10530 - EVAP System P0456 00 [096] - Very Small Leak Detected
   #21
There are no foreign devices here.
Have you had tuner do some work on your car which involved making any changes that changed settings in the engine ECU?
   #22
lepa71
MN, USA
C?ID=303671
Yes, re-mapping is the part of the tune. It does add more boost. It is also known that at 60K miles N80 can start going bad. This is what I'm trying to figure out. This would a physical issue and not a software issue in tune. Again, there is no FOD, there is no catless downpipes, no K04 upgrade turbo. This 2.0 engine can handle much more boot that is getting now. I have been running this tune for the last 2 years without any issues.
   #23
Of course you car has defeats/deletes it's just it has it in programming...........
Evaporation (EVAP) Leak Detection Pump (LDP) Test
Search How too section......
https://forums.ross-tech.com/forumdisplay.php?24-How-To-s-and-Tips
According to the scan data & that you provided all the sensor readiness tests are bypassed & because it is impossible for them to be all ready after a DTC reset.
I'm not saying you are lying & possibly are just restating what you think you know or been told, however, really don't know or been misinformed.
Just go read how readiness tests work and than you will see you have been fed a pile of bullshit.
   #26
lepa71
MN, USA
C?ID=303671
Just go read how readiness tests work and then you will see you have been fed a pile of bullshit.
How is this relevant to the original post. You asked me to do additional things and I did. Now you are going on this path about readiness and stuff. Why? I just simply don't get it. If you have nothing else to prove than, please, I beg you, stop responding to this thread. I don't need theoretical things with readiness and states and FOD.
I got a code and wanted to know what people think about it. Just practical things to try. You went on and on into LALA land.
Thank you for NO HELP!
   #27
lepa71
MN, USA
C?ID=303671
"Intermittent - Not Confirmed" DTCs are usually not a concern.
Take a look using Generic OBD-II, Mode 7 (Pending DTCs) to see if anything shows there.
This is what I expected to see or something similar.
   #29
You are missing the point. Not La la land
My responses are not to call attention to your tuner, however, you clearly have an inability to understand how stuff works, this has nothing to do with regulations or laws, it has to do with what can we test here.
Leak tests are done with mechanical tools and or in some cases the scanner, however, only when the ECU isn't a basket case or modified FOD unit & permits the tests to be done.
If the tests are posting as "READY" & before they are even given a chance to be tested, how the hell are you supposed to use VCDS?
The tool is only as good as the data that can be initiated and queried, if the ECU spits out bullshit data or prevents the test, the tool is for a sake crippled & mechanical tests must be done.
In this case all your readiness tests are ready after a mere reset of codes, so that means each test string is shut down and preset to zero or off/READY.
Since the rear OXS sensor is used to verify the blending process of the N80 gasses from gas tank, it is very possible your tuner missed something in a table.
The N80 could be queried fast to operate or hold gasses mechanically with a mighty vac.
   #30
lepa71
MN, USA
C?ID=303671
Ok. I will go along with your theory. I do scans quite often, maybe too often. I have not had that code 1 month ago. My tuner didn't miss anything. The UM tune is a self-adjustable tune. It probably is the most sensor depended tune out there.
I would expect that you would tell me to run a smoke test. That would be just fine. Being in IT for more than 25 years in BI world I know that data can't show everything and mechanical test can not be replaced by just data.
   #31
I prefer not to do smoke tests, they are sometimes too passive & because they are for people that need a visual and a mighty vac will hold or create PSI in order to see a leak.
Seriously a single vacuum line with crimps tests is superior to smoke tests and permits the qualified seal where smoke isn't going to tell you if something can handle a switch function & under a load of gas PSI.
Smoke test does have it's uses but in this circuit I have found it to be a complete waste of time and money to get that machine out.
Many times I find the leak where others didn't & by the choice of this test method.
As for self adjusting tunes or how dependable a tune is, I have my doubts about even the stock code sometimes, however, if you want to plug UM that's your choice and even though I don't agree with it, I respect your right to your faulted opinion.
   #32
lepa71
MN, USA
C?ID=303671
"I respect your right to your faulted opinion." Right, and you are always right. Your big ego shows.
   #33
You are correct, I should of stated for the record I am not always right and an asshole or clown, indeed I am humbled with my own mistakes made too.
I wouldn't say ego either, I'd say confident in ones abilities and to make a fast observation while maybe making a mistake myself sometimes.
For example I read your post quick skimming and thought you had cat-less down pipes but that was for your old allroad with announced deletes. :p
Nevertheless your own submitted data for readiness being ready after a DTC reset & shows the truth on the other side of things.
This stuff here is pretty routine and the shear repetition of the impaired diagnostic stacks by lazy tuners is not a secret.
In order to fix stuff it's good to know what is consistent and isn't to a degree, dont you think and if you could find a reason to explain to me why your tuner would set readiness flags in the spirit of Motorsports or why it wouldn't be a lazy method I'm all ears?
Does your tuner have an accreditation or exemption certificates with CARB or the EPA administrator? I think not?
Many would possibly think something is more reliable if they were not getting an MIL or DTC to be alerted now wouldn't they, maybe perceive it this way, like la la it looks good from my house or she looked great in the dark while drunk?
Everyone has done the walk of shame .......
   #34
lepa71
MN, USA
C?ID=303671
Just because you have certifications that do not give you rights to talk about others as you think they are incompetent. My tuner has his own shop that works on most European cars for the last almost 20 years. Primarily in Audi and VW but also works on Bentley and Maserati. He has 2 masters certified mechanics as himself as a 3rd one. One master mechanic is from Maserati manufacturing service department.
I also say that the ones who cannot do the work they either teach or demagogue.
So, please, don't be an asshole and stop insulting people you don't know.
I'm done with you in this thread. Please, stop posting.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Jack is an acquired taste. Jack is also absolutely correct in this situation.
Nope, just clear codes and turn car off , wait 1 minute and then key ON, start car and let idle for 5 minutes & going no where, than re-scan and post the complete data record.
Here is the scan after. Thank you for helping.
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
Clearing codes on a normal vehicle will set all supported readiness monitor bits to 1 until the respective tests have finished, at which time they're set to 0. If you see an ECU that says "No fault code found" and all the readiness monitors are zero, it's supposed to mean there's truly no faults, that everything has tested out successfully. The absence of an EVAP fault (or any system fault) alone doesn't mean that system is tested and working. The absence of a fault together with the readiness bit does.
https://www.ross-tech.com/vcds/tour/readiness.php
In your case, all the readiness monitors are at zero when you didn't drive the car. It's technically possible the EVAP test ran in that time, but improbable, I'd have to look at the exact conditions for your vehicle. But the catalytic converter monitor absolutely will not complete without a drive (or a specially commanded procedure which doesn't apply here). Your ECU is definitely confirmed lying about certain readiness bits. We just don't know how many.
Jack has some odd but deeply held opinions on tuning which you may regard or disregard as you like. I personally do not care if people show up here with tuned cars, provided they are upfront about it. Jack's point is, this will be more difficult to diagnose, because who knows what your tuner has done. Sometimes it's just a readiness bit ignored, sometimes the DTC will run and set but the MIL for that code is disabled, sometimes the routine or subsystem has been hacked out entirely. FOD = screwed with, be that software or hardware. In this, he is correct.
If that's something you can understand and acknowledge and take ownership of, then the rest of the discussion will be more productive toward finding a solution.
lepa71
MN, USA
C?ID=303671
In your case, all the readiness monitors are at zero when you didn't drive the car. It's technically possible the EVAP test ran in that time, but improbable, I'd have to look at the exact conditions for your vehicle. But the catalytic converter monitor absolutely will not complete without a drive (or a specially commanded procedure which doesn't apply here). The absence of an EVAP fault (or any system fault) alone doesn't mean that system is tested and working. The absence of a fault together with the readiness bit does. Your ECU is definitely confirmed lying about certain readiness bits. We just don't know how many.
You see I can totally understand your explanation. Thank you
What I don't get is to why some people "him" have a need to insult others, that he has no knowledge about, in the way he does.
   #37
You fail to realize when you dismiss me and argue a baseless argument, you are insulting the collective and only helping spread a disease!
Thank you Jason,
OP : You could flash back to stock and run tests if nothing in the car is truly altered or get a second ECU, one for the track and one for proper stack.
You could also do mechanical tests as I have aforementioned.
I am not a teacher and in the trenches doing this crap everyday, every car has to be qualified as "not modified" & before you start or you could waste a ton of time potentially.
To be clear:
I am not against modification, speed HP/TQ or tuning, I do have a serious problem with the tuners which cut corners or promote deletes & as a method of Motorsports.
This has and continues causing in many cases, people's unjustified repair bills, voided warranties & because people like you OP, don't know WTF is going on & this thread is a perfect example of it.
Just think of the poor guy that buys a car used and doesn't have a lot of money, he spends his check to change parts he doesn't need & because he has no MIL but cant figure why the car runs like a POS?
Now there will be guys justifying the inverse, saying to themselves, they didn't have to buy that expensive part and the car still runs and it has no MIL, ain't I clever, meanwhile the whole stack was set to zero, then the dumb bastard drives down road maybe a while & maybe he blows his motor, very frequently & indeed happens?
I can tell you from experience this is a problem!
When ECU's get sent to me, I often plugin right on bench & to start a transfer or after transfer doing a forensic extraction and they have no DTC's for anything and all readiness are set even after I clear a fault memory.
I consider this an important work detail too & since if I can retrieve the DTC's from a controller that went under water or burned up, I can then give insight to the installer WTF happened & before he plugs in the replacement to burn it up again.
All I'm saying is consider the other side and ramification of this crap, because it does matter!
The JPPSG rules matter as does FOD!............ :p
Wanna go ride the 737 MAX Boeing?
   #38
findalex
C?ID=95887
My 2013 A5 U.S.-spec is completely stock. And I'm getting the exact same code. I've cleared it before but it always comes back. No MIL lights though.
I came across this TSB: https://static.nhtsa.gov/odi/tsbs/2015/MC-10123710-9999.pdf The P045600 code matches.
Do you think this TSB applies to this particular code?
   #40
findalex
C?ID=95887
Please see my autoscan below. Also, according to an earlier TSB, this is the cause:
Technical Background
After the engine is switched off, the fuel system creates a natural vacuum as the fuel in the fuel tank cools off. If the natural vacuum leak detection (NVLD) system cannot detect this natural vacuum during the system self-test, the DTC will be stored in the ECM.System self-test background:• The NVLD system checks the natural vacuum that is created in the fuel tank as the fuel cools after the engine has been switched off.• The fuel tank pressure sensor, G400, senses the vacuum in the bleed line near the EVAP canister. The fuel tank leak detection control module, J909, monitors the temperature inside the fuel tank.• The fuel system is considered to be closed (leak-free) if the measured vacuum is 2.5 mbar (0.04 PSI).•If no vacuum is detected, there is a vacuum leak in the EVAP system, and the DTC will be stored
Sunday,12,July,2020,12:12:26:37015
VCDS Version: 19.6.1.0 (x64)
VIN: WAUCFAFR7DA017XXXX   License Plate:
Mileage: 139180km-86482mi   Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56
          77
VIN: WAUCFAFR7DA017XXX   Mileage: 139180km-86482miles
   Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0008
   Revision: ECH09---
   Coding: 5A2A0013242600062000
   Shop #: WSC 43966 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
   ROD: EV_ECM20TFS0118K5907115F.rod
   VCID: 356ADC8394D1E1E77A-8060
10530 - EVAP System
                    Mileage: 136847 km
                    Date: 2020.06.11
                    Time: 15:17:08
                    Engine speed: 1299.00 /min
                    Normed load value: 31.4 %
                    Coolant temperature: 30 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.981 V
                    Unlearning counter according OBD: 13
                    selected gear-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Calculated reducing transmission intervention torque: 1000.0 Nm
                    Engine torque: 62.6 Nm
                    Required RPM at idle speed: 1300.0 /min
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1002
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 4796A64BFE3D637718-8012
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 2D1D18
   Shop #: WSC 06325 000 00000
   VCID: 040C7147878B886FBD-8050
   Part No SW: 8K0 907 064 GL    HW: 8K0 907 064 FL
   Component: BCM2 2.0      H11 0621
   Coding: 09804000000000000000
   VCID: 00047D579393944F99-8054
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0512000042425014
   Serial number: 2312000154977010
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000034146290
   Coding: 08037025002400001000
   VCID: 458AAC43CC317167EA-8010
   Revision: C1000000    Serial number: 01140720120350
   Coding: 6482208000
   VCID: 3972D0B3B0C905879E-806C
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000444499001
   Coding: 26000091863CAFC00000480300003D0D0F1C528822090221000008004000030100000000000000
   Shop #: WSC 06325 123 12345
   VCID: 76E81B8FC157AAFFB3-8022
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 100712  H15 0080
   Serial number: SWF12070100322
   Coding: 00FD11
   Serial number: 20408358
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000207121228
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R298802
   Serial number: 1F588736000000000001
   Serial number: 003KJD90F99B
   Coding: 303343334830303030304A55304C38543053
   VCID: 4A909F7FED2F9E1F07-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R1200009GW2
   Serial number: 6334MSME6F35683FY
   Serial number: 6344MSME70640B29D
   Serial number: 6352QSME0A672E72P
   Serial number: 6362QSME01190B4EI
   Serial number: 63732SME6C1C0F6EM
   Serial number: 63832SME6C1C15622
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120716000060
   Coding: 000016
   VCID: 4FA68E6B1E4DBB3750-801A
   Part No SW: 8T0 920 951 D    HW: 8T0 920 951 D
   Component: KOMBIINSTR.   H11 0553
   Revision: 00200000    Serial number: RAH3CWA7D
   Coding: 8B1701000301D705020000
   VCID: 3A70CFBFB5CF0E9F97-806E
   Part No SW: 8R0 907 468 F    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0051
   Revision: 1V060024    Serial number: 2441V126198037
   Coding: 80C303FF00
   VCID: 4280B75FDD1F465FCF-8016
   Serial number: 2383937401
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000034154289
   Component: TSG FA        H09 0304
   Coding: 011C03224000120102
   VCID: 56A87B0F2197CAFF93-8002
   Revision: 00001000    Serial number: 0018663477
   Coding: 100000000001
   Shop #: WSC 22163 444 101275
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 346CE1879FABF8EF4D-8060
   Revision: 00002001    Serial number: 0180133682
   Coding: 0106069A00FA400482B0003200000000
   Shop #: WSC 06324 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000545858
   Component: J245EE20SKB13  H03 0220
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   VCID: 2B5EFAFB4A95A7171C-807E
   Component: TSG BF        H09 0304
   Coding: 011C03224C00120102
   VCID: 55AA7C033C91C1E79A-8000
   Revision: --------    Serial number: 00000001149101
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3874D5B783C31C8F61-806C
   Part No SW: 8R1 035 186 H    HW: 8R1 035 186 H
   Component: Con3 Sirius   H08 0461
   Revision: 00000001    Serial number: AUZ5Z6L1768616
   Coding: 040200020104850043D9070800
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Fault Frequency: 78
                    Reset counter: 108
                    Mileage: 121121 km
                    Date: 2019.08.05
                    Time: 13:15:19
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005277628
   Coding: 0010370
   VCID: 3E78C3AF69E722BFAB-806A
End-------------------------(Elapsed Time: 03:56)--------------------------
