Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Retrofit High Beam Assist Audi A6 4G 2016 Problem
    Sep 2018
    Spain
    Well ... install as it said k electronic ..... mirror connector T8 / 3 ..... PIN3 CAN HIGH and T8 / 8 ..... PIN8 CAN LOW ...... everything down below driver to T46 / 14 CAN HIGH and T46 / 14 CAN LOW. as pin 14 was busy, I put it in T46 / 15 CAN HIGH and T46 / 15 CAN LOW .... all good
  2. #12
    Sep 2018
    Spain
    code as said k electronic ..... register unit 19 GATEWAY ..... Installation list ... unit 20 ... HIGH BEAM ASSIST ......
  3. #13
    Sep 2018
    Spain
    UNIT 09 ..... byte 05 ..... bit 6 active ....... and byte 20 ..... bit 3 active
  4. #14
    Sep 2018
    Spain
    http://imgur.com/YyZxUfU
    today I entered unit 19 installation list and I marked unit 17 above ... I record and I go out
  5. #15
    Sep 2018
    Spain
    https://i.imgur.com/iGSlr1B.jpg
    I do scan with vag com and it gives those failures ....... but unit 20 is fine. I drive 100 km and I test High Beam Assist and it works perfect.
  6. #16
    Sep 2018
    Spain
  7. #17
    Sep 2018
    Spain
    What does not let me select is in unit 19 Gateway ... Installation List ... unit 17 below ... I just record and exit ... I go back in and the two unit 17 are pointed
  8. #18
    Sep 2018
    Spain
    I also checked fuses and all well
  9. #19
    Sep 2018
    Spain
    Fixed and fixed. The problem was coding. In unit 19 list installation. I get two Unit17, I mark the one below and I mark the one above. I record and go out. I go back in and the two unit17 are selected but really only the one below. I realized when entering the debug folder .. codinglog and see the coding. I have 3000 km and everything works fine. I still don't know why I get two unit 17 and two unit 03 ....
  10. Likes Uwe liked this post
