Results 1 to 5 of 5
Thread: MK6 golf RHD ABS module long code error 31 (MK60EC1)
    Jul 2019
    Australia
    Hi guys,
    Just put another used ABS module in this MK6 golf and having issues with coding. I'm not sure if the unit is incorrect or not, based on the part number.
    Here are 2 autoscans. 1 is of the original ABS module that was being replaced. The 2nd is of the replacement ABS module.
    ORIGINAL:
    Thursday,18,July,2019,12:38:54:28903
    VIN: WVWZZZ1KZAW007326   License Plate:
    Mileage: 140810km-87495mi   Repair Order: ORIGINAL
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAW007326   Mileage: 140810km-87495miles
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0050
       Revision: AAH03---    Serial number:
       Coding: 0403000C1C070160
       Shop #: WSC 01357 011 03080
       VCID: 679EAB33561D337738-8032
    Readiness: 0110 0101
       Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     431 1817
       Revision: 04843012    Serial number: 00000806191360
       Shop #: WSC 44551 111 44551
       VCID: 1366AFE332056FD734-8046
       Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
       Component: ESP MK60EC1   H45 0108
       Revision: 00H45001
       Coding: 163B600D89220001680E06E6911F0081B508
       VCID: 7DB2E95BE48189A7F2-8028
                        Fault Status: 00101101
                        Reset counter: 111
                        Mileage: 136272 km
                        Date: 2019.03.22
                        Time: 10:45:43
                        Count: 7
                        Count: 14
                        Count: 29440
                        Count: 8193
                        Count: 49920
                        Count: 64765
                        Fault Status: 00101110
                        Fault Frequency: 84
                        Reset counter: 62
                        Mileage: 136272 km
                        Date: 2019.03.22
                        Time: 10:59:37
                        Count: 7
                        Count: 4864
                        Count: 104
                        Count: 50723
                        Count: 64771
    01130 - ABS Operation
                        Reset counter: 93
                        Mileage: 136272 km
                        Date: 2019.03.22
                        Time: 10:45:42
                        Count: 2
                        Count: 14
                        Count: 29440
                        Count: 124
                        Count: 49920
                        Count: 64765
                        Reset counter: 71
                        Mileage: 140813 km
                        Date: 2019.07.18
                        Time: 00:00:08
                        Count: 7
                        Count: 14
                        Count: 28672
                        Count: 266
                        Count: 46592
                        Count: 49664
       Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
       Component: Climatronic   H14 0608
       Revision: 00003001
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 6D92D91BBCE1192742-8038
    9481988 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Fault Frequency: 136
                        Reset counter: 111
                        Mileage: 138459 km
                        Date: 2019.05.13
                        Time: 18:20:57
       Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
       Component: BCM PQ35  M   103 0537
       Revision: 00103 AB
       Coding: 48180A3A9025F1C044080080140001E441510088536D8960648000200000
       VCID: 302C006F6353B4CF29-8064
       Component: Wischer 12050  21  0501
       Coding: 009795
       Component: RLS 150509 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HO  H08 9001
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 10
                        Reset counter: 71
                        Mileage: 140813 km
                        Date: 2019.07.18
                        Time: 06:41:35
                        Voltage: 12.00 V
                            Term 50 Off
                        Fault Frequency: 10
                        Reset counter: 71
                        Mileage: 140813 km
                        Date: 2019.07.18
                        Time: 06:41:35
                        Voltage: 12.00 V
                            Term 50 Off
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 111
                        Mileage: 140813 km
                        Date: 2019.07.18
                        Time: 00:00:04
                            Term 15 Off
                        Voltage: 13.20 V
                            Term 50 Off
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2R91646R
       Coding: 00003134
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77BEFB73CEBDA3F7A8-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 2A076247ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 3B547146ZZZZZZZZZZZZ
       Serial number: 3805284BZZZZZZZZZZZZ
       Serial number: 06122957ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Coding: 0001632
       VCID: 76A0F67701B7DAFFB3-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000131
       Part No SW: 5K6 920 870 B    HW: 5K6 920 870 B
       Component: KOMBI         H05 0206
       Coding: 170B00
       VCID: 32280A67655F86DF5F-8066
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H16 0222
       Revision:   H16       Serial number: 4020K095160415
       Coding: ED807F06000202000003
       VCID: 6680A63751172A7F03-8032
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H05 0206
       Component: Tuer-SG         009 2110
       Coding: 0000692
       VCID: 312A056BA859BDC726-8064
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 74     2901
       Revision: 00H17000
       VCID: 2F2E0313BE6DAB3730-807A
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.1 V
                            PD
                        Temperature: 15.0°C
                        Count: 2
                        Steering Angle: 0.00°
                            SteerAng n.Init
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Component: Tuer-SG         009 2124
       Coding: 0000692
       VCID: 34240C7F574B88EF4D-8060
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  037 0144
       Revision: 00000001    Serial number: VWZ1Z3I4259919
       Coding: 0500040004
       VCID: 6582A13B6C1121670A-8030
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
       VCID: 3522317B5C3191E77A-8060
    End----------(Elapsed Time: 01:07, VBatt start/end: 12.9V/12.8V)-----------
    REPLACEMENT UNIT
    Thursday,18,July,2019,06:31:46:28903
    VIN: WVWZZZ1KZAW007326   License Plate: BNH20Q
    Mileage: 140810km-87495mi   Repair Order: 18368
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0104
       Revision: 00H35001
       Shop #: WSC 00046 412 00000
       VCID: 74A4CC7FD7CBC8EF8D-8020
                        Fault Status: 01100101
                        Reset counter: 0
                        Mileage: 140813 km
                        Count: 3
                        Count: 12288
                        Count: 279
                        Count: 43264
                        Reset counter: 0
                        Mileage: 140813 km
                        Count: 3
                        Count: 12288
                        Count: 295
                        Count: 43264
                        Reset counter: 0
                        Mileage: 140813 km
                        Count: 3
                        Count: 12288
                        Count: 270
                        Count: 43264
                        Reset counter: 71
                        Mileage: 140813 km
                        Count: 3
                        Count: 12288
                        Count: 195
                        Count: 43264
       Revision: 00003001
       Coding: 0000000000
                        Fault Frequency: 131
                        Reset counter: 111
                        Mileage: 138459 km
                        Date: 2019.05.13
                        Time: 18:20:57
       Revision: 00103 AB
       Coding: 009795
       Coding: 0330AD
                        Fault Status: 00101010
                        Reset counter: 111
                        Mileage: 135985 km
                        Date: 2019.03.16
                        Time: 00:50:04
                        Voltage: 12.65 V
                            Term 50 Off
                        Reset counter: 71
                        Mileage: 135985 km
                        Date: 2019.03.16
                        Time: 00:42:35
                            Term 15 Off
                        Voltage: 13.45 V
                            Term 50 Off
                        Reset counter: 71
                        Mileage: 140813 km
                        Date: 2019.07.18
                        Time: 06:28:07
                        Voltage: 12.05 V
                            Term 50 Off
       Coding: 00003134
       Coding: 0001632
       Coding: 00000131
       Coding: 170B00
       Coding: 0000692
       Revision: 00H17000
                000 - - - MIL ON
                            PD
                        Temperature: 15.0°C
                        Count: 2
                            SteerAng n.Init
       Coding: 0000692
       Coding: 0500040004
       Coding: 0000144
       Coding: 0000144
    End----------(Elapsed Time: 01:08, VBatt start/end: 12.1V/12.2V)-----------
    Thanks in advance!
    Hi and welcome.
    Installing random used parts without checking whether they are correct for the application may not be the optimal way to repair a car.
    Vehicle Identification No. WVWZZZ1KZAW007326
    Model Golf 2,0
    GOLF
    Date of production 29.05.2009
    Model year 2010
    Sales type 5K19V3
    Engine Code CCZB
    Transmission Code LQZ
    Revision: 00H45001
    PART NUMBER 1K0 907 375 BA Control unit for ABS
    LEGACY
    1K0 614 517 BB
    1K0 614 517 CM
    1K0 907 379 AM
    1K0 907 379 BA
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HA Vehicle class differentiation -1K0/5K0-
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG4 Hill hold assist + comfort driving assist
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D0 without trailer towing
    airbag 4UH Airbag for driver and passenger with knee airbag
    Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8H Top sports equipment
    Brake type in rear 1KY Disc brakes in rear
    batteries J1L Battery 280 A (60 Ah)
    Brake type, front 1ZB Disc brake in front
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0R Component parts set, complying with vehicle type for Australia, various parts
    vehicle tools and jack 1S4 vehicle tools with special jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    Chrome package QJ3 Chrome package (version 2)
    General operating permit, alterations C30 Operating permit, alteration
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear 1JE Rear sports shock absorption
    Suspension system in front G08 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5MD Decorative aluminum inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL1 Extended pedestrian protection measures
    Pedal cluster VF1 pedal cluster
    Headlight activation 8K3 Daytime headlights with automatic headlight control and coming home function
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
    Weight category front axle L98 Suspension range 98 installation control only, no requirement forecast
    Base engine TD6 4-cyl. petrol engine 2.0 l assembly 06J.D
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G1A 6-speed automatic transmission
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J4 Body-colored rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear seats 3NU Rear bench seat, not split, split backrest, folding centre armrest
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8BK Twin headlamps for driving on the left, with integrated high beam
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T1 Interior light in footwell
    Instrument clusters U5A Instrument insert, km/h speedometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8G Hatchback
    coolbox 1W2 Glove compartment cooling system
    Climatic zones 0Y2 Tropical zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    headrest for seat, rear 3T2 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A5 Petrol injector fuel system (FSI)
    Body measures 5C0 Without special body measures
    Radiator grille 6KA Radiator grille
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
    Paint coating FB0 standard paint coating
    Steering system arrangement L0R Right-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Air duct, front area VK1 Air duct, type 1
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2FU Leather-wrapped multi-function sports steering wheel with tiptronic
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Center armrest in front
    Marten repeller UM0 Without marten repeller
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Engine cooling 8Z6 Hot country
    Engine specifications D2D 4-cylinder petrol engine 2.0 L/155 KW (16 V) Turbo FSI, homogeneous Basic engine is: TM2/TV2/TG6/TJ6/TD6
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WD Integrated front fog light
    Upgrading measures GP1 Vehicles with special upgrade measures
    Rear of platform module base 4P0 Rear floor panel module, type 1
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels CG6 Alloy wheels 7.5J x 17
    Radios 8AI Radio "RCD510 MP3"
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire H6L Tires 225/45 R17 91W
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PH2 Air conditioning Climatronic
    PLA "Lights & Vision" package
    RHC "RCD 510" 4 x 20 W, 8 speakers
    W4B Power windows front and rear
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q6 Gearshift knob/handle in aluminum
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E0 Tailgate/trunk lid unlocking from outside
    Front seat, left 3TU Sports seat, front left
    Front seat, right 3SU Sports seat in front, right
    Nameplates for sales name QD0 Without lettering for sales name
    Seat belt check 9P3 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    seat covers N2T Seat trim covers in fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R3 Side turn signal lights (white)
    Start-stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
    Horns 8Y1 Two-tone horn
    Control number (no PR family) S0C Introductory volume
    Control number (no PR family) S5K Control (in-plant)
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JG bumper in color of vehicle
    Rear stabilizer 0BF Rear stabilizer
    Front stabilizer bar 0AE Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UC Sports version
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Special approval measures 3M0 Without special measures
    Nameplate set 0NH Nameplate set "GTI"
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B30 Type approval country Australia
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Identification plates 1EJ Special identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W0 without washer water level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  4. Likes Uwe, sam.bjp liked this post
    Jul 2019
    Australia
    Hi and welcome.
    Thanks Uwe.
    I used my usual parts supplier and provided them with the VIN and part number of the current ABS module, however it would seem they have provided an incorrect unit...
    You think......?
  7. Likes Fredrick Awuor liked this post
