Results 1 to 7 of 7
Thread: 09 2.0t CCTA VW GTI - throttle body issues?
    Jul 2019
    CT, USA
    Question 09 2.0t CCTA VW GTI - throttle body issues?
    The other day I noticed that once in awhile the car would kick a bit when engine load changed - it almost felt like a bad engine mount, but would only do it on occasion. Later on that day I came to a stop sign and the car went into limp mode. It had a hard time idling, it was hunting. It responded to the throttle just fine though. I pulled the codes and saw what was listed.
    I checked the connector on the TB to make sure it wasn't taunt, unplugged and plugged it back in.
    I checked measuring block 62 and all looked good. The pedal angles looked like what they're supposed to all through the pedal travel
    I unplugged the MAF to see if that would make any difference and it didn't
    I did a TB adaptation and that made no difference
    I figured unplugged the MAF might have thrown a new code, so let me clear everything and see what's still in here. As soon as I did that the car runs normal. Did a 15 minute drive around town and it's still good.
    I know something is going to die on me at the worst possible time so I'd like to find the root cause of this. Any guesses?
    Auto scan here:
    Friday,19,July,2019,19:49:29:30793
    VCDS Version: 19.6.1.0 (x64)
    Mode 03: Emission related fault codes
    Address 7E8: 2 Faults Found:
    P0121 - Throttle Position Sensor (G69): Implausible Signal
    P0221 - Angle Sensor 2 for Throttle (G188): Implausible Signal
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    VIN: WVWEV71K89W109834   Mileage: 260230km-161699miles
       Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
       Revision: AAH03---    Serial number: VWX7Z0H83N488U
       Coding: 0403010A18070160
       VCID: 69D34A474001AB072E-803C
    012408 - Throttle Control
                   P3078 - 000 - Airflow at Idle too Low
                        Mileage: 258332 km
                        Time: 19:02:06
                        RPM: 2340 /min
                        Load: 12.2 %
                        Speed: 80.0 km/h
                        Temperature: 97.0C
                        Temperature: 32.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.716 V
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal
                        Mileage: 260228 km
                        Time: 22:14:40
                        RPM: 2050 /min
                        Load: 16.1 %
                        Speed: 55.0 km/h
                        Temperature: 96.0C
                        Temperature: 39.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.589 V
    000289 - Throttle Position Sensor (G69)
                   P0121 - 000 - Implausible Signal - MIL ON
                        Fault Status: 11100000
                        Mileage: 260228 km
                        Time: 22:15:11
                        RPM: 1642 /min
                        Load: 17.2 %
                        Speed: 44.0 km/h
                        Temperature: 97.0C
                        Temperature: 45.0C
                        Voltage: 13.335 V
    000545 - Angle Sensor 2 for Throttle (G188)
                   P0221 - 000 - Implausible Signal - MIL ON
                        Mileage: 260228 km
                        Time: 22:15:11
                        RPM: 1642 /min
                        Load: 17.2 %
                        Speed: 44.0 km/h
                        Temperature: 97.0C
                        Temperature: 45.0C
                        Voltage: 13.335 V
    005445 - Throttle Valve Controller
                   P1545 - 000 - Malfunction - MIL ON
                        Date: 2047.15.31
                        Time: 31:63:63
                        Load: 0.0 %
                        Temperature: 30.0C
                        Temperature: 30.0C
                        Voltage: 11.811 V
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Component: ESP MK60EC1   H45 0107
       Revision: 00H45001
       Coding: 113B600D49220003881306E7921D00413000
       Shop #: WSC 51040 001 1048576
       VCID: 7EF9091BE98F3CBFEB-802A
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 176
                        Mileage: 260228 km
                        Count: 32768
                        Count: 4608
                        Count: 8193
                        Count: 49975
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78F51F030BAB028FA1-802C
       Revision: 00H54000    Serial number: 00000008791290
       Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
       Shop #: WSC 00000 785 00200
       VCID: 336FE82F524D21D754-8066
       Component: Wischer 280808 021  0501
       Coding: 00038805
       Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
       Component: SDAR SIRIUS     H07 0150
       Revision: 00000000    Serial number: AUZ4Z7H0402709
       Coding: 0000100
    00003 - Control Module
                        Fault Status: 00101110
                        Fault Frequency: 18
                        Reset counter: 91
                        Mileage: 225105 km
                        Time: 18:13:32
                        Fault Frequency: 8
                        Reset counter: 83
                        Mileage: 254509 km
                        Time: 11:49:15
       Component: 6K AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0BWM5H
       Coding: 0013899
       VCID: 6CDD33534FF3BE2F55-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME3F044458E
       Subsystem 3 - Serial number: 6342MSME3F326574H
       Subsystem 4 - Serial number: 6352QSME45080E1EN
       Subsystem 5 - Serial number: 6362QSME0704193CE
       Subsystem 6 - Serial number: 63727SME186C182B9
       Subsystem 7 - Serial number: 63827SME185929735
       Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
       Component: J0527           051 0101
       Coding: 0002022
       VCID: 010372E75871434796-8054
    00576 - Terminal 15
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
       Component: KOMBIINSTRUMENT VDD 2416
       Revision: V0003000    Serial number: VWX7Z0H83N488U
       Coding: 0007203
       VCID: 3973DA077021DB879E-806C
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 260808F2000791
       Coding: E9811F070013020000
       VCID: 356BD6375C393FE77A-8060
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T42D203
       VCID: 7DFB0E17248927A7F2-8028
       Component: IMMO            VDD 2416
       Component: Tuer-SG         006 1207
       Coding: 0001077
       VCID: 3875DF034B2BC28F61-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.074 H08 1901
       Component:    KSG PQ35 RDK 052 0221
       Coding: 139006885103281B0904058FB0080A04889C00
       VCID: 040D7BF34763566FBD-8050
       Coding: 0001076
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74ED2B3317C366EF8D-8020
       Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
       Component: Radio PM6       019 0037
       Revision: 00019000    Serial number: VWZ5Z7H2255538
       Coding: 0040401
       VCID: 29530A4780816B07EE-807C
       Component:    RDK              0450
       Coding: 0100101
                        Fault Status: 01110100
                        Reset counter: 9
                        Mileage: 237457 km
                        Time: 07:02:42
    End-------------------------(Elapsed Time: 01:49)--------------------------
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    Before clearing codes what are the long term fuel trims at idle and part load?
    +or- 5% is good.
    Also TSB for Throttle Body harness would be a good guess for P0121, P0221 & P1545
    Also check your PM I left you one.
    Good Luck
  3. Likes Uwe, Jack@European_Parts liked this post
    HQ
    Take a look at the wiring harness and connector at the throttle body itself. There was an updated terminal housing and terminals for the throttle body. The wires were cut, new wires crimped in and taped up. This was to fix a poor electrical/mechanical connection at the throttle body itself that can cause those types of fault codes.
    I did a quick bit of searching and found this:
    https://f01.justanswer.com/mike2765/...rottle+tsb.pdf
    Verify with your local VW dealer that the part numbers provided are applicable to your VIN.
    When this repair is done, it is important to be 100% you don't get any wires mixed up... I did these one wire at a time, double checking the correct location of each wire before I went to the next wire to cut/crimp.
    Jef
  5. Likes Uwe, Jack@European_Parts liked this post
    Jul 2019
    CT, USA
    I drove the car 45 miles to work today and it was OK. I'll check the fuel trim later on.
    As far as the TSB, it hasn't been done on my car, but there looks like plenty of slack on the cable. From my understanding the issues was caused because the cable was too tight and the wires would be pulled out of the connector, right?
    Mar 2014
    Wilkes-Barre, PA
    No the pins in connector go bad.
    Very common even on older MK4 models but no TSB was ever made for them. They started to fail later in life with high mileage.
    MK5 failed at much lower mileage therefor the TSB was produced.
    And the parts are not cheap pig tail wires costly for just short pig tails.
    Good Luck
  8. Likes Jack@European_Parts, Uwe, gh0st liked this post
  9. #6
    Stan Lee Marvel Comics is correct ( VWTECH )
    When someone can't get the connectors, I have found that taking TV apart drilling holes and soldering wires to the PINS in the TV stationary and crimp clip, then route wires out & fill connector with RTV silicone and too extend the needed length to make new plug in safe area or back to ECU directly + a strain relief with spiral-wrap does a nice trick.
  10. Likes Uwe, Fredrick Awuor liked this post
  11. #7
    Jul 2019
    CT, USA
    Ah, ok. That sounds like it applies then. I'll look into doing that. I checked the long term fuel trim (for the 45 miles this morning) and idle was at -0.2% and load was at 0.8%.
  12. Likes Uwe liked this post
