Results 1 to 8 of 8
Thread: Octavia Long coding help
    Dec 2016
    Hi Guys
    Have a 2016 Skoda Octavia 1.6tdi here. Customer had another car with faulty fuel gauge in the cluster and tried to swap clusters over to confirm problem was in the cluster.
    So now as usual ABS coding lost on both cars.
    Can anyone please help with possible coding for ABS.
    thanks
    uesday,16,July,2019,13:57:21:30982
    VIN: TMBKG7NE4G0160555   License Plate: GC65NNU
    Mileage: 121203km-75312mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 20 42 44 52 5F
    VIN: TMBKG7NE4G0160555   Mileage: 121203km-75312miles
    Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
       Component: R4 1.6l TDI   H06 2506
       Revision: 22004001
       Coding: 01114012432519090000
       Shop #: WSC 63751 002 1048576
       ASAM Dataset: EV_ECM16TDI03004L906056CL 002006
       ROD: EV_ECM16TDI03004L906056_002_VW37.rod
       VCID: 79BAE047F8A05487DE-802C
    25126 - Databus
              U1123 00 [035] - Received Error Message
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:53
                        Coolant temperature: 52 °C
                        Intake air temperature: 50 °C
                        Voltage terminal 30: 12.234 V
                        CAN status - engine control module: 0
                        Cruise Control System (CCS): status: main switch off
    Readiness: N/A
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 63385000002760
       Shop #: WSC 73430 031 00063
       ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
       VCID: 4BD66A8FE2BC16173C-801E
    8 Faults Found:
    0195 - Control module not coded
              U1013 00 [137] - -
              [ECU marked as Not Configured because vehicle ID is invalid]
                        Reset counter: 9
                        Date: 2019.07.16
                        Time: 13:34:52
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 9
                        Date: 2019.07.16
                        Time: 13:34:52
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 9
                        Date: 2019.07.16
                        Time: 13:34:52
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 9
                        Date: 2019.07.16
                        Time: 13:34:52
    0295 - Steering angle sensor
                        Reset counter: 9
                        Date: 2019.07.16
                        Time: 13:34:52
    8278 - Control Module Incorrectly Coded
              U1014 00 [137] - -
              [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                        Reset counter: 9
                        Date: 2019.07.16
                        Time: 13:34:52
    8306 - Databus
              U1122 00 [137] - Implausible Message
              [FCAN: Unplausible VIN number]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:57
    8308 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                        Reset counter: 9
                        Date: 2019.07.16
                        Time: 13:34:52
       Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
       Component: Climatronic   H04 1002
       Revision: 00001K07
       Coding: 02110104002100011005000000101000
       VCID: 3326126F9A4C6ED754-8066
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580812152840
       Coding: 0F000942424702FB07A04082B10C07280000000000000000000000000000
       Shop #: WSC 73430 790 00063
       ROD: EV_BCMBOSCH_015.rod
       VCID: 034682AF8A6C1E5784-8056
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 150925  041 0570
       Serial number:         151027060949
       Coding: 065DDD
       Component: RLHS  037 0059
       Serial number: S4Y15M12D16H07M00S33
       Coding: 00885D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY152570EGW
       Component: Sirene, DWA  005 0312
       Serial number: 00000000000033863520
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0054
       Revision: --------    Serial number: 39291534201177
       Coding: 0001050001
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       VCID: 3C343953B712A1AF85-8068
    13637426 - Databus
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 23111503213186
       Coding: 00000200FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       VCID: 3A383F4BBD269F9F97-806E
    1071 - Databus
              [FAULT_CIS_AXV_INVALID]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
                        Control Module temperature: 27 °C
                        Voltage terminal 15: 12.0 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
    1078 - Databus
              [FAULT_CIS_SAS_INIT]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
       Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
       Component: Airbag VW20   013 0200
       Revision: --------    Serial number: 003SQPRGC5S+
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 0F6EBE9FD6246A3710-805A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 612 15
       Serial number: 3576U000000B3089B71F
       Subsystem 2 - Part No SW: -----------    HW: 454 000 512 15
       Serial number: 3586U0000003D795871J
       Subsystem 3 - Part No SW: -----------    HW: 454 802 511 15
       Serial number: 3516REC4FF808000000W
       Subsystem 4 - Part No SW: -----------    HW: 454 800 212 15
       Serial number: 3526R8A014E090000003
       Subsystem 5 - Part No SW: -----------    HW: 454 801 410 15
       Serial number: 3556VF222D1080000007
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
       Part No SW: 5Q0 953 521 M    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20151210500480
       Coding: 1400
       ROD: EV_SMLSVALEOMQB.rod
       Part No SW: 5E0 920 951 B    HW: 5E0 920 951 B
       Component: KOMBI         324 6422
       Coding: 27A40A002180A60001886A011000000000000000
       VCID: 2600FB3B599E0B7FC3-8072
    16776973 - Databus
              [RKA_01 keine Kommunikation]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004245273
       Coding: 030100045F087300EB000248080F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000D0387271115
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185704001512132637
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 5G0 857 511 D    HW: 5G0 857 511
       Component: FLA           H04 0002
       Revision: AA001001
       Coding: 01028F6B76765D525220343E01
       VCID: 2B160A0F427C36171C-807E
       Serial number: 0000178773848
       Coding: 00150020D001040000001100
       VCID: 47DE56BFFED4F27718-8012
       Serial number: 00000000000008319031
       Coding: 1D0200
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 8103
       VCID: 44C441B3CFE2D96FFD-8010
    15873 - Steering angle sensor
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:51
                        Motor status: 00
                        Supply voltage: 11.75 V
                        Temperature: 27.0 °C
                        KFC: 3E
                        KFA: 00 01
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 11.91 V
                        uAdSensI_SwitchedKl30_xdu16: 11.91 V
       Serial number: 0000178897502
       VCID: 46C05BBBF9DEEB7FE3-8012
       Serial number: 00000000000008353717
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 874 A    HW: 5Q0 035 874 A
       Component: MU-S-ND-ER    H24 0245
       Serial number: SKZAZ2R8132372
       Coding: 03730201FF00000011111201008800002F0200C601200100C6
       ROD: EV_MUStd4CTSAT_VW41.rod
       VCID: 3228176B655667DF5F-8066
       Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
       Component: ABT_Std-2_Nav  H41 1028
       Serial number: SKZ8Z9RBT01AZF
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:54
                        Voltage terminal 30: 11.9 V
                        BAP-BAP_Function_ID: 02
    7206 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.16
                        Time: 13:34:54
    End----------(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.0V)-----------
    16.4905° S, 151.7375° W
    Silly question did you happen to perform an Auto-Scan on the vehicles before the work was done? Even if you did not save it, check the 'Scans folder in you VCDS directory.
    Worth a look... hope this helps,
    drpeter
    Dec 2016
    Hi Peter
    We only got car after dash had already been swapped.
    Quote Originally Posted by NWT View Post
    Hi Peter
    - Sorry to hear that, the coding is vehicle specific and it does not look like we have any details about this controller's coding. It looks like the vehicle will need to be coded with an online connection to the manufacture with the factory (ODIS) scan tool using the Software-Version-Management (SVM) test plan.
    drpeter
    ps... Would anyone else have an Auto-Scan???
  5. Likes Jack@European_Parts liked this post
    Dec 2016
    Ok, thanks anyway Peter. Thanks for the info.
    Oct 2014
    Arandjelovac, Serbia
    VIS database:
    The following code has been computed for the control unit EV_Brake1UDSContiMK100IPB:
    1C0762911426096C007C060541C8243846289000608224F200400070C002
    So You can try and report.
  8. Likes Uwe, Jack@European_Parts, DrPeter liked this post
    Oct 2014
    Arrow
    Tnx Uwe!
  10. Likes Uwe liked this post
  11. #8
    Dec 2016
    Thanks soo much Boki Ar. Car did accept coding but does have a few communication errors in other modules, and still fault stored for coding. No coding helper at all to try and correct vehicle specs. Still managed to adapt most sensors as well except steering angle sensor. Will take car out later and try that again.
    Saturday,20,July,2019,08:51:39:30982
    VIN: TMBKG7NE4G0160555   License Plate: 20.7.19
       Revision: 22004001
    25126 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:08
                        Engine speed: 845.00 /min
                        Normed load value: 38.4 %
                        Coolant temperature: 17 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 14.953 V
    Readiness: N/A
       Coding: 1C0762911426096C007C060541C8243846289000608224F200400070C002
                        Reset counter: 9
                        Date: 2019.07.20
                        Time: 08:45:07
              U1014 00 [137] - -
                        Reset counter: 9
                        Date: 2019.07.20
                        Time: 08:45:07
    8299 - Databus
              [FCAN: Anhaenger_01_alt veraltet bit is set]
                        Reset counter: 9
                        Date: 2019.07.20
                        Time: 08:45:07
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:16
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:16
       Revision: 00001K07
       Coding: 065DDD
       Coding: 00885D
       Coding: 0001050001
    13637426 - Databus
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:06
    1071 - Databus
                        Reset counter: 49
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:06
                        Control Module temperature: 21 °C
                        Voltage terminal 15: 14.8 V
    1058 - Databus
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:09
                        Voltage terminal 15: 14.6 V
    1059 - Databus
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:06
    1078 - Databus
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:06
              B13BC F2 [008] - No function
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:06
       Coding: 1400
       Revision: AA001001
       Coding: 1D0200
       Coding: 8103
    19204 - Databus
              [ESP_02 Botschaft - SNA_Check]
                        Reset counter: 49
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:06
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 14.50 V
                        Temperature: 24.0 °C
                        KFC: 4B
                        KFA: 00 04
                        Environmental conditions: 25
                        uioUdNotFilt_xdu16: 14.72 V
                        uAdSensI_SwitchedKl30_xdu16: 14.71 V
                        Reset counter: 9
                        Mileage: 121203 km
                        Date: 2019.07.20
                        Time: 08:45:06
                        Motor status: 01
                        KFC: 3E
                        KFA: 00 01
                        uioUdNotFilt_xdu16: 14.42 V
                        uAdSensI_SwitchedKl30_xdu16: 14.41 V
       Coding: 050200
    End----(Elapsed Time: 01:38, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
