Results 1 to 10 of 15
Thread: 2005 Audi A8L Basic settings help
    Jul 2019
    Canada
    Hello all, I'm new here. My basic settings for MMI got deleted because car battery voltage was insufficient. My MMI buttons don't do anything. How do I reprogram basic settings to make it work? The button "Basic settings" when I go into head control is locked and I can't press it. Thank you.
    Hi and welcome.
    Please post an Auto-Scan so we can see what your car knows/thinks that might be relevant to the problem you're experiencing.
    Jul 2019
    Canada
    Just a little back story first. My car was absolutely flawless except for a abs light due to a sensor on a back right wheel, and because of that my traction light was on and couldn't use ebrake. Then battery died and this happened and so I went to a dealer and they reprogrammed it and everything was perfectly fine again. Until this happened again and so I just bought vcds to do this myself instead of paying the dealer. I didn't change any values just looked around and did a bunch of scans and now not only does the mmi not work but also on the scan list theres a ton more malfunctions and the drivers side of the car is sitting half an inch higher than the passenger side. I just need to reprogram basic settings for the mmi and hopefully everything else will fix itself after that.
    Here is the scan.
    https://www.dropbox.com/s/dhigf4etm0...iScan.pdf?dl=0
    Please post the text of the scan here as described in the link I provided. A PDF print-out hosted elsewhere is less than optimal. If you look in the Scans sub-folder you will find a file with the original text of that scan.
    I'll say this: The voltage in shown in your scan (11.7V/11.7V) is quite low and some modules are likely to refuse basic settings or adaptations as a result.
    How long ago was this car's battery changed? Do you have a battery charger?
  5. Likes Jack@European_Parts liked this post
    Yeah nein links, post data here & indeed if voltage is insufficient the wake maybe purposely prevented to keep essential components alive.
    Jul 2019
    Canada
    I have no idea when it was last changed. I can change it out if need be. But when I do get a new battery, how do I go about fixing this issue? & Do you need me to repost the file but in a text format or is that link sufficient for now?
    I would charge the battery to see what happens.
    Posting the text would be appreciated.
  9. #8
    Jul 2019
    Canada
    I will try that & I'll get back with an update in a day or two. Thank you.
  10. #9
    Jul 2019
    Canada
    I unplugged the battery for 15 minutes and then had it on with a battery booster to pretend that I have a new battery. Did the scan and here are the results. I also tried going into adaptation for control head and the leveling and read channel 00 and pressed save which is supposed to reset all adaptations to default values and still nothing. Also still cant press Basic Settings button for the control head. In the scan it says that control head button is stuck but I have no idea what that means because it doesn't specify which buttons and I pressed every button to make sure nothing is stuck. I'm super lost.
    Here is the text version of the scan:
    Monday,15,July,2019,17:27:12:17457
    VIN: WAUML44E65N015437   License Plate:
    Mileage: 375800km-233511mi   Repair Order:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
              47 4F 52 53 55 56 61 62 65 67 72 76 77
    VIN: WAUML44E65N015437   Mileage: 375800km-233511miles
    0E-Media Player 1 -- Status: Malfunction 0010
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 077-910-560-BFM.clb
       Part No SW: 4E0 910 560 J    HW: 4E0 907 560
       Component: 4.2L V8/5V      G   0010
       Revision: --H01---    Serial number: AUX3Z0E1759150
       Coding: 0007773
       Shop #: WSC 02313 785 00200
       VCID: 2809F89C8EF75857A29-807C
    18061 - Please check DTC Memory of ABS Controller
                P1653 - 008 -
    18010 - Power Supply Terminal 30
                P1602 - 002 - Voltage too Low
    Readiness: 0110 1101
       Part No SW: 4E0 910 156 S    HW: 09E 927 156 A
       Component: AG6 09E 4,2L5V USA  0020
       Revision: --H01---    Serial number:        0053789
       VCID: 323D1AF4B82B22870CD-8066
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
       Component: ESP 5.7 allrad  H44 0510
       Coding: 0007597
       VCID: 221DEAB4E8CBB207FCD-8076
    00003 - Control Module
                014 - Defective
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 D
       Component:     FBS AUDID3  H04 0140
       Revision: 01404004    Serial number: AUX3Z0E1759150
       Coding: 0410624
       Shop #: WSC 02311 785 00200
       VCID: 58E9885CFE1728D7D29-800C
    00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
                001 - Upper Limit Exceeded
                        Fault Status: 01100001
                        Fault Frequency: 0
                        Reset counter: 28
                        Mileage: 375744 km
                        Date: 2019.07.12
                        Time: 18:54:48
    00183 - Interior Access/Start Authorization Antenna 1 (R138)
                        Fault Frequency: 0
                        Reset counter: 28
                        Mileage: 375744 km
                        Date: 2019.07.12
                        Time: 18:54:48
    00191 - Passenger's Door Handle Touch Sensor (G416)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 31
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H08  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3940576
       VCID: 2313EFB0F7D1BB0FF7B-8076
    Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
       Part No SW: 4E0 910 730 G    HW: 4E0 035 729
       Component: Interfacebox    H43 1070
       Revision: 00000000    Serial number: 346BL057520375
       Coding: 0000003
       Shop #: WSC 47344 001 104857
       VCID: 2411ECACF2DFBC378E1-8070
       Subsystem 1 - Part No: 4E0 910 609 C
       Component: Bedienteil MMI  H42 0100
       Subsystem 2 - Serial number: 390B9057502202
       Subsystem 3 - Serial number: 7416.02.0500000000290B0145˙
       Subsystem 4 - Serial number: 0B0145˙
                        Reset counter: 28
                        Mileage: 375757 km
                        Date: 2019.07.12
                        Time: 18:15:49
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      100
       Part No SW: 4E0 910 043 B    HW: 4E0 820 043 E
       Component: KLIMAAUTOMAT    016 0400
       Revision: 00000030    Serial number: 00000000062010
       Coding: 1052993
       VCID: 1C61D44CCAAF84F7361-8048
       Subsystem 1 - Part No: 4E0 910 772 A
       Component: Sitzluefter  FS H02  010
       Subsystem 2 - Part No: 4E0 910 772 A
       Component: Sitzluefter BFS H02  010
       Subsystem 3 - Serial number: 898053000
       Subsystem 4 - Serial number: HO20122004065A000000000404˙†89
       Subsystem 5 - Serial number: 000404˙†898053000      000-SHO
       Subsystem 6 - Serial number:     000-SHO20122004065A00000000
       Subsystem 7 - Serial number: 65A000000000435˙
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 29
                        Mileage: 375778 km
                        Date: 2019.07.14
                        Time: 12:07:37
                        Temperature: 29.0°C
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 L    HW: 4E0 907 279 L
       Component: ILM Fahrer      H12 0210
       Coding: 0123104
       VCID: 313F15F8BD2D199F757-8064
       Subsystem 1 - Part No: 4E1 910 113 B
       Component: Wischer WWS D3  H50 0400
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
                        Reset counter: 71
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7115454
       VCID: 1B63D750CFA183CF3FB-804E
                        Reset counter: 61
                        Mileage: 375666 km
                        Date: 2019.07.10
                        Time: 16:55:17
    Address 15: Airbags        Labels: 4E0-910-655-84.lbl
       Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
       Component: Airbag 8.4E+    H10 0920
       Coding: 0530707
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549
       Coding: 0012141
       VCID: 6597B1A8B965853F59F-8030
       Component: Lenkradmodul    H05 0080
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 900 J    HW: 4E0 920 900 J
       Component: KOMBIINSTR. VDO H53 0200
       Revision: D05         Serial number: AUDID3E1004146
       Coding: 0016333
       Shop #: WSC 91550 999 95537
       VCID: 2615F6A484E34E27905-8072
    Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
       Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
       Component: Gateway         H10 0080
       Revision: 10          Serial number: 1900304B290051
       Coding: FCFE7BDD1B7104
       VCID: 270BFBA083E9572FAB3-8072
                        Fault Frequency: 7
                        Reset counter: 69
                        Mileage: 375757 km
                        Date: 2019.07.12
                        Time: 18:03:08
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0410624
       XXXXXXXXXXX ELV                 XXXX
                        Fault Frequency: 0
                        Reset counter: 28
                        Mileage: 375744 km
                        Date: 2019.07.12
                        Time: 18:54:48
                        Fault Frequency: 0
                        Reset counter: 28
                        Mileage: 375744 km
                        Date: 2019.07.12
                        Time: 18:54:48
                        Reset counter: 31
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 H    HW: 4E0 907 553 F
       Component: LUFTFDR.-CDC    H06 4480
       Coding: 0013310
    01437 - Control Position not Learned
                        Fault Status: 11100101
                        Reset counter: 29
                        Mileage: 375778 km
                        Date: 2019.07.13
                        Time: 16:33:22
       Component: Sitzmemory FS  H08  0060
       Coding: 4071658
       Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
       Component: MNS US          H44 0570
       Revision: 00000000    Serial number: 378B.057517767
       VCID: 353721E8494535BF29F-8060
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135
       Component: Dachknoten D3   H02 0090
       Serial number: 00000435200088
       Coding: 0003477
       VCID: 1D67D948D1B58DFFC1F-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
       Component: Türsteuer.FS BRM002 0060
       Coding: 0032364
       VCID: 2019E0BCE6C7A017EA9-8074
    02110 - Window Regulator Switch
                        Fault Frequency: 14
                        Reset counter: 70
                        Mileage: 375648 km
                        Date: 2019.07.09
                        Time: 18:12:08
    00913 - Window Regulator Switch; Front Right Driver (E81)
                        Reset counter: 67
                        Mileage: 375664 km
                        Date: 2019.07.10
                        Time: 13:03:54
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 A    HW: 4E0 907 289
       Component: Komfortgeraet   H04 0040
       Revision: 00400004    Serial number:  W040502280115
       Coding: 0065086
       Component: Heckdeckel      H06 0050
       Component: Neigungssensor  H03 0020
    01134 - Alarm Horn (H12)
                        Reset counter: 31
                        Mileage: 320417 km
                        Date: 2004.04.30
                        Time: 05:10:53
    00984 - Left Tail Light (M4)
                        Reset counter: 31
                        Mileage: 375802 km
                        Date: 2004.03.25
                        Time: 00:04:21
    00985 - Right Tail Light (M2)
                        Reset counter: 31
                        Mileage: 375802 km
                        Date: 2004.03.25
                        Time: 00:04:21
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 P    HW: 4E0 035 223 A
       Component: DSP-Amp.-High   H13 0460
       Revision: PROD_01     Serial number: 00000000011504
       Coding: 0000016
       VCID: 2A0D029490FB6A47B4D-807E
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H09 0040
       Revision:             Serial number: 00000000055177
       Coding: 0010111
       VCID: 1E65DE44DCB396E7D85-804A
    02258 - Door Opener Transmitter
                        Fault Frequency: 17
                        Reset counter: 31
                        Mileage: 262136 km
                        Date: 2019.07.12
                        Time: 18:01:00
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
       Component: Türsteuer.BF BRM002 0060
       Coding: 0032364
                        Fault Frequency: 0
                        Reset counter: 155
                        Mileage: 373392 km
                        Date: 2004.04.06
                        Time: 21:59:08
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 A    HW: 4E0 907 801
       Component: EPB  AV1C1010   H01 1010
       Revision: AV1C1010
       Coding: 0000532
       Shop #: WSC 25984 067 57207
                        Fault Status: 11101000
                        Reset counter: 31
                        Mileage: 372224 km
                        Date: 2019.02.07
                        Time: 17:10:39
                        Voltage: 10.56 V
                        Count: 231
    Address 55: Headlight Range        Labels: 4E0-910-357.lbl
       Part No SW: 4E0 910 357     HW: 4E0 907 357
       Component: Pre-AFS         H01 0040
       VCID: 629DAAB4A84BF207BCD-8036
                        Fault Status: 11101101
                        Reset counter: 31
                        Mileage: 375752 km
                        Date: 2019.07.12
                        Time: 18:01:44
    01310 - Level Control System Control Module (J197)
                        Reset counter: 31
                        Mileage: 375784 km
                        Date: 2019.07.15
                        Time: 07:11:59
       Part No SW: 4E0 910 541 F    HW: 4E0 035 541 E
       Component: TUNER EU/US/RDW H42 0480
       Revision: 00000000    Serial number: 396BS057504753
       Shop #: WSC 47344 001 1048576
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: ENERGIEMANAGER  H12 0390
       Revision: 00000000    Serial number: 00000000001457
       Shop #: WSC 93285 999 00235
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  1502240141
       Coding: 344530393135313035412056413031353032323430313431
       Shop #: WSC 00000 128 00289
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
       Component: Türsteuer.HL BRM002 0060
       Coding: 0032364
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273     HW: 4E0 907 273
       Component: Reifendruck 2   H01
       Revision: 00010028    Serial number: 00000700030883
       Coding: 0202127
       VCID: 5F9BA3409B39DFEF933-800A
    01477 - System Switched Off
                        Fault Frequency: 253
                        Reset counter: 31
                        Mileage: 373403 km
                        Date: 2004.04.06
                        Time: 21:59:22
                        Temperature: 19.0°C
                        Error Code: 128
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Fault Status: 11100100
                        Reset counter: 158
                        Mileage: 373428 km
                        Date: 2019.05.03
                        Time: 19:57:28
                        Speed: 47.0 km/h
                        Temperature: 4.0°C
                        Error Code: 128
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Part No SW: 4E0 910 753 S    HW: 4E0 035 753 A
       Component: SDS 3501 US     H45 0550
       Revision: 00000000    Serial number: 00000502160426
       Shop #: WSC 12336 024 394758
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
       Component: Türsteuer.HR BRM002 0060
       Coding: 0032364
                        Fault Frequency: 0
                        Reset counter: 155
                        Mileage: 373392 km
                        Date: 2004.04.06
                        Time: 21:59:00
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Component: Parkhilfe 8-Kan H12 0020
       Revision: --.--.--    Serial number: 08720504000086
       Coding: 0001208
       VCID: 211FE5B8EDCDA91FE57-8074
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 28
                        Mileage: 375757 km
                        Date: 2019.07.12
                        Time: 19:28:08
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                        Reset counter: 28
                        Mileage: 375757 km
                        Date: 2019.07.12
                        Time: 19:28:09
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
                        Reset counter: 28
                        Mileage: 375767 km
                        Date: 2019.07.12
                        Time: 19:37:05
                        Reset counter: 68
                        Mileage: 375757 km
                        Date: 2019.07.12
                        Time: 19:28:07
    Address 77: Telephone
    End----------(Elapsed Time: 02:33, VBatt start/end: 13.5V/14.0V)-----------
  11. #10
    Look at MVBs 017 and 018 in 07-Control Head.
    017.1 is a bit field with the following meanings:
    xxxxxxx? = RADIO
    xxxxxx?x = CD/TV
    xxxxx?xx = NAME
    xxxx?xxx = TEL
    xxx?xxxx = NAV
    xx?xxxxx = INFO
    x?xxxxxx = CAR
    ?xxxxxxx = SETUP
    017.2 is a bit field with the following meanings:
    0xxxxxx? = Left Upper Control Button
    0xxxxx?x = Left Lower Control Button
    0xxxx?xx = Right Upper Control Button
    0xxx?xxx = Right Lower Control Button
    0xx?xxxx = Return Button
    0x?xxxxx = Left Arrow Button
    0?xxxxxx = Right Arrow Button
    018.1 is a bit field with the following meanings
    000000x? = Control Button
    000000?x = ON/OFF Knob
    018.2 = Control Knob,Rotation, Range: -127.0...+127.0
    018.3 = ON/OFF Knob,Rotation,Range: -127.0...+127.0
    Fiddle with all the buttons one at a time while watching these values. One (or more) will produce no change when pressed and released. That's the one that's stuck.
