Results 1 to 10 of 12
Thread: Tiguan N5 2011 ABS lost coding
    Jul 2019
    Slovenia
    This is my first post so I hope I don't mess up :-)
    I need help with coding of ABS module on Tuguan Y 2011.
    Car was brought to me with ABS/ESP lights on.
    When I scanned for dtcs there was this one : "01044 - Control Module Incorrectly Coded"
    Coding was 000000000
    Some mechanic killed coding by entering incorrect value. I don't know why they messed with coding since they only changed oil and brake pads....
    Anyway... I tried to do coding but there is no help in coding section for this module. (I use latest vcds version) That is why I tutn to you.
    I found some coding help on the net but they didn't work.
    Car details: (I also left full autoscan)
    Tuguan 2.0tdi y2011
    CFFA engine 100 kW
    4x4
    DSG
    tyre monitoring button present
    black abs sensors in the back
    OFF-road or not that I don't know how to see ???
    Please help me with this code or if you have some table of engine codes so I can calculate it.
    I found some on the net but there was no 100kW tdi engine on list ....
    Thank you
    Best regrads
    Marko
    Friday,19,July,2019,19:59:38:63817
    VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
    VIN: WVGZZZ5NZBW079714   License Plate:
    Mileage: 196010km-121794mi   Repair Order:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 37 42 44 46 4F 52 53 55
              56 62 69 72 77
    VIN: WVGZZZ5NZBW079714   Mileage: 196010km-121794miles
    Address 01: Engine (J623-CFFA)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 JF    HW: 03L 907 309 R
       Component: R4 2,0L EDC   H23 7417
       Revision: 42H23---    Serial number: 00000000000000
       Coding: 00250012043600080000
       Shop #: WSC 01324 020 00200
       ASAM Dataset: EV_ECM20TDI01103L906018JF 003001
       ROD: EV_ECM20TDI01103L906018JF_VW36.rod
       VCID: 77BE0BE4CE340DF7A8-8022
       Part No SW: 0BH 300 011 S    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H08 1805
       Revision: 00H08V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 3228FAF065D628DF5F-8066
    Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
       Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
       Component: J104    C4 450 V210 0006
       Revision: --H28---    Serial number: 00000003581605
       Coding: 0000000
       VCID: 393ACDDC70A0DB879E-806C
                        Reset counter: 16
                        Mileage: 196016 km
                        Date: 2013.12.09
                        Time: 00:42:06
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 169
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000002
       VCID: 6E902E80B16E4C3F7B-803A
       Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
       Component: BCM PQ35 H    011 0046
       Revision: BE011001
       Coding: 40180A3B88251AC040080080B400092443553088736D85605C8000000040
       VCID: 3FCEA3C4AE84F5B7A0-806A
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 22121  012 0203
       Serial number: N1955119   °203!
       Coding: 009795
       Component: RLS 171210 05  54  0403
       Coding: 03304D
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 P    HW: 3T0 919 475 C
       Component: PARKHILFE PLA H08 0116
       Revision: --------    Serial number: 13991034233272
       Coding: 118103
       VCID: 48DCB818FB4AB20F11-801C
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__200 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PRCHBJ5
       Coding: 0012336
       VCID: 4CD484082F325E2F35-8018
       Subsystem 1 - Serial number: 6332MTS651333380
       Subsystem 2 - Serial number: 6342MTS691633380
       Subsystem 3 - Serial number: 6351HTS67KHFI9KJ
       Subsystem 4 - Serial number: 6361HTS6MGSJI9KR
       Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101222201018
       Coding: 1982140000
       VCID: 7CB414C8F7122EAFC5-8028
       Component: E221__MFL-TAS  H07 0013
       Coding: 820000
       Part No SW: 5N0 920 872 A    HW: 5N0 920 872 A
       Component: KOMBI         H20 0420
       Coding: 110F01
       VCID: 302CF0F86BDA1ACF29-8064
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 171210F1003391
       Coding: 356002
       Shop #: WSC 01042 202 104269
       VCID: 312AF5FC68D013C726-8064
       Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
       Component: Haldex 4Motion      0042
       Coding: 0000005
       Component: IMMO          H20 0420
       VCID: 6A9822908D86A01F27-803E
    Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
       Part No SW: 3C0 035 270 B    HW: 3C0 035 270
       Component: RNS310        H19 0353
       Revision: 10000000    Serial number: VWZ1Z2K3888383
       Coding: 000004010400000000000000
       ASAM Dataset: VW_RNS310 A02007
       ROD: EV_VWRNS310UDS.rod
       VCID: 197A2D5C1860FB877E-804C
       Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
       Component: Tuer-SG         009 2112
       Coding: 0004286
       VCID: 373ECBE446B4CDF768-8062
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.287 0802
       Revision: 1AH03831    Serial number: 00103550320801
       Coding: 0000258
       VCID: 3B36D7D47A9CE9978C-806E
       Component: EZE_2         H35 0614
       Coding: 050B0500
       VCID: 6FAE3384BE64453770-803A
       Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
       Component: Tuer-SG         009 2111
       Coding: 0004542
       VCID: 383CC8D84BAAC28F61-806C
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000094961
       Coding: 0023057
       VCID: 3326FFF452CC21D754-8066
       Coding: 1361094
       VCID: 3424FCE857C226EF4D-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000020
       Coding: 00000020
       Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
       Component: Tuer-SG         007 2102
       Coding: 0000144
       Shop #: WSC 01324 020 1012552
       Revision: 3A001001    Serial number: 00000140135910
       Coding: 410D000100000000
       VCID: 302CF0F863DA1ACF29-8064
       Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
       Coding: 0000144
       Part No SW: 5K0 035 730 A    HW: 5K0 035 730 A
       Component: TELEFON       H09 1020
       Revision: 1B001001    Serial number: 00007661530148
       Coding: 0A00000000000001
       ASAM Dataset: UHVNA A01009
       ROD: UHVNA.rod
       VCID: 23060FB42A2CB157A4-8076
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
              [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
                        Reset counter: 16
                        Mileage: 196016 km
                        Date: 2019.07.19
                        Time: 00:42:08
    9457939 - Telephone baseplate
              B1051 13 [009] - Open Circuit
              [Halterung für Handyhalter (Baseplate): Unterbrechung]
                        Reset counter: 16
                        Mileage: 196016 km
                        Date: 2019.07.19
                        Time: 00:42:08
    9458453 - Cellular Antenna
              B1053 15 [009] - Open or Short to Plus
              [GSM-Antenne: Unterbrechung/Kurzschluß nach Plus]
                        Reset counter: 16
                        Mileage: 196016 km
                        Date: 2019.07.19
                        Time: 00:42:08
    End----------(Elapsed Time: 01:27, VBatt start/end: 12.4V/12.3V)-----------
  2. Likes Uwe liked this post
  3. #2
    Coding: 0056641
    Please report if helpful?
  4. Likes Fredrick Awuor liked this post
  5. #3
    Jul 2019
    Slovenia
    Thank you,
    I will try it on monday when I get the car back.
    Best regards
    Marko
  6. #4
    Jul 2019
    Slovenia
    I tryed your coding but it is not ok....
    these are dtcs now ...
    Tuesday,23,July,2019,17:42:44:63817
    VCDS Version: Release 19.6.1 Running on Windows 7 x86
    Control Module Part Number: 5N0 614 109 Q    HW: 5N0 614 109 Q
      Component and/or Version: J104    C4 450 V216 0006
               Software Coding: 0056641
                Work Shop Code: WSC 01324 020 00200
                        Reset counter: 22
                        Mileage: 196226 km
                        Date: 2031.14.30
                        Time: 22:28:04
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 242
                        Hex Value: 0x0000
                        Reset counter: 22
                        Mileage: 196226 km
                        Date: 2031.14.30
                        Time: 22:28:04
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 247
                        Hex Value: 0x0000
                        Reset counter: 22
                        Mileage: 196226 km
                        Date: 2031.14.30
                        Time: 22:28:04
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 219
                        Hex Value: 0x0000
                        Reset counter: 22
                        Mileage: 196226 km
                        Date: 2031.14.30
                        Time: 22:28:04
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 169
                        Hex Value: 0x0000
    Jul 2019
    Slovenia
    There are no DTCs on other modules....
    How about this?
    Coding: 0002333
    Jul 2019
    Slovenia
    Hi.
    Still the same....
    Same 4 dtcs as before
  10. #8
    Any chance you can find a car or scan in your region or from someone or maybe go visit a dealership for some test drives to grab scans?
  11. #9
    Try this please
    Coding: 0050503
    Coding: 0056717
  12. Likes Uwe liked this post
  13. #10
    Jul 2019
    Slovenia
    Hi
    I tried to find a car to scan, but noone had similar engine...
    But I DID IT .... I think...
    I was trying all possible codings and I found one that works. There are no DTCs. Car drives normaly.
    Can anyone check what this coding stands for?
    0011591
    Thanks for help anyway :-)
  14. Likes Uwe liked this post
