Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: 10530 - EVAP System P0456 00 [096] - Very Small Leak Detected
    Jan 2019
    MN, USA
    I was looking at my battery using VCDS and this code showed up but it says "not confirmed"
    Is there something I should look at?
    Here is the whole scan.
    Friday,19,July,2019,15:17:58:53218
    VIN: WA1UFAFL7DA047656   License Plate:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
              6D 72
    VIN: WA1UFAFL7DA047656   Mileage: 99210km-61646miles
    Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 UM03
       Revision: ECH09---
       Coding: 722A0013242600062000
       ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
       ROD: EV_ECM20TFS0118K5907115F.rod
       VCID: 35342857B5CD888F29F-8060
    10530 - EVAP System
       Part No SW: 8K1 927 158     HW: 0BK 927 156 AL
       Component: 0BK 20TFSIUSA H16 1001
       Revision: --H16---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002018
       VCID: 74B2D553FE37D187DE1-8020
       Part No SW: 8K9 907 379 M    HW: 8K9 907 379 M
       Coding: 0E1D18
       Shop #: WSC 06334 000 00000
       VCID: 4CC26DB3C6C7E947661-8018
       Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H10 0602
       Coding: 0D820000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 0350868FAB19E63FD7B-8056
       Serial number: 2312000061348003
       Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
       Revision: C1000000    Serial number: 01300320122314
       Coding: 6480208000
       VCID: 3330164FBB3996BF07B-8066
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
       Component: BCM1 1.0      H14 0103
       Revision: 08014001    Serial number: 00000399423601
       Coding: 26080091863CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000
       Shop #: WSC 08255 444 10141
       VCID: 78AAE163E2DFB5E7F29-802C
       Component: WWS 280312  H07 0070
       Serial number: SWF12030286375
       Coding: 00F511
       Serial number: 20220743
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002403121288
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R17DX02
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: DB28CE16000000000001
       Part No SW: 8K0 959 655 M    HW: 8K0 959 655 M
       Component: AirbagVW-AU10 H46 0610
       Serial number: 003KEDA00EPD
       Coding: 303844354A32303030304A55304C384B3053
       Shop #: WSC 57810 001 1048576
       VCID: 47C8529FDF210A1F4B3-8012
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1200004VJD
       Serial number: 6334MSME6C10434AD
       Serial number: 6344MSME6C020E4CO
       Serial number: 6352QSME0E10034ED
       Serial number: 6362QSME041114762
       Serial number: 63732SME250B4F485
       Serial number: 63832SME2C103D682
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20120404000984
       Coding: 000017
       VCID: 4FF87ABF37D1D25F033-801A
       Component: E221 - MFL  H03 0003
       Part No SW: 8K0 920 982 A    HW: 8K0 920 982 A
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTC320V3D
       Coding: 8B3729020301D705020000
       VCID: 323E134B44239FB70CD-8066
       Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H10 0025
       Revision: 1Y030014    Serial number: 1441Y123200488
       Coding: 00C303FF00
       VCID: 3FD84A7F877142DFF33-806A
       Serial number: 1822277101
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000026212909
       Coding: 00581B00000000000000
       VCID: 3B203E6F93695EFFDFB-806E
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000027559573
       Coding: 011C13205E00410001
       VCID: 4DC460B73DDDE04F71F-8018
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0015443982
       Coding: 100000000001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 34321553BEB791871E1-8060
       Revision: 00002001    Serial number: 0174310749
       Coding: 0126063A20BA709580B0023200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000504983
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS150  H08 0043
       Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000027386618
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000016970
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 382A2163A2DF75E7329-806C
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H53 0138
       Revision: AB001007    Serial number: 236C-0C7527841
       Coding: 020007020100000001
       VCID: 2514F81705EDF80F99F-8070
    02617 - Satellite Antenna (R170)
                        Reset counter: 5
                        Mileage: 95421 km
                        Date: 2019.04.19
                        Time: 19:04:58
                        Voltage: 12.10 V
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 A
       Component: H-BNT-NA      H42 1040
       Revision: --------    Serial number: 096DY0C7505406
       Coding: 010200050006A1EF41028F4E00000403140000000000000000
       Subsystem 1 - Part No: 8R0 060 884 CS
       Component: NAR 2015  1201
       Component: DU7 High  H41 0104
       Serial number: A130C30CS135527
       Serial number: 00000001111061
       Component: CD-Database  3371
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Revision:             Serial number: 0000027297794
       Coding: 010C13204000210001
       VCID: 43D0468FEB99263F97B-8016
       Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
       Component: J772__Rearview      0140
       Revision: --H06---    Serial number: 525PA8-J2290SB
       Coding: 1000007
       VCID: 392C246795556CEFCD7-806C
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C223D73966759C7D61-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Serial number: 8K9827852A
       Revision:             Serial number: 0000027297793
    End----(Elapsed Time: 02:00, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    2013 Allroad Premium Plus UM stage 1
    2003 Allroad EPL Stage1+ straight downpipes catless(sold at 187K miles)
    "Intermittent - Not Confirmed" DTCs are usually not a concern.
    Take a look using Generic OBD-II, Mode 7 (Pending DTCs) to see if anything shows there.
  3. Likes Jack@European_Parts, lepa71 liked this post
    Does or did your MIL illuminate, I think not?
    This is a sporadic DTC and has not occurred enough times to cause a call up to the MIL via OBD2 yet in Mode 3 or 7, however, we can see in the ID or CAL ID that UM and your post that this car is FOD modified.
    So there is a very good chance your car is with deletes of some type.
    IE Catless downpipes!
    Considering the rear OXS are used to calculate the evap I dont see how the tests could run proper anyway.
    Jan 2019
    MN, USA
    I don't have any deletes. I'm running UM tune and have DV+ but everything else is stock. I have odblink lx odb2 so I will check with it. I only have 60K miles but have heard that N80 can cause it. My PCV was replaced about 15K miles ago.
    Clear fault codes and repost a complete auto-scan please.
    I'm sure the old sold allroad did with catless downpipes.
    Jan 2019
    MN, USA
    What is the new auto-scan will do? Just wondering.
    Let's possibly see and maybe I show you if I see something I can then explain.
  9. #8
    Jan 2019
    MN, USA
    Do you want me to clear the code then drive it and do a scan after or just clear the code and re-scan?
  10. #9
    Nope, just clear codes and turn car off , wait 1 minute and then key ON, start car and let idle for 5 minutes & going no where, than re-scan and post the complete data record.
  11. #10
    Jan 2019
    MN, USA
    Here is the scan after. Thank you for helping.
    Sunday,21,July,2019,18:12:24:53218
              6D 72
       Revision: ECH09---
       Revision: --H16---
       Coding: 000002
       Coding: 0E1D18
       Coding: 6480208000
       Coding: 00F511
       Coding: 02005D
       Coding: 000017
       Coding: 00C303FF00
                        Reset counter: 5
                        Mileage: 95421 km
                        Date: 2019.04.19
                        Time: 19:04:58
                        Voltage: 12.10 V
       Coding: 1000007
    End----------(Elapsed Time: 01:59, VBatt start/end: 12.6V/12.5V)-----------
  12. Likes Uwe liked this post
