Instrument Panel Output test (MQB)
Amarton
Europe - Hungary
C?ID=338434
Why I couldn't do selective output test on (17) instrument panel?
https://drive.google.com/open?id=1uzLsLfOaV3S9AAWkwVdPzrzYYjHJ4x9h
I think this is a Session issue (suplier session or developer session), but why the VCDS couldn't run UDS session commands when I click the output test button?
Saturday,13,July,2019,14:43:44:64377
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
Workshop Code: 790 73430 000063
VIN: TMBAR7NEXK0000001   License Plate:
Mileage: 18411km-11440mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 6C
VIN: TMBAR7NEXK0036742   Mileage: 18411km-11440miles
Address 01: Engine (J623-DADA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 AL    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 6084
   Revision: 81H22000
   Coding: 011900322324190800000000000000000000000000000000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM15TFS01105E906018AL 003002
   ROD: EV_ECM15TFS01105E906018AL.rod
   VCID: 6FBBD0C76712BBEF233-803B
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 DF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0974
   Revision: 00000000    Serial number: 62278000000267
   Coding: 24076A9124232172407E060460C5242456248402600624722023F070C006430B00000012121212B835351919323200
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
   VCID: 78A9EB9B125CFC57F29-802D
   Part No SW: 5E0 907 044 AP    HW: 5E0 907 044 AP
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 01010004000110011005004800101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   VCID: 73B3DCB70B3A9F0FC7B-8027
   Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H38 0273
   Serial number: 00001823902159
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7AADF1932C50EE4784D-802F
   Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180811  051 0916
   Serial number: 887353F0401822300929
   Coding: 1E4DFD
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Serial number: 72290246
   Part No SW: 5QA 919 283 C    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0050
   Serial number: 000308419618240
   Coding: 0601150001
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA14AU3700000 009037
   ROD: EV_EPHVA14AU3700000_009.rod
   VCID: 4ACD61533C30BEC754D-801F
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W4PHN028S
   Shop #: WSC 73430 790 00000
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0557926F55AE91BFF9F-8051
   Subsystem 1 - Part No SW: -----------    HW: 454 001 308 18
   Serial number: 3570000000090C38B03I
   Subsystem 2 - Part No SW: -----------    HW: 454 001 608 18
   Serial number: 35800000000F1358313C
   Subsystem 3 - Part No SW: -----------    HW: 454 801 908 18
   Serial number: 35100AD22EF15000000S
   Subsystem 4 - Part No SW: -----------    HW: 454 802 108 18
   Serial number: 352005545B6150000009
   Subsystem 5 - Part No SW: -----------    HW: 454 800 408 18
   Serial number: 3550095843915000000E
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 30081820241335
   Coding: 1400
   VCID: 7EA5FD833078C267B85-802B
   Part No SW: 5E0 920 740 F    HW: 5E0 920 740 F
   Component: KOMBI         212 2501
   Coding: 07AD02002180000809003A001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009066
   VCID: 2615F5E38868BAA7905-8073
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008379434
   Coding: 030100047F085700EB000248080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: 3D273A8F7DFE197FE1F-8069
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000D2174290818
   Serial number: 75886002001809012D3D
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000336807160
   Coding: 00110120D000020000001100
   VCID: 48C95B5B223C4CD7429-801D
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000023505338
   Coding: 010200
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 856026 00
   Coding: 0100001000400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: 2B0304D7938A87CF4FB-807F
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000341102239
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 47CB58672F2243AF4B3-8013
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000023517010
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 840 C    HW: 5Q0 035 840 C
   Component: MU-S--ER      H41 0475
   Serial number: SKZAZ2U0789211
   Coding: 03730100FF00000041110001000002002F0208C40120050003
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 2D070ACFAD9E89FF51F-8079
   Subsystem 1 - Part No SW: 5E0 919 605 N    HW: 5E0 919 605 N
   Component: ABT_Std-2  H52 8130
   Serial number: SKZ6ZHV2471660
   Coding: 0473010102002017000040
   VCID: 392F2E9F69D6255FCD7-806D
End----------(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V)-----------
Moved to VCDS Support.
DV52
C?ID=194404
^^^Amarton: you are correct - my virtual MQB test bench has the same problem (see details of hex17 module below). Most output test options work, but for some reason the first two don't (gong & segment test). what does 7F 2F 31 mean?
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         252 2210
   Coding: 27A41A002780260001882A01000000 - this is NOT a working code-string (it's for a test-bench)
   VCID: 281C3DC853B2B302D4-807
Not sure if it helps, but my "other" device does work on the gong output test and the segment test. However, I needed to select some starting variables before the test would successfully run. For example, in the gong test, I had a list of acoustic signal numbers from which to choose - I selected "all acoustics". Not sure how VCDS manages this precondition?
Amarton
Europe - Hungary
C?ID=338434
2F UDS command means input / output test.
The respond has to be 6F. (always more than 0x40)
The 7F means error. The control module reject the command. Maybe uds security access missing or the command was sent in wrong session state.
DV52
C?ID=194404
Eric: forgive my impudence - but I couldn't resist (not sure if the pic captures your face correctly - but because you "are from Ross-Tech", I know that the physique is a close match)
