I was looking at my battery using VCDS and this code showed up but it says "not confirmed"
Is there something I should look at?
Here is the whole scan.
Friday,19,July,2019,15:17:58:53218
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WA1UFAFL7DA047656 License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
6D 72
VIN: WA1UFAFL7DA047656 Mileage: 99210km-61646miles
Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 UM03
Revision: ECH09---
Coding: 722A0013242600062000
ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
ROD: EV_ECM20TFS0118K5907115F.rod
VCID: 35342857B5CD888F29F-8060
10530 - EVAP System
Part No SW: 8K1 927 158 HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1001
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: 74B2D553FE37D187DE1-8020
Part No SW: 8K9 907 379 M HW: 8K9 907 379 M
Component: ESP8 quattro H09 0100
Coding: 0E1D18
Shop #: WSC 06334 000 00000
VCID: 4CC26DB3C6C7E947661-8018
Part No SW: 8K0 907 064 FP HW: 8K0 907 064 FP
Component: BCM2 2.0 H10 0602
Coding: 0D820000000000000000
Shop #: WSC 06335 000 00000
VCID: 0350868FAB19E63FD7B-8056
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000061348003
Part No SW: 8K1 820 043 N HW: 8K1 820 043 N
Revision: C1000000 Serial number: 01300320122314
Coding: 6480208000
VCID: 3330164FBB3996BF07B-8066
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 AH
Component: BCM1 1.0 H14 0103
Revision: 08014001 Serial number: 00000399423601
Coding: 26080091863CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000
Shop #: WSC 08255 444 10141
VCID: 78AAE163E2DFB5E7F29-802C
Component: WWS 280312 H07 0070
Serial number: SWF12030286375
Coding: 00F511
Component: G397_RLFS H06 0002
Serial number: 20220743
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002403121288
Component: USHL4.2 H30 0030
Serial number: 0000002274555R17DX02
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: DB28CE16000000000001
Part No SW: 8K0 959 655 M HW: 8K0 959 655 M
Component: AirbagVW-AU10 H46 0610
Serial number: 003KEDA00EPD
Coding: 303844354A32303030304A55304C384B3053
Shop #: WSC 57810 001 1048576
VCID: 47C8529FDF210A1F4B3-8012
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1200004VJD
Serial number: 6334MSME6C10434AD
Serial number: 6344MSME6C020E4CO
Serial number: 6352QSME0E10034ED
Serial number: 6362QSME041114762
Serial number: 63732SME250B4F485
Serial number: 63832SME2C103D682
Revision: 00000000 Serial number: 20120404000984
Coding: 000017
VCID: 4FF87ABF37D1D25F033-801A
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 982 A HW: 8K0 920 982 A
Component: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NTC320V3D
Coding: 8B3729020301D705020000
VCID: 323E134B44239FB70CD-8066
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y123200488
Coding: 00C303FF00
VCID: 3FD84A7F877142DFF33-806A
Serial number: 1822277101
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000026212909
Coding: 00581B00000000000000
VCID: 3B203E6F93695EFFDFB-806E
Part No SW: 8K0 959 793 P HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000027559573
Coding: 011C13205E00410001
VCID: 4DC460B73DDDE04F71F-8018
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0015443982
Coding: 100000000001
ROD: EV_RCEPSAU48X_008.rod
VCID: 34321553BEB791871E1-8060
Revision: 00002001 Serial number: 0174310749
Coding: 0126063A20BA709580B0023200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000504983
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS150 H08 0043
Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J394 PS240 H08 0043
Part No SW: 8K0 959 792 P HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000027386618
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000016970
ROD: EV_ParkiBrake_AU48.rod
VCID: 382A2163A2DF75E7329-806C
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H53 0138
Revision: AB001007 Serial number: 236C-0C7527841
Coding: 020007020100000001
VCID: 2514F81705EDF80F99F-8070
02617 - Satellite Antenna (R170)
Fault Status: 01101011
Reset counter: 5
Mileage: 95421 km
Date: 2019.04.19
Time: 19:04:58
Voltage: 12.10 V
Part No SW: 8R1 035 746 K HW: 8R1 035 746 A
Component: H-BNT-NA H42 1040
Revision: -------- Serial number: 096DY0C7505406
Coding: 010200050006A1EF41028F4E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130C30CS135527
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001111061
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000027297794
Coding: 010C13204000210001
VCID: 43D0468FEB99263F97B-8016
Part No SW: 8T0 907 441 D HW: 8T0 907 441 D
Component: J772__Rearview 0140
Revision: --H06--- Serial number: 525PA8-J2290SB
Coding: 1000007
VCID: 392C246795556CEFCD7-806C
Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
Component: J605 Master H52 0330
Revision: -------- Serial number: 8K9827851A
VCID: 3C223D73966759C7D61-8068
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H52 0330
Serial number: 8K9827852A
Component: TSG HR H01 0506
Revision: Serial number: 0000027297793
End----(Elapsed Time: 02:00, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
