Results 1 to 2 of 2
Thread: Dpf pressure sensor problem after stage 2
    New User
    Jul 2019
    Sweden
    I have a problem I can't get rid of and have a long road trip in front of me. After I had done stage 2 and removed catalyst and diesel particulate filter at a workshop that programmed them away from ecu, I got problem with dpf pressure sensor. I have tested change sensor, checked leakage and wiring to sensor but still does not work. I have read that it should help to do a calibration of sensor with vcds. I have search but I cannot get into Coding II with code 30605. Best regards Robert from sweden
    Tuesday,16,July,2019,11:47:29:02028
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUZZZ4F6BN062375 License Plate:
    Chassis Type: 4F-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 18 19 34 42 46 4F 52 53 55 56
    5F 62 69 6D 72 76
    VIN: WAUZZZ4F6BN062375 Mileage: 179500km-111536miles
    Address 01: Engine (CDY) Labels: Redir Fail!
    Part No SW: 4F9 910 402 A HW: 4F0 907 401 E
    Component: 3.0TDI EDC17G004AG 0080
    Revision: 16H14--- Serial number:
    Coding: 0125002C191F0928
    Shop #: WSC 40970 222 95490
    VCID: 247E7C85E7DC136FDD-8070
    001139 - Exhaust Pressure Sensor 1
    P0473 - 001 - Signal too High - MIL ON
    Fault Status: 11100001
    Mileage: 178502 km
    Date: 2019.07.15
    Time: 13:47:56
    RPM: 1680 /min
    Speed: 30.2 km/h
    Pressure: 94 mbar
    Temperature: 28.8C
    Temperature: -5.9C
    Pressure: 6 mbar
    (no units): 211.5
    001152 - Coolant Fan Control Circuit 1
    P0480 - 000 - Electrical Malfunction
    Mileage: 178502 km
    Date: 2019.07.15
    Time: 13:47:56
    RPM: 1680 /min
    Speed: 30.2 km/h
    Temperature: 28.8C
    Mass Air / Rev.: 487.6 mg/str
    Duty Cycle: 19.7 %
    Temperature: -5.9C
    001683 - Fan 2 Control Circuit
    P0693 - 000 - Short to GND
    Mileage: 178502 km
    Date: 2019.07.15
    Time: 13:48:06
    RPM: 1281 /min
    Speed: 23.5 km/h
    Temperature: 27.9C
    Mass Air / Rev.: 376.0 mg/str
    Duty Cycle: 19.7 %
    Temperature: -5.9C
    001153 - Coolant Fan Control Circuit 2
    P0481 - 000 - Electrical Malfunction
    Mileage: 178502 km
    Date: 2019.07.15
    Time: 13:48:06
    RPM: 1260 /min
    Speed: 24.6 km/h
    Temperature: 27.9C
    Mass Air / Rev.: 340.8 mg/str
    Duty Cycle: 19.7 %
    Temperature: -5.9C
    Readiness: 1 1 0 0 0
    Part No SW: 4F2 910 156 R HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0050
    Revision: --H05--- Serial number: 4608058
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 345E8CC5573C83EF4D-8060
    006241 - Throttle Position Sensor (G79)
    P1861 - 000 - Error Message from ECU - Intermittent
    Mileage: 178418 km
    Date: 2019.07.14
    Time: 11:40:17
    Address 03: ABS Brakes Labels: 4F0-910-517.clb
    Part No SW: 4F0 910 517 AM HW: 4F0 614 517 BK
    Component: ESP8 quattro H03 0100
    Coding: 0000396
    VCID: 6FD443A97E9AE03770-803A
    Fault Status: 00101101
    Reset counter: 4
    Mileage: 178418 km
    Date: 2019.07.14
    Time: 11:40:16
    Hex Value: 0x0000
    Hex Value: 0x0082
    Hex Value: 0x0029
    Hex Value: 0x0192
    Hex Value: 0x00FF
    Nov 2015
    If you've had the dpf removed then I'm curious as to why the ECU is reading the pressure sensor. I'd probably be back to the tuner (or workshop) who supposedly removed them from the ECU.
  3. Likes Boki Ar, Uwe, PetrolDave liked this post
