I have problem with mmi in car like in title. when i start car mmi turns on, plays for few sconds (5-10), non of any keys on center console work. Than mmi turns off.
I checked amplifier in trunk-its OK( put a fiber optic loop-nothign change), checked bluetooth under pasenger seat-OK.
Any ideas?
Optical Bus Diagnostic: https://ibb.co/1vnZppp
Auto Scan:
Any ideas?
Auto Scan:
Monday,15,July,2019,18:32:08:48233
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4L97D101205 License Plate: ZDR Q7
Mileage: 317410km-197229mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 37 42 46 47 4F 52 55
56 61 62 6D 6F 72 76 77
VIN: WAUZZZ4L97D101205 Mileage: 317410km-197229miles
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 K HW: 4L0 907 401
Component: 3.0L V6TDI G000AG 0030
Revision: --H04--- Serial number:
Coding: 0011779
Shop #: WSC 31414 790 00001
VCID: 2A512BFB8543401AA3-807E
009301 - Diesel Particle Filter; Differential Pressure Sensor
P2455 - 001 - Short to Plus - Intermittent
Fault Status: 00100001
Mileage: 317049 km
Date: 2019.06.27
Time: 13:10:05
Torque: 0.0 Nm
Temperature: 893.2°C
Temperature: 94.4°C
(no units): 0.0
Absolute Pres.: 81.6 mbar
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Fault Status: 01110010
Mileage: 317064 km
Date: 2019.06.28
Time: 16:00:45
RPM: 1932 /min
Torque: 0.0 Nm
Speed: 44.8 km/h
Duty Cycle: 1.0 %
Duty Cycle: 54.8 %
(no units): 0.0
(no units): 16.0
009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
P2414 - 002 - - Intermittent
Fault Status: 00110010
Mileage: 317238 km
Date: 2019.06.30
Time: 11:13:40
RPM: 756 /min
Torque: 101.4 Nm
Duty Cycle: 1.0 %
Duty Cycle: 50.8 %
(no units): 0.0
(no units): 80.0
009263 - Diesel Particulate Filter (Bank 1)
P242F - 001 - Restricted/Clogged - Intermittent
Mileage: 317363 km
Date: 2019.07.02
Time: 08:42:38
RPM: 798 /min
(no units): 47.0
(no units): 10.5
(no units): 20.0
Temperature: 118.0°C
Absolute Pres.: 0.0 mbar
Pressure: 0 mbar
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
Component: AL 750 6A 1000
Revision: 00H64000 Serial number:
Coding: 0000504
VCID: 040DA54347A7766AF9-8050
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033937
VCID: 2855D1F39B4F720AB5-807C
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100729018
Coding: 0000131
VCID: 63CF86DFA2E9D152A0-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 IDG H01 0040
Reset counter: 103
Mileage: 317418 km
Date: 2019.07.15
Time: 16:34:10
Address 07: Control Head
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Revision: 00---012 Serial number: 00000000110972
Coding: 0000022
VCID: 61C38CD7B8F5C342B2-8034
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0012121
VCID: 31633C97A89533C262-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 B HW: 4L0 959 655
Component: 31 AIRBAG AUDI8RH39 0120
Revision: 06H39000 Serial number: 0037GD09747N
Coding: 0013105
VCID: 2C5D2DE38FB75E2A51-8078
Subsystem 1 - Serial number: 6332QSME25370B2DI
Subsystem 2 - Serial number: 6342QSME245431432
Subsystem 3 - Serial number: 6352QSME26510965B
Subsystem 4 - Serial number: 6362QSME2676190FO
Subsystem 5 - Serial number: 63734SME224B3D496
Subsystem 6 - Serial number: 63834SME2224116FZ
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Revision: 00H08000 Serial number: 90054070890011
Coding: 0002042
VCID: 66C99FCB51DBA47A47-8032
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 930 H
Component: KOMBIINSTR. M73 H18 0170
Revision: 00400000 Serial number: 5HG57MC47
Coding: 2561048
Shop #: WSC 00001 001 00001
VCID: 234FC6DFE2699152E0-8076
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 D
Component: Heizgeraet H08 0080
Revision: 0000000C Serial number: 00000009014264
VCID: 60C589D3B3FFCA4ABD-8034
01413 - Dosing/Metering Pump (V54)
007 - Short to Ground
02251 - Heater Unit Locked
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0733181DC
Coding: F55BBE77303202
Shop #: WSC 00470 259 85502
VCID: 6CDDEDE34F379E2A11-8038
Address 37: Navigation
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00-00000
Coding: 0000587
VCID: 2F673AEFBEA1253274-807A
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H07 0040
Revision: 0040 --- Serial number: 01038168230000
Coding: 7610501
VCID: 336F369F528901D210-8066
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 63
Mileage: 303498 km
Date: 2018.06.15
Time: 14:14:13
Address 47: Sound System
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000248371
Coding: 0011001
VCID: 5EB9B72B898BFCBA8F-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00-00000
Coding: 0000587
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000007
VCID: 3D7B10A764CDC7A2F6-8068
Reset counter: 63
Mileage: 317416 km
Date: 2019.07.15
Time: 16:34:09
Address 56: Radio
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000018649
Shop #: WSC 00477 128 59435
VCID: 64CD85C3A7E7D66A59-8030
Component: von VA0 2704141156
Coding: 344630393135313035442056413032373034313431313536
Fault Frequency: 7
Mileage: 317418 km
Date: 2019.07.12
Time: 09:55:33
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0000010
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 3 - Serial number: RD10.04.07--H21001001A0190˙
Subsystem 4 - Serial number: 1A0190˙
00317 - Rear Lid Control Module (J605)
Reset counter: 103
Mileage: 317418 km
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002658971-----
Coding: 0003591
VCID: 2649DFCB915B647A87-8072
Component: J_245_EE15_SKB09H10 0180
Component: J_394_EE15_SKB09H10 0180
Component: J_392_EE15_SKB09H10 0180
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 63
Mileage: 317418 km
Date: 2019.07.11
Time: 21:07:56
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
Reset counter: 63
Mileage: 317418 km
Date: 2019.07.11
Time: 21:07:56
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0000010
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330708500498
Coding: 0201046
01549 - Supply Voltage for Parking-Aid Sensor
Reset counter: 63
Mileage: 317418 km
Date: 2019.07.15
Time: 17:53:58
Fault Status: 01100010
Reset counter: 63
Mileage: 317418 km
Date: 2019.07.15
Time: 17:53:59
Address 77: Telephone
End-------------------------(Elapsed Time: 03:14)--------------------------
