Results 1 to 9 of 9
Thread: RHD to lhd 6r polo rear lights
    Apr 2019
    Hi I have changed the rear lights to LHD ones but the rear fog and reversing lights are on the wrong sides. I have found the long code to change from 'RHD long code 0300184042130A7B0F244080B12703C810005B025701 If I change it to LHD long code 0000184042130A7B0F244080B12703C810005B025701 will that do the trick?
    Justin
    Can't answer that without seeing a full unedited VCDS Auto-Scan
  3. Likes Uwe liked this post
    Apr 2019
    Tuesday,23,July,2019,12:03:04:36901
    VIN: WVWZZZ6RZHY184359   License Plate: LS17 VVN
    Mileage: 30060km-18678mi   Repair Order:
    Chassis Type: 6R-VW26 (6C0)
    Scan: 01 02 03 08 09 10 15 17 19 44 5F
    VIN: WVWZZZ6RZHY184359   Mileage: 30060km-18678miles
    Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 LH    HW: 04E 907 309 AF
       Component: R4 1.2l TFS   H23 3855
       Revision: R4H23---
       Coding: 01250032232411080000
       Shop #: WSC 04275 002 1048576
       ASAM Dataset: EV_ECM12TFS01104E906027LH 001001
       ROD: EV_ECM12TFS01104E906027BB.rod
       VCID: 75B611F3954834FFE9F-8020
       CAN Converter 01:
       Part No SW: 0CW 300 040 L    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1003
       Revision: 00005026    Serial number: CU501706217169
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW26.rod
       VCID: 3D26C9D3EDF8ACBFE1F-8068
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
       Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
       Component: ESP9.0i       H04 0006
       Serial number: 08501618170114
       Coding: 23DD2885892B33C41117106E005AC41491CC88080005CB098F00
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 3E24CEDFE0FEB7A7F85-806A
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6C0 820 045 G    HW: 6C0 820 045 G
       Component: AC Manuell    H03 0204
       Serial number:  1612201B-0292
       Coding: 200100001100100000
       ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
       ROD: EV_ACManueKMMValeoPQ26.rod
       VCID: 23121FAB6B5CFA4FF7B-8076
    1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
              B10F0 00 [012] - -
                        Reset counter: 151
                        Mileage: 29849 km
                        Date: 2019.07.14
                        Time: 23:30:25
                        Voltage terminal 30: 14.1 V
                        Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 D    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H10 0094
       Serial number: 006308322249
       Coding: 0300184042130A7B0F244080B12703C810005B0257010000000000000000
       ASAM Dataset: EV_BCMA0 006002
       ROD: EV_BCMA0_006_VW26.rod
       VCID: 313EE5E321A058DF757-8064
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  042 0105
       Serial number: S2Y17M01D03H19M32S30
       Coding: 0038DD
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 6R0 959 802 DM    HW: 6R0 959 802 DM  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 0620
       Serial number: KU0KU004011770041708
       Coding: 1400A1
       Subsystem 3 - Part No SW: 6R0 959 801 DK    HW: 6R0 959 801 DK  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 0620
       Serial number: KU0KU004011770046179
       Coding: 0400A1
       Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY163482NG7
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000036740388
       Revision: --------    Serial number: 39361700905979
       Coding: 0031051011
       ROD: EV_EPHVA18AU3700000_VW26.rod
       VCID: 43D2BF2B8B1CDA4F97B-8016
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
       Component: VW20Airbag00B 002 0380
       Revision: --------    Serial number: 003TH00FB380
       Coding: 88C0C000000000005C000000008800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3A2CC2CFFCD69B87C4D-806E
       Subsystem 1 - Part No SW: -----------    HW: 410 821 912 16
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00A3233EFA4422N
       Subsystem 2 - Part No SW: -----------    HW: 410 821 912 16
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00A122D3D4310DH
       Subsystem 3 - Part No SW: -----------    HW: 442 151 501 17
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A000C2A5195AC67J
       Subsystem 4 - Part No SW: -----------    HW: 442 151 501 17
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00122A52B3636A2
       Part No SW: 6C0 920 940 G    HW: 6C0 920 940 G
       Component: KOMBI         202 2310
       Coding: 232401082180260001082A001000000000000000
       Shop #: WSC 12345 123 61029
       VCID: 28080887127A1917A29-807C
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901 A    HW: 6C0 937 089
       Component: GW MQB A0     H10 0094
       Revision: --------    Serial number: 006308322249
       Coding: 030100046F0A560071000000000000010001010000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 013020
       ROD: EV_GatewA0Lear_013_VW26.rod
       VCID: 261406BF186E0F67905-8072
       Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
       Serial number: 0171715560401697AD1B
       Coding: 280000
       Subsystem 2 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
       Component: J367-BDM  H08 0270
       Serial number: 53356954595881079205
    Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
       Part No SW: 6C2 909 144 AJ    HW: 6C2 909 144 D
       Component: EPS_TRW_ALow  323 3242
       Serial number: CH1B1288
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 71BE25E3E12018DF357-8024
       Part No SW: 3Q0 035 842 B    HW: 3Q0 035 842 B
       Component: MU-S-D-ER     H30 0359
       Serial number: VWZAZ2S0740188
       Coding: 02620000BE00000051110101008808001F0100C60120010003
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 2C00F49706823537461-8078
       Subsystem 1 - Part No SW: 6C0 919 603 B    HW: 6C0 919 603 B
       Component: ABTm_Std2  H53 1031
       Serial number: VWZ8Z9TKW029FE
    End----------(Elapsed Time: 00:54, VBatt start/end: 13.3V/13.2V)-----------
  5. Likes Uwe liked this post
    Jun 2014
    Swansea, UK
    This may be a silly question, but when you say the lights are on the wrong sides, what do you mean?
    Are you converting a RHD car to drive on LHD roads abroad, but the wrong bulbs are being lit, or are you retro-fitting lights that came from a LHD car onto a RHD car, to continue using it in the UK?
  7. Likes Uwe liked this post
  8. #5
    Apr 2019
    I live in Spain. It is a RHD car. The reversing light and rear fog opposite. I have fitted LHD rear lights but now the reversing light is red and the fog white.
  9. #6
    Quote Originally Posted by justinmart View Post
    So is the reversing light still on the left and the fog light still on the right?
  10. #7
    May 2014
    justin: Like Dave, I'm a little confused too
    As far as the operation of the 2 x lamps is concerned- these are managed by Leuchte-commands. To swap the lamps, try this (in adaptation, in the BCM):
    • For the Reversing light - ONLY if ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28 has the value Rueckfahrlicht - change to NebelschlusslichtwennkeinAnhaengergestecktundRecht sverkehr
    • For the rear fog light - ONLY if ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26 has the value NebelschlusslichtwennkeinAnhaengergestecktundRecht sverkehr -change to Rueckfahrlicht
  11. Likes Uwe, PetrolDave, Mike@Gendan liked this post
  12. #8
    Apr 2019
    Hi Don, Just tried to change codes but failed because lack of security access code any idea where to find the code?
    Justin
  13. #9
    Try to press the button [Security Access-16], it should pop up.
  14. Likes Uwe liked this post
