Results 1 to 10 of 14
Thread: 2010 Beetle Airbag code 00594 Airbag Igniter Circuits HELP
    New User
    Jul 2019
    I have a 2010 Beetle with airbag code 00594 Airbag Igniter Circuits and under that says 008 Implausible Signal.
    Module is new. Got no clue where or what to do. Anybody know the fix??
    Please post an Auto-Scan for context.
    New User
    Jul 2019
    Thursday,11,July,2019,16:44:55:19936
    VCDS Version: 19.6.1.0 (x64)
    VIN: 3VWPW3AG5AM016801   License Plate: BLUE BUG
    Mileage: 176370km-109591mi   Repair Order:
    Chassis Type: AG (1C - VW New Beetle (1998 > 2010))
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
    VIN: 3VWPW3AG5AM016801   Mileage: 176370km-109591miles
    Address 01: Engine (BPS)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 CP    HW: 07K 906 032 AA
       Component: NB R5 MT        G   4573
       Revision: 1SH04---    Serial number: VWX5Z0J0197105
       Coding: 0000001
       Shop #: WSC 00066 000 00000
       VCID: 79F9DD023094B287DE-802C
    Readiness: 0110 1101
       Part No: 1C0 907 379 Q
       Coding: 0019978
       VCID: 387F1806481E6B8F61-5140
       Part No: 6Q0 909 605 AK
       Component: 01 AIRBAG VW71      0911
       Coding: 0012337
       VCID: 000FB0E6574EE34F99-8054
       Subsystem 1 - Component: BF-Gewichtsens.
    00594 - Airbag Igniter Circuits
                008 - Implausible Signal
       Part No: 1C0 920 801 K
       Component: KOMBI+WEGFAHRS. M73 V05
       Coding: 11232
       Shop #: WSC 00066
       VCID: 2345DF6AB1981857A4-4AE8
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V052
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EFE02630EEF3CF69-4B00
    Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
       Part No SW: 1C0 920 801 K    HW: 1C0 920 801 K
       Component: IMMO                X007
       Revision: xxxxxxxx    Serial number: VWX5Z0J0197105
       VCID: 2345DF6AE1981857A4-5140
    Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
       Part No: 1C0 962 258 AC
       Component: 4G Zentr.Verriegel. 0004
       Coding: 00016
       Shop #: WSC 00066
       VCID: 68DF8846083E3B0F31-4B00
       Part No: 1C0 035 196 CS
       Component:  RADIO DE2         0006
       Coding: 00401
       Shop #: WSC 00066
       VCID: 72EBEA2E3EE2C1DF9F-51D4
    00856 - Radio Antenna
                36-00 - Open Circuit
    Address 65: Tire Pressure        Labels: None
       Part No SW: 1C0 907 273 A    HW: 1C0 907 273 A
       Component:    RDK          H02 0230
       Revision: --H02-E0    Serial number: 13115791824578
       Coding: 0100101
       VCID: 2149D562F8840A47B6-8074
    End-------------------------(Elapsed Time: 04:07)--------------------------
    Address 56: DTCs clearedTuesday,16,July,2019,18:42:05:19936
       Coding: 0000001
       Coding: 0019978
       Coding: 0012337
       Coding: 11232
       Shop #: WSC 00066
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EFE02630EEF3CF69-4AE8
       Coding: 00016
       Shop #: WSC 00066
       VCID: 68DF8846083E3B0F31-4B1A
       Coding: 00401
       Shop #: WSC 00066
       VCID: 72EBEA2E3EE2C1DF9F-51B6
       Coding: 0100101
    End-------------------------(Elapsed Time: 04:04)--------------------------
    Hmmm.. That's not a fault I'm familiar with. It almost sounds like a problem internal to the airbag module.
    But before you condemn it, scroll through the first 13 or so Measuring Blocks and look for anything out of place.
    Also, check the ground for the airbag module.
    Jul 2014
    Hi fastboat2003,
    Did you change the module because you had this DTC, or did it appear after you changed the module? Was it dealer new? Has the vehicle been in a collision?
    Regards HMC
  6. #6
    Quote Originally Posted by HMC View Post
    ...and does the replacement module have the same "colour code" as the original one?
  7. Likes Uwe liked this post
    New User
    Jul 2019
    Module was replace because of this DTC. This was the recommended repair from the dealer. Module was dealer brand new and ordered from VIN.
  9. #8
    New User
    Jul 2019
    So...no one here has any info that can help or has seen this before??
  10. #9
    Quote Originally Posted by fastboat2003 View Post
    Correct, I for one have not seen that DTC before.
    But have you looked at the measuring values like I recommended in post #4?
  11. #10
    New User
    Jul 2019
    The module is BRAND NEW......how would a brand new module and the old module have the same fault due to measuring values?????
    This forum is no help at all.....
