Hey guys I have the above vehicle that has a Xenon failure,
When you switch the lights on both lamps go on properly and stay on for about a minute,
after that they both Go off simultaneously,
The errors logged dont make sense as it appears 09 central electrics is logging faults for headlamp low beams on both sides even though
this vehicle is fitted with xenon lamps.
this leads me to belive that we are dealing with a faulty coding issue.
So far ive checked that all fuses are in the correct place and of the correct rating as per Erwin VW online.
Ive also measured the powers and grounds (using a power probe) and have full battery voltage and proper ground at the headlight socket .
Has anyone dealt with this before? any input is appriciated
Tuesday,16,July,2019,09:53:43:54859
VCDS Version: 19.6.1.0 HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Euro Tecnik Ltd
VIN: WVWZZZ3CZCE702650 License Plate: KCU 520Y
Mileage: 57230km-35561mi Repair Order: LY Passat CC
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 36 37 42 44 46 4C 4F 52
53 55 56 61 62 6C 72 77
VIN: WVWZZZ3CZCE702650 Mileage: 57230km-35561miles
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 06J 997 027 F HW: 06J 907 309 B
Component: MED17.5.2 05 7706
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 0404000C24070160
Shop #: WSC 27202 001 1048576
VCID: 3828DED47E5EEF77329-806C
U1017 - 015 -
Fault Status: 01101111
Fault Frequency: 19
Mileage: 57083 km
Date: 2013.12.03
Time: 17:38:12
RPM: 704 /min
Load: 13.3 %
Temperature: 101.0°C
Temperature: 66.0°C
Absolute Pres.: 830.0 mbar
Voltage: 12.827 V
P0300 - 000 - - Intermittent
Mileage: 57184 km
Date: 2013.12.05
Time: 20:18:28
RPM: 755 /min
Load: 12.2 %
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 12.573 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent
Mileage: 57184 km
Date: 2013.12.05
Time: 20:18:32
RPM: 785 /min
Load: 13.3 %
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 12.446 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Mileage: 57184 km
Date: 2013.12.05
Time: 20:18:32
RPM: 785 /min
Load: 13.3 %
Temperature: 51.0°C
Temperature: 33.0°C
Voltage: 12.446 V
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 Q HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: CU501506157279
Shop #: WSC 56478 002 1048576
VCID: 3FDAB5C85B70D84FF33-806A
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Fault Frequency: 53
Reset counter: 10
Mileage: 57083 km
Date: 2013.12.03
Time: 17:38:15
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AG HW: 3AA 614 109 AG
Component: J104 C2 450M VD44 0023
Revision: --H07--- Serial number: 00000005208805
Coding: 0001914
Shop #: WSC 05311 000 08193
VCID: 72BC2CFC58A24527CCD-8026
03842 - RPM Sensor Rear Right: Incorrect Signal
Fault Frequency: 77
Reset counter: 63
Mileage: 57083 km
Date: 2013.12.03
Time: 17:38:17
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.75 V
Bin. Bits: 00011111
Count: 157
Hex Value: 0x0000
Fault Frequency: 50
Reset counter: 68
Mileage: 57083 km
Date: 2013.12.03
Time: 17:38:27
Hex Value: 0x0000
Voltage: 12.75 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Part No SW: 3AA 907 044 C HW: 3AA 907 044 C
Component: Climatronic H03 0101
Revision: 00001K01
Coding: 0010002008
Shop #: WSC 00015 115 08193
VCID: 3038E6F49AAE37377A9-8064
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 0465
Revision: BD421001
Coding: 0008000000000000008C0280940009642355000064200D20E484462400C1
Shop #: WSC 05311 123 08193
VCID: 41DEB3302184AEBF857-8014
Subsystem 1 - Part No SW: 3C8 955 119 G HW: 3C8 955 119 G Labels: 1KX-955-119.CLB
Component: WWS464 161111 010 0604
Serial number: 161111
Coding: 00B795
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559 Labels: 7N0-955-559.CLB
Component: RLFS 021 0024
Serial number: Y12M01D04h19m26s25S1
Coding: 0280DD
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 11
Reset counter: 68
Mileage: 57083 km
Date: 2013.12.03
Time: 18:23:30
Voltage: 14.10 V
Fault Frequency: 11
Reset counter: 68
Mileage: 57083 km
Date: 2013.12.03
Time: 18:23:30
Voltage: 14.10 V
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H06 0016
Revision: -------- Serial number: 28261200501936
Coding: 308104
ASAM Dataset: EV_EPHVA18VW47X0000 001005
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3E24C8CC50FAD147F85-806A
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__703 VW10 HI 1918
Revision: 23016000 Serial number: 003K0P086UAG
Coding: 0012339
VCID: 4CC092041AC673D7661-8018
Subsystem 1 - Serial number: 6332MTS612983421
Subsystem 2 - Serial number: 6342MTS633693431
Subsystem 3 - Serial number: 6351HTS6QQ3QU9KJ
Subsystem 4 - Serial number: 6361HTS63ON3V9KJ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Revision: FF010040 Serial number: 20120102301372
Coding: 099A270001
Shop #: WSC 32505 001 1048576
VCID: 6B823198730894EF0FB-803E
Component: E221__MFL-TK6 H06 0022
Coding: E30000
365080 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Fault Frequency: 49
Reset counter: 108
Mileage: 57083 km
Date: 2019.07.13
Time: 18:56:10
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3C8 920 870 K HW: 3C8 920 870 K
Component: KOMBI H04 0609
Coding: 140F01
Shop #: WSC 30001 810 194785
VCID: 3332E9F86BB80C2F07B-8066
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 281111F6000339
Coding: 469007
Shop #: WSC 05314 000 00000
VCID: 3E24C8CC507AD147F85-806A
Fault Status: 00110100
Reset counter: 104
Mileage: 57123 km
Date: 2013.12.04
Time: 15:57:12
03981 - Pause recommendation not available
Fault Status: 01110000
Reset counter: 68
Mileage: 57222 km
Date: 2013.12.05
Time: 21:05:19
Part No SW: 3AA 959 799 A HW: 3AA 959 799 A
Component: IMMO 083 0400
Revision: 00083000 Serial number: VWZCZ000000000
VCID: 46D4A02C04AA8987B05-8012
Component: ELV 029 0380
3C0905861J ELV 029 0380
01176 - Key
Reset counter: 107
Mileage: 57159 km
Date: 2013.12.04
Time: 22:52:44
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661547527
VCID: 290E0B90B9F446FFBD7-807C
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 A HW: 3C8 959 760 A
Component: Sitzmemory H05 2601
Revision: 00H05000
Coding: 000039
VCID: 3332E9F86B380C2F07B-8066
01901 - Lumbar Support Height Adjustment Motor (V229)
Fault Status: 00101100
Reset counter: 105
Mileage: 57083 km
Date: 2013.12.03
Time: 23:08:17
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 D
Component: RNS-MID H61 3970
Revision: AB001001 Serial number: VWZ6Z7M9006110
Coding: 04000402040000A0000F
VCID: 2F3AE588871028CF633-807A
Reset counter: 104
Mileage: 57123 km
Date: 2013.12.04
Time: 15:57:11
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0538
Revision: 12110009 Serial number: 0004140429
Coding: 0013B7
Shop #: WSC 05311 115 08193
VCID: 6D863F804D1C9ADF11F-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000002646374
Coding: 010090
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 205 3301
Revision: 00H22000
VCID: 3536D7E0694C121F29F-8060
Fault Status: 11100101
Mileage: 57083 km
Date: 2013.12.03
Time: 17:38:60
Battery Volts: 12.7 V
DU
Temperature: 71.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Fault Status: 11101101
Reset counter: 63
Mileage: 57083 km
Date: 2013.12.03
Time: 17:39:01
Voltage: 12.63 V
DU
Temperature: 71.0°C
RPM: 758 /min
Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
Component: 09 KESSY PQ47 083 0341
Coding: 01900A0001C60E76360494157200DFCE1058011324379C
Component: Neigungssensor 004 0611
Subsystem 4 - Part No: 3AA 962 243
Component: GEB.F.Heckoef 0719
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1623
Coding: 00000008
VCID: 6FBA2588479068CF233-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0003
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0538
Revision: 14110009 Serial number: 0004155828
Coding: 0013B6
VCID: 6E84388C401A61C7285-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000002635502
Coding: 010090
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000576312
Coding: 0022157
Fault Status: 01101101
Reset counter: 68
Mileage: 56412 km
Date: 2013.11.16
Time: 14:13:05
Voltage: 12.30 V
Count: 105
Hex Value: 0x12E3
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 071600000B000200
VCID: 372ADDE87FC0E00F3B3-8062
Subsystem 1 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 350000
Subsystem 2 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 350000
5277959 - Swivel Module Left
C1089 07 [009] - Mechanical Failure
Reset counter: 63
Mileage: 57083 km
Date: 2019.07.13
Time: 18:11:36
9574144 - Bulb for Low Beam Headlamp Left
B1217 00 [009] - -
Fault Frequency: 25
Reset counter: 68
Mileage: 57083 km
Date: 2019.07.13
Time: 17:48:01
9574400 - Bulb for Low Beam Headlamp Right
B1218 00 [009] - -
Fault Frequency: 28
Reset counter: 68
Mileage: 57083 km
Date: 2019.07.13
Time: 17:48:00
13705987 - Databus
U1123 00 [137] - Received Error Message
[Fehlerwert im Signal BR3_Rad_kmh_HR]
Fault Frequency: 49
Reset counter: 68
Mileage: 57083 km
Date: 2019.07.13
Time: 17:39:11
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 104
Mileage: 57123 km
Date: 2013.12.04
Time: 15:57:11
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1623
Coding: 03260858
VCID: 71BE23F051A47E3F357-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900448277
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C8 907 441 A HW: 3C8 907 441 A
Component: J772__Rearview 0140
Revision: 00H10000 Serial number: 525PA8-J1Z9072
Coding: 0020008
VCID: 28080E94AEFE7FF7A29-807C
Part No SW: 5K0 035 730 A HW: 5K0 035 730 A
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007661430221
Coding: 0201000000010110
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 231219B8DB589CAFF7B-8076
0022 - Radio
U1066 00 [000] - No Communication
[Steuergerät Radio (RNS): kein Signal/Kommunikation]
End----------(Elapsed Time: 02:09, VBatt start/end: 12.1V/12.1V)-----------
