    VIN Number: WUAZZZ4B43N903565   License Plate: Mileage:    Repair Order:
    Chassis Type: 4B - Audi A6 C5 Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56,57,65,67,75,76,77
    ------------------------------------------------------------------------------Address 01: Engine       Labels: 077-907-558-BCY.LBL   Controller: 4D1 907 558    Component: 4.2l V8/5VT     G   0003   Coding: 0010752   Shop #: WSC 33278   VCID: EBA965648A9D 2 Faults Found: 17072 -  ECM Power Relay Load Circuit: (J271): Open Circuit        P0688 - 004 -  No Signal/Communication - Intermittent 18057 -  Powertrain Data Bus: Missing Message from ABS Controller        P1649 - 008 -  Implausible Signal - Intermittent Readiness: 0110 0000
    ------------------------------------------------------------------------------Address 02: Auto Trans       Labels: 01V-927-156.LBL   Controller: 4B0 927 156 FB   Component: AG5 01L 4.2l5VT VT2 1315   Coding: 00001   Shop #: WSC 60100   VCID: 6CABE6780F93 No fault code found.
    ------------------------------------------------------------------------------Address 03: ABS Brakes       Labels: 4B0-614-517.LBL   Controller: 4B0 614 517 AD   Component: ESP 5.7 RS 6        2310   Coding: 06697   Shop #: WSC 12345   VCID: 63B98D44E24D 4 Faults Found: 01486 -  System Function Test Activated        35-10 -   - - Intermittent 00778 -  Steering Angle Sensor (G85)        37-10 -  Faulty - Intermittent 18256 -  Please check DTC Memory of Engine Controller        P1848 - 35-00 -   65535 -  Internal Control Module Memory Error        00-00 -
    VCDS-Lite Self-Diagnosis Log Saturday, 20 July 2019, 11:19:06:41419 Page 2
    Address 08: Auto HVAC       Labels: 4B0-820-043-MY1.LBL   Controller: 4B0 820 043 AM   Component: A6-Klimavollautomat 0105   Coding: 00001   Shop #: WSC 00000   VCID: 65BD935CEC79 1 Fault Found: 01206 -  Signal for Duration of Ignition Off Time        27-00 -  Implausible Signal
    ------------------------------------------------------------------------------Address 15: Airbags       Labels: 4B0-959-655-AI7.LBL   Controller: 4B0 959 655 AA   Component: Airbag 8.4EP        1002   Coding: 0000606   Shop #: WSC 00298   VCID: 6F91F1743E85 No fault code found.
    ------------------------------------------------------------------------------Address 17: Instruments       Labels: 4B0-920-xxx-17.LBL   Controller: 4B0 920 983 B   Component: KOMBI+WEGFAHRS. VDO D12   Coding: 01484   Shop #: WSC 00045   VCID: 2721D954D6F5   WUAZZZ4B43N903565     AUZ7Z0C2379670 No fault code found.
    VCDS-Lite Self-Diagnosis Log Saturday, 20 July 2019, 11:19:06:41419 Page 3
    Address 35: Centr. Locks       Labels: 4B0-962-258.LBL   Controller: 4B0 962 258 N   Component: Zentralverrieg.,DWA D37   Coding: 06859   Shop #: WSC 00298   VCID: 341B3E181723 11 Faults Found: 01374 -  Alarm triggered by Terminal 15        35-00 -   01370 -  Alarm triggered by Interior Monitoring        35-00 -   01369 -  Alarm triggered by Hood Switch        35-00 -   00668 -  Supply Voltage Terminal 30        07-10 -  Signal too Low - Intermittent 01560 -  Passenger Door        59-10 -  Can't Unlock - Intermittent 01561 -  Left Rear Door        59-00 -  Can't Unlock 01562 -  Right Rear Door        59-10 -  Can't Unlock - Intermittent 01560 -  Passenger Door        61-10 -  Won't De-Safe - Intermittent 01561 -  Left Rear Door        61-10 -  Won't De-Safe - Intermittent 01562 -  Right Rear Door        61-10 -  Won't De-Safe - Intermittent 01134 -  Alarm Horn (H12)        49-10 -  No Communications - Intermittent
    VCDS-Lite Self-Diagnosis Log Saturday, 20 July 2019, 11:19:06:41419 Page 4
    Address 37: Navigation       Labels: None   Controller: 4B0 035 192 P   Component: RNS-E HIGH EU   H58 X--   Coding: 0509363   Shop #: WSC 00779   VCID: 2A272060C5E7 8 Faults Found: 00532 -  Supply Voltage B+        002 -  Lower Limit Exceeded - Intermittent 00446 -  Function Limitation due to Under-Voltage        002 -  Lower Limit Exceeded - Intermittent 00862 -  Antenna for GPS Navigation (R50/R52)        007 -  Short to Ground 00878 -  Connection to Speaker Front Left        011 -  Open Circuit 00879 -  Connection to Speaker Front Right        011 -  Open Circuit 01317 -  Control Module in Instrument Cluster (J285)        008 -  Implausible Signal - Intermittent 02230 -  Digital Radio (DAB) (R147)        004 -  No Signal/Communication 02005 -  Coding Pin        004 -  No Signal/Communication
    ------------------------------------------------------------------------------Address 45: Inter. Monitor       Labels: None   Controller: 4B0 951 178 A   Component: Innenraumueberw.    D04   Coding: 00102   Shop #: WSC 00000   VCID: 263FD450D1FF 2 Faults Found: 01349 -  Alarm via Theft Warning System; Front        35-00 -   01462 -  Anti-theft alarm ultra sonic Sensor (G209)        53-10 -  Supply Voltage Too Low - Intermittent
    ------------------------------------------------------------------------------Address 55: Xenon Range       Labels: 4Z7-907-357.LBL   Controller: 4Z7 907 357    Component: dynamische LWR       D09   Coding: 00050   Shop #: WSC 00000   VCID: 047BAED80703 1 Fault Found: 01539 -  Headlights Not Adjusted        35-00 -
    VCDS-Lite Self-Diagnosis Log Saturday, 20 July 2019, 11:19:06:41419 Page 5
    Address 56: Radio       Labels: None   Controller: 4B0 035 192 P   Component: RNS-E HIGH EU   H58 X--   Coding: 0509363   Shop #: WSC 00779   VCID: 2A272060C5E7 8 Faults Found: 00532 -  Supply Voltage B+        002 -  Lower Limit Exceeded - Intermittent 00446 -  Function Limitation due to Under-Voltage        002 -  Lower Limit Exceeded - Intermittent 00862 -  Antenna for GPS Navigation (R50/R52)        007 -  Short to Ground 00878 -  Connection to Speaker Front Left        011 -  Open Circuit 00879 -  Connection to Speaker Front Right        011 -  Open Circuit 01317 -  Control Module in Instrument Cluster (J285)        008 -  Implausible Signal - Intermittent 02230 -  Digital Radio (DAB) (R147)        004 -  No Signal/Communication 02005 -  Coding Pin        004 -  No Signal/Communication
    ------------------------------------------------------------------------------Address 65: Tire Pressure       Labels: 4D0-907-273.LBL   Controller: 4D0 907 273 CRu   Component: eifendruckueberw.  D310    Coding: 20329   Shop #: WSC 00298   VCID: EEAF6C70B98F 2 Faults Found: 65535 -  Internal Control Module Memory Error        00-00 -   01477 -  System Switched Off        35-00 -
    ------------------------------------------------------------------------------Address 76: Park Assist       Labels: 8E0-919-283-8E2.LBL   Controller: 8E0 919 283    Component: Parkingsyst. A6 RDW D09   Coding: 01156   Shop #: WSC 00000   VCID: EDAD6B7CB489 No fault code found.
    End   -------------------------------------------------------------------------------------------------
    Must default module or replace and bleed brakes as per RTFB.
    Try bleeding ABS pump using outputs once fault is corrected.
    0x03-03
  3. Likes Uwe liked this post
    Quote Originally Posted by willowzn View Post
    Here is a full scan
    For future reference, please don't use the [Print] function to post data here. The formatting it produces is far from optimal here.
    Instead, please use the [Copy Results] button on the Auto-Scan screen.
