Results 1 to 7 of 7
Thread: 1Z 2011 Skoda Octavia - Charging Issue & ABS Coding
    Feb 2015
    Good Afternoon,
    Been having quite a few problems with a 2011 Skoda Octavia.
    Most recently is a problem with the battery charging, measuring voltage I tested around 11V with the engine running.
    I replaced the complete alternator, checked earths and battery/alternator connections, and still testing at 11V.
    I've tested the alternator on a different car and output was around 14V
    I replaced the ECU with one from a donor car and tested battery voltage at 12V with the engine running.
    The voltage rises to around 12.2V when the engine is turned off.
    I'm starting to run out of ideas as to the cause of this, any help will be greatly appreciated.
    Also, is anyone able to help with the ABS coding for this car please?
    Thanks in advance and I've posted AutoScan below.
    Wednesday,17,July,2019,14:58:56:20472
    VCDS Version: 19.6.1.0 (x64)
    Dealer/Shop Name: S81 Diagnostics
    VIN: TMBCT21Z9C2031673   License Plate: YC61VAO
    Mileage: 405520km-251978mi   Repair Order:
    Chassis Type: 1Z-SK35 (7N0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
    VIN: TMBCT21Z9C2031673   Mileage: 405520km-251978miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
       Component: 1,6l R4 CR td H43 9972
       Revision: --H43---    Serial number:
       Coding: 00114014030500080000
       Shop #: WSC 73430 031 00083
       ASAM Dataset: EV_ECM16TDI02103L906023LP 003010
       ROD: EV_ECM16TDI02103L997557A.rod
       VCID: 7F070FB6E6B284B7E0-802A
    Readiness: 1110 0000
       Revision: 00H31001
       Shop #: WSC 73430 790 00083
       VCID: 7BFFFBA6FAAA9897CC-802E
                        Reset counter: 98
                        Date: 2013.12.07
                        Time: 02:43:55
                        Count: 3
                        Count: 20992
                        Count: 195
                        Count: 44288
                        Fault Status: 01100101
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:43:42
                        Count: 3
                        Count: 2
                        Count: 20992
                        Count: 279
                        Count: 44288
                        Count: 256
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:43:42
                        Count: 3
                        Count: 2
                        Count: 20992
                        Count: 295
                        Count: 44288
                        Count: 256
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:43:42
                        Count: 3
                        Count: 2
                        Count: 20992
                        Count: 270
                        Count: 44288
                        Count: 256
       Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
       Component: Climatronic   H18 0506
       Revision: 00001007
       Coding: 0000000002
       VCID: 7CFDF8BAF7A49FAFC5-8028
              B10AB F0 [009] - Too Low
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2019.07.17
                        Time: 02:37:45
       Part No SW: 1K0 937 084 F    HW: 1K0 937 084 F
       Component: BCM PQ35  B   110 0651
       Revision: 00110 AC
       Coding: 48000AB8A05BB1C04008008011000024430000AE524D81605CC440000040
       VCID: 3163198E6866A2C726-8064
       Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 30111  26  0601
       Coding: 00D7B7
    8 Faults Found:
    01134 - Alarm Horn (H12)
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:40:01
                        Voltage: 12.20 V
                            Term 50 Off
    03156 - Sensor for Anti-Theft System (G578)
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:40:01
                        Voltage: 12.20 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:47:40
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:47:50
                        Voltage: 12.05 V
                            Term 50 Off
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Fault Status: 00101010
                        Reset counter: 138
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:48:35
                        Voltage: 11.85 V
                            Term 50 Off
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 05:20:28
                        Voltage: 12.30 V
                            Term 50 Off
    01506 - Bulb for Rear Fog; Right (L47)
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 05:20:30
                        Voltage: 12.25 V
                            Term 50 Off
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:51:52
                        Voltage: 12.15 V
                            Term 50 Off
       Component: Q4 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD2U6225
       Coding: 0020788
       VCID: 3D7B35BE643E56A7B2-8068
       Subsystem 1 - Serial number: 6332MSME666220610
       Subsystem 2 - Serial number: 6342MSME67254A43D
       Part No SW: 5K0 953 521 BJ    HW: 5K0 953 569 C
       Revision: FF010040    Serial number: 20111207800950
       Coding: 5080040000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 75EBED9ED48ECEE7BA-8020
       Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
       Component: KOMBI         H04 0607
       Coding: 410A00
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       VCID: 4993516EE8F6FA070E-801C
    9453842 - Oil Level Thermal Sensor
              B1041 35 [009] - Signal high time > maximum
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2019.07.17
                        Time: 02:40:51
    13639427 - Please Check Fault Codes in Engine Control Module
              U101F 00 [009] - -
                        Reset counter: 98
                        Mileage: 405523 km
                        Date: 2019.07.17
                        Time: 05:20:46
       Revision:   H42       Serial number: 031211F1000737
       Coding: 352303
       VCID: 3A713EA2B510619F97-806E
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 458B5D5E0CEE1E67EA-8010
       Component: IMMO          H04 0607
       VCID: 6AD1CEE28D30111F27-803E
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2120
       Coding: 0000756
       VCID: 4895546A3BFC030F11-801C
       Part No: 1K0 909 144 N
       Component: EPS_ZFLS Kl. 69     3301
       Revision: 00H22000
       VCID: 356B2D9E5C0E8EE77A-8060
    16344 - Control Module - RAM Error
                        Fault Status: 00101110
                        Mileage: 152745 km
                        Date: 2016.01.31
                        Time: 21:10:07
                        Voltage: 11.50 V
                            DU
                        Temperature: 44.0C
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0xE1D4
                        Count: 8
    16355 - Control Module - Watchdog Timer
                        Mileage: 152745 km
                        Date: 2016.01.31
                        Time: 21:10:07
                        Voltage: 11.50 V
                            DU
                        Temperature: 44.0C
                        Count: 60
                        Fault Status: 11100101
                        Mileage: 405523 km
                        Date: 2013.12.07
                        Time: 02:40:27
                        Battery Volts: 12.3 V
                            DD
                        Temperature: 27.0C
                        Count: 3
                        Steering Angle: 0.00
                            SteerAng n.Init
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000756
       VCID: 4797575636E20C7718-8012
       Part No SW: 1Z0 035 156 M    HW: 1Z0 035 156 M
       Component: BOLERO        001 0008
       Revision: -----08S    Serial number: SKZ4Z3L1155503
       Coding: 050004000001
       VCID: 3C7D38BABF245FAF85-8068
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012563
       VCID: 32611682AD6099DF5F-8066
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 336F1386527A90D754-8066
    End-------------------------(Elapsed Time: 02:36)--------------------------
                    Address 09: Cent. Elect.  (1K0 937 084 F)
    15:34:25
      Inactive   Load Management
      12.10 V   Voltage Term.(30)
      99.6 %   Generator Load
      Invalid   Quiescent Voltage Recent Phase
      Invalid   Quiescent Voltage Second Phase
      Invalid   Quiescent Voltage Third Phase
      6.0   Quiescent Voltage Total Phases
      0.000 V   Voltage Difference Mean Value
      0.0   Battery disconn. Counter
      12.15 V   Voltage Term. 30 left
      12.15 V   Voltage Term. 30 right
      12.10 V   Voltage Term. 30 refer.
    15:44:26 Group 031: Load Management
      4.0  Short-Distance Operations
    15:45:25 Group 031: Load Management
      Active  Load Management
      12.00 V  Voltage Term.(30)
    Feb 2015
    Update
    Found the charging wire, wire from ECU to alternator was damaged. Replaced this and battery is now charging correctly.
    Recoded the ABS Module (133B201C092305FBC81004EB901EA081000000) but now have the below fault.
    What is the cause of this fault, is it down to the coding?
    02186 - Engine <-> ADR Interface
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.14
                        Time: 04:21:01
                        Count: 3
                        Count: 2
                        Count: 29184
                        Count: 8206
                        Count: 51712
                        Count: 65281
    Post a new auto-scan please.
  4. Likes PetrolDave, DazJ liked this post
    Feb 2015
    Autoscan posted below.
    Recoded ABS Module, then completed basic setting for BrakePressureSensor (G201), LateralAccelerationSensor (G200) in Channel 03, then completed basic setting for SteeringAngleSensor in Channel 44.
    Steering Angle Sensor is still showing in Channel 03 and ESP Warning light is showing on the clocks.
    Wednesday,24,July,2019,16:50:17:20472
    Dealer/Shop Name:
    VIN: TMBKT21ZXC2111575   License Plate:
    Mileage: 424140km-263548mi   Repair Order:
    VIN: TMBKT21ZXC2111575   Mileage: 424140km-263548miles
       Part No SW: 03L 906 023 LQ    HW: 03L 906 023 JH
       Component: 1,6l R4 CR td H43 8880
       Coding: 00194016030700080000
       ASAM Dataset: EV_ECM16TDI02103L906023LQ 003004
       VCID: 00058C4A9B4CFB4F99-8054
    Readiness: 1110 1000
       Revision: 00H31001
                        Reset counter: 99
                        Date: 2013.12.13
                        Time: 00:17:04
                        Count: 3
                        Count: 20992
                        Count: 195
                        Count: 50944
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.13
                        Time: 00:17:03
                        Count: 3
                        Count: 2
                        Count: 29184
                        Count: 279
                        Count: 50432
                        Count: 512
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.13
                        Time: 00:17:03
                        Count: 3
                        Count: 2
                        Count: 29184
                        Count: 295
                        Count: 50432
                        Count: 512
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.13
                        Time: 00:17:03
                        Count: 3
                        Count: 2
                        Count: 29184
                        Count: 270
                        Count: 50432
                        Count: 512
       Revision: 00001007
       Coding: 0000000002
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2019.07.23
                        Time: 00:11:43
       Revision: 00110 AC
       Coding: 00D7B7
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.13
                        Time: 00:17:06
                        Voltage: 14.00 V
                            Term 50 Off
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.13
                        Time: 00:17:06
                        Voltage: 14.00 V
                            Term 50 Off
       Coding: 0020788
       Coding: 5080040000
       Part No SW: 1Z0 920 903 S    HW: 1Z0 920 903 S
       Component: KOMBI         H05 0607
       Coding: 410E00
       VCID: 458B5D5EC4EE1E67EA-8010
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2019.07.23
                        Time: 00:17:09
       Coding: 352303
       Coding: 0000005
       Component: IMMO          H05 0607
       Coding: 0000756
       Revision: 00H22000
                        Mileage: 424141 km
                        Date: 2013.12.13
                        Time: 00:17:15
                        Battery Volts: 14.2 V
                            DU
                        Temperature: 31.0C
                        Count: 3
                        Count: 1
                            SteerAng n.Init
       Coding: 0000756
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:37)--------------------------
    Gateway Installation List:  7N0 907 530 M
    Address 03,1K0 907 379 BJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,133B201C092305FBC81004EB901EA081000000,(73430/790/00083),
    Address 03: DTCs cleared
    Address 44: DTCs cleared
    Wednesday,24,July,2019,17:32:42:20472
    Dealer/Shop Name:
       Revision: 00H31001
       Coding: 133B201C092305FBC81004EB901EA081000000
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.14
                        Time: 04:21:01
                        Count: 3
                        Count: 2
                        Count: 29184
                        Count: 295
                        Count: 51712
                        Count: 65281
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.14
                        Time: 04:21:01
                        Count: 3
                        Count: 2
                        Count: 29184
                        Count: 8206
                        Count: 51712
                        Count: 65281
       Revision: 00001007
       Coding: 0000000002
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2019.07.24
                        Time: 03:51:12
       Revision: 00110 AC
       Coding: 00D7B7
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.14
                        Time: 03:51:13
                        Voltage: 12.45 V
                            Term 50 Off
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2013.12.14
                        Time: 03:51:13
                        Voltage: 12.45 V
                            Term 50 Off
       Coding: 0020788
       Coding: 5080040000
       Coding: 410E00
                        Reset counter: 99
                        Mileage: 424141 km
                        Date: 2019.07.24
                        Time: 03:51:12
       Coding: 352303
       Coding: 0000005
       Coding: 0000756
       Revision: 00H22000
       Coding: 0000756
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:32)--------------------------
    Oct 2014
    Are you sure that lcode for the ABS unit is correct and didn't show that fault previously?
    I found some other AWD Octavia scans from other members:
    133B401C0A2900FDC81402E9501B0082350000 < Tinbum
    133B401C0A2400FDC81402ED50190082310000 < Claudiu
    113B401C0A2200FA880F02E9501C0042310000 < Badea_Cristian (lhd)
    133B201C092305FBC81004EB901EA081000000 < DazJ
    133B201C0A2300FBC81004EB501E0081350000 < try this
  7. Likes Jack@European_Parts, DazJ liked this post
    Feb 2015
    Thanks for the code mate, I didn't have any scan data so was relying on a calculator.
    All ABS related faults have cleared now, however just a few queries from the calc used.
    Working Code - 133B201C0A2300FBC81004EB501E0081350000
    Previous Code - 133B201C092305FBC81004EB901EA081000000
    - On the calculator it gives the following options with no guidance for byte 04 - 09/0A/11/49/19/21/89, do you know what these values represent?
    - Byte 06 gives guidance against FWD/AWD, however from your list of other members scans this appears incorrect (00 - FWD / 01 - AWD / 05 - AWD(2011+)
    - The last 4 bytes are listed as optional extras with some guidance.
    Once again thank you for your recommendation.
    Oct 2014
    Not sure what byte 04/12 is :/
    As for byte 06/14, I think that's been 00 on every scan I found for an Octavia. Never seen any guidance apart from the 2 stage ESP off tweak that's popular.
    I'd expect a fault code if the ABS unit was coded for FWD in the AWD vehicle so it's probably OK assuming there are no faults
