Results 1 to 5 of 5
Thread: 2017 GTI O2 sensor codes after subframe re-install
    Sep 2018
    Car is 2017 GTI Sport 6MT, Eurodyne stg.2 w/ ECode catted DP.
    I removed the subframe to install pendulum mount bushings, and after re-installing the subframe I got a permanent CEL.
    After scan there are some O2 sensor codes and an outside temp sensor code. I didn't disconnect anything related to those items when I did the subframe removal/re-install.
    I will have to get a re-alignment this coming week, but before I do that, if anyone can help me figure this out I would really appreciate it. TIA
    Here is the full scan:
    Sunday,14,July,2019,14:49:07:47244
    VIN: 3VW547AU4HMxxxxxx   License Plate:
    Mileage: 71812km-44621mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 05 08 09 15 16 17 19 2B 32 42 44 52 55 5F 75 A9
    VIN: 3VW547AU4HMxxxxxx   Mileage: 71812km-44621miles
    Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0402
       Revision: --H13---
       Coding: 091900122424002F1000
       Shop #: WSC 00066 790 00206
       ASAM Dataset: EV_ECM20TFS0205G0906259L 001007
       ROD: EV_ECM20TFS0205G0906259L.rod
       VCID: 372822F67FC60C7F3B3-8062
    20650 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
              P0031 00 [175] - Short to Ground
                        Mileage: 71804 km
                        Date: 2019.07.11
                        Time: 17:20:26
                        Engine speed: 994.00 /min
                        Normed load value: 14.1 %
                        Coolant temperature: 38 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 12.011 V
                        Engine: operating status: IS
                        ECU_STATE: SYN_ENG_IGK_ON
                        T_ES: 0 min
                        T_AST_SAE: 1 s
                        TTIP_MES_LS_UP[1]: -2048.0000 °C
                        TEG_DYN_LS_UP[1]: 179.2250 °C
                        Lambda probes actual: bank1: 1.2002
    20642 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
              P0037 00 [175] - Short to Ground
                        Mileage: 71804 km
                        Date: 2019.07.11
                        Time: 17:20:26
                        Engine speed: 1001.50 /min
                        Normed load value: 12.9 %
                        Voltage terminal 30: 11.796 V
                        T_ES: 0 min
                        T_AST_SAE: 0 s
                        Lambda probe heater: resistance: bank 1: probe 2: 65535 Ohm
                        TEG_DYN_LS_DOWN[1]: 30.3500 °C
                        VLS_DOWN_SAE[1]: 1.275 V
    17178 - Databus
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0398
       Revision: 00000000    Serial number: 51966000002422
       Coding: 01FA6BA15421096D407D020241C96880D62A90024082163600430051C00803
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
       ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
       VCID: 75B4E8FE254ABE6FE9F-8020
    8277 - Databus
              U1122 00 [009] - Implausible Message
              [FCAN: EPS_DSR_Status signal is invalid]
                        Fault Frequency: 14
                        Reset counter: 17
                        Date: 2019.04.28
                        Time: 19:27:42
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 58
                        Mileage: 71561 km
                        Date: 2019.07.05
                        Time: 10:57:54
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0408655336
       Coding: 032C0C
       VCID: 3B203EC643EE281FDFB-806E
       Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
       Component: AC Manuell    H03 1601
       Revision: 00001K03
       Coding: 00020004200100000000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004132
       ROD: EV_ACManueBHBVW37X_004.rod
       VCID: 48CA510A02387387429-801C
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 865830061601NS
       Coding: 00010A464041A04169E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00202
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7AAEFBC20C54D11784D-802E
       Component: WWS    160819  043 0581
       Serial number:         160829224544
    137217 - Outside temperature sensor
              B103F 1B [136] - Resistance Too High
       Serial number: 003GCR05FDV-
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47C852360F267CFF4B3-8012
       Occupant Detection:
       Serial number: IBH000000000005N7SQ6
       Coding: 30305A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 107 16
       Serial number: 35700000000A10B48C1J
       Subsystem 3 - Part No SW: -----------    HW: 480 000 107 16
       Serial number: 358000000001D9B86C1Y
       Subsystem 4 - Part No SW: -----------    HW: 480 402 706 16
       Serial number: 3510002AF20FC4C4808F
       Subsystem 5 - Part No SW: -----------    HW: 480 402 806 16
       Serial number: 3520002BD21160C490B$
       Subsystem 6 - Part No SW: -----------    HW: 480 401 807 16
       Serial number: 3550002BF21160D3804-
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 807 16
       Serial number: 3560002C121160D3713N
       Revision: FF034034    Serial number: 20160701401071
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 0452853A7E9097E7EE1-8050
       Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
       Component: KOMBI         344 8311
       Coding: 0B2C0912A980CF0502086A001000000000000000
       VCID: 2D04009E8D9AB6AF51F-8078
       Revision: --------    Serial number: 20041610801549
       Coding: 0101000830085900FB00002B080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti_013.rod
       VCID: 7CA2FDDA0660EF27961-8028
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001073940086217
       Coding: 30FFFF
       Revision: 00000000    Serial number: 16000120610002
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 343215FA6EB0E7671E1-8060
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
       Component: Quersperre    H52 8042
       Serial number: HA1-00024.05.16
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       Serial number: 170816060502DN
       Coding: 003E13200000020000000000
       VCID: 43D046263B1E50DF97B-8016
       Serial number: 00000000000004026957
       Coding: 011000
       Coding: 8002
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2E3BC24CD41117C4D-806E
       Serial number: 1608160605081M
       VCID: 42DE4322240459D79CD-8016
       Serial number: 00000000000004023017
       Coding: 091000
       Coding: 021801010B000400
       VCID: 40DA492A2A084BC78A9-8014
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
       Component: MU-S-S-US     710 0751
       Coding: 02730000FF00000051220001001808009F0203D40120010002
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJW00X3C
              B11CF 53 [009] - Deactivated
                        Reset counter: 140
                        Mileage: 63561 km
                        Date: 2019.04.28
                        Time: 19:28:12
                        Voltage terminal 30: 12.3 V
                        SDARS_tuner_status_2-Antenna current: 22 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
    0009 - Antenna for Satellite Radio
              B10F4 13 [008] - Open Circuit
                        Reset counter: 55
                        Mileage: 63561 km
                        Date: 2019.04.28
                        Time: 19:27:42
       Component: OCULowMQBUS   007 0568
       ROD: EV_OCULowMQB.rod
       Serial number: 160607200408
       VCID: 6B80CE86730E789F0FB-803E
    End----------(Elapsed Time: 01:21, VBatt start/end: 13.5V/13.5V)-----------
    Sunday,14,July,2019,14:53:38:47244
    VIN: 3VW547AU4HM011626   License Plate:
    VIN: 3VW547AU4HM011626   Mileage: 71812km-44621miles
       Revision: --H13---
                        Mileage: 71804 km
                        Date: 2019.07.11
                        Time: 17:20:26
                        T_ES: 0 min
                        T_AST_SAE: 1 s
                        Mileage: 71804 km
                        Date: 2019.07.11
                        Time: 17:20:26
                        T_ES: 0 min
                        T_AST_SAE: 0 s
    17178 - Databus
    8277 - Databus
                        Fault Frequency: 14
                        Reset counter: 17
                        Date: 2019.04.28
                        Time: 19:27:42
              C102D 00 [008] - -
                        Reset counter: 58
                        Mileage: 71561 km
                        Date: 2019.07.05
                        Time: 10:57:54
       Coding: 032C0C
       Revision: 00001K03
       Occupant Detection:
       Coding: 30305A
       Coding: 0400
       Coding: 30FFFF
       Coding: 0001
       Coding: 011000
       Coding: 8002
       Coding: 091000
       Coding: 2E0000
       Coding: 2E0000
                        Reset counter: 140
                        Mileage: 63561 km
                        Date: 2019.04.28
                        Time: 19:28:12
                        Reset counter: 55
                        Mileage: 63561 km
                        Date: 2019.04.28
                        Time: 19:27:42
    End----------(Elapsed Time: 01:21, VBatt start/end: 13.6V/13.6V)-----------
    edit: AFAIK any stg.2 tune disregards the post-cat O2 sensor for people who run cat-less, but on my downpipe it is actually installed post-cat, and mine is a 400cell cat so it might not give me a CEL even with the stock tune, however I haven't tried that.
    The ABS codes might be related to the Audi TTS front calipers and/or the higher sidewall (225/45/18) of my winter tires, but I'm not sure since I haven't scanned neither before nor after I installed them about a year ago (the TTS calipers).
    If it were mine, I would start looking for wiring that got damaged during the sub-frame job.
  3. Likes Jack@European_Parts, PetrolDave liked this post
    I'd say either you stretched the harness and made OXS heater go open or pinched it, & FYI the lazy tuners delete the probe ref test but never seem to deal with heater circuit when playing with setting block areas to zero to make cat test go bye bye in addition to cat test too.
    FOD! & Induced on all sides!
    Did you check heater circuit fuse and who knows maybe you bumped it too, could just be a bad sensor too, but both heaters are not likely bad so ohm them out!
    Sep 2018
    Well, I finally had time to check and you guys were right, the SB8 fuse was blown, and the replacement burned up as soon as I put it in. The fuses diagram I found showed it was supposed to be a 10A, but mine was a 15A, which, according to the diagram is for diesels
    So I guess a short? I'll have to get it back on the lift to check, maybe the midpipe got slightly off-center and the O2 sensor is rubbing inside the tunnel.
    It seems strange to me that it would be energized at all times, even with the car off..
    That is because it's hot on BUS and ground is switched by ECU & in this case before ECU....you hope!
    Fortunately you have a fuse, earlier cars didn't and sacrifice the ECU immediately!
