Results 1 to 10 of 13
Thread: Hello
    New User
    Jul 2019
    Hello
    I have a Mk7 golf and have been trying to get footwell lights fitted. I have followed a guide for this using vcds. Now I have no lights on the interior or the puddle lights on the mirrors. Is it possible that I have turned these off accidentally?? I have checked all fuses and seem ok.
    Any help would be appreciated.
    Neil
    What coding/adaptations have you changed with VCDS?
    A full Auto-Scan would be a starting point for us to help you.
  3. Likes Uwe liked this post
    New User
    Jul 2019
    Will post one up. Thanks
    New User
    Jul 2019
    Hello, Please see scan below. Hope you can see it.
    Sunday,14,July,2019,14:35:03:24573
    VIN: WVWZZZAUZFP598083   License Plate: N666HWL
    Mileage: 112863km-70129mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZFP598083   Mileage: 112863km-70129miles
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 7635
       Revision: 84H22---
       Coding: 01110012034505092000
       Shop #: WSC 00028 028 00074
       ASAM Dataset: EV_ECM16TDI01104L906021M 002012
       ROD: EV_ECM16TDI01104L906021P.rod
       VCID: 2F3B10CC1798B3AF633-807A
    17158 - Databus
              U1123 00 [040] - Received Error Message
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:22
                        Coolant temperature: 44 °C
                        Intake air temperature: 42 °C
                        Voltage terminal 30: 12.160 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
              U0428 00 [040] - -
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:21
                        Voltage terminal 30: 12.220 V
                        Cruise Control System (CCS): status-Bits 0-7: 0
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 60345000001046
       Coding: 04FA8AA1242909740777060841C62520512490E06082A4F31440F078C002
       VCID: 7EA5FD8880728A27B85-802A
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Reset counter: 20
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:22
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 139
                        Mileage: 109030 km
                        Date: 2019.02.23
                        Time: 12:09:11
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 21
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:32
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 21
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:32
       Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
       Component: AC Manuell    H02 1001
       Revision: 00001K06
       Coding: 02120104202100001000000000000000
       Shop #: WSC 00028 028 00067
       VCID: 3C213780D6EE5837D61-8068
       Part No SW: 5Q0 937 086 AC    HW: 5Q0 937 086 AC
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86581901150701
       Coding: 07000842C2C1027B0BA44080B10403281008000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7BA3F49C93609F0F9FB-802E
       Component: WWS    150115  042 0551
       Serial number:         150122023223
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S3Y15M01D26H06M19S58
       Coding: 00A8DD
       Serial number: 000000000ZY150140ENQ
       Serial number: 00000000000061534146
    8 Faults Found:
    919560 - Light Switch
              B126A 29 [136] - Signal Implausible
                        Reset counter: 21
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:00:30
    460041 - Heated Rear Window
              B1265 14 [008] - Open or Short to Ground
                        Reset counter: 21
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:00:30
    132619 - Voltage Supply; Terminal 30; Right
              B140E 13 [008] - Open Circuit
                        Reset counter: 21
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:34:55
    132363 - Voltage Supply; Terminal 30; Left
              B140D 13 [008] - Open Circuit
                        Reset counter: 21
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:00:30
    133131 - Voltage Supply Terminal 30
              B1423 13 [008] - Open Circuit
                        Reset counter: 21
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:00:30
    525056 - Production Mode Active
              U1103 00 [009] - -
                        Reset counter: 0
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:00:30
    262912 - Sensor for Anti-Theft Alarm System
              B1330 F5 [009] - Alert Emergency Activation Stage 1
                        Reset counter: 236
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:36:51
    565764 - LED Light Bar
              B1664 31 [009] - No Signal
                        Reset counter: 236
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 05:27:56
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391502007979
       Coding: 0071051001
       VCID: 3D273A84CDF4513FE1F-8068
    13637426 - Databus
                        Reset counter: 21
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:22
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 04011503212077
       Coding: 00000300FE0739
       VCID: 38292B90E2D67417329-806C
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 21
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:22
                        Control Module temperature: 21 °C
                        Voltage terminal 15: 12.2 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 21
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:22
                        Voltage terminal 15: 12.1 V
    1078 - Databus
              [FAULT_CIS_SAS_INIT]
                        Reset counter: 21
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:23
    1043 - Automatic Distance Control
              B10E7 F0 [008] - Disconnected
              [FAULT_CIS_TSK_IRREV_FAIL]
                        Reset counter: 22
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:22
       Component: AirbagVW20    014 0386
       Serial number: 003MLR0BSC83
       Shop #: WSC 00028 028 00064
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F5B008C8778832FB33-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169677B29011541565
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34169676B30011571383
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 901 15
       Serial number: 3576700000053575F21S
       Subsystem 4 - Part No SW: -----------    HW: 480 002 901 15
       Serial number: 358670000001D375F21X
       Subsystem 5 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 3516502B51901D92C1DD
       Subsystem 6 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 3526502C9192BC70226A
       Subsystem 7 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 3556502A71901D9140D8
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 21
                        Mileage: 112806 km
                        Date: 2019.07.13
                        Time: 00:05:23
       Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150125400158
       Coding: 0C00
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 41DF4674B10C35DF857-8014
       Part No SW: 5G1 920 941     HW: 5G1 920 941
       Component: KOMBI         204 4270
       Coding: 27A512002780260001886A011400000000000000
       VCID: 6695B5E8F8E232E7505-8032
    16777022 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_NAV SD_0x32 keine Kommunikation]
                        Reset counter: 125
                        Mileage: 107323 km
                        Date: 2018.12.08
                        Time: 13:13:15
       Revision: --------    Serial number: 31011510800175
       Coding: 030100040F087300EF00005C080F00010001050000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72BDD9B8C42ADE47CCD-8026
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150000154740065051
       Coding: 2CFFFF
       Serial number: 8758365303
    131659 - Door Control Module - Passenger's Door
              U0200 00 [008] - No Communications
              [Timeout Knoten 0x4B / 52 - Türsteuergerät Beifahrerseite]
                        Reset counter: 21
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 06:34:59
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
       Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
       Component: TSG FS        009 0015
       Serial number: 0000133918880
       Coding: 00310220D001028000001000
       VCID: 45D75264A52419FFB9F-8010
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000007894654
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8102
       VCID: 43D34C7CAB1027CF97B-8016
    12289 - Supply voltage
              [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
                        Reset counter: 40
                        Mileage: 112840 km
                        Date: 2019.07.13
                        Time: 00:00:01
                        Motor status: 00
                        Supply voltage: 7.25 V
                        Temperature: 17.0 °C
                        KFC: 30
                        KFA: 00 01
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 5.11 V
                        uAdSensI_SwitchedKl30_xdu16: 5.11 V
       Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0015
       Serial number: 0000135176896
       Coding: 00310020DE01028000801000
       VCID: 44D14F60AE1E20F7AE1-8010
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000007792626
       Coding: 050000
       Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
       Component: MU-S-D-ER     041 0421
       Serial number: V5C02901151851
       Coding: 02730200FF00000021111201000800001F0100060100010001
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 1F1BE00C6738232FD33-804A
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H60 0030
       Serial number: VWZ8Z9RS206ZXA
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
    Sep 2014
    You seem to have a number of Supply voltage (terminal 30) issues showing in the (09) Central Electric module.
    These need to be investigated and fixed.
    Was the guide you followed definitely for your model and year of car?
    You need to have a good look at the new wiring to see what has caused these faults.
  7. Likes Uwe liked this post
    New User
    Jul 2019
    Ok will have look. The guide I followed did say it was suitable for my car. Thanks
    Neil: To add to the responses that you have already received from Grant - and for the simpler matter (I suspect) of the puddle lights- here's a more readable version of the code string on the Passenger door module @hex52:
    Byte	Hex	Binary
    0	00	00000000
    1	31	00110001
    2	00	00000000
    3	20	00100000
    4	DE	11011110
    5	01	00000001
    6	02	00000010
    7	80	10000000
    8	00	00000000
    9	80	10000000
    10	10	00010000
    11	00	00000000
    I've highlighted Byte1, Bit2 -which should be set for puddle light operation. (it's obtusely called "exit light" in the Long Coding Helper screen).
    So- Byte1 should be hex35 and the same for the Driver door module @ address hex42)
    Last edited by DV52; 07-17-2019 at 08:47 PM. Reason: can't mentally do binary-to-hex conversion! - should be hex35
  10. Likes Uwe liked this post
  11. #8
    New User
    Jul 2019
    Thanks Don, I have had a guy look at with a different dealer level software and the interior lights now work, but not the puddle lights. I will look at your information and see if I can see why. Many thanks.
    Neil
  12. #9
    New User
    Jul 2019
    Puddle lights now working. Thanks to everyone who has given advice. Now cam someone point in the correct direction for a guide on trying again to get the footwell lights working.
    Thanks Neil
  13. Likes Uwe liked this post
  14. #10
    Neil - good to read about your success with the puddle-lights!!
    Please help me with my confusion: what part of the seemingly diametrically-opposite positions in your 2 x posts below have I failed to understand (the blue bold bits)?
    Quote Originally Posted by Neil73 View Post
    Neil
    Thanks Neil
