Results 1 to 5 of 5
Thread: 2011 Touareg MFD steering wheel buttons wont work.
    Nov 2016
    I recently bought a Touareg but my steering wheel buttons and horn does not work. The Airbag light is NOT on and the cruise control does work. VW looked at it and said that they believe its the clock spring. I replaced the clockspring, re coded it, and re calibrated the steering angle sensor but the problem remains the same. I have the 02071 - Local Databus: No Signal/Communication Error. Do you guys think its the module inside the steering wheel itself or is there something I am missing. FWIW. For anybody that needs to disconnect the battery in a 2011+ Touareg, there is a disconnect located in the drivers footwell in front of the seat. Its a lot easier than removing the seat.
    Can we get an Auto-Scan for complete context please?
    Nov 2016
    Wednesday,17,July,2019,17:45:57:59829
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVGFK9BP6BD005553   License Plate:
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
              62 65 69 6C 6D 72
    VIN: WVGFK9BP6BD005553   Mileage: 191760km-119154miles
    Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
       Component: 3.0TDI FSA    H17 0008
       Revision: 56H17---
       Coding: 292A4012233600050000
       Shop #: WSC 04909 444 00000
       ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
       ROD: EV_ECM30TDI0117P0907401J_002.rod
       VCID: 3662A77B89AEC8FF73-8062
    Readiness: 0 0 0 1 1
       Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
       Component: AL1000 AISIN  001 3407
       Coding: 001368
       Shop #: WSC 09198 003 1048576
       ROD: EV_TCMAL991031_002.rod
       VCID: 306E91636BCAE6CF29-8064
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
       Component: MK25A         H36 0418
       Revision: --------    Serial number: 406110010EC010
       Coding: 5B7613C349242558DAF9C89892D5A4407700
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 007001
       ROD: EV_ESPMK25A00700.rod
       VCID: 4580D0B7C4485367EA-8010
       Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 AK
       Component: BCM2 2.0      H24 0217
       Coding: 0D860000000000000000
       VCID: 72EA5B6BAD4694DF9F-8026
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 2311000045963009
       Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
       Component: Klima 2 Zonen H18 0613
       Coding: B686200A80
       VCID: 79F86C47F830E787DE-802C
       Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0092
       Revision: 15012002    Serial number: 00000000823550
       Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
       VCID: 3168946768C0EFC726-8064
       Component: WWS    110305  31  0020
       Serial number: 90243400110312103614
       Coding: 004DBD
       Component: RLFS  H09 0011
       Serial number: 10135348
       Coding: 035223
       Component: E1 - LDS  H04 0031
       Serial number: 00000000001802110330
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R0B7606
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475     HW: 7P6 919 475
       Component: PARKHILFE 8K  H03 0016
       Revision: --------    Serial number: 55901103800370
       Coding: 318501
       ASAM Dataset: EV_VW526ParkiAssis2 001008
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 55A000F734E8E3E79A-8000
       Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
       Component: VW10Airbag025 H05 0023
       Revision: --------    Serial number: 003JX001V1EG
       Coding: 000000000000000000000000000000003235
       VCID: 408EC1A3DB6A764FD9-8014
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R10A01020KK
       Serial number: 3575LRB405H0EACC2H55
       Serial number: 3585LRB40530EACCB14R
       Serial number: 3515RRB40630G944JPGD
       Serial number: 3525RRB40670H4DQIGJ
       Serial number: 3555NRB404V0CIU04GF+
       Serial number: 3565NRB404V0CIU0K1M7
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372SBK000AC
       Coding: 000C15
       VCID: 387EA9438BBA3E8F61-806C
                        Fault Frequency: 15
                        Reset counter: 169
                        Mileage: 191728 km
                        Date: 2019.07.16
                        Time: 00:21:34
                        Reset counter: 40
                        Mileage: 191757 km
                        Date: 2019.07.16
                        Time: 21:19:33
                        Reset counter: 40
                        Mileage: 191760 km
                        Date: 2019.07.16
                        Time: 21:24:20
       Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
       Component: Kombi         H13 0239
       Revision: 11240062    Serial number: 658250211593013
       Coding: 8B7733022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 479CDABFFE44417718-8012
       Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5202
       Revision: --------    Serial number: 00000000108385
       Coding: 0001037500
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 387EA94383BA3E8F61-806C
       Serial number: 00000000005650764688
       Revision: AA000000    Serial number: 00001002343677
       Coding: 00581B0000004001000001010101202020202121202020
       VCID: 34669D7397D2DAEF4D-8060
       Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
       Component: TSG FA        H07 0162
       Revision: --------    Serial number: 0000113896634
       Coding: 011D17205E00453005080000
       VCID: 3C76B553BF8212AF85-8068
       Revision: 00002001    Serial number: 0144492504
       Coding: 0186123A28B9509580A00620210000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 349104754
       Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
       Component: J245 PS30.050  H07 0006
       Serial number:     WOO11378093
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
       Component: J394 PS30.050  H07 0006
       Serial number:     WOO1144072-
       Coding: 191100
    01134 - Alarm Horn (H12)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 139
                        Mileage: 189795 km
                        Date: 2019.06.29
                        Time: 12:56:11
       Part No SW: 7P6 035 466     HW: 7P6 035 466
       Component: DSP Prem      H01 0090
       Revision: 00001001    Serial number: 10811000483002
       VCID: 75E06077DC2883E7BA-8020
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0162
       Revision: --------    Serial number: 0000113694315
       VCID: 3B74B64FBA8C15978C-806E
       Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
       Component: EPB           H51 1100
       Revision: 00000000    Serial number: A1121300170
       Coding: 01040000
       Shop #: WSC 05356 001 1048576
       ROD: EV_ParkbA7.rod
       VCID: 3560A07794A8C3E77A-8060
       Slave 3:
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 010A00010F000400
       VCID: 7CF67553F702D2AFC5-8028
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0001
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0001
       Coding: 130000
       Part No SW: 4G0 035 082     HW: 4G0 035 082
       Component: Radio U SIRIU H51 0052
       Revision: AB001007    Serial number: 471CV0B7563414
       Coding: 020007010000000001
       Shop #: WSC 08308 002 1048576
       VCID: 5DB018D744D83BA7D2-8008
       Part No SW: 7P6 035 664     HW: 7P6 035 664
       Component: H-BN-NA       H43 0170
       Revision: --------    Serial number: 445CY0B7511747
       Coding: 020200050040E1EF41022B0E00000003F0080101
       Subsystem 1 - Part No: 8R0 060 884 P
       Component: NAR 2010  0407
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H24 0045
       Serial number: VWZ8Z9L29005BB
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0162
       Revision: --------    Serial number: 0000113828712
       Coding: 011C17200000253005080000
       VCID: 3A7AB34BB5B62C9F97-806E
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000024635
       ROD: EV_RDKBERU25_VW52.rod
       VCID: 3F8CC25FA69409B7A0-806A
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H09 0110
       Revision: 5A001001    Serial number: 00000139920641
       Coding: 020D000000000000
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H04000    Serial number: 525 PA8J112031
       Coding: 0130001
       VCID: 377CAA7F46A431F768-8062
       Part No SW: 7P6 959 107     HW: 7P6 959 107
       Component: HDSG-Modul    H10 0611
       Revision: 22010001    Serial number: 060100049
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202135
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H09 0162
       Revision: --------    Serial number: 0000113829174
    End-------------------------(Elapsed Time: 05:02)--------------------------
  4. Likes Uwe liked this post
    If you've already replaced the clockspring (which is integral with the steering wheel control module in this vehicle, right?) then I'm not sure what else it could be other than the button modules themselves.
    Have you looked at the Measuring Values? The first eight or so have real-time status information for the various controls on (and around) the steering wheel.
    Nov 2016
    I have no communication with the button module. The buttons also has no backlight. So I think there is no power going to them. Its either the steering wheel or wires in the airbag module i guess.
