Results 1 to 2 of 2
Thread: 2010 Audi Q5 3.0 tdi, HVAC V158 MOTOR REPLACEMENT & BASIC SETTING
    Jul 2019
    Australia
    I AM LOOKING FOR SOME HELP WITH THE HVAC V158 BASIC SETTING.
    I have only owned the car a few months and have been working through the faults. Managed to clean up quite a few and so happy with the Ross tech VCD software.
    However the problem I am currently having needs a bit more knowledge than I have currently.
    The original defect was V158 flapper motor fail, along with this only the left side of the cabin received warm air. Also on start up there was a motor running noise for maybe a minute (guessing it was the v158 trying to position correctly ) ( I should have done a basic setting at this point "newby" mistake )
    I gained access to the V158 motor & gearbox and removed the assembly ( Steering column and brake pedals removed ) I checked the v158 flap moved freely.
    So I purchased a second hand motor from an 2010 A4 that was installed in V159 position. Note : easiest to remove at the wreckers, it is the same part number unit. However it was an unknown unit as I could not test it.
    I then took out of my Q5 the V159 as I knew this worked and installed it into the gearbox for v158 the reinstalled the assembly into that v158 position.
    The new motor from the wrecker went to my v159 position.
    I then carried out a basic setting for the potentiometer and flap alignment this test aborts and then I got msg that the V158 had exceeded upper limit. I have also done the basic address look up / initiation for flap motor
    This is were I may have built in a defect (I made a bad choice ) I carried out a 08 auto HVAC adaption, standard settings. Before checking.
    I then gained access to the V158 and removed the assemble, at this point I realized I may not have installed correctly onto the flap crank arm and hece it was exceeding its upper limit.
    I then installed it correctly and ran the HVAC basic settings again and this is were I am up to with the defect. I am guessing I deleted some important info on the coding
    Fault Found:
    So peps , anybody know how to retrieve the information, or know what the code should be ? and how to do it ? so I can get the basic HVAC performed ?
    Thursday,18,July,2019,12:58:45:23479
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUZZZ8R6AA069580   License Plate: BNJ84K
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 56 62 72
              77
    VIN: WAUZZZ8R6AA069580   Mileage: 174130km-108199miles
    Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
       Part No SW: 8R0 907 401 J    HW: 8K1 907 401 A
       Component: 3.0TDI EDC17  H03 0008
       Revision: 15H03---
       Coding: 0121002C240F0128
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
       ROD: EV_ECM30TDI0118R0907401J.rod
       VCID: 397996A2B80225879E-806C
       Part No SW: 8R0 927 156 AD    HW: 0B5 927 156 E
       Component: 0B5 30 TDIRdW H04 0004
       Revision: --H04---    Serial number: 0000000288
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDL501.rod
       VCID: 7DF142B2ECAAD9A7F2-8028
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 L    HW: 8R0 907 379 L
       Component: ESP8 quattro  H07 0010
       Coding: 0F1500
       VCID: 4999E662E0E2B5070E-801C
       Part No SW: 8K0 907 064 CT    HW: 8K0 907 064 CT
       Component: BCM2 2.0      H07 0437
       Coding: 051500
       Shop #: WSC 34134 003 1048576
       VCID: 040737568740A86FBD-8050
       Subsystem 1 - Part No SW: 8T0 959 754 F    HW: 8T0 959 754 F
       Component: FBSAUDIB8 IDG  H38 0060
       Serial number: 0509000071023013
       Serial number: 0209000108792014
       Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
       Component: KLIMA 3 ZONEN H08 0171
       Revision: D0000000    Serial number: 01110120100126
       Coding: 36056000
       VCID: 76E35D9EC19C8AFFB3-8022
                        Fault Status: 01100101
                        Reset counter: 167
                        Mileage: 174132 km
                        Date: 2019.07.18
                        Time: 12:53:45
       Part No SW: 8K0 907 063 L    HW: 8K0 907 063 L
       Component: BCM1 1.0      H25 0380
       Revision: 07025001    Serial number: 00000000431474
       Coding: 690040B10034A7010001000000005F5F0F1D460800000141000000
       VCID: 387F93A68B083C8F61-806C
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 091205  H10 0041
       Serial number: 90243015091203155259
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 10730944
       Coding: 024D25
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001512092333
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51290936300019
       Coding: 000105
       VCID: 479DE05AF6F6437718-8012
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 C    HW: 8R0 959 655 C
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003FQD067XW6
       Coding: 30453331313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 4487F756CFC0686FFD-8010
       Serial number: 6334MSME4D150C7CR
       Serial number: 6344MSME4F046C70M
       Serial number: 6352QSME68493A14M
       Serial number: 6362QSME15481D0CM
       Serial number: 63732SME6C4A18388
       Serial number: 63832SME7E4730361
       Revision: --------    Serial number: 90304JA60003A
       Coding: 000037
       VCID: 3D7182B2A42A19A7B2-8068
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 900 F    HW: 8R0 920 900 F
       Component: KOMBIINSTR.   H11 0255
       Revision: 00000000    Serial number: CJF26UGD9
       Coding: AF06220002000008010000
       VCID: 3467A7969760D8EF4D-8060
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G10104844E
       Coding: 00C303
       VCID: 50AFCB0603B884CF49-8004
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140861203
       Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001010049665
       Coding: 00781B00000044440000
       VCID: 408FFB46D3D8744FD9-8014
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009838214
       Coding: 011D12205E01440004
       VCID: 4581EA52CCFA5167EA-8010
       Revision: 00002001    Serial number: 0444393185
       Coding: 01000E22203904810420053280000000
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F6DA8FA7E46FB3730-807A
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009817129
       VCID: 4487F756C7C0686FFD-8010
       Revision: 00000003    Serial number: 10000000404736
       Part No SW: 8T2 035 195 AA    HW: 8T2 035 195 AA
       Component: Symphony3     H04 0310
       Revision: 00000007    Serial number: AUZ5Z4J1169207
       Coding: 0502008201058D0003DB070000
       VCID: 77FD509AC696F3F7A8-8022
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102584994
       Coding: 010C12204001240004
       VCID: 428BF14EDDD4665FCF-8016
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102584991
       Part No SW: 8T0 862 335 D    HW: 8T0 862 335 D
       Component: FSE_256x BT     H39 0600
       Revision: 00000000    Serial number: 00000005148816
       Coding: 0010390
       VCID: 3B758CAA7A3E17978C-806E
    End-------------------------(Elapsed Time: 03:12)--------------------------
    16.4905° S, 151.7375° W
    The V158, V159 and several other flap motor's part numbers have dropped and have been superseded from [8K0-820-511-C] to [8K0-820-511-D].
    You may want to consider updating the flap motors. Also you can use the Measuring Value Blocks to view the information about the current position of the flap motors and their learned values. For example:
    MVB-018 = Left Temperature Flap Control Motor (V158)
    MVB-020 = Right Temperature Flap Control Motor (V159)
    Also more information can be found in the Official Factory Repair Information
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
