I have a P0243 fault code on a recently rebuilt 1.4 TSI engine, the engine revs to 3,800 rpm maximum.
The VCDS log is below, all looks fine on the engine so wonder what the issue is? Any suggestions to look at appreciated!
This scan was just after the car battery was replaced, so many faults due to low voltage show up in the scan..
Sunday,14,July,2019,11:29:47:31648
VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
VIN: WVWZZZ1KZCK012796 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 26 2E 42 44 46 52 56 62 72
77
VIN: WVWZZZ1KZCK012796 Mileage: 124310km-77242miles
2E-Media Player 3 -- Status: Malfunction 0010
Address 01: Engine (J623-CAVD) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 BE HW: 03C 907 309 J
Component: 1.4l R4/4V TS X04 1681
Revision: LGX04--- Serial number: 00000000000000
Coding: 00190012002400000000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM14TSI01103C906027BE 001006
ROD: EV_ECM14TSI01103C906027BE.rod
VCID: 6597B2FA45E67C2F593-8030
2644 - Brake Switch (F)
P0571 00 [175] - Implausible Signal
Mileage: 124313 km
Vehicle speed: 255 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
CAN status - engine control module-Bits 0-7: 00000000
Generator power: 0 W
CAN TimeOut meter - gateway-Bits 0-7: 00000000
8221 - System Voltage
P0562 00 [032] - Too Low
Mileage: 124313 km
Date: 2019.07.08
Time: 18:21:00
Coolant temperature: 18 °C
Intake air temperature: 20 °C
Voltage terminal 30: 7.468 V
Unlearning counter according OBD: 38
Mass flow through throttle valve: 0.0 kg/h
Median injection timing: 0.000 ms
Engine operating condition-Channel 87: Idling
Relative load value: 90.75 %
Torque request: sum of auxiliary aggregate: 6.6 Nm
Engine torque: 0.0 Nm
2985 - Solenoid Valve for Boost Pressure Control (N75)
P0243 00 [237] - Malfunction
Mileage: 124310 km
Date: 2019.06.12
Time: 17:46:31
Engine speed: 994.00 /min
Normed load value: 21.2 %
Coolant temperature: 79 °C
Intake air temperature: 44 °C
Voltage terminal 30: 11.285 V
High fuel pressure: control deviation: -3.8985 MPa
Charge air pressure specified value: 241.56 hPa
Charge press. ctrl.: spec. value: 5.1 %
Status of error conditions of charge pressure control diagnosis: 0
Status adjust recovery conditions of charge press ctrl diagn: 80
4261 - System Voltage
P0562 00 [096] - Too Low
Mileage: 124313 km
Date: 2019.07.08
Time: 18:21:00
Intake air temperature: 19 °C
Voltage terminal 30: 7.444 V
CAN status - engine control module-Bits 0-7: 01000000
Readiness: 0010 0100
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 163B600D092300FC681206ED901F0080350000
Shop #: WSC 00040 040 00001
VCID: 7BA3F482D3E2DADF9F7-802E
Reset counter: 182
Mileage: 124313 km
Date: 2013.11.15
Time: 12:32:13
Count: 7
Count: 3
Count: 28672
Count: 128
Count: 24320
Count: 255
Part No SW: 5K0 907 044 ER HW: 5K0 907 044 ER
Component: Climatronic H18 1112
Revision: 00001003
Coding: 1000004002
Shop #: WSC 00040 040 00015
VCID: 7F5B0092C77AC6FFB3F-802A
Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 48000A3A8A37F10040082088340081E44359158851208960648040200050
VCID: 3A2D31869C5823D7C41-806E
Subsystem 1 - Part No SW: 5K7 955 119 A HW: 5K7 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 16051 10 0605
Coding: 009795
Subsystem 2 - Part No: 5K7 955 559 Labels: 5K7-955-559.CLB
Component: RLS 260811 02 21 0011
Coding: 0280DD
Subsystem 3 - Part No: 1Q0 951 171
Component: DWA-Sensor 00 002 0204
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
01134 - Alarm Horn (H12)
Reset counter: 224
Mileage: 124307 km
Date: 2013.11.02
Time: 00:00:01
Term 15 Off
Voltage: 11.40 V
Term 50 Off
Reset counter: 224
Mileage: 124313 km
Date: 2013.11.15
Time: 00:00:02
Term 15 Off
Voltage: 17.75 V
Term 50 Off
00532 - Supply Voltage B+
Reset counter: 224
Mileage: 124313 km
Date: 2013.11.15
Time: 00:00:17
Term 15 Off
Voltage: 17.75 V
Term 50 Off
Reset counter: 224
Mileage: 124313 km
Date: 2013.11.15
Time: 12:23:11
Term 15 Off
Voltage: 7.65 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 222
Mileage: 124313 km
Date: 2013.11.15
Time: 00:01:20
Term 15 On
Voltage: 17.75 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K7 919 475 HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0004
Revision: -------- Serial number: 12561121300703
Coding: 108001
VCID: 7AADF186DCD8E3D7841-802E
Part No SW: 5C0 959 655 A HW: 5C0 959 655 A
Component: AirbagVW10 011 0906
Serial number: 003EPD07C963
Coding: 00004342
Shop #: WSC 01383 790 00008
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 303913AE4AA4E9877A5-8064
Serial number: 3572MSME3A4C0063ZZZV
Serial number: 3582MSME242B0063ZZZM
13635840 - Supply voltage
[Powersupply lower threshold fall short of]
Reset counter: 222
Mileage: 124313 km
Date: 2019.06.25
Time: 12:32:59
Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KHO0005E
Coding: 1082140000
Shop #: WSC 00040 040 00014
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 42DD4966F4086B179C1-8016
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000450171
Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 224
Time: 00:00:00
136194 - Supply voltage
Reset counter: 224
Time: 00:00:00
Part No SW: 5K7 920 970 HW: 5K7 920 970
Component: KOMBI H04 0607
Coding: 170901
VCID: 72BDD9A684289B97CC1-8026
[Supply voltage too low]
Reset counter: 224
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 280811F6000769
Coding: 365001
VCID: 353722BAB546CCAF293-8060
Reset counter: 222
Mileage: 124313 km
Date: 2013.11.15
Time: 00:00:12
Part No SW: 5K7 857 511 A HW: 8J0 857 511 C
Component: FLA H03 0006
Revision: AA002001
Coding: 0102906B74745D545420363E00
VCID: 33331CA2BB32D29F077-8066
Component: IMMO H04 0607
VCID: 6A8DC1C6ACF85357741-803E
Address 26: Auto Roof Labels: None
Part No: 5K7 959 255
Component: VSG GOLF 6 H15 0360
VCID: 7AADF186D0D8E3D7841-802E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660747137
VCID: 290FFECA69FE984FBDB-807C
Reset counter: 222
Reset counter: 222
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2156
Coding: 0017076
VCID: 392F2E8A955E28CFCDB-806C
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 34311FBEB23CD5A71ED-8060
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 6.5 V
PD
Temperature: 18.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0017332
VCID: 3A2D3186905823D7C41-806E
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 A HW: 3C8 035 195 A
Component: Radio RCD510 041 0166
Revision: 00000001 Serial number: VWZ1Z3K9797309
Coding: 0100040004
Shop #: WSC 01324 020 00200
VCID: 2615F5F678E0B737909-8072
Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
Component: Tuer-SG H01 2103
Coding: 0000144
Shop #: WSC 00040 040 1012545
VCID: 42DD4966F8886B179C1-8016
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Part No SW: 8P7 959 812 B HW: 8P7 959 812 B
Coding: 0000144
VCID: 43D34C62E792621F977-8016
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660660769
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2615F5F67860B737909-8072
U1400 00 [008] - -
Reset counter: 222
Mileage: 124313 km
Date: 2019.06.25
Time: 12:32:02
End----------(Elapsed Time: 01:24, VBatt start/end: 12.1V/12.1V)-----------
