Results 1 to 2 of 2
Thread: 00778 - Steering Angle Sensor (G85)
    Apr 2015
    Norway
    Greetings from Norway...
    I have some issues with the steering on a VW Polo 9N from 2003.
    The steering wheel was off by approx 20 degrees and the ESP indicator light went on.
    This seems to be reset if I turn the engine off, align the steering to the mechanical position of the wheels (straight ahed) and then turn engine on again.
    It lasts for about 200 meters and there we go again...
    So, I did a complete scan.
    Wednesday,17,July,2019,13:44:26:19306
    VCDS Version: 19.6.1.0
    VIN: WVWZZZ9NZ5Y094792   License Plate:
    Chassis Type: 9N (9N - VW Polo (2002 > 2010))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ5Y094792   Mileage: 125720km-78118miles
    Address 01: Engine        Labels: 036-906-034-APE.lbl
       Part No: 036 906 034 GQ
       Component:  MARELLI 4TV        6280
       Coding: 00071
       VCID: 67D744950526BE7738-4B00
       WVWZZZ9NZ5Y094792     VWZ7Z0D0930085
    Readiness: 1110 0001
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.clb
       Part No SW: 6Q0 907 379 T    HW: 6Q0 907 379 T
       Component: ESP 8.0 front   H03 0002
       Coding: 0000305
       Shop #: WSC 00788 785 00200
       VCID: 4E999131DA9C4F3F5B-515A
                        Reset counter: 149
                        Mileage: 125724 km
    Address 08: Auto HVAC        Labels: 6Q0-907-044.lbl
       Part No: 6Q0 907 044 B
       Component: CLIMAtronic PQ24    0201
       VCID: 3163EACDAB6230C726-515A
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 D
       Component: 0000 BN-SG.         1S34
       Coding: 26046
       Shop #: WSC 00788
       VCID: 3C7DCBF92C20CDAF85-515A
       Part No: 1C0 909 605 K
       Component: 18 AIRBAG VW51 0P   0008
       Coding: 12600
       Shop #: WSC 00788
       VCID: 2C5DFBB9DC405D2F15-515A
    Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
       Part No: 6Q0 920 800
       Component: KOMBI+WEGFAHRSP VDO V19
       Coding: 01141
       VCID: 6AD13DA11634831F27-513C
       Part No: 6N0 909 901
       Component: 001H GATEWAY CAN    1S34
       Coding: 00014
       Shop #: WSC 00788
       VCID: 70E52FC930E879CF69-515A
       Part No: 6Q0 423 156 AB
       Component: LenkhilfeTRW        V270
       Coding: 10140
       Shop #: WSC 00788
       VCID: 6FE72CB52DD6663770-515A
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 6Q0 959 433 H
       Component: 1G Komfortgerát     0002
       Coding: 00067
       Shop #: WSC 00788
       VCID: 4085BF0940C8A94FD9-4B00
       Subsystem 1 - Part No: 6Q2959802A
       Component: 1G Tőrsteuer.FS TFK 0004
       Subsystem 2 - Part No: 6Q2959801A
       Component: 1G Tőrsteuer.BF TFK 0004
    End-------------------------(Elapsed Time: 03:30)--------------------------
    I have performed the procedure for calibration the G85 without any errors, but it still only lasts for 200 meters.
    I belive that the G85 itself is faulty. Should I perform any other tests before replacing it?
    Recheck mechanical baseline positions again at components directly & for improper alignment.
