'14 Audi A7 - programming ABS module for Auto Hold feature, coding rejected error 13!
acr89
C?ID=375277
Hello, I'm attempting to activate auto brake hold on my 2014 Audi A7 with the instructions in this thread: https://www.audizine.com/forum/showthread.php/844428-A7-C7-Auto-Hold-Retrofit
I have my new auto hold button installed in my 2014 A7 TDI, and have used my newly purchased VCDS to successfully implement various other mods, but can't get the car to accept the coding...I use the security code 10505 successfully, and double/triple checked my coding.
Current coding:
27A79703E4E5E9C05B00
New coding:
27A79703E4E5E9C09B00
I keep getting the following error:
"Coding rejected
Error 13: incorrect message length or invalid format"
The code length and format are exactly the same as before, except it's 9B in place of 5B. I also tried 7B and DB to see if those would work, to try and rule out just 9B being unacceptable, but no dice. Any ideas how I can make this work?
 Thursday,18,July,2019,13:14:57:10396
VIN: WAU2MAFC4EN075702   License Plate: B2KZYUPDATED
Mileage: 97117km-60345mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
VIN: WAU2MAFC4EN075702   Mileage: 97117km-60345miles
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0013
   Revision: 58H14---
   Coding: 1A2A4012056601050000
   Shop #: WSC 04251 003 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401N 002013
   ROD: EV_ECM30TDI0114G0907401N_002.rod
   VCID: 2E050EF70095CCB7685-807A
   Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H16 1008
   Revision: --H16---
   Coding: 000001
   VCID: 3C2134BFC6E92E27D61-8068
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Coding: 27A79703E4E5E9C05B00
   VCID: 3B2337A3C3E7291FDFB-806E
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Ldm_ApbFailureState]
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:11:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 20
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: 9B
0690 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SCL_EPB_Schalterposition_Error]
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:11:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 20
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 02
                    Uz: 9B
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 DR
   Component: BCM2 2.0      H35 0510
   Coding: 0DAA2046000000000000
   VCID: 7CA1F4BF86E9EE27961-8028
   Serial number: 0213000333256003
   Part No SW: 4G0 820 043 AF    HW: 4G0 820 043 AF
   Component: KLIMA 4 ZONEN H13 0088
   Serial number: 11101300040036
   Coding: 3603207A4D
   ASAM Dataset: EV_AirCondiComfoUDS 002043
   VCID: 6393AFC31BD731DFB7B-8036
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 223
                    Mileage: 96408 km
                    Date: 2019.06.25
                    Time: 00:00:22
                    Voltage terminal 30: 11.82 V
   Revision: 11012002    Serial number: 00000001490129
   Coding: 02002091163C9FE2C1008884A0003928CF9CD208A6080225800008406000
   VCID: 6FBBD3F3C79F85BF233-803A
   Component: WWS57X 131001  H36 0080
   Serial number:         131007220434
   Coding: 0045F7
   Serial number: 21845516
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 15 10 2013  00000255
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R81V903
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0078084152
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106971000004944846
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 529842D6000000000001
                    Reset counter: 223
                    Mileage: 96505 km
                    Date: 2019.06.27
                    Time: 09:29:00
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 223
                    Mileage: 96505 km
                    Date: 2019.06.27
                    Time: 09:29:00
   Revision: 11001001    Serial number: 61061328802111
   Coding: A8EB04
   VCID: 71BFD58BD12B934F357-8024
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 2809F8EF22719287A29-807C
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_EPB_FAIL]
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 11.326 V
                    Velocity_vehicle_reference: -0.01 m/s
131328 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_EPB_SWITCH_FAIL]
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8003K6W%
   Coding: 303145313131303031304A55304C34473853
   VCID: 33331F83EBB7E15F07B-8066
   Serial number: 6940000Y130000Y0440D
   Serial number: 3575HRB400S50KMKFHMD
   Serial number: 3585HRB400O50N20FOTU
   Serial number: 3515JRB401850NQIE8NT
   Serial number: 3525JRB401850NQICPDZ
   Serial number: 3554VRB400450NI2H0L8
   Serial number: 3564VRB400450NI2N936
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372MJG00078
   Coding: 0000DC
   VCID: 372B2B93FF4F0D7F3B3-8062
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 27 06 2013  C1088028
   Part No SW: 4G8 920 984 A    HW: 4G8 920 984 A
   Component: TDieUsaAccNv  H58 0621
   Revision: 29460233    Serial number: 658161013596006
   Coding: 0BC702060F53D705020100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 34311C9FEEB9E6671E1-8060
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001134025
   Coding: 00CD077D00
   VCID: 72BDDA87D42DA857CCD-8026
   Serial number: 8336371603
   Voltage stabilizer:
   Serial number: 1308210000000000031E
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 221
                    Mileage: 96408 km
                    Date: 2019.06.25
                    Time: 00:00:10
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 38 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0088
   Serial number: 16101300041237
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
   VCID: 36352697F8C5F477205-8062
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Revision: AA000000    Serial number: 00000078114735
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 382928AFF2510207329-806C
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA82056P2%
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0060
   Revision: 00H04000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: 36352697F445F477205-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H04 0060
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F16.10.1300H04000AMS14555ÿ
   Subsystem 4 - Serial number: S14555ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F57025E00628002000413
   VCID: 45D7515BB5A36FEFB9F-8010
   Component: RCEPS         H39 0010
   Revision: 00001000    Serial number: 0015953756
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1A8714ADE8570CD-8066
   Revision: 00002001    Serial number: 0318001413
   Coding: 0126063A20FAF08580A00A8402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000184890
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO23954715
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00005100188
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA107207000005344526
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93071471
03394 - Play protection for rear spoiler adjustment active
                    Reset counter: 221
                    Mileage: 96408 km
                    Date: 2019.06.25
                    Time: 21:45:37
   Revision: CJ007001    Serial number: 00000000041576
   Coding: 030000
   VCID: 1D67D93B7DB3472FC1F-8048
03405 - Bass Loudspeaker
                    Fault Status: 00111011
                    Fault Frequency: 83
                    Reset counter: 231
   Coding: 011F57025E00628002000402
   VCID: 46D5565788A564F7B05-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000845860
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C0104FF3689BEA7461-8078
131840 - Switch for Electric Parking Brake
          C100C 13 [008] - Open Circuit
                    Reset counter: 190
                    Voltage terminal 30: 12.1 V
                    Internal Fault ID: 34
                    Vehicle speed: 510 km/h
                    Network management state: Reset
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: Emergency running mode
                    Status of parking brake button: Open circuit
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 131013-0004-089
   Coding: 1223A633701AA500
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156JC0D7922699
   Coding: 020007010000000001
   VCID: 2411ECDF5ED976E78E1-8070
   Part No SW: 4G0 035 746 E    HW: 4G0 035 746 E
   Component: H-BNT-NA      H40 0735
   Revision: --------    Serial number: 194J+0D7560073
   Coding: 090200040003E9EF7D12CB3E00000003100001000000000000
   VCID: 290FFDEB39FBAB8FBD7-807C
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD002THD3
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Serial number: 90349MJL000K9
   Component: CD-Database  5298
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 221
                    Time Indication: 15
                    Voltage: 11.90 V
   Coding: 010F17024000628002000002
   VCID: 49CF5D6B99BB8B8F5D7-801C
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0111708
   Coding: 0205000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007_AU57.rod
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 261300714
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 44D14C5FBE1956E7AE1-8010
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F6D7286584F7905-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X_002.rod
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 11.539 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000121110137
   Coding: 03C198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F158B11ABD34F757-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 131980421
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B0307E33387B99F4FB-807E
End----------(Elapsed Time: 02:58, VBatt start/end: 13.7V/14.1V)-----------
downtime
C?ID=280813
This is your issue :
                    Reset counter: 190
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
Fix this and you will be able to code the ABS module.
PetrolDave
Westbury, UK
C?ID=1423
Since that's an intermittent fault with a fault frequency of 1 try just clearing it and see if it comes back...
And if it doesn't then try your coding change again.
acr89
C?ID=375277
Thanks, will try clearing that. If clearing it doesn’t fix the issue - would it indicate that the part needs to be replaced?
PetrolDave
Westbury, UK
C?ID=1423
No, there may be a wiring problem - don't just assume that all faults are caused by "parts", very often there are other causes.
acr89
C?ID=375277
I cleared the fault codes on both the ABS and the Parking Brake, still got same coding rejected error. I then turned off and restarted the car, and still coding rejected. Any other ideas?
downtime
C?ID=280813
Can you please post an autoscan after you cleared the faults so we'll see what faults are still active?
Are you absolutely sure the autohold wiring is correctly installed? Because if the button is not correctly wired it will reject the coding.
Dana
Western PA, USA
Please do check the wiring per the above suggestions but I have a SA code question and suggestion.
1) 10505 is a known ABS SA code (Don has that listed in this thread) however we don't have the function documented. For that reason it would be helpful if you could confirm that was accepted, rather than a typo or incorrect copy/paste, so I can add it as a note to the label file.
2) I would firstly see if this 03 controller will allow you to copy and paste the factory original coding string back into the module:
  • Without a SA code at all.
  • With SA code 61378.
  • With SA code S11820. The letter S must be upper case.
Depending on those results, I would use the SA code that allowed re-coding to the same value to try entering the modified coding after you double checked the wiring to see if something like SA S11820 was all this controller needed before it would cooperate.
acr89
C?ID=375277
Thanks Dana. Will try that next week once I'm back home. The Auto Hold button is a documented "plug and play" mod with the C7/C7.5 A7 and A6 cars, no need to modify or add wiring. The Audizine thread I posted has many C7/C7.5 Audi owners who installed this button with no wiring mods. I will double check though that the plug is fully seated. The parking brake works just fine so I think the plug is seated.
1. Confirmed, 10505 SA was accepted. 61378 didn't work in my car.
2. I'll try these next week. Thanks for the help.
New autoscan is below after I cleared the faults, in case this provides any help:
Friday,19,July,2019,10:20:57:10396
VIN: WAU2MAFC4EN075702   License Plate: B2KZYAFTERCODESCLEARED
Mileage: 97277km-60445mi   Repair Order:
VIN: WAU2MAFC4EN075702   Mileage: 97277km-60445miles
   Revision: 58H14---
   Revision: --H16---
   Coding: 000001
   Coding: 3603207A4D
          P150A 00 [008] - -
                    Reset counter: 223
                    Mileage: 96408 km
                    Date: 2019.06.25
                    Time: 00:00:22
   Coding: 0045F7
   Coding: 02006E
   Coding: 853000
   Coding: 020300
                    Reset counter: 223
                    Mileage: 96505 km
                    Date: 2019.06.27
                    Time: 09:29:00
                    Reset counter: 223
                    Mileage: 96505 km
                    Date: 2019.06.27
                    Time: 09:29:00
   Coding: A8EB04
   Coding: 7E01010201
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
   Coding: 0000DC
   Coding: 00CD077D00
   Voltage stabilizer:
                    Reset counter: 221
                    Mileage: 96408 km
                    Date: 2019.06.25
                    Time: 00:00:10
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 0000007
   Coding: 101F00
                    Reset counter: 221
                    Mileage: 96408 km
                    Date: 2019.06.25
                    Time: 21:45:37
   Coding: 030000
                    Fault Frequency: 98
                    Reset counter: 232
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
                    Reset counter: 221
                    Time Indication: 15
                    Voltage: 11.90 V
   Coding: 0A3305C102
   Coding: 6A060000
   Coding: 7E01010201
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
          U1113 00 [008] - -
                    Reset counter: 230
                    Mileage: 97106 km
                    Date: 2019.07.17
                    Time: 18:13:55
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:52, VBatt start/end: 14.2V/14.2V)-----------
acr89
C?ID=375277
Security code S11820 did the trick and my auto hold feature is working! Thanks for the help. Weird that 10505 was accepted as a security code but wouldn’t let me change the coding.
Dana
Western PA, USA
Glad to hear that worked out!
Although this is speculation, 10505 might unlock a specific Adaptation channel or Basic Setting. Either way, I'll add that as an internal note to our label file so we can recommend it to anyone with non-Coding related ESP PREMIUM problems in the future.
Edmontonrs
Edmonton, AB, Canada
C?ID=415856
I have a 2015 Audi RS7 C7.
I have added the new auto hold emergency brake switch and did the above coding but the auto switch doesn’t power up. The E brake works manually. I would assume if the Ebrake has power to that part of the switch the switch is powered up through the plug.
S11820 worked for the SA code. Checked by bits and modified as instructed. Worked out to be 4B to 9B and I did check the code and converted not copy.
Any thoughts on how the switch should turn on? From videos I see it’s supposed to light up.
no codes or faults in VCDS.
Thank you,
Dana
Western PA, USA
Thank you,
I think you might have tweaked the incorrect bits in Byte 8 based on the OP's before / after coding info. Please post the complete Auto-Scan prior to coding in addition to the current condition scan if this isn't resolved.
