Results 1 to 7 of 7
Thread: Polo 1.2 tdi 2014 year delphi dcm 3.7
    Jun 2018
    Turkey
    sometime lose 1 and 3 injector signal and car not working
    I see same problem 2 times in my history in different cars..but not fixed..
    vcds not any dtc..in engine ecu,also I make .frf update to last version but still this error..
    may be anyone found solution..thanks
    btw: car came from diesel shop..its not inj error,also seem not dpf or egr error too ,because we remove exhaust too
    Please post an Auto-Scan for context, even if the are no DTCs.
  3. Likes emin liked this post
    Jun 2018
    Turkey
    Hello Boss
    here autoscan...no dtc..I was tried remove egr pipes,connectors,dpf pipes exhaust too...but car same...
    problem may be mechanic too..But I dont have any expeirence before on it..Help please
    Saturday,20,July,2019,18:08:45:11570
    VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: beyinci.com
    Workshop Code: 389 04501 103077
    VIN: WVWZZZ6RZBY262994   License Plate:
    Mileage: 140370km-87221mi   Repair Order:
    Chassis Type: 6R-VW25 (6R0)
    Scan: 01 03 08 09 15 17 19 25 44 56 61
    VIN: WVWZZZ6RZBY262994   Mileage: 140370km-87221miles
    Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 B    HW: 03P 907 425
       Component: R3 1.2l TDI   H06 9980
       Revision: 12005001    Serial number:
       Coding: 00114014032401080000
       ASAM Dataset: EV_ECM12TDI03103P906021B 001043
       ROD: EV_ECM12TDI03103P906021AA.rod
       VCID: 271E02265EC02677F8-8072
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0001
       Revision: --------
       Coding: 210224E3417300B4842E24EB82D500521300
       Shop #: WSC 00788 648 00255
       VCID: 075E62A6B2000677D8-8052
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
       Component: Man AC         02 0101
       Revision: 0002S 02
       VCID: 3228E3726D0253DF5F-8066
       Part No SW: 6R0 937 088 D    HW: 6R0 937 088
       Component: BCM PQ25 Re4  H46 0322
       Revision: BU046001    Serial number: 0379 062110025
       Coding: 24B02BBF08A10000003009B03C2B0CD0CF80610F7E860441A00000000000
       VCID: 3FCEBA46AE508EB7A0-806A
       Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  007 1611
       Serial number: KU0KU024021100012698
       Coding: 58BC30
       Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  007 1611
       Serial number: KU0KU002031100010124
       Coding: 48BC30
       Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
       Component: J388__TSG_HL  007 1611
       Serial number: KU0KU028021100010036
       Coding: 48BC32
       Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
       Component: J389__TSG_HR  007 1611
       Serial number: KU0KU001031100011989
       Coding: 48BC32
       Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
       Component: VW10Airbag00E H09 0020
       Revision: --------    Serial number: 003GW00412V3
       Coding: 003045
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 49DAA49EE89430070E-801C
       Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
       Component: KOMBI         H05 0304
       Coding: 140800
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 383CD15A837EB98F61-806C
    Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
       Part No SW: 6R0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H38 0025
       Revision:   H38       Serial number: 110211F1002309
       Coding: 2500C2
       VCID: 3326E67692185AD754-8066
    01304 - Radio
                        Reset counter: 204
                        Mileage: 140376 km
                        Date: 2013.12.10
                        Time: 17:49:09
       Component: IMMO          H05 0304
       VCID: 6A983B128D52DB1F27-803E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11230
       Shop #: WSC 00788
       VCID: 2F2EEA06EA307E3730-807A
    Address 56: Radio
       Part No SW: 6R0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H38 0025
       Coding: 03031A5A
       VCID: 74A4256AD7961DEF8D-8020
       Subsystem 1 - Part No SW: 6R0 915 181 B    HW: 6R0 915 181
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370594572
    End----------(Elapsed Time: 00:58, VBatt start/end: 12.4V/12.4V)-----------
    Jun 2018
    Turkey
    solved myself,special thanks to me
    Quote Originally Posted by emin View Post
    To help others, please post how you solved the problem
  7. Likes Uwe liked this post
    Jun 2018
    Turkey
    wiring problem near the ecu
  9. Likes Uwe liked this post
  10. #7
    Aug 2016
    The Hague, NL
    Interesting to see it didn't show as a DTC. Good you fixed it
