Results 1 to 10 of 11
Thread: '14 Audi A7 - programming ABS module for Auto Hold feature, coding rejected error 13!
    Jul 2019
    Hello, I'm attempting to activate auto brake hold on my 2014 Audi A7 with the instructions in this thread: https://www.audizine.com/forum/showt...-Hold-Retrofit
    I have my new auto hold button installed in my 2014 A7 TDI, and have used my newly purchased VCDS to successfully implement various other mods, but can't get the car to accept the coding...I use the security code 10505 successfully, and double/triple checked my coding.
    Current coding:
    27A79703E4E5E9C05B00
    New coding:
    27A79703E4E5E9C09B00
    I keep getting the following error:
    "Coding rejected
    Error 13: incorrect message length or invalid format"
    The code length and format are exactly the same as before, except it's 9B in place of 5B. I also tried 7B and DB to see if those would work, to try and rule out just 9B being unacceptable, but no dice. Any ideas how I can make this work?
     Thursday,18,July,2019,13:14:57:10396
    VIN: WAU2MAFC4EN075702   License Plate: B2KZYUPDATED
    Mileage: 97117km-60345mi   Repair Order:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
              52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
    VIN: WAU2MAFC4EN075702   Mileage: 97117km-60345miles
    Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
       Component: 3.0TDI FSA    H14 0013
       Revision: 58H14---
       Coding: 1A2A4012056601050000
       Shop #: WSC 04251 003 1048576
       ASAM Dataset: EV_ECM30TDI0114G0907401N 002013
       ROD: EV_ECM30TDI0114G0907401N_002.rod
       VCID: 2E050EF70095CCB7685-807A
       Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
       Component: 0BK 30 TDIUSA H16 1008
       Revision: --H16---
       VCID: 3C2134BFC6E92E27D61-8068
       Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
       Component: ESP PREMIUM   H09 0450
       Coding: 27A79703E4E5E9C05B00
       Shop #: WSC 02391 785 00200
       VCID: 3B2337A3C3E7291FDFB-806E
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Ldm_ApbFailureState]
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:11:32
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 20
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 08
                        Uz: 9B
    0690 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SCL_EPB_Schalterposition_Error]
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:11:32
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 20
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 02
                        Uz: 9B
       Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 DR
       Component: BCM2 2.0      H35 0510
       Coding: 0DAA2046000000000000
       VCID: 7CA1F4BF86E9EE27961-8028
       Serial number: 0213000333256003
       Part No SW: 4G0 820 043 AF    HW: 4G0 820 043 AF
       Component: KLIMA 4 ZONEN H13 0088
       Serial number: 11101300040036
       Coding: 3603207A4D
       ASAM Dataset: EV_AirCondiComfoUDS 002043
       VCID: 6393AFC31BD731DFB7B-8036
    0276 - Engine Off Timer Performance
              P150A 00 [008] - -
                        Reset counter: 223
                        Mileage: 96408 km
                        Date: 2019.06.25
                        Time: 00:00:22
                        Voltage terminal 30: 11.82 V
       Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
       Revision: 11012002    Serial number: 00000001490129
       Coding: 02002091163C9FE2C1008884A0003928CF9CD208A6080225800008406000
       VCID: 6FBBD3F3C79F85BF233-803A
       Component: WWS57X 131001  H36 0080
       Serial number:         131007220434
       Coding: 0045F7
       Serial number: 21845516
       Coding: 02006E
       Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
       Component: E1 - LDS  H07 0044
       Serial number: 15 10 2013  00000255
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R81V903
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0078084152
       Coding: 853000
       Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA106971000004944846
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 529842D6000000000001
                        Reset counter: 223
                        Mileage: 96505 km
                        Date: 2019.06.27
                        Time: 09:29:00
    01229 - A/C Humidity Sensor (G260)
                        Reset counter: 223
                        Mileage: 96505 km
                        Date: 2019.06.27
                        Time: 09:29:00
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Revision: 11001001    Serial number: 61061328802111
       Coding: A8EB04
       VCID: 71BFD58BD12B934F357-8024
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Coding: 7E01010201
       VCID: 2809F8EF22719287A29-807C
    105984 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_EPB_FAIL]
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
                        Control Module temperature: 37 °C
                        Voltage terminal 15: 11.326 V
                        Velocity_vehicle_reference: -0.01 m/s
    131328 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_EPB_SWITCH_FAIL]
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
    140288 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_ECD_FAIL]
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H33 0033
       Revision: --------    Serial number: 003D8003K6W%
       Coding: 303145313131303031304A55304C34473853
       VCID: 33331F83EBB7E15F07B-8066
       Serial number: 6940000Y130000Y0440D
       Serial number: 3575HRB400S50KMKFHMD
       Serial number: 3585HRB400O50N20FOTU
       Serial number: 3515JRB401850NQIE8NT
       Serial number: 3525JRB401850NQICPDZ
       Serial number: 3554VRB400450NI2H0L8
       Serial number: 3564VRB400450NI2N936
       Revision: --------    Serial number: 90372MJG00078
       Coding: 0000DC
       VCID: 372B2B93FF4F0D7F3B3-8062
       Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
       Component: E221 - MFL  H09 0010
       Serial number: 27 06 2013  C1088028
       Part No SW: 4G8 920 984 A    HW: 4G8 920 984 A
       Component: TDieUsaAccNv  H58 0621
       Revision: 29460233    Serial number: 658161013596006
       Coding: 0BC702060F53D705020100
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 34311C9FEEB9E6671E1-8060
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001134025
       Coding: 00CD077D00
       VCID: 72BDDA87D42DA857CCD-8026
       Serial number: 8336371603
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 1308210000000000031E
    0267 - Optical data bus
              U1049 00 [008] - Open circuit
                        Reset counter: 221
                        Mileage: 96408 km
                        Date: 2019.06.25
                        Time: 00:00:10
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 38 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
       Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
       Component: KLIMA FOND    H07 0088
       Serial number: 16101300041237
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
       VCID: 36352697F8C5F477205-8062
       Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000078114735
       Coding: C0581B008F006001000001010101102030303232203232
       VCID: 382928AFF2510207329-806C
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H03 0056
       Revision: --------    Serial number: EJ1BPA82056P2%
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 J    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0060
       Revision: 00H04000    Serial number: 6PZ 010 287-08
       Coding: 0000007
       VCID: 36352697F445F477205-8062
       Subsystem 1 - Part No: 4G0 907 568 J
       Component: J770  SWA Slave H04 0060
       Subsystem 2 - Serial number: 6PZ 010 287-28
       Subsystem 3 - Serial number: 5F16.10.1300H04000AMS14555˙
       Subsystem 4 - Serial number: S14555˙
       Component: TSG FA        H04 0507
       Coding: 011F57025E00628002000413
       VCID: 45D7515BB5A36FEFB9F-8010
       Component: RCEPS         H39 0010
       Revision: 00001000    Serial number: 0015953756
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1A8714ADE8570CD-8066
       Revision: 00002001    Serial number: 0318001413
       Coding: 0126063A20FAF08580A00A8402030D470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000184890
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO23954715
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00005100188
       Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA107207000005344526
       Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93071471
    03394 - Play protection for rear spoiler adjustment active
                        Reset counter: 221
                        Mileage: 96408 km
                        Date: 2019.06.25
                        Time: 21:45:37
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007001    Serial number: 00000000041576
       Coding: 030000
       VCID: 1D67D93B7DB3472FC1F-8048
    03405 - Bass Loudspeaker
                        Fault Status: 00111011
                        Fault Frequency: 83
                        Reset counter: 231
       Coding: 011F57025E00628002000402
       VCID: 46D5565788A564F7B05-8012
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000845860
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C0104FF3689BEA7461-8078
    131840 - Switch for Electric Parking Brake
              C100C 13 [008] - Open Circuit
                        Reset counter: 190
                        Voltage terminal 30: 12.1 V
                        Internal Fault ID: 34
                        Vehicle speed: 510 km/h
                        Network management state: Reset
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: Emergency running mode
                        Status of parking brake button: Open circuit
                        Status ParkingBrake left: Open
                        Status ParkingBrake right: Open
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0020
       Serial number: 131013-0004-089
       Coding: 1223A633701AA500
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H01 0031
       Coding: 3A0000
    H01 0031
       Coding: 3A0000
       Revision: AB001007    Serial number: 156JC0D7922699
       Coding: 020007010000000001
       VCID: 2411ECDF5ED976E78E1-8070
       Part No SW: 4G0 035 746 E    HW: 4G0 035 746 E
       Component: H-BNT-NA      H40 0735
       Revision: --------    Serial number: 194J+0D7560073
       Coding: 090200040003E9EF7D12CB3E00000003100001000000000000
       VCID: 290FFDEB39FBAB8FBD7-807C
       Subsystem 1 - Part No: 8R0 060 884 BD
       Component: NAR 2013/2014  0802
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD002THD3
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349MJL000K9
       Component: CD-Database  5298
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 221
                        Time Indication: 15
                        Voltage: 11.90 V
       Coding: 010F17024000628002000002
       VCID: 49CF5D6B99BB8B8F5D7-801C
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0111708
       Coding: 0205000001010100000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007_AU57.rod
       Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
       Component: HDSG-Modul    H13 0043
       Revision: 12013001    Serial number: 261300714
       Coding: 0A3305C102
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571.rod
       VCID: 44D14C5FBE1956E7AE1-8010
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2615F6D7286584F7905-8072
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7E01010201
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
                        Control Module temperature: 41 °C
                        Voltage terminal 15: 11.539 V
                        Velocity_vehicle_reference: -0.00 m/s
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000121110137
       Coding: 03C198180111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F158B11ABD34F757-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H09 0010
       Revision: 00000000    Serial number: 131980421
       ROD: EV_RDCMA00100_008.rod
       VCID: 2B0307E33387B99F4FB-807E
    End----------(Elapsed Time: 02:58, VBatt start/end: 13.7V/14.1V)-----------
    May 2017
    This is your issue :
                        Reset counter: 190
                        RWU: not active
                        DSD: not active
                        HTR: active
                        ECD: not active
    Fix this and you will be able to code the ABS module.
    Since that's an intermittent fault with a fault frequency of 1 try just clearing it and see if it comes back...
    And if it doesn't then try your coding change again.
    Jul 2019
    Thanks, will try clearing that. If clearing it doesn’t fix the issue - would it indicate that the part needs to be replaced?
    Quote Originally Posted by acr89 View Post
    No, there may be a wiring problem - don't just assume that all faults are caused by "parts", very often there are other causes.
  6. Likes Dana liked this post
    Jul 2019
    I cleared the fault codes on both the ABS and the Parking Brake, still got same coding rejected error. I then turned off and restarted the car, and still coding rejected. Any other ideas?
    May 2017
    Can you please post an autoscan after you cleared the faults so we'll see what faults are still active?
    Are you absolutely sure the autohold wiring is correctly installed? Because if the button is not correctly wired it will reject the coding.
  9. Likes Dana liked this post
  10. #8
    United States
    Please do check the wiring per the above suggestions but I have a SA code question and suggestion.
    1) 10505 is a known ABS SA code (Don has that listed in this thread) however we don't have the function documented. For that reason it would be helpful if you could confirm that was accepted, rather than a typo or incorrect copy/paste, so I can add it as a note to the label file.
    2) I would firstly see if this 03 controller will allow you to copy and paste the factory original coding string back into the module:
    • Without a SA code at all.
    • With SA code 61378.
    • With SA code S11820. The letter S must be upper case.
    Depending on those results, I would use the SA code that allowed re-coding to the same value to try entering the modified coding after you double checked the wiring to see if something like SA S11820 was all this controller needed before it would cooperate.
  11. Likes PetrolDave, Uwe liked this post
  12. #9
    Jul 2019
    Thanks Dana. Will try that next week once I'm back home. The Auto Hold button is a documented "plug and play" mod with the C7/C7.5 A7 and A6 cars, no need to modify or add wiring. The Audizine thread I posted has many C7/C7.5 Audi owners who installed this button with no wiring mods. I will double check though that the plug is fully seated. The parking brake works just fine so I think the plug is seated.
    1. Confirmed, 10505 SA was accepted. 61378 didn't work in my car.
    2. I'll try these next week. Thanks for the help.
    New autoscan is below after I cleared the faults, in case this provides any help:
    Friday,19,July,2019,10:20:57:10396
    VIN: WAU2MAFC4EN075702   License Plate: B2KZYAFTERCODESCLEARED
    Mileage: 97277km-60445mi   Repair Order:
    VIN: WAU2MAFC4EN075702   Mileage: 97277km-60445miles
       Revision: 58H14---
       Revision: --H16---
       Coding: 3603207A4D
              P150A 00 [008] - -
                        Reset counter: 223
                        Mileage: 96408 km
                        Date: 2019.06.25
                        Time: 00:00:22
       Coding: 0045F7
       Coding: 02006E
       Coding: 853000
       Coding: 020300
                        Reset counter: 223
                        Mileage: 96505 km
                        Date: 2019.06.27
                        Time: 09:29:00
                        Reset counter: 223
                        Mileage: 96505 km
                        Date: 2019.06.27
                        Time: 09:29:00
       Coding: A8EB04
       Coding: 7E01010201
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
       Coding: 0000DC
       Coding: 00CD077D00
       Voltage stabilizer:
                        Reset counter: 221
                        Mileage: 96408 km
                        Date: 2019.06.25
                        Time: 00:00:10
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
       Coding: 20
       ROD: EV_SARA2.rod
       Coding: 0000007
       Coding: 101F00
                        Reset counter: 221
                        Mileage: 96408 km
                        Date: 2019.06.25
                        Time: 21:45:37
       Coding: 030000
                        Fault Frequency: 98
                        Reset counter: 232
    H01 0031
       Coding: 3A0000
    H01 0031
       Coding: 3A0000
                        Reset counter: 221
                        Time Indication: 15
                        Voltage: 11.90 V
       Coding: 0A3305C102
       Coding: 6A060000
       Coding: 7E01010201
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 97106 km
                        Date: 2019.07.17
                        Time: 18:13:55
       ROD: EV_BC7.rod
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    End----------(Elapsed Time: 02:52, VBatt start/end: 14.2V/14.2V)-----------
  13. Likes Dana, downtime, Boki Ar liked this post
  14. #10
    Jul 2019
    Security code S11820 did the trick and my auto hold feature is working! Thanks for the help. Weird that 10505 was accepted as a security code but wouldn’t let me change the coding.
  15. Likes Dana, Uwe liked this post
