Results 1 to 6 of 6
Thread: 0B5 S-tronic adaptation error/jerky start - 2010 Audi S4
    May 2017
    Hello, currently I'm trying to adapt an S-tronic with the following story. The car (2010 Audi S4 S-tronic) was towed in with very jerky starting in 1st/R gears. Scanning it then gave me:
    Tuesday,16,July,2019,17:18:01:35753
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAUKGAFL2AA069194   License Plate: INITIAL 2019.07.16
    Mileage: 157330km-97760mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 47 52 53 55 56 5F 62
              72
    VIN: WAUKGAFL2AA069194   Mileage: 157330km-97760miles
    09-Cent. Elect. -- Status: Malfunction 1010
    Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
       Component: 3.0T SIMOS84  H06 0003
       Revision: --H06---
       Coding: 0104000A240F0128
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
       ROD: EV_ECM30TFS0218K0907551D.rod
       VCID: 3228E95765A4C8DF5F-8066
    7810 - Intake Air Regulating Flap
              P10A4 00 [096] - Mechanical Malfunction
                        Mileage: 157319 km
                        Date: 2019.05.03
                        Time: 14:13:24
                        Coolant temperature: 93 °C
                        Intake air temperature: 51 °C
                        Ambient air pressure: 950 mbar
                        Voltage terminal 30: 12.898 V
                        Unlearning counter according OBD: 37
                        Engine speed: actual: 0 /min
                        PDT_ENVD: 875.59570 hPa
                        RFP_AD_STOP_SAVE_LOW_ENVD: 2
                        RFP_AD_STOP_SAVE_HIGH_ENVD: 0
                        VP_RFP_AD_LIH_1_ENVD: 4.39453 V
                        VP_RFP_BOL_MTC_1_ENVD: 0.52734 V
    6506 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [104] - -
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 13:42:47
                        Engine speed: 516.00 /min
                        Normed load value: 34.5 %
                        Coolant temperature: 98 °C
                        Intake air temperature: 60 °C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 12.288 V
                        Engine speed: actual: 1152 /min
                        MAF_ENVD: 245.11764 mg/stroke
                        Coolant temperature (unfiltered): 20.3 °C
                        Engine: operating status: IS
                        Engine load: 17.968750 %
                        Vehicle speed: actual: 0 km/h
    Readiness: 0000 0001
       Part No SW: 8K0 927 156 M    HW: 0B5 927 156 E
       Component: 0B5 30TFSINAR H03 0008
       Revision: --H03---    Serial number: 0000001362
       ASAM Dataset: EV_TCMDL501 A02044
       ROD: EV_TCMDL501.rod
       VCID: 3E30CD67A1FC1CBFAB-806A
    8021 - Clutch
              P2789 00 [100] - Adaptive Learning at Limit
                        Reset counter: 40
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 13:30:58
                        Engine speed: 666 /min
                        Transmission input speed: 666 /min
                        Engine torque: 4 Nm
                        Transmission fluid temperature: 61 °C
                        Accelerator position: 0.0 %
                        Clutch status: Beide Kupplungen offen
    8957 - Clutch 1
              P17D6 00 [104] - Pressure too High
                        Reset counter: 37
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 13:41:06
                        Engine speed: 596 /min
                        Transmission input speed: 596 /min
                        Transmission output speed: 15 /min
                        Engine torque: 20 Nm
                        Transmission fluid temperature: 85 °C
                        Clutch status: Kupplung 1 kann Moment übertragen
    8962 - Clutch 2
              P17D7 00 [104] - Pressure too High
                        Reset counter: 37
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 13:39:57
                        Engine speed: 519 /min
                        Transmission input speed: 519 /min
                        Transmission output speed: 18 /min
                        Engine torque: 16 Nm
                        Transmission fluid temperature: 83 °C
                        Clutch status: Kupplung 2 kann Moment übertragen
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 290D18
       VCID: 7AB80177F554F09FD7-802E
                        Fault Status: 00101101
                        Fault Frequency: 7
                        Reset counter: 54
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 13:39:57
                        Hex Value: 0x00C0
                        Hex Value: 0x4082
                        Hex Value: 0x0027
                        Hex Value: 0x23A1
                        Hex Value: 0x00FF
    02214 - Tire Pressure Warning
                        Fault Frequency: 6
                        Reset counter: 17
                        Mileage: 157328 km
                        Date: 2019.06.25
                        Time: 15:13:07
                        Hex Value: 0x4300
                        Hex Value: 0x4006
                        Hex Value: 0x1237
                        Hex Value: 0x19B0
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0326
       Coding: 0D0100
       VCID: 78BC1B7FCB58E28FA1-802C
       Subsystem 1 - Part No SW: 8T0 959 754 AJ    HW: 8T0 959 754 AJ
       Component: FBSAUDIB8 IDG  H38 0060
       Serial number: 0509000050783016
       Serial number: 0209000073092009
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Fault Status: 00101011
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.07
                        Time: 17:07:15
    03285 - Sensor for Contact with Door Handle; Front Left
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.10
                        Time: 08:31:09
                        Fault Status: 00100001
                        Fault Frequency: 12
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:08:43
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 14:58:08
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01061020091259
       Coding: 66102000
       VCID: 004C739F9388AA4F99-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000359769
       Coding: 26001811003CAF010000080300003D0D0F1C520800010161000000
       Shop #: WSC 06325 123 12345
       VCID: 3C34C76FBFE00EAF85-8068
       Component: WWS 021009  H06 0070
       Serial number: SWF09100020282
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10621974
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002809090578
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 13:37:00
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EGD051ZFG
       VCID: 42C8B997D504785FCF-8016
       Serial number: 5810000R0900004EMV
       Serial number: 6334MSME4B2239127
       Serial number: 6344MSME4B605A32F
       Serial number: 6352QSME273D0D0AP
       Serial number: 6362QSME0B3B3F28V
       Serial number: 63732SME353D5426/
       Serial number: 63832SME1D3C4A1CD
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90319IJ2000BI
       Coding: 000036
       VCID: 3D32CA6BA4FA07A7B2-8068
                        Fault Frequency: 8
                        Reset counter: 40
       Part No SW: 8K0 920 980 Q    HW: 8K0 920 980 Q
       Component: KOMBIINSTR.   H05 0255
       Revision: 00000000    Serial number: CJ23185A9
       Coding: 839F09000300D705020000
       VCID: 40CCB39FD3086A4FD9-8014
       Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0105
       Revision: EB800053    Serial number: 5300E099298053
       Coding: 00C303
       VCID: 52E889D70D64E8DF7F-8006
       Component: J367-BDM  H06 0170
       Serial number: 19090299100909
                        Fault Frequency: 25
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.05.31
                        Time: 13:51:53
                        Bin. Bits:    10000
                        Voltage: 11.50 V
                        Count: 10
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 08:09:27
                        Bin. Bits:    00011
                        Voltage: 10.80 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 0.90 s
    00532 - Supply Voltage B+
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:17:30
                        Bin. Bits:    10000
                        Voltage: 15.80 V
                        Count: 19
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001010006691
       Coding: 00581B00000000000000
       VCID: 3B36C473BAEE09978C-806E
                        Fault Frequency: 10
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:16:17
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 13:38:26
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009405935
       Coding: 011C13204E00410001
       VCID: 45C2A28BCC2A4F67EA-8010
                        Fault Status: 00101100
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.05.28
                        Time: 12:08:19
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 14:44:32
       Revision: 00002001    Serial number: 0122016630
       Coding: 01060E3A007E440500B0010000000000
       Component: GTO BF  H06 0050
       Serial number: 00000000000000171415
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
    9 Faults Found:
    02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
                        Reset counter: 54
                        Mileage: 157308 km
                        Date: 2019.04.30
                        Time: 20:11:06
    02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 15:27:31
    02902 - Lamp for Brake / Blink / Parking 2; Right (M73)
                        Reset counter: 54
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 11:57:48
    02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:50
    02742 - Bulb for Brake/Turn Signal Light; Left
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:50
    02743 - Bulb for Brake/Turn Signal Light; Right
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:50
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:51
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 08:09:27
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:09:25
       Part No SW: 8T0 035 223 AK    HW: 8T0 035 223 AK
       Component: DSP Prem      H08 0170
       Revision: 00008001    Serial number: 34881005584803
       VCID: 77BE1843C646EDF7A8-8022
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009449734
       VCID: 44C4BF8FC710766FFD-8010
                        Fault Frequency: 11
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:05:36
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:56:56
       Revision: 00000003    Serial number: 00000000464604
       VCID: 3424EF4F97B0C6EF4D-8060
                        Reset counter: 14
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 13:38:15
                        Voltage: 16.20 V
                        Count: 45
                        Hex Value: 0x0860
                        Hex Value: 0x0088
                        Hex Value: 0x0101
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 77BE18430646EDF7A8-8022
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335J-097532545
       Coding: 020000010000000001
       VCID: 1D722AEB043A67A792-8048
       Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
       Component: H-BN-NA       H41 0042
       Revision: --------    Serial number: 490JZ097519411
       Coding: 010200000206A1EC41000F0C000000030000
       VCID: 3620D54781CCD4FF73-8062
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356JL091080031
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000373517
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102027796
       Coding: 010C13204000210001
       VCID: 42C8B997DD04785FCF-8016
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 14:44:32
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102027777
                        Fault Frequency: 10
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:05:38
    End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.3V)-----------
    Checking the ATF level (per factory specs) showed that it was 0.5L low on ATF and it looked slightly brown with no burnt smell. Filled it up with OE fluid, cleared engine and transmission fault codes, here's the scan.
    Wednesday,17,July,2019,13:18:07:35753
    VIN: WAUKGAFL2AA069194   License Plate: AFTER CLEAR
              72
       Revision: --H06---
    Readiness: 1110 0001
       Coding: 290D18
                        Fault Frequency: 7
                        Reset counter: 54
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 13:39:57
                        Hex Value: 0x00C0
                        Hex Value: 0x4082
                        Hex Value: 0x0027
                        Hex Value: 0x23A1
                        Hex Value: 0x00FF
                        Fault Frequency: 16
                        Reset counter: 19
                        Mileage: 157328 km
                        Date: 2019.06.25
                        Time: 15:13:07
                        Hex Value: 0x4300
                        Hex Value: 0x4006
                        Hex Value: 0x1237
                        Hex Value: 0x19B0
                        Hex Value: 0x00FF
       Coding: 0D0100
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.07
                        Time: 17:07:15
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.10
                        Time: 08:31:09
                        Fault Frequency: 12
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:08:43
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 14:58:08
       Coding: 66102000
       Coding: 00FD11
       Coding: 025028
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 13:37:00
       Coding: 000036
                        Fault Frequency: 8
                        Reset counter: 40
       Coding: 00C303
                        Fault Frequency: 25
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.05.31
                        Time: 13:51:53
                        Bin. Bits:    10000
                        Voltage: 11.50 V
                        Count: 10
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 08:09:27
                        Bin. Bits:    00011
                        Voltage: 10.80 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 0.90 s
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:17:30
                        Bin. Bits:    10000
                        Voltage: 15.80 V
                        Count: 19
                        Fault Frequency: 10
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:16:17
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 13:38:26
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.05.28
                        Time: 12:08:19
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 14:44:32
    9 Faults Found:
                        Reset counter: 54
                        Mileage: 157308 km
                        Date: 2019.04.30
                        Time: 20:11:06
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 15:27:31
                        Reset counter: 54
                        Mileage: 157308 km
                        Date: 2019.05.03
                        Time: 11:57:48
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:50
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:50
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:50
                        Reset counter: 54
                        Mileage: 157319 km
                        Date: 2019.05.07
                        Time: 16:53:51
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 08:09:27
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:09:25
                        Fault Frequency: 11
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:05:36
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:56:56
                        Reset counter: 14
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 13:38:15
                        Voltage: 16.20 V
                        Count: 45
                        Hex Value: 0x0860
                        Hex Value: 0x0088
                        Hex Value: 0x0101
       Coding: 0000004
                        Fault Frequency: 6
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 14:44:32
                        Fault Frequency: 10
                        Reset counter: 54
                        Mileage: 157321 km
                        Date: 2019.06.21
                        Time: 10:05:38
    Then went on to do the basic settings as per:
    http://wiki.ross-tech.com/wiki/index...rbox_(DSG/0B5)
    After this step:
    Select Erase counter for start and stop processes
    [Go!] to activate the Basic Setting.
    I immediately get an error:
    ERROR: Request out of range
    If I try to continue and do:
    Select Clutch valve calibration [Go!] to activate the Basic Setting.
    It runs for a few seconds and the I get an error:
    Aborted for safety reasons (or something similar)
    If I try to drive the car, it still jerks when in D trying to pull off sometimes pretty violently and sometimes a bit smooth. The car jerks forward, then it feels like the clutch disengages and the engine revs rise to 1000 - 1300 rpm.
    It is very random. It feels very similar to a manual clutch (from back in the day) when you misjudge the engagement point of the clutch and car jerks violently and sometimes the engine stalls (here it doesn't stall as the clutch seems to disengage and engine revs rise).
    There are no codes whatsoever after the only 1 clear all I have done after the fluid correction.
    I tried to check all kinds of TPIs for the codes above and nothing comes up.
    Of course a new transmission, clutch and mechatronic will fix it. I would like to first find out what exactly is the problem for the jerky start and for the basic settings errors (probably they are related).
    Anyone has seen this or has any ideas? Thanks in advance!
    Bestiale - incredible quality tuning and full service for Audi, VW and Bentley backed with 101 year labor warranty
    8651 Washington blvd., Culver City, CA 90232
    562-448-2599 or Grigor@bestiale.net, www.bestiale.net
    16.4905° S, 151.7375° W
    Yes, there does appear to be several Technical Service Bulletins from Audi factory service information/repair manuals that detail flash updates for the Transmission Controller, VAG# [8K0 927 156 M].
    Here is one of the latest one I have found:
    Technical product information Transaction No.: 2027286
    Jerk when changing from 2nd to 1st gear, S-tronic
    SW version 0008 has been updated to (at least) 0012
    Hope this helps,
    drpeter
  3. Likes Uwe, jyoung8607, Golftwincharged liked this post
    Yeah and isn't this under useful life warranty too?
    Nice post Peter!
    OP you better read the whole JPPSG
    MIL + clutch smell + call up = FREE Repair?
  5. Likes DrPeter liked this post
    May 2017
    Quote Originally Posted by DrPeter View Post
    drpeter
    Thanks Peter! Indeed this is what I found a few minutes after posting, updated to 0012 and clutch engagement was a lot better, but still every now and then super jerky. I assume that there is a problem with either the clutch, mechatronic or something between them. Is there any way to test which one exactly is the problem?
    Nice post Peter!
    I read it. There is no clutch smell, but in any case do you mean that Audi has extended warranty on this? If so, how do you know besides obviously calling the dealer? Thanks!
    Ask yourself this question okay?
    Isn't the fact that the car is covered under useful life warranty & software was considered incorrect & from the beginning, further needed change so many times a reason & to request it be covered under warranty for defect or even recalled?
    There is a document on erWin Audi called "Servicing-7-Speed Dual Clutch Transmission 0B5 (S tronic)", I suggest having a look at that.
    There does not appear to be any specific tests, however there is a lot of information on the "Disassembling and Assembling" of the transmission and this may help with the inspection of specific components.
    Check the basics! Starting with fluid level and quality....
    You really have only two choices, call any NAR Audi dealership or contact Audi North America - Warranty, the source of the information is from the manufacture, they will be able to use your VIN number and verify if there is any open recalls, campaigns or extended warranties that may exist.
    drpeter
  9. Likes Uwe, Jack@European_Parts liked this post
