Retrofit High Beam Assist Audi A6 4G 2016 Problem
torrebasetez
Spain
C?ID=354490
hola. hace aproximadamente dos años hice retrofit High beam assistant con kit de k electronic. todo iba bien pero ha dejado de funcionar y me da fallo. pueden ayudar. gracias.
torrebasetez
Spain
C?ID=354490
Friday,19,July,2019,18:23:35:58101
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUZZZ4G7GN133678   License Plate:
Mileage: 51603km-32064mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 3B 3C 42 44 46 52 53 5F 62
          72 85 8E 8F 90 AC
VIN: WAUZZZ4G7GN133678   Mileage: 51603km-32064miles
17-Instruments -- Status: Cannot be reached 0100
20-High Beam Assist. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1649
   Revision: 85H23---
   Coding: 0A254012242401080000
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFEFA639577D9F8DF-802C
   Part No SW: 4G1 927 153 B    HW: 0CK 927 156 S
   Component: 0CK 20TDI RdW H04 0002
   Revision: --H04---    Serial number: 0000000396
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002020
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 290FFFE689770D1FBDF-807C
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051150265000574
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41DF47461107E55F85F-8014
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Component: BCM2 2.0      H37 0572
   Coding: 05A86F0E000000000000
   VCID: 7DA7FBB62DFF41BFA17-8028
   Part No SW: 4G0 820 043 CA    HW: 4G0 820 043 CA
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 11121500111108
   Coding: 34010908250000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 6099A2C2BACD8C57AA1-8034
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001240863602
   Coding: 2600001500749FE08181408000001D0CCF9CC3082E090201000004206101140200400035030000
   Shop #: WSC 12345 123 61029
   VCID: 71BFD78661A735DF35F-8024
   Component: WWS57X 151013  H38 0080
   Serial number:         151104195000
   Coding: 0045F7
   Serial number: 61164683
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 14 12 2015  00000414
   Serial number: 3A98C1E7000000000001
03395 - Control Module for High Beam Assistant
                    Reset counter: 61
                    Mileage: 51603 km
                    Date: 2019.07.19
                    Time: 18:17:00
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1007WPNU
   Coding: 30333130313630323638554A304C34473053
   VCID: 3B2335AE73EB8F8FDF3-806E
   Serial number: 3575HRB404R3N8CE4P1S
   Serial number: 3585HRB405N3N8CE20JH
   Serial number: 3515JRB404T3KVP45PAG
   Serial number: 3525JRB404V3KVP4M0DE
   Serial number: 3554VRB405N3I38KG1ET
   Serial number: 3564VRB405P3I38KDGQD
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372MC60001Q
   Coding: 0000F4
   VCID: 372B299E4F43ABEF3BB-8062
                    Fault Frequency: 24
                    Reset counter: 0
                    Mileage: 51557 km
                    Date: 2019.07.17
                    Time: 14:12:41
   Part No SW: 4G8 920 934 D    HW: 4G8 920 934 D
   Component: TDieRdw       H11 0106
   Revision: 08001098    Serial number: 658141215592055
   Coding: 13AF0A000B550008050000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 323D188AA4A14EC70C5-8066
   Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002085041
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 38292AA242DDA497321-806C
   Serial number: 1085088603
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 151006000000000004FC
5701 - High Beam Assistant Control Module
          U1070 00 [009] - No Communication
                    Reset counter: 61
                    Mileage: 51603 km
                    Date: 2019.07.19
                    Time: 18:16:59
                    Voltage terminal 30: 12.6 V
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 33 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 60
                    Mileage: 51557 km
                    Date: 2019.07.17
                    Time: 14:14:15
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 37 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
Address 20: High Beam Assist.
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820ASA3C
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635249A48C952E720D-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0389946338
   Coding: 040311
   VCID: 392F2FA679D7BD9FCDF-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0391174110
   Coding: 040311
   Coding: 011F17015C00628002080012
   VCID: 47CB595E3FA3DB6F4BB-8012
   Component: RCevo         H53 0202
   Revision: 00000001    Serial number: 0000525526
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D30AA7CD1B687C45-806E
   Revision: 00002001    Serial number: 0391229514
   Coding: 01000E3800B900818320088408030E470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00027884591
   Subsystem 2 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93708073
01308 - Control Module for Roof Electronics (J528)
                    Reset counter: 101
                    Mileage: 51557 km
                    Date: 2019.07.17
                    Time: 14:24:38
   Coding: 011F17015E00628002080002
   VCID: 46D5545A38A9C267B0D-8012
   Revision: --------    Serial number: 00000001703096
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070BF6BD9F113F517-8078
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 G    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   053 0910
   Serial number: A733B0H7533174
   Coding: 01750101AA00000013110001000A00102F0006E5F1700100DF
   VCID: 1E65DC3AC039FAA7D8D-804A
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9FY801AJX
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Serial number: 90349MCE000L3
   Component: Gracenote  --- 1010
          B201A 00 [009] - -
                    Reset counter: 60
                    Mileage: 51557 km
                    Date: 2019.07.17
                    Time: 14:12:50
                    Voltage terminal 30: 11.8 V
                    Status_Software_Version_Management-module_name: MDUA009/Front
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 60
                    Mileage: 51557 km
                    Date: 2019.07.17
                    Time: 14:12:46
                    Voltage terminal 30: 11.9 V
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 60
                    Mileage: 51557 km
                    Date: 2019.07.17
                    Time: 14:12:46
   Coding: 010F15004000628002080002
   VCID: 49CF5F6629B72D1F5DF-801C
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0081
   Coding: 72060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C0106F286851837469-8078
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621712157
   Coding: 0440B9181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1786A1A775DF75F-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 153221760
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F3B11FEB793632F63B-807A
End----(Elapsed Time: 01:48, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
torrebasetez
Spain
C?ID=354490
when I did retrofit note that in modulo 19 in installation list two modules 17 instruments appeared. Remove one and everything worked fine until now.
Two adress unit 17 instruments
Yes, I think it is because there are two different paths that data can take between the instruments and the gateway.
torrebasetez
Spain
C?ID=354490
but when you remove a 17 address in unit 19 installation list it follows the failure.
torrebasetez
Spain
C?ID=354490
because there are two modules? .... abs also comes two modules in unit 19 installation list ..
torrebasetez
Spain
C?ID=354490
I enter unit 19 installation list ...... I select unit 17 (only the one above) and I record and I leave ... and when I go back into unit 19 installation list the two unit 17 instruments are selected ... .... there are ghosts in my car?
torrebasetez
Spain
C?ID=354490
Can someone please help me? ....... thanks
torrebasetez
Spain
C?ID=354490
I know it's Sunday and it's hot and many are drinking beer .......
torrebasetez
Spain
C?ID=354490
Well ... install as it said k electronic ..... mirror connector T8 / 3 ..... PIN3 CAN HIGH and T8 / 8 ..... PIN8 CAN LOW ...... everything down below driver to T46 / 14 CAN HIGH and T46 / 14 CAN LOW. as pin 14 was busy, I put it in T46 / 15 CAN HIGH and T46 / 15 CAN LOW .... all good
torrebasetez
Spain
C?ID=354490
code as said k electronic ..... register unit 19 GATEWAY ..... Installation list ... unit 20 ... HIGH BEAM ASSIST ......
torrebasetez
Spain
C?ID=354490
UNIT 09 ..... byte 05 ..... bit 6 active ....... and byte 20 ..... bit 3 active
torrebasetez
Spain
C?ID=354490
http://imgur.com/YyZxUfU
today I entered unit 19 installation list and I marked unit 17 above ... I record and I go out
torrebasetez
Spain
C?ID=354490
https://i.imgur.com/iGSlr1B.jpg
I do scan with vag com and it gives those failures ....... but unit 20 is fine. I drive 100 km and I test High Beam Assist and it works perfect.
torrebasetez
Spain
C?ID=354490
What does not let me select is in unit 19 Gateway ... Installation List ... unit 17 below ... I just record and exit ... I go back in and the two unit 17 are pointed
torrebasetez
Spain
C?ID=354490
I also checked fuses and all well
torrebasetez
Spain
C?ID=354490
Fixed and fixed. The problem was coding. In unit 19 list installation. I get two Unit17, I mark the one below and I mark the one above. I record and go out. I go back in and the two unit17 are selected but really only the one below. I realized when entering the debug folder .. codinglog and see the coding. I have 3000 km and everything works fine. I still don't know why I get two unit 17 and two unit 03 ....
