Renew KESSY ecu
andy_911
Austria
C?ID=149628
Hy, does anybody of you know if it's possible to do the necessary coding and adaption to renew the kessy ecu from a VW Sharan with VCDS?
This is the car I mean
Monday,15,July,2019,18:39:49:24421
VIN: VSSZZZ7NZGV708020   License Plate:
Mileage: 151660km-94237mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 25 2B 36 3C 42 44 46
          4C 4F 52 53 55 5F 61 62 69 6C 6D 72 A5 BE BF
VIN: VSSZZZ7NZGV708020   Mileage: 151660km-94237miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CUWA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 CK    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1737
   Revision: 8AH20---
   Coding: 011D001A047401083000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_ECM20TDI01104L906016CK 001004
   ROD: EV_ECM20TDI01104L906016BJ_001_VW36.rod
   VCID: 74B02B69AE3ED9F7DE1-8020
   Part No SW: 02E 300 063 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4902
   Revision: 06253104    Serial number: 00001507232976
   Shop #: WSC 44551 111 44551
   VCID: 167431E194826BE7005-8042
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CG    HW: 5N0 614 109 CK
   Component: ESC-EBC460iV1 H10 0013
   Serial number: A01BURS
   Coding: 12F0449A0920C2740877480222C39043103917F8F00B4895
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 72BC2D71D42AD7C7CCD-8026
   Revision: 00092000    Serial number: 0375621325
   Coding: 03100C
   Shop #: WSC 00020 999 39850
   VCID: 372ADC65FFC872EF3B3-8062
   Part No SW: 7N0 907 044 AC    HW: 7N0 907 044 AC
   Component: Clima-Sharan  H02 0606
   Revision: 00001K04
   Coding: 021010C549
   Shop #: WSC 00020 999 00000
   VCID: 71BE227DD12CECDF357-8024
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20150817000000016318
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 60590A3B892508C4508800C8B400897403D50008676D2DB26484C720A2C1
   Shop #: WSC 00020 790 00000
   VCID: 45D6A6ADB5A4107FB9F-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 110715  024 0644
   Serial number: 15070906072131
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S2Y15M09D08H00M15S01
   Coding: 0228BB
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331524102160
   Coding: 0071155211
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   VCID: 3634D161F8C28BE7205-8062
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 17111577091554
   Coding: 00001900FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3536D66DE5C480FF29F-8060
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag10X H15 0016
   Serial number: 003PWPHJML0Z
   Coding: 003058
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40D8B7B9AA0635578A9-8014
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS60DA6FB11B9DE
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS605DEDB41B9DA
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS600D8BB21B9D$
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60B5E7B11B9D1
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS6094A8A31BDDX
   Part No SW: 5K0 953 501 DQ    HW: 5K0 953 569 AP
   Revision: FF010042    Serial number: 20150902100965
   Coding: 3112A40000
   VCID: 7CA00349866E91B7961-8028
   Subsystem 1 - Part No SW: 7N5 919 719     HW: 7N5 919 719   Labels: 3C8-959-537.CLB
   Serial number: 000000000B0049300715
   Coding: 011000
   Part No SW: 7N5 920 880 A    HW: 7N5 920 880 A
   Component: KOMBI         H04 1007
   Coding: 140F010000
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 G
   Component: Standheizer     051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0001042
   VCID: 3828DF59FE567D97329-806C
02245 - Connection; RF Remote Control
                    Reset counter: 31
                    Mileage: 151629 km
                    Date: 2019.07.15
                    Time: 01:43:14
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 230815F1001301
   Coding: 468232
   Shop #: WSC 00020 790 12345
   VCID: 72BC2D71D4AAD7C7CCD-8026
   Component: IMMO          H04 1007
   Coding: 000007
   VCID: 6A8C3511FCFA1F0774D-803E
   Revision: 00000000    Serial number: 15000190810005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3038E7791AA6A5D77A9-8064
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 F    HW: 3C8 959 760 F
   Component: Sitzmemory    H02 1301
   Revision: 00H02000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 3828DF59F2567D97329-806C
   Component: HRE_Master    H11 0071
   Serial number: 0378307517
   Coding: 02011102
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C20C349C6EE51B7D61-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0378415333
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H04 0561
   Revision:             Serial number: 0000163734024
   Coding: 01112F209E00411001
   VCID: 49CEAA9D99BCF41F5D7-801C
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.325 1401
   Revision: 1BH04739    Serial number: 00152040223701
   Coding: 0000258
   Shop #: WSC 00046 000 00000
   VCID: 41DEB2BDAD8C3C5F857-8014
   Component: EZE_2         H56 1663
   Coding: 050B0501
   VCID: 6FBA2405C798FA2F233-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H04 0561
   Revision:             Serial number: 0000163681524
   Coding: 01112D209E00411001
   VCID: 48C8AF9982B60D17429-801C
   Component: AFS-ECU       H05 0111
   Coding: 068200000B000000
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 7N5 035 680 B    HW: 7N5 035 680 B
   Component: MU-S-N-ER     H20 0240
   Serial number: SEZAZ2R0241952
   Coding: 04240801FF00000011110001000808001F0100840020010086
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 323CED7114AA97C70CD-8066
   Subsystem 1 - Part No SW: 5F0 060 884 BN    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Component: Batt.regelung H56 1663
   Coding: 030F7873
   VCID: 71BE227DD1ACECDF357-8024
   Component: J367-BDM  H07 0180
   Serial number: 42242M55401491566675
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H02 0561
   Revision:             Serial number: 0000163856216
   Coding: 01006D200000411001
   VCID: 4CC0938996CEE137661-8018
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00008130005327
   Coding: 410C040001000000
   Shop #: WSC 00049 770 00119
   VCID: 73B22875ABB0DECFC7B-8026
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012301000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 222500791
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B22C055C3E0568FDFB-806E
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H02 0561
   Revision:             Serial number: 0000163856444
   Part No SW: 3Q0 980 654     HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0010
   Serial number: 24081511P10705
   Coding: 0304020800000401002613068080400090000E100020
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 15334958
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 3828DF59F2D67D97329-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 15335197
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:09, VBatt start/end: 12.7V/12.4V)-----------
Thank's for your ideas!
"Renew" means replace?
If so, no. Not with VCDS.
andy_911
Austria
C?ID=149628
Yes I mean replace ...
I will retrofit the easy open function of the tailgate.
For that i have to change the kessy ecu to a type that supports this function (5K0 959 434H)
Spacewalker
Poland
C?ID=159607
install new
re-learn keys in dealer or any other supporting tool ... and bingo
Moving to Retrofits.
golfi_vend
Tartu, Estonia
C?ID=195131
You might need parameters to be loaded which can't be done with vcds nor odis because odis will reject because of being incorrect part to car.
andy_911
Austria
C?ID=149628
Do you think it's not possible to change the kessy ecu?
There must be a way to do so, I think I've read about the possibility to retrofit the easy open function. They wrote that the kessy ecu is different and needs to be changed - there must be a way to do so.
I'll try the next days. I'll keep you up to date ;-)
