- Joined
- Jul 11, 2019
- Messages
- 14
- Reaction score
- 2
- Location
- Surrey, BC, Canada
- VCDS Serial number
- C?ID=330170
Car came in not running, checked fault codes. Cleared codes and deactivated transport mode. After car would start after a really long cranking and run poorly. Checked codes again and pin tested the faulting components back to the ecu. wiring tested good. Got a used ecu from the exact make and model (has different part # tho) and had Malone delete the immobilizer. Installed the ecu and it fired right up and initially had no codes in the engine. Took it for a drive, still glow plug light flashing and lack of power with limited rpms
2013 jetta tdi auto scan
Help please
Monday,15,July,2019,13:02:54:45192
VCDS Version: 19.6.0.6 (x64) HEX-NET CB: 0.4505.4
VIN: 3VWWL7AJ0BM044336 License Plate:
Mileage: 136640km-84904mi Repair Order: 2013 jetta tdi
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VWWL7AJ0BM044336 Mileage: 136640km-84904miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 Q HW: 03L 906 019 DA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H13--- Serial number:
Coding: 0050072
VCID: 3C34C3CC7FDB2FAF89-8068
15 Faults Found:
008215 - Intake Manifold Flap Position Sensor (Bank 1)
P2017 - 000 - Short to Plus - MIL ON
Fault Status: 11100000
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Voltage: 11.93 V
Lambda: 0.0 %
Lambda: 0.0 %
Bin. Bits: 00000000
Voltage: 5.016 V
009258 - Exhaust Gas Temperature Sensor; B1 S3
P242A - 001 - Malfunction - MIL ON
Fault Status: 11100001
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Voltage: 11.93 V
Temperature: -40.5°C
Temperature: 930.0°C
008241 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
P2031 - 001 - Electrical Malfunction - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Voltage: 11.93 V
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0544 - 001 - Circuit Malfunction - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Voltage: 11.93 V
009326 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E - 001 - Electrical Malfunction - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Voltage: 11.93 V
000280 - Engine Coolant Temp. Sensor (G62)
P0118 - 000 - Signal too High - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Temperature: -90.0°C
Temperature: 99.0°C
Temperature: 27.9°C
Temperature: 25.2°C
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Temperature: 99.0°C
Temperature: 27.9°C
Temperature: 25.2°C
001152 - Coolant Fan Control Circuit 1
P0480 - 000 - Electrical Malfunction
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:01
Temperature: 25.2°C
Temperature: 18.0°C
Lambda: 89.2 %
Lambda: 0.0 %
P0544 - 000 - Circuit Malfunction - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:05
Voltage: 11.93 V
P2031 - 000 - Electrical Malfunction - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:05
Voltage: 11.93 V
P242A - 000 - Malfunction - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:05
Voltage: 11.93 V
P246E - 000 - Electrical Malfunction - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:05
Voltage: 11.93 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:38:20
RPM: 989 /min
Voltage: 10.87 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 435.0 mg/str
Mass Air / Rev.: 0.0 mg/str
000403 - Fuel Pressure Sensor (G247)
P0193 - 000 - Short to Plus - Intermittent - MIL ON
Fault Status: 10100000
Mileage: 136649 km
Date: 2013.11.30
Time: 23:38:22
RPM: 1012 /min
Voltage: 13.76 V
Inj. Quantity: 4.7 mg/str
Temperature: 37.8°C
Temperature: 27.0°C
001037 - EGR Temperature Sensor 1
P040D - 000 - Signal too High - MIL ON
Mileage: 136649 km
Date: 2013.11.30
Time: 23:42:36
(no units): 0.0
Temperature: -48.0°C
Temperature: -276.0°C
Readiness: 1 10 0 1 1
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B14B400C492200FB8D0E02E492200042211000
VCID: 7DB20EC8E441E6A7FE-8028
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 36
Mileage: 136649 km
Date: 2013.11.30
Time: 23:36:17
Count: 3
Count: 2
Count: 20736
Count: 8193
Count: 42752
Count: 3328
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BA HW: 5C0 820 047 BA
Component: J301 Klimaanlage 0204
Revision: 2001012S Serial number: 00000001278198
VCID: 608C57BCB3F32B4FF5-8034
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0256
Revision: B2066001 Serial number: 04371307120423
Coding: 73994B9A08230F0008382000240884C50082502E60000000300000000000
VCID: 2F2EE4807EADC4373C-807A
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585131121215058
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3465
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH00072H95
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0595039
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
03589 - Switch for Driver Side Window Regulator
Fault Status: 00101110
Reset counter: 76
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM08Y5D1
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3424EBEC9F8BE7EF41-8060
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y120000LYAK0C
Coding: 303038
Serial number: 3572MSME0A64557FZZZ2
Serial number: 3582MSME6C6D6272ZZZ5
Serial number: 3516KSME280D201FZZZU
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME7B553E1FZZZ8
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME1B0E4D17ZZZ3
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 136649 km
Date: 2019.07.12
Time: 21:48:12
Part No SW: 5C6 920 852 A HW: 5C6 920 852 A
Component: KOMBI H06 0705
Coding: 370E00
Shop #: WSC 00066 000 00122
VCID: 291A0A984849AA07E2-807C
13639424 - Please Check Fault Codes in Engine Control Module
U101F 00 [009] - -
[Steuergerät für Motor: bitte Fehlerspeicher auslesen Kühlmitteltemperatur]
Reset counter: 36
Mileage: 136649 km
Date: 2019.07.15
Time: 00:36:49
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0256
Revision: B2066001
Coding: 102200
VCID: 70AC27FCA3139BCF65-8024
Component: IMMO H06 0705
VCID: 6A9835948DCF611F2B-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663492811
Coding: 010100
VCID: 2A18F594454FA11FEB-807E
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 373EDCE046FD0CF764-8062
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0006
Revision: -----06S Serial number: VWZ4Z6M3455789
Coding: 01000400020006
VCID: 230618B022657057A8-8076
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663433608
Coding: 0210040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A38C5D4BDEF119F9B-806E
End----------(Elapsed Time: 01:22, VBatt start/end: 12.1V/12.1V)-----------
Help please
