Results 1 to 8 of 8
Thread: Channel Not Available Polo AW 2018
    Jul 2019
    Brazil
    I have a Hex v2 and when it's time to adapt on Channel 17 Instruments, the Channel Not Available message appears.
    Do I need to do any procedure or installation of a Beta or Alpha product?
    Thank you!!!
    Monday,15,July,2019,19:24:15:00092
    VIN: 9BWAL5BZ1JP065524   License Plate:
    Mileage: 12012km-7463mi   Repair Order:
    Chassis Type: BZ-VW27 (2QW)
    Scan: 01 03 08 09 15 17 19 44 5F
    VIN: 9BWAL5BZ1JP065524   Mileage: 12012km-7463miles
    Address 01: Engine (0001-CNXC)       Labels: None
       Part No SW: 04E 906 032 AS    HW: 04E 907 425 F
       Component: R4 1.6l MPIH04 5245
       Revision: --H04---
       Coding: 01110016020400000000
       Shop #: WSC 01530 935 00200
       ASAM Dataset: EV_ECM16MPI02104E906032AS 002002
       ROD: EV_ECM16MPI02104E906032AS_002.rod
       VCID: 71BFD582F1291F4F357-8024
       Part No SW: 2Q0 614 517 S    HW: 2Q0 614 517 L
       Component: ESC_base      H13 0222
       Serial number: 86400234180113
       Coding: 31044B6717478CB2D201E81814DE126A49444926224A242444542254452848569222926444522424222A442AA22924400494240220
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: EV_Brake1BOSCHESPMQBA0.rod
       VCID: 3E253EBEF0F7B037F85-806A
       Part No SW: 6EA 820 045     HW: 6EA 820 045
       Component: SG_AC_Manuell H50 0301
       Coding: 012000000800000010000000000000000000000000000000000000000000
       ASAM Dataset: EV_ACManuePrehMQBA0 001011
       ROD: EV_ACManuePrehMQBA0_VW27.rod
       VCID: 6FBBD3FAE71D09BF233-803A
       Part No SW: 2QW 937 089     HW: 2QW 937 089
       Component: BCM A0 Entry  H65 0612
       Serial number: 70117321034801
       ASAM Dataset: EV_BCMA0 104001
       ROD: EV_BCMA0_104.rod
       VCID: 1E65DE3E5037D037D85-804A
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 2Q1 959 881     HW: 2Q1 959 881
       Component: FHSG_DRV  001 0001
       Serial number: 00000000000018908601
       Coding: 130000
       Subsystem 2 - Part No SW: 2Q1 959 882     HW: 2Q1 959 882
       Component: FHSG_PSG  001 0001
       Serial number: 00000000000019263829
       Coding: 090000
       Serial number: 000000000ZY1733326BA
       Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000018610958
       Coding: 030000
       Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000018592473
       Coding: 1B0000
       Part No SW: 2QB 959 655     HW: 2QB 959 655
       Component: VW22Airbag    010 0246
       Revision: --------
       Coding: 88C0C00000000000540000CF000000000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 0C41A476F6CB52A7A61-8058
       Subsystem 1 - Part No SW: -----------    HW: 442 1A1 912 17
       Component: SideSensor_Df  2C4 0148
       Serial number: 349B4D19B28A7CC5A349
       Subsystem 2 - Part No SW: -----------    HW: 442 1A1 912 17
       Component: SideSensor_Pf  2C4 0148
       Serial number: 350B4D1AD28A7CC64192
       Subsystem 3 - Part No SW: -----------    HW: 442 131 708 17
       Component: FrontSensor_D  290 118A
       Serial number: 355AG119926DCC3254C1
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 6EA 920 740 A    HW: 6EA 920 740 A
       Component: KOMBI         309 0460
       Coding: 082D02002000000C020932001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001020
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
       VCID: 33331F8ACBB56D5F07B-8066
       Part No SW: 2QW 909 901     HW: 2QW 937 089
       Component: GW MQB A0     H65 0612
       Coding: 0101000020086400F8000008080F00000000000000000000000000000000
       ASAM Dataset: EV_GatewA0 013020
       ROD: EV_GatewA0_VW27.rod
       VCID: 1675C61EB8079877005-8042
       Subsystem 2 - Part No SW: 18D 959 442     HW: 18D 959 442
       Component: E221__MFL-YLG  H01 0120
       Serial number: 000000000A0133111017
       Coding: 200000
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
       Component: TRW_G4L_MQBA0 610 6030
       Serial number: 01HBL0F9DC15GR0
       Coding: 00000001000000000101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
       VCID: 392F2DA2E9D9970FCD7-806C
       Part No SW: 5G0 035 280 C    HW: 5G0 035 280 C
       Component: MU-G--RW      557 5516
       Serial number: VWZ7Z2U3601014
       Coding: 02721000AA00000000220001010000002F0006140000010003
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_MUGlb4CGen25TPWR 001001
       ROD: EV_MUGlb4CGen25TPWR_VW27.rod
       VCID: 211FE5C26149EFCFE57-8074
    End----------(Elapsed Time: 00:37, VBatt start/end: 11.9V/12.0V)-----------
    Jul 2019
    Brazil
    Not all clusters support the channel for Staging.
    PS: Moving to tweaks because I do not think this is a problem with VCDS.
    Jul 2019
    Brazil
    Thanks for listening. Sorry for attaching the help to another topic.
    Jun 2017
    What about Byte 1 Bit 0 in unit 17?
    Staging does not work anymore for the Active Info Display Gen 2, but according to your part no it should be a classic analog cluster?
    It is active on his Coding.
  7. Likes Uwe liked this post
    Jul 2019
    Brazil
    I got it in coding! Exactly this way!
    Thank you.
  9. #8
    Jul 2019
    Brazil
    Thank you.
