Results 1 to 10 of 13
Thread: Audi RS4 4.2 Avant Quattro. J792 No signal/communications. And yes there is autoscan.
    Jul 2019
    Hello new user here.
    This Audi RS4 B8 Production year 2014 belongs to a friend. Imported from another european country, however the instrument and autoscan show plenty of errors. Do mind i have no service history nor any idea which madman has conjured all these errors. Just as usual.
    The primary issue is multiple J792 No signal/communications, errors. This control unit seems to be related to the Dynamic Steering feature.
    Steps i have taken:
    1. Check fuses. There is no fuse on ST1 SC1 (or ST3 SC4), which the wiring diagrams suggest. No wires either. Bummer.
    2. According to workshop manual, the J792 units is supposed to reside under the drivers seat, beneath the carpet in front of the crossmember. I had to check, and there was no J792 unit/wires.
    3. Check PR codes. Of course the PR sticker was missing, however i checked the VIN using this shady site https://carinfo.kiev.ua/cars/vin/audi
    According to the ukranian site the car is fitted with 1N8, which corresponds to "Steering: Power steering (dynamic steering)"
    4. In VCDS i tried disabling Dynamic Steering in 09 Central Elec. Byte 7 bit 4. (Using information from this page http://www.audienthusiasts.com/VagCom_FL_ADS.html).
    5. I tried enabling Adress 1B in the gateway installation list. No dice.
    Can the J792 be located in another spot because of RS designation?
    Can this J792 function be delegated to another control unit in some configurations?
    Maybe this car doesn't have Dynamic Steering, and this is a coding matter?
    2. Secondary problem the J428 sensor/control unit is in Component Protection mode, i believe local Audi can code the module, matching it to the VIN of the car yes?
    3. The fuse for the alarm system is missing, probably because of the broken glass sensor error. However the window is not broken. Bad wires perhaps.
    2 &3 i will fix myself.
    Now here's what you really came for
    Saturday,13,July,2019,13:20:21:10970
    VCDS Version: 19.6.1.0 (x64)
    VIN: WUAZZZ8K9EAxxxxxx   License Plate:
    Mileage: 114530km-71165miRS4nyefter   Repair Order:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 22 36 42 44 46 47 52 53
              56 5C 5F 62 6C 6D 72
    VIN: WUAZZZ8K9EAxxxxxx   Mileage: 114530km-71165miles
    13-Auto Dist. Reg -- Status: Cannot be reached 1100
    5C-Lane Maintain. -- Status: Malfunction 0010
    Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
       Part No SW: 8T2 907 560     HW: 8T1 907 560
       Component: 4.2l V8HDZ /  H04 0003
       Revision: NAH04---
       Coding: 1225003225C6000A3000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM42FSI0118T2907560 001006
       ROD: EV_ECM42FSI0118T2907560.rod
       VCID: 79F9D5BCF8F38887DE-802C
    4327 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
                        Coolant temperature: 19 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 11.850 V
                        AFS dm: 0.0 kg/h
                        Engine operating condition-Channel 87: Idling
                        Relative load value: 59.77 %
                        Tumg: 20.3 °C
                        Psr w: 1006.02 hPa
                        Engine torque: 0.0 Nm
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [039] - -
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
                        AFS dm: 0.0 kg/h
                        Tumg: 20.3 °C
                        Psr w: 1006.02 hPa
    4729 - Steering Effort Control Module
              U0130 00 [039] - No Communications
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
                        CAN status - engine control module-Bits 0-7: 00000000
                        CAN status - transmission control module-Bits 0-7: 00000000
                        CAN status - brake control module 1-Bits 0-7: 00000000
                        CAN status - brake control module 2-Bits 0-7: 00000000
                        selected gear-Bits 0-7: 00000000
                        Cruise control switch actuation-Bits 0-7: 00000000
    Readiness: 1110 1101
       Part No SW: 8K5 927 156     HW: 0B5 927 156 J
       Component: 0B5 42 FSIRdW H01 0005
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021.rod
       VCID: 76E3DE80C9EDE7FFB3-8022
       Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
       Coding: 346D4A
       Shop #: WSC 45463 002 1048576
       VCID: 4581694CCC8B3C67EA-8010
       Part No SW: 8K0 907 064 GH    HW: 8K0 907 064 FH
       Component: BCM2 2.0      H11 0621
       Coding: 05824000000000000000
       VCID: 7CF7CCA8FFC1BDAFC5-8028
       Subsystem 1 - Part No SW: 4H0 959 754 DD    HW: 4H0 959 754 DD
       Component: FBSAUDID4 IDG  H71 0083
       Serial number: 0813000008566002
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01071120121443
       Coding: 4800000000
       VCID: 397915BCB07348879E-806C
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:03
                        Temperature: 25.0°C
                        Temperature: 19.0°C
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 31.0°C
       Revision: 08016001    Serial number: 00000510001001
       Coding: 0600001000349FF0358140C3000019090F9CC70822090201000008004401030100000024000000
       VCID: 78FFD0B8CBF9918FA1-802C
       Component: WWS 091112  H07 0080
       Serial number: SWF12110095625
       Coding: 00FD11
       Serial number: 20718148
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002910120199
       Serial number: 29284856000000000001
    03110 - Active Steering Control Module (J792)
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
    Address 13: Auto Dist. Reg
       Serial number: 003KFD96LUB%
       Coding: 30524435363030303030554A304C384B3053
       Shop #: WSC 37351 001 1048576
       VCID: 489F6078F399210F11-801C
       Serial number: 6334MSME720354723
       Serial number: 6344MSME720532261
       Serial number: 6352QSME5324216EE
       Serial number: 6362QSME4F224B64Q
       Serial number: 63732SME6D3A0868A
       Serial number: 63832SME4D3754621
    12660736 - Steering Effort Control Module
              U0130 00 [009] - No Communications
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
       Revision: --------    Serial number: 90372LK2000L2
       Coding: 0000BF
       Shop #: WSC 21471 003 104857
       VCID: 44877448C7B1056FFD-8010
    02795 - Steering Wheel Vibration Motor (V331)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:03
       Part No SW: 8K0 920 931 G    HW: 8K0 920 931 G
       Component: KOMBIINSTR.   H35 0556
       Revision: 00000000    Serial number: UW32DCZAD
       Coding: 13EF1100CF010008010000
       Shop #: WSC 06325 123 12345
       VCID: 326B22906D05BBDF5F-8066
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:05
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 1Z100027    Serial number: 2741Z12A18012A
       Coding: 80E3031600
       VCID: 4C975C68EFE1CD2F35-8018
       Serial number: 1247678501
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
                        Bin. Bits:    10111
                        Voltage: 11.80 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
       Revision: AA001002
       Coding: 02019164747464545425363E00
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H13 0100
       Serial number: 002210120001153
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F6D2BE47637963730-807A
    0308 - System Function Test
              C102A F0 [137] - Could not be Performed
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
    0226 - Steering Effort Control Module
              U0130 00 [137] - No Communications
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
    0261 - No Basic Setting
              B2010 00 [137] - -
                        Reset counter: 0
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000042045438
       Coding: 00581B00000000000000
       VCID: 3B750FB4BA4F7A978C-806E
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000043737671
       Coding: 011C12205E00410001
       VCID: 4D91516C14FBC42722-8018
       Revision: 00001000    Serial number: 0018980022
       Coding: 100001010001
       Shop #: WSC 06324 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 346724889F11B5EF4D-8060
       Revision: 00002001    Serial number: 0186298783
       Coding: 013A0E20A0B930958030023280000000
       Subsystem 1 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS150  H08 0043
       Subsystem 2 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
    01403 - Glass-Break Sensors; Rear
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:03
    03156 - Sensor for Anti-Theft System (G578)
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:07
    01134 - Alarm Horn (H12)
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:07
       Revision: 00005001    Serial number: 94813007725702
       VCID: 2D5131EC743BE42702-8078
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000043543765
       Shop #: WSC 06342 000 00000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000122375
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 387F10B88379518F61-806C
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:04
                        Voltage terminal 30: 11.9 V
                        Internal Fault ID: 188
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
       Part No SW: 4G1 035 053 G    HW: 4G1 035 053
       Component: Radio U Basic H41 0121
       Revision: AB001007    Serial number: 227K+0C7660741
       Coding: 010003010000000001
       VCID: 2345D7D422FF2257A4-8076
    Address 5C: Lane Maintain.        Labels: None
       Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
       Component: J759 HC             0040
       Revision: 00H08006    Serial number: 600212B0600102
       Coding: 0022001
       VCID: 377D138446675EF768-8062
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:03
    02797 - Control Module for Directional Stabilization Assistance (J759)
                        Fault Status: 01100101
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:03
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:03
       Part No SW: 8R1 035 666 B    HW: 8R1 035 666 C
       Component: H-BN-EU       H45 0639
       Revision: --------    Serial number: 205K%0C7556652
       Coding: 12010001030689EF6D80CB5E00000403E40000020000000000
       VCID: 377D138486675EF768-8062
       Subsystem 1 - Part No: 8R0 060 884 AR
       Component: ECE 2013  1505
       Component: DU7 High  H41 0104
       Serial number: A130K-0C2579226
       Subsystem 3 - Part No SW: 8T0 919 611 N    HW: 8T0 919 611 J
       Serial number: 00000001321212
       Component: CD-Database  4949
                        Reset counter: 139
                        Mileage: 114534 km
                        Date: 2019.07.13
                        Time: 13:15:11
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
       Revision:             Serial number: 0000043819431
       Coding: 010C12204000210001
       VCID: 46836E40F18D377FE3-8012
       Revision: --H07---    Serial number: 525PA8-J28947C
       Coding: 1020007
       VCID: 387F10B84B79518F61-806C
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C770CA8BF417DAF85-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Serial number: 8K9827852A
       Revision:             Serial number: 0000043817134
    End-------------------------(Elapsed Time: 04:08)--------------------------
  2. Likes _Val, Uwe liked this post
  3. #2
    Hello OP nice first post and welcome to the VCDS forum!
    Are you sure correct WSM?
    Please provide a VIN number.
    What did RTFB say & when searching WD for J792 or component locations?
    JPPSG
    Jul 2019
    Thank you!
    WSM would be workshop manual? In that case yes, elsawin 4.0, and the correct car is selected. Everything match the car, engine, gearbox.
    Why do you need the full VIN?
    The last 6 digits are 900021.
    Well Elsawin says it resides under the drivers seat, under the carpet. I had the entire side of the carpet of, and there is nothing but a coupling station for the seat.
    This is not the manual i use, but the pages are the exact same: https://workshop-manuals.com/audi/a4...trol_unitj792/
    Jul 2019
    Awesome, right on the floor to collect water ingress FOD to be verified?
    Is the car LHD or RHD? Sometimes Elsawin assumes LHD which means on a RHD car it could be under the passenger seat?
  8. Likes Fredrick Awuor liked this post
    Jul 2019
    #Jack
    Yes also very practical when you have to get to the unit. Remove seat, remove all kinds of trim, pry up the carpet, hold it with a piece of lumber. Yes! The manual says to use an appropriate piece of wood!
    Which i did, and there was no unit and no signs of removal.
    The J428 controller is a sensor and computer in one. Its located in the front bumper right side. This is the only visible problem on this car, someone tried to solder on yellow repair wires. I have never seen worse soldering in my life. Big blops of solder the size of peppercorns. Electrical tape to water "proof" it.
    And a bad battery. I changed it.
    Poor car...
    #PetrolDave
    LHD. And there is even RHD instructions too.
    Edit:
    And the cars runs fine, power steering works. Everything mechanical seems to work.
  11. #8
    WTF
    Pictures please!
  12. #9
    Jul 2019
    Pictures tomorrow, promise.
    The unit is unharmed, it's just the wires.
    Meanwhile, shoutout to anyone with knowledge on the PR-1N8/1N8 configuration.
    According to the WSM both hydraulic and electromechanical power steering can be fitted. I think Dynamic Steering is only electromechanical but i am not sure.
    My head is spinning now, i'm heading for bed.
  13. #10
    Use the microfiche to cross stuff or part numbers and PR over ..........
