Results 1 to 5 of 5
Thread: POLO 1.2 BLUE MOTION TPMS fault
    Apr 2018
    South Africa
    ABS FAULT
    stop start cant work tpms light on cant be cancelled
    Monday,15,July,2019,13:50:39:16946
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: AUDI VW AUTO CLINIC
    Workshop Code: 996 02232 000010
    VIN: WVWZZZ6RZDY156612   License Plate:
                    Address 03: ABS Brakes       Labels: 6R0-907-37x-ESP90.clb
    Control Module Part Number: 6R0 907 379 AS    HW: 6R0 907 379 AS
      Component and/or Version: ESP9.0i front H02 0002
               Software Coding: 23DD2485412800C6C41A246A825300920905
                Work Shop Code: WSC 01383 785 00200
                  ASAM Dataset: EV_Brake1ESP90iBOSCH 003020 (VW25)
                           ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
                          VCID: 0F6E569FD61F5E3710-805A
    0612 - TPMS Display
              C1146 F2 [008] - EEPROM Malfunction
                        Reset counter: 92
                        Mileage: 89294 km
                        Date: 2019.07.15
                        Time: 00:21:37
    Monday,15,July,2019,11:26:52:16946
    VIN: WVWZZZ6RZDY156612   License Plate: CA449445
    Mileage: 89290km-55482mi   Repair Order: POLO 1.2 BLUE MOTION
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 44 56 61
    VIN: WVWZZZ6RZDY156612   Mileage: 89290km-55482miles
    Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 AH    HW: 03P 907 425
       Component: R3 1.2 DCM3.7 H09 3315
       Revision: 12005001    Serial number:
       Coding: 00114014032501080000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_ECM12TDI03103P906021AH 001004
       ROD: EV_ECM12TDI.rod
       VCID: 6E902B1BB1D5373F7B-803A
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
       Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
       Component: ESP9.0i front H02 0002
       Serial number: --------------
       Shop #: WSC 01383 785 00200
    0612 - TPMS Display
              C1146 F2 [137] - EEPROM Malfunction
                        Fault Frequency: 34
                        Reset counter: 51
                        Mileage: 89159 km
                        Date: 2019.07.10
                        Time: 12:44:10
       Part No SW: 6R0 959 654     HW: 6R0 959 654
       Component: LENKW.SENSOR  H06 0060
       Serial number: 05121204650802
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EB01B5BE1B547BFEB-802A
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
       Component: Man AC        H02 0202
       Revision: 0003SH02
       VCID: 393AC847B01BA0879E-806C
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 090     HW: 7H0 937 090
       Component: BCM PQ25 Max4 H72 0708
       Revision: B9072001    Serial number: 0531 332121645
       Coding: 25B42B3F08E12400923809B0262B0CD05F80412F7E840440A00020020000
       VCID: 6B96220F8AC7C2175C-803E
       Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  008 1611
       Serial number: KU0KU012101200014318
       Coding: 58BC30
       Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  008 1611
       Serial number: KU0KU011101200018039
       Coding: 58BC30
       Subsystem 3 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 5 - Part No: 1K8 951 171 A
       Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0350169
       Coding: 020000
       Subsystem 7 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
       Component: J388__TSG_HL  003 8610
       Serial number: KU0KU010071441913090
       Coding: 0080A0
       Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
       Component: J389__TSG_HR  008 1611
       Serial number: KU0KU005111200010527
       Coding: 58BC32
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag028 H10 0020
       Revision: --------    Serial number: 003GX01H03K7
       Coding: 003238
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4AD8878BEDFD3B1F07-801E
       Serial number: 3575HRB40104UOB6F9GN
       Serial number: 3585HRB40024UNTCEGNI
       Serial number: 3515RRB40511NOT6IOON
       Serial number: 3525RRB40671O70U9G7J
       Part No SW: 6R0 920 861 K    HW: 6R0 920 861 K
       Component: KOMBI         H03 0306
       Serial number: 00000014179657
       Coding: 140801
       ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
       ROD: EV_DashBoardUDSJCIPQ25_A01.rod
       VCID: 3D32DC57AC339CA7B2-8068
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H72 0708
       Revision: B9072001
       Coding: 002300
       VCID: 70AC3563A3E121CF69-8024
    Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H03 0015
       ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
       ROD: EV_ImmobUDSJCIPQ25.rod
       Part No: 6R0 423 156 C
       Component: LenkhilfeTRW        V278
       Coding: 11230
       Shop #: WSC 00788
       VCID: 302CF563F76161CF29-8064
       Part No SW: 5M0 035 156 D    HW: 5M0 035 156 D
       Component: Radio         553 0555
       Revision: R0553007    Serial number: VWZ5Z1M0791346
       Coding: 0500040002
       VCID: 2A18E70B45BD1B1FE7-807E
       Part No SW: 7H0 907 534     HW: 7H0 937 090
       Component: Batt.regelung H72 0708
       Coding: 03031A59
       Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
       Component: J367-BDM  H08 0181
       Serial number: 00000000004970523755
    End----------(Elapsed Time: 01:45, VBatt start/end: 13.1V/13.1V)-----------
    Apr 2015
    South Africa
    Make sure all tyres are pumped to spec. Swith the switch in the cubby on and test drive. Should reset then.
    Apr 2018
    South Africa
    eeprom fault
  4. Likes PetrolDave liked this post
    HQ
    From what I can tell, there is going to be a E492 "Tyre Pressure loss Indicator button" that goes to the ABS T38/4. The button looks to be a normally open circuit and when pushed, a battery voltage + signal from fuse SB9 passes through the switch and to the ABS module. Is that button shorted?
    Are the powers and grounds for the ABS module to factory design... no voltage drop issues for the main powers/grounds at the ABS module?
    If those things check out good, it would seem the ABS module has failed.
    Jef
  6. Likes Uwe liked this post
    Apr 2018
    South Africa
    thanks for the imput ..will check and report back
