Results 1 to 3 of 3
Thread: Readiness changing from Passed to Failed or Incomplete after a restart
    Jul 2019
    VW New Beetle 2000 Reflex Yellow (essentially a GLS)
    Vehicle has no mods. This vehicle has been sitting non-operational since 2014. In order to get it registered a SMOG test is required so I took it to the test facility and was informed that the vehicle was not ready. Basically SAI and EVAP were the two not ready and I purchased a Hex-Net in order to test and repair the vehicle myself. After a few days and a couple of parts I was able to complete the Readiness - 15 procedures and get everything ready. I closed out VCDS and shut the vehicle off. About a half hour later I started the car up and headed out to the test facility thinking everything was ready but when I got there and the technician connected their OBD2 tool the vehicle was no longer ready.
    The replacement parts are the SAIP, SAI pressure side hose and gas cap gasket. I checked the cables at the battery and they are tight. At this point I am at a loss for why the ECM changed the readiness to Failed or Incomplete and some help figuring out what's going on with my vehicle. Here's an auto scan taken when I got back home from the test facility:
    Thursday,18,July,2019,16:09:31:20353
    Mileage: 233810km-145282mi   Repair Order:
    Chassis Type: 1C - VW New Beetle (1998 > 2010)
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
       Mileage: 233810km-145282miles
    Address 01: Engine        Labels: 06A-906-032-AVC.lbl
       Part No: 06A 906 032 A
       Component: 1.8l 5VT NB AT  G   3157
       Coding: 00003
       Shop #: WSC 00066
       VCID: 9C7443800EE4C6AFE5-5160
    17965 - Charge Pressure Control
                P1557 - 35-00 - Positive Deviation
    Readiness: 0010 1101
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 AF
       Component: ASR     20 IE CAN  0001
       Coding: 13204
       Shop #: WSC 00066
       VCID: F5A27624CD8E37E73A-4B1E
                16-10 - Signal Outside Specifications - Intermittent
       Part No: 6Q0 909 605 A
       Component: 06 AIRBAG VW5       0003
       Coding: 12342
       Shop #: WSC 00066
       VCID: B522B6248D0E77E7FA-4B3C
                32-00 - Resistance Too High
    Address 17: Instruments        Labels: 1C0-920-xx0.lbl
       Part No: 1C0 920 901 G
       Component: KOMBI+WEGFAHRS. M73 V07
       Coding: 07202
       VCID: A00C7770228CE24F39-4B1E
       Subsystem 1 - Part No: Ident
       Component: Nr. Wegfahrs.:VWZ5Z0Y1216179
       Ident.-Nr. Wegfahrs.:VWZ5Z0Y1216179
    01039 - Coolant Temperature Sensor (G2)
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V072
       Coding: 00007
       Shop #: WSC 00066
       VCID: F0AC4730B2EC12CFE9-4B1E
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 5X Zentral-SG Komf. 0001
       Coding: 00256
       Shop #: WSC 00066
       VCID: 864001E8A0682C7F23-4B00
       Subsystem 1 - Part No: 1J2959802C
       Component: 5X Tőrsteuerger. FS0002F
       Subsystem 2 - Part No: 1J2959801D
       Component: 5X Tőrsteuerger. BF0002r
    00953 - Interior Light Time limit
                25-10 - Unknown Switch Condition - Intermittent
    00943 - Heated Exterior Mirror; Driver Side (Z4)
                35-00 - -
                35-00 - -
    Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
       Part No: 1C0 959 733 B
       Component: Heckspoiler         0002
       VCID: AA18955854B0281F67-51A8
    Address 56: Radio        Labels: None
       VCID: D5E216A42D4E57E71A-4B00
    00856 - Radio Antenna
    00855 - Connection to CD changer
    00852 - Loudspeaker(s); Front
    End----------(Elapsed Time: 03:33, VBatt start/end: 13.5V/13.7V)-----------
    Here's the next auto scan after clearing the codes:
    Thursday,18,July,2019,16:14:28:20353
       Coding: 00003
       Shop #: WSC 00066
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 FB
       Component: AG4 Getriebe 01M    4609
       Coding: 00000
       VCID: F5A27624CD8E37E73A-0962
       Coding: 13204
       Shop #: WSC 00066
       Coding: 12342
       Shop #: WSC 00066
       Coding: 07202
       Coding: 00007
       Shop #: WSC 00066
       Coding: 00256
       Shop #: WSC 00066
       Component: 5X Tőrsteuerger. FS0002r
    No Faults Found
       VCID: AA18955854B0281F67-51CE
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1C0 035 180 D
       Component:  RADIO             0002
       Coding: 06403
       VCID: 997A5A9401D6B387FE-4B00
    End----------(Elapsed Time: 03:46, VBatt start/end: 13.8V/13.7V)-----------
    I know what's wrong.
    I have seen this before.
    This is where either the terminal 15 is wired incorrectly or is picking up a back feed and failing the cars sleep period for interrupting terminal 30 and before 15.
    On at least 3 occasions it was an ignition switch or circuit tapped by an aftermarket alarm.
    In few cases was a faulty ECU for eeprom cleanup or processor sweeping ram to eeprom to save the bits or water ingress or FOD programming.
    I often see this happen on conversions due to morons failing to observe a WD and switching ground off on the ECU too!
  3. Likes Uwe, Zenerdiode, jyoung8607 liked this post
    Agreed. Most likely some kind of wiring or power problem.
