Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Audi RS4 4.2 Avant Quattro. J792 No signal/communications. And yes there is autoscan.
    Jul 2019
    Update time!
    #Jack
    Use the micro-what?
    Here are the pictures of the bodged wire repair:
    https://imgur.com/a/65fM4Tg
    Now, today i fixed a part of the problem. I believe this car is NOT fitted with Dynamic Steering. In some control modules Dynamic Steering is checked, in others unchecked. In 09 Central, byte 08 bit 3 was set (see pictures), and clearly the car does not have magnetic ride suspension.
    Conclusion, someone fucked the coding up, maybe in the Hidden Green Menu?
    Unflagging byte 7 bit 4 was not enough for the 09 Central module to forget the J792, but when i also unflagged the byte 08 bit 1, AND enabled bit 4, 09 CECM is now error free.
    I hoped this would fix all J792 errors, but apparently there are other control units calling for it.
    06C Backup cam does not invoke J792 no communications, but in other forum posts i have seen this happen. More proof this is coding error.
    https://imgur.com/a/6OHnRC9
    Furthermore disabled byte 4 bit 5 in 17 Instrument, didn't seem to help.'
    Also a bit in 44 Steering was unchecked called Dynamic Setting installed (PR-1N7/1N8). What is this supposed to be i wonder?
    https://imgur.com/a/bElAcr4
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #12
    Jul 2019
    And here is new autoscan:
    Monday,15,July,2019,15:24:05:10970
    VCDS Version: 19.6.1.0 (x64)
    VIN: WUAZZZ8K9EAxxxxxx   License Plate:
    Mileage: 114530km-71165miRS410   Repair Order:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 22 36 42 44 46 47 52 53
              56 5C 5F 62 6C 6D 72
    VIN: WUAZZZ8K9EA900021   Mileage: 114530km-71165miles
    13-Auto Dist. Reg -- Status: Cannot be reached 1100
    5C-Lane Maintain. -- Status: Malfunction 0010
    Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
       Part No SW: 8T2 907 560     HW: 8T1 907 560
       Component: 4.2l V8HDZ /  H04 0003
       Revision: NAH04---
       Coding: 1225003225C6000A3000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM42FSI0118T2907560 001006
       ROD: EV_ECM42FSI0118T2907560.rod
       VCID: 79F9D5BCF8F38887DE-802C
    4327 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:08
                        Coolant temperature: 15 °C
                        Intake air temperature: 20 °C
                        Voltage terminal 30: 11.355 V
                        AFS dm: 0.0 kg/h
                        Engine operating condition-Channel 87: Idling
                        Relative load value: 60.61 %
                        Tumg: 19.5 °C
                        Psr w: 1003.59 hPa
                        Engine torque: 0.0 Nm
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [039] - -
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:08
                        Voltage terminal 30: 11.379 V
                        AFS dm: 0.0 kg/h
                        Tumg: 19.5 °C
                        Psr w: 1003.59 hPa
    4729 - Steering Effort Control Module
              U0130 00 [039] - No Communications
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:08
                        CAN status - engine control module-Bits 0-7: 00000000
                        CAN status - transmission control module-Bits 0-7: 00000000
                        CAN status - brake control module 1-Bits 0-7: 00000000
                        CAN status - brake control module 2-Bits 0-7: 00000000
                        selected gear-Bits 0-7: 00000000
                        Cruise control switch actuation-Bits 0-7: 00000000
    Readiness: 1110 1101
       Part No SW: 8K5 927 156     HW: 0B5 927 156 J
       Component: 0B5 42 FSIRdW H01 0005
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021.rod
       VCID: 76E3DE80C9EDE7FFB3-8022
       Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
       Coding: 346D4A
       Shop #: WSC 45463 002 1048576
       VCID: 4581694CCC8B3C67EA-8010
       Part No SW: 8K0 907 064 GH    HW: 8K0 907 064 FH
       Component: BCM2 2.0      H11 0621
       Coding: 05824000000000000000
       VCID: 7CF7CCA8FFC1BDAFC5-8028
       Subsystem 1 - Part No SW: 4H0 959 754 DD    HW: 4H0 959 754 DD
       Component: FBSAUDID4 IDG  H71 0083
       Serial number: 0813000008566002
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01071120121443
       Coding: 4800000000
       VCID: 397915BCB07348879E-806C
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
                        Temperature: 19.0°C
                        Temperature: 15.0°C
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 22.0°C
       Revision: 08016001    Serial number: 00000510001001
       Coding: 0600001000349FE0358140C3000019090F9CC70822090201000008004401030100000024000000
       VCID: 78FFD0B8CBF9918FA1-802C
       Component: WWS 091112  H07 0080
       Serial number: SWF12110095625
       Coding: 00FD11
       Serial number: 20718148
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002910120199
       Serial number: 29284856000000000001
    Address 13: Auto Dist. Reg
       Serial number: 003KFD96LUB%
       Coding: 30524435363030303030554A304C384B3053
       Shop #: WSC 37351 001 1048576
       VCID: 489F6078F399210F11-801C
       Serial number: 6334MSME720354723
       Serial number: 6344MSME720532261
       Serial number: 6352QSME5324216EE
       Serial number: 6362QSME4F224B64Q
       Serial number: 63732SME6D3A0868A
       Serial number: 63832SME4D3754621
    12660736 - Steering Effort Control Module
              U0130 00 [009] - No Communications
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:08
       Revision: --------    Serial number: 90372LK2000L2
       Coding: 0000BF
       Shop #: WSC 21471 003 104857
       VCID: 44877448C7B1056FFD-8010
    02795 - Steering Wheel Vibration Motor (V331)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
       Part No SW: 8K0 920 931 G    HW: 8K0 920 931 G
       Component: KOMBIINSTR.   H35 0556
       Revision: 00000000    Serial number: UW32DCZAD
       Coding: 13EF1100CF010008010000
       Shop #: WSC 06325 123 12345
       VCID: 326B22906D05BBDF5F-8066
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:08
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 1Z100027    Serial number: 2741Z12A18012A
       Coding: 80E3031600
       VCID: 4C975C68EFE1CD2F35-8018
       Serial number: 1247678501
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:08
                        Bin. Bits:    10111
                        Voltage: 11.40 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
       Revision: AA001002
       Coding: 02019164747464545425363E00
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H13 0100
       Serial number: 002210120001153
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F6D2BE47637963730-807A
    0308 - System Function Test
              C102A F0 [137] - Could not be Performed
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
    0226 - Steering Effort Control Module
              U0130 00 [137] - No Communications
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
    0261 - No Basic Setting
              B2010 00 [137] - -
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000042045438
       Coding: 00581B00000000000000
       VCID: 3B750FB4BA4F7A978C-806E
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000043737671
       Coding: 011C12205E00410001
       VCID: 4D91516C14FBC42722-8018
       Revision: 00001000    Serial number: 0018980022
       Coding: 100001010001
       Shop #: WSC 06324 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 346724889F11B5EF4D-8060
       Revision: 00002001    Serial number: 0186298783
       Coding: 013A0E20A0B930958030023280000000
       Subsystem 1 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS150  H08 0043
       Subsystem 2 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
    01403 - Glass-Break Sensors; Rear
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
    03156 - Sensor for Anti-Theft System (G578)
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:11
    01134 - Alarm Horn (H12)
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:11
       Revision: 00005001    Serial number: 94813007725702
       VCID: 2D5131EC743BE42702-8078
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000043543765
       Shop #: WSC 06342 000 00000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000122375
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 387F10B88379518F61-806C
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
                        Voltage terminal 30: 11.5 V
                        Internal Fault ID: 188
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
       Part No SW: 4G1 035 053 G    HW: 4G1 035 053
       Component: Radio U Basic H41 0121
       Revision: AB001007    Serial number: 227K+0C7660741
       Coding: 010003010000000001
       VCID: 2345D7D422FF2257A4-8076
    Address 5C: Lane Maintain.        Labels: None
       Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
       Component: J759 HC             0040
       Revision: 00H08006    Serial number: 600212B0600102
       Coding: 0022001
       VCID: 377D138446675EF768-8062
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:06
    02797 - Control Module for Directional Stabilization Assistance (J759)
                        Fault Status: 01100101
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:07
       Part No SW: 8R1 035 666 B    HW: 8R1 035 666 C
       Component: H-BN-EU       H45 0639
       Revision: --------    Serial number: 205K%0C7556652
       Coding: 12010001030689EF6D80CB5E00000403E40000020000000000
       VCID: 377D138486675EF768-8062
       Subsystem 1 - Part No: 8R0 060 884 AR
       Component: ECE 2013  1505
       Component: DU7 High  H41 0104
       Serial number: A130K-0C2579226
       Subsystem 3 - Part No SW: 8T0 919 611 N    HW: 8T0 919 611 J
       Serial number: 00000001321212
       Component: CD-Database  4949
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.15
                        Time: 15:19:15
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
       Revision:             Serial number: 0000043819431
       Coding: 010C12204000210001
       VCID: 46836E40F18D377FE3-8012
       Revision: --H07---    Serial number: 525PA8-J28947C
       Coding: 1020007
       VCID: 387F10B84B79518F61-806C
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C770CA8BF417DAF85-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Serial number: 8K9827852A
       Revision:             Serial number: 0000043817134
    End-------------------------(Elapsed Time: 04:09)--------------------------
  4. #13
    May 2016
    Vcds75, yeah seen battery at 11.9 at idle so prudent you changed.
    Not having wiring in front of me dont know if replaced wiring involve twisted pairs or can bus. Just saying cant just add on as you like in some circuits.
    Good luck.
    LARIMORE
