Results 1 to 2 of 2
Thread: Boost pressure valve fault code on VW 2011 Golf 1.4 TSI GT
    Nov 2018
    I have a P0243 fault code on a recently rebuilt 1.4 TSI engine, the engine revs to 3,800 rpm maximum.
    The VCDS log is below, all looks fine on the engine so wonder what the issue is? Any suggestions to look at appreciated!
    This scan was just after the car battery was replaced, so many faults due to low voltage show up in the scan..
    Sunday,14,July,2019,11:29:47:31648
    VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
    VIN: WVWZZZ1KZCK012796 License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 20 25 26 2E 42 44 46 52 56 62 72
    77
    VIN: WVWZZZ1KZCK012796 Mileage: 124310km-77242miles
    Address 01: Engine (J623-CAVD) Labels:. 03C-907-309-V1.clb
    Part No SW: 03C 906 027 BE HW: 03C 907 309 J
    Component: 1.4l R4/4V TS X04 1681
    Revision: LGX04--- Serial number: 00000000000000
    Coding: 00190012002400000000
    Shop #: WSC 92521 052 00000
    ASAM Dataset: EV_ECM14TSI01103C906027BE 001006
    ROD: EV_ECM14TSI01103C906027BE.rod
    VCID: 6597B2FA45E67C2F593-8030
    2644 - Brake Switch (F)
    P0571 00 [175] - Implausible Signal
    Mileage: 124313 km
    Vehicle speed: 255 km/h
    Coolant temperature: -40 C
    Intake air temperature: -40 C
    Ambient air pressure: 0 mbar
    Voltage terminal 30: 0.000 V
    CAN status - engine control module-Bits 0-7: 00000000
    Generator power: 0 W
    CAN TimeOut meter - gateway-Bits 0-7: 00000000
    8221 - System Voltage
    P0562 00 [032] - Too Low
    Mileage: 124313 km
    Date: 2019.07.08
    Time: 18:21:00
    Coolant temperature: 18 C
    Intake air temperature: 20 C
    Voltage terminal 30: 7.468 V
    Unlearning counter according OBD: 38
    Mass flow through throttle valve: 0.0 kg/h
    Engine operating condition-Channel 87: Idling
    Relative load value: 90.75 %
    Torque request: sum of auxiliary aggregate: 6.6 Nm
    Engine torque: 0.0 Nm
    2985 - Solenoid Valve for Boost Pressure Control (N75)
    P0243 00 [237] - Malfunction
    Mileage: 124310 km
    Date: 2019.06.12
    Time: 17:46:31
    Engine speed: 994.00 /min
    Normed load value: 21.2 %
    Coolant temperature: 79 C
    Intake air temperature: 44 C
    Voltage terminal 30: 11.285 V
    High fuel pressure: control deviation: -3.8985 MPa
    Charge air pressure specified value: 241.56 hPa
    Charge press. ctrl.: spec. value: 5.1 %
    Status of error conditions of charge pressure control diagnosis: 0
    Status adjust recovery conditions of charge press ctrl diagn: 80
    4261 - System Voltage
    P0562 00 [096] - Too Low
    Mileage: 124313 km
    Date: 2019.07.08
    Time: 18:21:00
    Intake air temperature: 19 C
    Voltage terminal 30: 7.444 V
    CAN status - engine control module-Bits 0-7: 01000000
    Readiness: 0010 0100
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 163B600D092300FC681206ED901F0080350000
    Shop #: WSC 00040 040 00001
    VCID: 7BA3F482D3E2DADF9F7-802E
    Reset counter: 182
    Mileage: 124313 km
    Date: 2013.11.15
    Time: 12:32:13
    Count: 7
    Count: 3
    Count: 28672
    Count: 128
    Count: 24320
    Count: 255
    Part No SW: 5K0 907 044 ER HW: 5K0 907 044 ER
    Component: Climatronic H18 1112
    Revision: 00001003
    Coding: 1000004002
    Shop #: WSC 00040 040 00015
    VCID: 7F5B0092C77AC6FFB3F-802A
    Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
    Component: BCM PQ35 M 110 0651
    Revision: 00110 AC
    Coding: 48000A3A8A37F10040082088340081E4435915885120896064 8040200050
    VCID: 3A2D31869C5823D7C41-806E
    Subsystem 1 - Part No SW: 5K7 955 119 A HW: 5K7 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer 16051 10 0605
    Coding: 009795
    Subsystem 2 - Part No: 5K7 955 559 Labels: 5K7-955-559.CLB
    Component: RLS 260811 02 21 0011
    Coding: 0280DD
    Subsystem 3 - Part No: 1Q0 951 171
    Component: DWA-Sensor 00 002 0204
    Component: LIN BACKUP HO H11 9005
    01134 - Alarm Horn (H12)
    Reset counter: 224
    Mileage: 124307 km
    Date: 2013.11.02
    Time: 00:00:01
    Term 15 Off
    Voltage: 11.40 V
    Term 50 Off
    Reset counter: 224
    Mileage: 124313 km
    Date: 2013.11.15
    Time: 00:00:02
    Term 15 Off
    Voltage: 17.75 V
    Term 50 Off
    00532 - Supply Voltage B+
    Reset counter: 224
    Mileage: 124313 km
    Date: 2013.11.15
    Time: 00:00:17
    Term 15 Off
    Voltage: 17.75 V
    Term 50 Off
    Reset counter: 224
    Mileage: 124313 km
    Date: 2013.11.15
    Time: 12:23:11
    Term 15 Off
    Voltage: 7.65 V
    Term 50 Off
    00153 - Windshield Wiper Motor; Driver Side (V216)
    Reset counter: 222
    Mileage: 124313 km
    Date: 2013.11.15
    Time: 00:01:20
    Voltage: 17.75 V
    Term 50 Off
    Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
    Part No SW: 5K7 919 475 HW: 5K0 919 475 E
    Component: PARKHILFE 8K H01 0004
    Revision: -------- Serial number: 12561121300703
    Coding: 108001
    VCID: 7AADF186DCD8E3D7841-802E
    Part No SW: 5C0 959 655 A HW: 5C0 959 655 A
    Component: AirbagVW10 011 0906
    Serial number: 003EPD07C963
    Coding: 00004342
    Shop #: WSC 01383 790 00008
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 303913AE4AA4E9877A5-8064
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME3A4C0063ZZZV
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME242B0063ZZZM
    13635840 - Supply voltage
    [Powersupply lower threshold fall short of]
    Reset counter: 222
    Mileage: 124313 km
    Date: 2019.06.25
    Time: 12:32:59
    Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90440KHO0005E
    Coding: 1082140000
    Shop #: WSC 00040 040 00014
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 42DD4966F4086B179C1-8016
    Component: E221__MFL-TK6 H06 0022
    Serial number: 40000000000000450171
    Coding: E20000
    114178 - Function Restricted due to Insufficient Voltage
    U1400 00 [008] - -
    Reset counter: 224
    Time: 00:00:00
    136194 - Supply voltage
    Reset counter: 224
    Time: 00:00:00
    Part No SW: 5K7 920 970 HW: 5K7 920 970
    Component: KOMBI H04 0607
    Coding: 170901
    VCID: 72BDD9A684289B97CC1-8026
    [Supply voltage too low]
    Reset counter: 224
    Part No SW: 7N0 907 530 H HW: 1K0 907 951
    Component: J533 Gateway H42 1620
    Revision: H42 Serial number: 280811F6000769
    Coding: 365001
    VCID: 353722BAB546CCAF293-8060
    Reset counter: 222
    Mileage: 124313 km
    Date: 2013.11.15
    Time: 00:00:12
    Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
    Part No SW: 5K7 857 511 A HW: 8J0 857 511 C
    Component: FLA H03 0006
    Revision: AA002001
    Coding: 0102906B74745D545420363E00
    VCID: 33331CA2BB32D29F077-8066
    Component: IMMO H04 0607
    VCID: 6A8DC1C6ACF85357741-803E
    Address 26: Auto Roof Labels: None
    Part No: 5K7 959 255
    Component: VSG GOLF 6 H15 0360
    VCID: 7AADF186D0D8E3D7841-802E
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Revision: A1001003 Serial number: 7660747137
    VCID: 290FFECA69FE984FBDB-807C
    Reset counter: 222
    Reset counter: 222
    Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
    Component: Tuer-SG 009 2156
    Coding: 0017076
    VCID: 392F2E8A955E28CFCDB-806C
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 69 3201
    Revision: 00H20000
    VCID: 34311FBEB23CD5A71ED-8060
    000 - - - MIL ON
    Fault Status: 11100000
    Battery Volts: 6.5 V
    PD
    Temperature: 18.0C
    Count: 2
    Steering Angle: 0.00
    SteerAng n.Init
    Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
    Coding: 0017332
    VCID: 3A2D3186905823D7C41-806E
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 A HW: 3C8 035 195 A
    Component: Radio RCD510 041 0166
    Revision: 00000001 Serial number: VWZ1Z3K9797309
    Coding: 0100040004
    Shop #: WSC 01324 020 00200
    VCID: 2615F5F678E0B737909-8072
    Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
    Component: Tuer-SG H01 2103
    Coding: 0000144
    Shop #: WSC 00040 040 1012545
    VCID: 42DD4966F8886B179C1-8016
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
    Coding: 0000144
    VCID: 43D34C62E792621F977-8016
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007660660769
    Coding: 0A01000000010101
    ASAM Dataset: EV_UHVNA A01719
    ROD: UHVNA.rod
    VCID: 2615F5F67860B737909-8072
    U1400 00 [008] - -
    Reset counter: 222
    Mileage: 124313 km
    Date: 2019.06.25
    Time: 12:32:02
    End----------(Elapsed Time: 01:24, VBatt start/end: 12.1V/12.1V)-----------
    Please post more complete scan data. A complete Auto-Scan is preferred, but at a very minimum, enough to show the ECU's identifying data.
