Results 1 to 10 of 12
Thread: 2013 Volkswagen tdi blinking glow plug light limited rpms and no power
    Jul 2019
    Surrey, BC, Canada
    Car came in not running, checked fault codes. Cleared codes and deactivated transport mode. After car would start after a really long cranking and run poorly. Checked codes again and pin tested the faulting components back to the ecu. wiring tested good. Got a used ecu from the exact make and model (has different part # tho) and had Malone delete the immobilizer. Installed the ecu and it fired right up and initially had no codes in the engine. Took it for a drive, still glow plug light flashing and lack of power with limited rpms
    2013 jetta tdi auto scan
    Monday,15,July,2019,13:02:54:45192
    VCDS Version: 19.6.0.6 (x64)  HEX-NET CB: 0.4505.4
    VIN: 3VWWL7AJ0BM044336   License Plate:
    Mileage: 136640km-84904mi   Repair Order: 2013 jetta tdi
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
    VIN: 3VWWL7AJ0BM044336   Mileage: 136640km-84904miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 Q    HW: 03L 906 019 DA
       Component: R4 2.0l TDI G000SG  9983
       Revision: 12H13---    Serial number:
       Coding: 0050072
       VCID: 3C34C3CC7FDB2FAF89-8068
    15 Faults Found:
    008215 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2017 - 000 - Short to Plus - MIL ON
                        Fault Status: 11100000
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Voltage: 11.93 V
                        Lambda: 0.0 %
                        Lambda: 0.0 %
                        Bin. Bits: 00000000
                        Voltage: 5.016 V
    009258 - Exhaust Gas Temperature Sensor; B1 S3
                   P242A - 001 - Malfunction - MIL ON
                        Fault Status: 11100001
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
    008241 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
                   P2031 - 001 - Electrical Malfunction - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
    001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
                   P0544 - 001 - Circuit Malfunction - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
    009326 - Exhaust Gas Temperature Sensor 4 Bank 1
                   P246E - 001 - Electrical Malfunction - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
    000280 - Engine Coolant Temp. Sensor (G62)
                   P0118 - 000 - Signal too High - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Temperature: -90.0C
                        Temperature: -40.5C
                        Temperature: 99.0C
                        Temperature: 27.9C
                        Temperature: 25.2C
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 000 - Signal too High - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Temperature: -90.0C
                        Temperature: -40.5C
                        Temperature: 99.0C
                        Temperature: 27.9C
                        Temperature: 25.2C
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 000 - Electrical Malfunction
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:01
                        Temperature: 25.2C
                        Temperature: -40.5C
                        Temperature: 18.0C
                        Lambda: 89.2 %
                        Lambda: 0.0 %
                   P0544 - 000 - Circuit Malfunction - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:05
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
                   P2031 - 000 - Electrical Malfunction - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:05
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
                   P242A - 000 - Malfunction - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:05
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
                   P246E - 000 - Electrical Malfunction - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:05
                        Voltage: 11.93 V
                        Temperature: -40.5C
                        Temperature: 930.0C
                        Temperature: 930.0C
                        Temperature: 930.0C
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 000 - Signal too Low - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:38:20
                        RPM: 989 /min
                        Voltage: 10.87 V
                        Load: 100.0 %
                        Load: 100.0 %
                        Mass Air / Rev.: 435.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    000403 - Fuel Pressure Sensor (G247)
                   P0193 - 000 - Short to Plus - Intermittent - MIL ON
                        Fault Status: 10100000
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:38:22
                        RPM: 1012 /min
                        Voltage: 13.76 V
                        Inj. Quantity: 4.7 mg/str
                        Temperature: 37.8C
                        Temperature: -40.5C
                        Temperature: 27.0C
    001037 - EGR Temperature Sensor 1
                   P040D - 000 - Signal too High - MIL ON
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:42:36
                        Temperature: -40.5C
                        Temperature: 930.0C
                        (no units): 0.0
                        Temperature: -48.0C
                        Temperature: -276.0C
    Readiness: 1 10 0 1 1
       Revision: 00H31001
       Coding: B14B400C492200FB8D0E02E492200042211000
       VCID: 7DB20EC8E441E6A7FE-8028
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 36
                        Mileage: 136649 km
                        Date: 2013.11.30
                        Time: 23:36:17
                        Count: 3
                        Count: 2
                        Count: 20736
                        Count: 8193
                        Count: 42752
                        Count: 3328
       Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
       Component: J301  Klimaanlage   0204
       Revision: 2001012S    Serial number: 00000001278198
       VCID: 608C57BCB3F32B4FF5-8034
       Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0256
       Revision: B2066001    Serial number: 04371307120423
       Coding: 73994B9A08230F0008382000240884C50082502E60000000300000000000
       VCID: 2F2EE4807EADC4373C-807A
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Serial number: 14102585131121215058
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  004 3465
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.022  H10 0007
       Serial number:     WRH00072H95
       Coding: 180000
       Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
       Serial number: 0595039
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3464
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
       Component: J389__TSG_HR  004 3464
       Coding: 800000
    03589 - Switch for Driver Side Window Regulator
                        Fault Status: 00101110
                        Reset counter: 76
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   014 0808
       Serial number: 003GTM08Y5D1
       Coding: 00003936
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3424EBEC9F8BE7EF41-8060
       Serial number: 6940000Y120000LYAK0C
       Coding: 303038
       Serial number: 3572MSME0A64557FZZZ2
       Serial number: 3582MSME6C6D6272ZZZ5
       Serial number: 3516KSME280D201FZZZU
       Serial number: 3526KSME7B553E1FZZZ8
       Serial number: 3566LSME1B0E4D17ZZZ3
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 136649 km
                        Date: 2019.07.12
                        Time: 21:48:12
       Part No SW: 5C6 920 852 A    HW: 5C6 920 852 A
       Component: KOMBI         H06 0705
       Coding: 370E00
       Shop #: WSC 00066 000 00122
       VCID: 291A0A984849AA07E2-807C
    13639424 - Please Check Fault Codes in Engine Control Module
              U101F 00 [009] - -
              [Steuergert fr Motor: bitte Fehlerspeicher auslesen Khlmitteltemperatur]
                        Reset counter: 36
                        Mileage: 136649 km
                        Date: 2019.07.15
                        Time: 00:36:49
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H66 0256
       Revision: B2066001
       Coding: 102200
       VCID: 70AC27FCA3139BCF65-8024
       Component: IMMO          H06 0705
       VCID: 6A9835948DCF611F2B-803E
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663492811
       Coding: 010100
       VCID: 2A18F594454FA11FEB-807E
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       VCID: 373EDCE046FD0CF764-8062
       Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
       Component: LOW NAR       H02 0006
       Revision: -----06S    Serial number: VWZ4Z6M3455789
       Coding: 01000400020006
       VCID: 230618B022657057A8-8076
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663433608
       Coding: 0210040000010110
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A38C5D4BDEF119F9B-806E
    End----------(Elapsed Time: 01:22, VBatt start/end: 12.1V/12.1V)-----------
    Help please
    Jul 2019
    Surrey, BC, Canada
    Oh and rad fans stay running when the car off. is it possible all these things could be corrected by coding the ecu to the car?
    Wow, the ECU has a whole truckload of various electrical malfunctions. All those things didn't fail simultaneously. There's some common source for most (if not all) of this. Get out your wiring diagrams, identify each of the components with a fault code, and look for what they might have in common. My WAG is a bad ground.
    Quote Originally Posted by Tdibros4 View Post
    Are you sure you've got the correct ECU for the car?
    Jul 2019
    Surrey, BC, Canada
    I agree it’s a centralized problem, the components didn’t fail all at once.and I did check the wiring from the components to the ecu and didn’t find anything wrong. Which is why I changed the ecu which did fix a bunch of things. I don’t have a good set of wiring diagrams for this car tho. I have the Bentley that covers up to cbea but not cjaa if anyone has some good engine diagrams for the cjaa and want to share them that would be great. no I’m not sure I have the right ecu. Although when I initially installed it it the car had very little faults. It wasn’t until I started clearing codes in other modules for no communication with the ecu that the faults started popping up in the engine. I’m prepared to get a pass through device to use Odis to work with the ecu. But I’m stuck right now. Is it worth coding the ecu to the car or is more likely I need to find bad wiring, or would a bad cluster cause these symptoms?
    I do not think a problem with the instrument cluster could cause those faults in the ECU.
    I do not think that "coding the ECU to the car" (which I presume means matching it to the immobilizer) is likely fix them either.
    Assuming the ECU is correct for the car, I really think you've got some physical electrical problem that underlies this.
    These are my opinions only. They are free of charge and come with a double-your-money-back guarantee if I'm wrong.
    You may wish to look at: Where do I get a Wiring Diagram?
  7. Likes Jack@European_Parts liked this post
    Looks like a wire is open or crossed on the daisy chain of shared components for EGT/Intake flap or a sensor on chain is wrong or faulty!
    Don't dismiss Uwe's FOD too!
    Vehicle Identification No. 3VWWL7AJ0BM044336
    Model Jetta
    JEM
    Date of production 05.12.2010
    Model year 2011
    Sales type 162W9L
    Engine Code CJAA
    Transmission Code LHD
    PART NUMBER ILLUSTRATION DESCRIPTION REMARK MODEL RRP PG QUANTITY
    03L 997 030 Q control module-diesel engine
    03L 130 118
    (9-156) CJAA+PR-7GB+
    G0K $1,272.31
    Vehicle intelligent genuine part.
    Order only with additional instructions.
    Also Use
    03L 130 118 vibration damper
  9. #8
    Jul 2019
    Surrey, BC, Canada
    Thank you very much for your help I really appreciate it
  10. #9
    Jul 2019
    Surrey, BC, Canada
    I’m having real problems with the Erwin site I cannot login I have been on the phone with them and they have sent several new logins and none of the work. I have been trying to get set with Erwin for a week now err.
  11. #10
    Jul 2019
    Surrey, BC, Canada
    I apologize in advance I’m new to this forum let me know if I’m out of line at anytime
