Results 1 to 3 of 3
Thread: VW Polo 6C DSG Reset and Adaption procedure
    Feb 2018
    Egypt
    Hello everyone,
    I'm newbie to VCDS and I found this : http://wiki.ross-tech.com/wiki/index..._%28DSG/0AM%29 But couldn't find any group numbers - is there a specific procedure to follow?
    Scan :
    Monday,15,July,2019,19:54:05:52234
    VIN: WVWZZZ6RZFY279292   License Plate: 3727254
    Mileage: 43232km-26863mi   Repair Order:
    Chassis Type: 6R-VW26 (6C0)
    Scan: 01 02 03 08 09 15 17 19 44 5F
    VIN: WVWZZZ6RZFY279292   Mileage: 43232km-26863miles
    Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
       Component: R4 1.2l TFS   H21 9314
       Revision: R4H21---
       Coding: 01250012230411080000
       Shop #: WSC 10690 730 00000
       ASAM Dataset: EV_ECM12TFS01104E906027BB 001010
       ROD: EV_ECM12TFS01104E906027BB.rod
       VCID: 6597B1D1E5ED068F59F-8030
       CAN Converter 01:
       Part No SW: 0CW 300 048 S    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 6560
       Revision: 00043014    Serial number: CU501502095372
       Shop #: WSC 00788 648 00255
       ROD: EV_TCMDQ200021_VW26.rod
       VCID: 4CC164756647D7C7661-8018
       Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0003
       Serial number: 08506601150219
       Coding: 21DD2885892A33C9111610720053841491CC88080005CB098F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
       VCID: 33331F891BB9A83F07B-8066
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
       Component: AC Manuell    H03 0108
       Serial number:  1502131B-0320
       Coding: 200000011000100000
       ROD: EV_ACManueKMMValeoPQ26.rod
       VCID: 1D67D9318D3D0E4FC1F-8048
    1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
              B10F0 00 [012] - -
                        Reset counter: 69
                        Mileage: 43054 km
                        Date: 2019.07.06
                        Time: 20:15:18
                        Voltage terminal 30: 14.3 V
                        Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 B    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H07 0065
       Serial number: 001098078832
       Coding: 000018404253007B4B844000400703881000580251010000000000000000
       ASAM Dataset: EV_BCMA0 004008
       ROD: EV_MQBA0.rod
       VCID: 2F3B13F9F7918CDF633-807A
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  003 8612
       Serial number: KU0KU003021550345083
       Coding: 0400A0
       Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  003 8612
       Serial number: KU0KU026011550268194
       Coding: 1400A0
       Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
       Component: J388__TSG_HL  003 8611
       Serial number: KU0KU006021550374267
       Coding: 0400A0
       Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
       Component: J389__TSG_HR  003 8611
       Serial number: KU0KU005021550363798
       Coding: 1400A0
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
       Component: VW20Airbag01B 001 0330
       Revision: --------    Serial number: 003LM0095C5Y
       Coding: 88C0C000000000005C0000CA000800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 313F1581E1A59A2F757-8064
       Subsystem 1 - Part No SW: -----------    HW: 410 820 202 15
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00A518F2600529E
       Subsystem 2 - Part No SW: -----------    HW: 410 820 202 15
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00A519B7D32D37-
       Subsystem 3 - Part No SW: -----------    HW: 442 151 202 15
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00B718F262641BE
       Subsystem 4 - Part No SW: -----------    HW: 442 151 202 15
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00B718F2624926E
       Part No SW: 6C0 920 740 A    HW: 6C0 920 740 A
       Component: KOMBI         211 0290
       Coding: 0724090821800808000800001000000000000000
       VCID: 2019E0C5BA4F23A7EA9-8074
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H07 0065
       Revision: --------    Serial number: 001098078832
       Coding: 03010004370A560070000000000000010001010000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: EV_GatewA0Lear_001_VW26.rod
       Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
       Serial number: 0491504303300520AB1B
       Coding: 240000
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 62052J12292821572744
       Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  312 3211
       Serial number: PF330640
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 323D1A8DE4A3A1370CD-8066
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
       Component: MU-E--ER      820 6230
       Serial number: 20111400010772
       Coding: 02620000BE00000041110001000130001F0000840000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001017
       ROD: EV_MUEnt4CGen2LGE_VW26.rod
       VCID: 2A0D02EDCC73E9F7B4D-807E
    End----------(Elapsed Time: 00:42, VBatt start/end: 12.1V/12.0V)-----------
    A little backstory : since the car is pretty new I've never been happy with the loud harsh shifts when coming to a stop or taking off (not my first DSG so I experienced a normal level of jerkiness) there is still no fault codes present and I wanted to give this procedure a try. Hope you guys can help me =]
    The TCU uses the UDS protocol, there are no "group numbers" in it.
    I'm not sure if anyone has made a detailed procedure for your transmission yet.
    Feb 2018
    Egypt
    I found some unofficial procedures (UDS protocol) for the DQ250 but none for the DQ200
    Is anyone know what values should be reset?
    This TCU is not new at all so I'm actually surprised to find nothing because this is the problematic one 😅
