Good Afternoon,
Been having quite a few problems with a 2011 Skoda Octavia.
Most recently is a problem with the battery charging, measuring voltage I tested around 11V with the engine running.
I replaced the complete alternator, checked earths and battery/alternator connections, and still testing at 11V.
I've tested the alternator on a different car and output was around 14V
I replaced the ECU with one from a donor car and tested battery voltage at 12V with the engine running.
The voltage rises to around 12.2V when the engine is turned off.
I'm starting to run out of ideas as to the cause of this, any help will be greatly appreciated.
Also, is anyone able to help with the ABS coding for this car please?
Thanks in advance and I've posted AutoScan below.
Wednesday,17,July,2019,14:58:56:20472
VCDS Version: 19.6.1.0 (x64)
Dealer/Shop Name: S81 Diagnostics
VIN: TMBCT21Z9C2031673 License Plate: YC61VAO
Mileage: 405520km-251978mi Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: TMBCT21Z9C2031673 Mileage: 405520km-251978miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LP HW: 03L 906 023 JH
Component: 1,6l R4 CR td H43 9972
Revision: --H43--- Serial number:
Coding: 00114014030500080000
Shop #: WSC 73430 031 00083
ASAM Dataset: EV_ECM16TDI02103L906023LP 003010
ROD: EV_ECM16TDI02103L997557A.rod
VCID: 7F070FB6E6B284B7E0-802A
Readiness: 1110 0000
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Shop #: WSC 73430 790 00083
VCID: 7BFFFBA6FAAA9897CC-802E
Reset counter: 98
Date: 2013.12.07
Time: 02:43:55
Count: 3
Count: 20992
Count: 195
Count: 44288
Fault Status: 01100101
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:43:42
Count: 3
Count: 2
Count: 20992
Count: 279
Count: 44288
Count: 256
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:43:42
Count: 3
Count: 2
Count: 20992
Count: 295
Count: 44288
Count: 256
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:43:42
Count: 3
Count: 2
Count: 20992
Count: 270
Count: 44288
Count: 256
Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
Component: Climatronic H18 0506
Revision: 00001007
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 7CFDF8BAF7A49FAFC5-8028
B10AB F0 [009] - Too Low
Reset counter: 98
Mileage: 405523 km
Date: 2019.07.17
Time: 02:37:45
Part No SW: 1K0 937 084 F HW: 1K0 937 084 F
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 48000AB8A05BB1C04008008011000024430000AE524D81605CC440000040
VCID: 3163198E6866A2C726-8064
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 30111 26 0601
Coding: 00D7B7
8 Faults Found:
01134 - Alarm Horn (H12)
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:40:01
Term 15 On
Voltage: 12.20 V
Term 50 Off
03156 - Sensor for Anti-Theft System (G578)
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:40:01
Term 15 On
Voltage: 12.20 V
Term 50 Off
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:47:40
Term 15 On
Voltage: 12.10 V
Term 50 Off
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:47:50
Term 15 On
Voltage: 12.05 V
Term 50 Off
01505 - Bulb for Blinkers; Rear Right (M8)
Fault Status: 00101010
Reset counter: 138
Mileage: 405523 km
Date: 2013.12.07
Time: 02:48:35
Term 15 On
Voltage: 11.85 V
Term 50 Off
Fault Status: 01101100
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 05:20:28
Term 15 On
Voltage: 12.30 V
Term 50 Off
01506 - Bulb for Rear Fog; Right (L47)
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 05:20:30
Term 15 On
Voltage: 12.25 V
Term 50 Off
Reset counter: 98
Mileage: 405523 km
Date: 2013.12.07
Time: 02:51:52
Term 15 On
Voltage: 12.15 V
Term 50 Off
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2U6225
Coding: 0020788
VCID: 3D7B35BE643E56A7B2-8068
Subsystem 1 - Serial number: 6332MSME666220610
Subsystem 2 - Serial number: 6342MSME67254A43D
Part No SW: 5K0 953 521 BJ HW: 5K0 953 569 C
Revision: FF010040 Serial number: 20111207800950
Coding: 5080040000
ROD: EV_SMLSNGVOLWS.rod
VCID: 75EBED9ED48ECEE7BA-8020
Part No SW: 1Z0 920 943 S HW: 1Z0 920 943 S
Component: KOMBI H04 0607
Coding: 410A00
ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
VCID: 4993516EE8F6FA070E-801C
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Reset counter: 98
Mileage: 405523 km
Date: 2019.07.17
Time: 02:40:51
13639427 - Please Check Fault Codes in Engine Control Module
U101F 00 [009] - -
Reset counter: 98
Mileage: 405523 km
Date: 2019.07.17
Time: 05:20:46
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 031211F1000737
Coding: 352303
VCID: 3A713EA2B510619F97-806E
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 458B5D5E0CEE1E67EA-8010
Component: IMMO H04 0607
VCID: 6AD1CEE28D30111F27-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2120
Coding: 0000756
VCID: 4895546A3BFC030F11-801C
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 69 3301
Revision: 00H22000
VCID: 356B2D9E5C0E8EE77A-8060
16344 - Control Module - RAM Error
Fault Status: 00101110
Mileage: 152745 km
Date: 2016.01.31
Time: 21:10:07
Voltage: 11.50 V
DU
Temperature: 44.0°C
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0xE1D4
Count: 8
16355 - Control Module - Watchdog Timer
Mileage: 152745 km
Date: 2016.01.31
Time: 21:10:07
Voltage: 11.50 V
DU
Temperature: 44.0°C
Count: 60
Fault Status: 11100101
Mileage: 405523 km
Date: 2013.12.07
Time: 02:40:27
Battery Volts: 12.3 V
DD
Temperature: 27.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 4797575636E20C7718-8012
Part No SW: 1Z0 035 156 M HW: 1Z0 035 156 M
Component: BOLERO 001 0008
Revision: -----08S Serial number: SKZ4Z3L1155503
Coding: 050004000001
VCID: 3C7D38BABF245FAF85-8068
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012563
VCID: 32611682AD6099DF5F-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 336F1386527A90D754-8066
End-------------------------(Elapsed Time: 02:36)--------------------------
Address 09: Cent. Elect. (1K0 937 084 F)
15:34:25
Inactive Load Management
12.10 V Voltage Term.(30)
99.6 % Generator Load
Invalid Quiescent Voltage Recent Phase
Invalid Quiescent Voltage Second Phase
Invalid Quiescent Voltage Third Phase
6.0 Quiescent Voltage Total Phases
0.000 V Voltage Difference Mean Value
0.0 Battery disconn. Counter
12.15 V Voltage Term. 30 left
12.15 V Voltage Term. 30 right
12.10 V Voltage Term. 30 refer.
15:44:26 Group 031: Load Management
4.0 Short-Distance Operations
15:45:25 Group 031: Load Management
Active Load Management
12.00 V Voltage Term.(30)
