Greetings from Norway...
I have some issues with the steering on a VW Polo 9N from 2003.
The steering wheel was off by approx 20 degrees and the ESP indicator light went on.
This seems to be reset if I turn the engine off, align the steering to the mechanical position of the wheels (straight ahed) and then turn engine on again.
It lasts for about 200 meters and there we go again...
So, I did a complete scan.
I have performed the procedure for calibration the G85 without any errors, but it still only lasts for 200 meters.
I belive that the G85 itself is faulty. Should I perform any other tests before replacing it?
Wednesday,17,July,2019,13:44:26:19306
VCDS Version: 19.6.1.0
VIN: WVWZZZ9NZ5Y094792 License Plate:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ5Y094792 Mileage: 125720km-78118miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 GQ
Component: MARELLI 4TV 6280
Coding: 00071
VCID: 67D744950526BE7738-4B00
WVWZZZ9NZ5Y094792 VWZ7Z0D0930085
Readiness: 1110 0001
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP80.clb
Part No SW: 6Q0 907 379 T HW: 6Q0 907 379 T
Component: ESP 8.0 front H03 0002
Coding: 0000305
Shop #: WSC 00788 785 00200
VCID: 4E999131DA9C4F3F5B-515A
Reset counter: 149
Mileage: 125724 km
Address 08: Auto HVAC Labels: 6Q0-907-044.lbl
Part No: 6Q0 907 044 B
Component: CLIMAtronic PQ24 0201
VCID: 3163EACDAB6230C726-515A
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 26046
Shop #: WSC 00788
VCID: 3C7DCBF92C20CDAF85-515A
Part No: 1C0 909 605 K
Component: 18 AIRBAG VW51 0P 0008
Coding: 12600
Shop #: WSC 00788
VCID: 2C5DFBB9DC405D2F15-515A
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 800
Component: KOMBI+WEGFAHRSP VDO V19
Coding: 01141
VCID: 6AD13DA11634831F27-513C
Part No: 6N0 909 901
Component: 001H GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: 70E52FC930E879CF69-515A
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10140
Shop #: WSC 00788
VCID: 6FE72CB52DD6663770-515A
Address 46: Central Conv. Labels:. 6Q0-959-433.clb
Part No: 6Q0 959 433 H
Component: 1G Komfortgerát 0002
Coding: 00067
Shop #: WSC 00788
VCID: 4085BF0940C8A94FD9-4B00
Subsystem 1 - Part No: 6Q2959802A
Component: 1G Tõrsteuer.FS TFK 0004
Subsystem 2 - Part No: 6Q2959801A
Component: 1G Tõrsteuer.BF TFK 0004
End-------------------------(Elapsed Time: 03:30)--------------------------
