Tuesday,23,July,2019,12:03:04:36901
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ6RZHY184359 License Plate: LS17 VVN
Mileage: 30060km-18678mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 02 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZHY184359 Mileage: 30060km-18678miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 LH HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 3855
Revision: R4H23---
Coding: 01250032232411080000
Shop #: WSC 04275 002 1048576
ASAM Dataset: EV_ECM12TFS01104E906027LH 001001
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: 75B611F3954834FFE9F-8020
CAN Converter 01:
Part No SW: 0CW 300 040 L HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1003
Revision: 00005026 Serial number: CU501706217169
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW26.rod
VCID: 3D26C9D3EDF8ACBFE1F-8068
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 R HW: 6R0 907 379 BA
Component: ESP9.0i H04 0006
Serial number: 08501618170114
Coding: 23DD2885892B33C41117106E005AC41491CC88080005CB098F00
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
VCID: 3E24CEDFE0FEB7A7F85-806A
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 G HW: 6C0 820 045 G
Component: AC Manuell H03 0204
Serial number: 1612201B-0292
Coding: 200100001100100000
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 23121FAB6B5CFA4FF7B-8076
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [012] - -
Reset counter: 151
Mileage: 29849 km
Date: 2019.07.14
Time: 23:30:25
Voltage terminal 30: 14.1 V
Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0094
Serial number: 006308322249
Coding: 0300184042130A7B0F244080B12703C810005B0257010000000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 313EE5E321A058DF757-8064
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S2Y17M01D03H19M32S30
Coding: 0038DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 DM HW: 6R0 959 802 DM Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0620
Serial number: KU0KU004011770041708
Coding: 1400A1
Subsystem 3 - Part No SW: 6R0 959 801 DK HW: 6R0 959 801 DK Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0620
Serial number: KU0KU004011770046179
Coding: 0400A1
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY163482NG7
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000036740388
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39361700905979
Coding: 0031051011
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 43D2BF2B8B1CDA4F97B-8016
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00B 002 0380
Revision: -------- Serial number: 003TH00FB380
Coding: 88C0C000000000005C000000008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A2CC2CFFCD69B87C4D-806E
Subsystem 1 - Part No SW: ----------- HW: 410 821 912 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00A3233EFA4422N
Subsystem 2 - Part No SW: ----------- HW: 410 821 912 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A122D3D4310DH
Subsystem 3 - Part No SW: ----------- HW: 442 151 501 17
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A000C2A5195AC67J
Subsystem 4 - Part No SW: ----------- HW: 442 151 501 17
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00122A52B3636A2
Part No SW: 6C0 920 940 G HW: 6C0 920 940 G
Component: KOMBI 202 2310
Coding: 232401082180260001082A001000000000000000
Shop #: WSC 12345 123 61029
VCID: 28080887127A1917A29-807C
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006308322249
Coding: 030100046F0A560071000000000000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 261406BF186E0F67905-8072
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 0171715560401697AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 53356954595881079205
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AJ HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3242
Serial number: CH1B1288
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 71BE25E3E12018DF357-8024
Part No SW: 3Q0 035 842 B HW: 3Q0 035 842 B
Component: MU-S-D-ER H30 0359
Serial number: VWZAZ2S0740188
Coding: 02620000BE00000051110101008808001F0100C60120010003
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2C00F49706823537461-8078
Subsystem 1 - Part No SW: 6C0 919 603 B HW: 6C0 919 603 B
Component: ABTm_Std2 H53 1031
Serial number: VWZ8Z9TKW029FE
End----------(Elapsed Time: 00:54, VBatt start/end: 13.3V/13.2V)-----------
