Results 1 to 6 of 6
Thread: VAGCom report, 4 diagnostic lights, trying to find out issue
    New User
    Oct 2016
    Exclamation VAGCom report, 4 diagnostic lights, trying to find out issue
    I have an Audi A6 C7 2014 2.0TDI.
    During a course of a day, I would get 3-4 diagnostic lights come on, Traction, Triangle Light, Tyre Pressure Monitoring, Parking Brake fault. Also shows headlight adjustment error.
    All the errors come on at the same time, then 5 minutes they all go, to another random moment in day.
    Have cleared and re done a VAGCom report and listed below:
    Some of the modules state that Missing Information, trying to work out what is actually going on.
    If someone could take a few minutes to look over and see what they think in their opinion.
    Saturday,13,July,2019,00:03:30:22334
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(Parallels)
    VCDS Version 18.9.1.0 (x64)
    Ross-Tech: Home
    VIN: WAUZZZ4G2EN157061 License Plate: BO55YEA
    Mileage: 149733km-93039mi Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 47 52 53 55
    5F 62 6D 72 AC
    VIN: WAUZZZ4G2EN157061 Mileage: 149733km-93039miles
    3B-Sensor Elect. -- Status: Malfunction 0010
    Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 021 BD HW: 04L 907 309
    Component: R4 2,0L EDC H23 8284
    Revision: 85H23---
    Coding: 12254012242401080000
    Shop #: WSC 00046 000 00000
    ASAM Dataset: EV_ECM20TDI01104L906021BD 002006
    ROD: EV_ECM20TDI01104L906021BD_002.rod
    VCID: 68DE338C9324E50A75-803D
    U1113 00 [040] - -
    Fault Frequency: 10
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    Engine speed: 835.00 /min
    Normed load value: 55.3 %
    Coolant temperature: 91 °C
    Intake air temperature: 79 °C
    Voltage terminal 30: 13.120 V
    Cruise Control System (CCS): switch position-Bits 0-7: 0
    Cruise Control System (CCS): status-Bits 0-7: 15
    Cruise control switch-off: irreversible-Bits 0-7: 255
    Cruise control switch-off: reversible-Bits 0-7: 255
    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
    U1113 00 [040] - -
    Fault Frequency: 10
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    Voltage terminal 30: 13.060 V
    5250 - Function Restriction due to Faults in Other Modules
    U1113 00 [040] - -
    Fault Frequency: 10
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    Engine speed: 839.00 /min
    Normed load value: 54.9 %
    Voltage terminal 30: 13.100 V
    Longitudinal acceleration: raw value: 32.767 m/s²
    Vehicle inclination acceleration angle: raw value: 32.767 m/s²
    Status: incline angle-Bits 0-7: 1
    Longitudinal acceleration: -0.099 m/s²
    Longitudinal acceleration sensor: status-Bits 0-7: 1
    Vehicle lateral acceleration: raw value: 327.67 g
    Vehicle lateral acceleration: 0.00 g
    Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
    Part No SW: 4G0 927 153 HW: 0CK 927 156 L
    Component: 0CK 20TDI RdW H03 0002
    Revision: --H03--- Serial number: 0000000434
    Coding: 000001
    ASAM Dataset: EV_TCMDL382021 002009
    ROD: EV_TCMDL382021_AU57.rod
    VCID: 66C23DB49930F37A47-8033
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
    Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
    Component: ESP PREMIUM H09 0450
    Coding: 06A29F016045F980DB00
    VCID: 3A7AB9C4BD08A79AD3-806F
    0518 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Fault Frequency: 21
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:38:21
    VzRef: 00
    Bit Info 1: 00
    Bit Info 2: 02
    Bit Info 3: 00
    Bit Info 4: 1F
    F-Path: 01
    F-Type: 0D
    Uz: 93
    0486 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    VzRef: 00
    Bit Info 1: 80
    Bit Info 2: 42
    Bit Info 3: 22
    Bit Info 4: 1F
    F-Path: 02
    F-Type: 08
    Uz: B0
    Part No SW: 4H0 907 064 EN HW: 4H0 907 064 EN
    Component: BCM2 2.0 H36 0521
    Coding: 01B93046000000000000
    VCID: 79F866C8F08E6C829A-802D
    Serial number: 0214000076168002
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
    Part No SW: 4G0 820 043 BB HW: 4G0 820 043 BB
    Component: KLIMA 2 ZONEN H14 0096
    Serial number: 25041400110416
    Coding: 3422090821
    ASAM Dataset: EV_AirCondiBasisUDS 004002
    ROD: EV_AirCondiBasisUDS_004.rod
    VCID: 60CE2BAC7B149D4ABD-8035
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
    Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
    Component: BCM1 2.0 H12 0130
    Revision: 20012002 Serial number: 00000001733510
    Coding: 2600201141349FE00181008380001D0C0F9DC60827090201000004606100
    Shop #: WSC 01179 210 93569
    VCID: 6ED24594B9C03B3A3F-803B
    Component: WWS57X 140328 H37 0080
    Serial number: 140405045501
    Coding: 0045F7
    Component: G397_RLFS H06 0002
    Serial number: 22543811
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
    Component: E1 - LDS H07 0044
    Serial number: 22 04 2014 00001496
    Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
    Component: Humidity_Sens H03 0002
    Serial number: 08284627000000000001
    Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
    Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
    Revision: 11001001 Serial number: 61061411801301
    Coding: 08C308
    VCID: 71E85EE8A0FE24C222-8025
    Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
    Component: Airbag10.43 H43 0040
    Revision: -------- Serial number: 003JG00HPP8R
    Coding: 3032343631324E303235554A305234473053
    VCID: 3662ADF4891043FA37-8063
    Serial number: 3575HRB405R2FL64B187
    Serial number: 3585HRB405D2FNOG1OF3
    Serial number: 3515JRB405J2DJEUB8TA
    Serial number: 3525JRB40652GGHIN1IQ
    Serial number: 3554VRB401E50VKSCQ5H
    Serial number: 3564VRB401E50VKSMPO3
    1049093 - Databus
    Fault Frequency: 10
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    1049094 - Databus
    Fault Frequency: 10
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    1049095 - Databus
    Fault Frequency: 10
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
    Component: Lenks.Modul H05 0201
    Revision: 00000000 Serial number: 20140423000134
    Coding: 000035
    VCID: 306E9BEC63746DCA6D-8065
    Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G8 920 950 S HW: 4G8 920 950 S
    Component: MDieGb H43 0411
    Revision: 27450259 Serial number: 658180414592025
    Coding: 23A511000B412E00010400
    ASAM Dataset: EV_RBC7KMID 004048
    ROD: EV_RBC7KMID.rod
    VCID: 3F8CC8D0A62A82B2E4-806B
    Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
    Revision: -------- Serial number: 00000001365006
    Coding: 00CD074400
    VCID: 72EA51E4A5F81FDADB-8027
    Serial number: 5875333203
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
    Component: J532_DCDCStab H23 0021
    Serial number: 140208000000000005DB
    6655 - Sensor electronics control module
    U1077 00 [008] - No communication
    Fault Frequency: 54
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:38:21
    Voltage terminal 30: 11.3 V
    Voltage terminal 15: 0.0 V
    Control Module temperature: 26 °C
    Engine running: OFF
    IN ZAS_Te_X: OFF
    Terminal 15 status: OFF
    Datenfeld: 0
    0274 - FlexRay-Data bus
    U1048 00 [008] - defective
    Fault Frequency: 34
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:26
    Voltage terminal 30: 11.6 V
    Voltage terminal 15: 11.7 V
    Control Module temperature: 30 °C
    System status: Terminal 15 on
    Engine running: OFF
    IN ZAS_Te_X: On
    Terminal 15 status: On
    Datenfeld: 4
    12290 - Quiescent Current
    U1406 00 [008] - Too High
    Fault Frequency: 7
    Reset counter: 22
    Mileage: 149686 km
    Date: 2019.07.10
    Time: 19:00:25
    Voltage terminal 30: 12.1 V
    Control Module temperature: 25 °C
    System status: LIN_active
    Engine running: OFF
    IN ZAS_Te_X: OFF
    Datenfeld: 0
    U140B 00 [008] - -
    Reset counter: 22
    Mileage: 149686 km
    Date: 2019.07.10
    Time: 22:03:45
    Voltage terminal 30: 12.0 V
    Control Module temperature: 23 °C
    Engine running: OFF
    IN ZAS_Te_X: OFF
    Datenfeld: 1
    Component: MEM-FS H03 0157
    Revision: AA000000 Serial number: 00000098883876
    VCID: 77FC60F0C69A7AF2EC-8023
    Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
    Component: SARA 3D H03 0056
    Revision: -------- Serial number: EJ1BPA7209P1KF
    ASAM Dataset: EV_SARA2 005012
    ROD: EV_SARA2.rod
    VCID: 336494E09A6256D210-8067
    3801346 - Databus
    Reset counter: 23
    Mileage: 149688 km
    Date: 2019.07.12
    Time: 14:11:29
    DCU_Internal_DTC: 3A 01 02
    Ignition Cycle Count: 54598
    DCU Temperature: 24 °C
    Voltage terminal 30: 12.4 V
    Voltage VBG 22: 2.5 V
    VIN received: WAUZZZ4G2EN157061
    Debug Data: 00 00 00 00 00 00 00 00
    Component: TSG FA H03 0507
    Coding: 011C16004E01620002080002
    VCID: 479CD030F6FACA725C-8013
    Component: RCEPS H40 0010
    Revision: 00001000 Serial number: 0008195383
    Coding: 101000010000
    ASAM Dataset: EV_RCEPS 009008
    ROD: EV_RCEPS_009.rod
    VCID: 326A91E465785FDA1B-8067
    Revision: 00002001 Serial number: 0334638114
    Coding: 013B0622A0B930008320090400010F470000000000000000000000000000
    Component: DWA-Sensor H01 0010
    02615 - Fuel Tank Cap; Lock
    Fault Status: 00101001
    Reset counter: 22
    Mileage: 149686 km
    Date: 2019.07.11
    Time: 20:34:02
    02616 - Fuel Tank Cap; Unlock
    Reset counter: 22
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 08:12:59
    01505 - Bulb for Blinkers; Rear Right (M8)
    Fault Status: 00101100
    Reset counter: 21
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 12:23:10
    Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
    Component: BOSE-G3-C7 H07 0160
    Revision: CJ007001 Serial number: 00000000099013
    VCID: 1D30525804E6F0A2D6-8049
    Component: TSG BF H03 0507
    VCID: 4682DD34F1F0D37AA7-8013
    Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
    Component: EPB-4 H04 0015
    Revision: -------- Serial number: 00000001445673
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 2D5082987C46002246-8079
    459264 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    Fault Frequency: 10
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    Voltage terminal 30: 13.8 V
    Internal Fault ID: 138
    Red operating lamp: OFF
    Red warning lamp: OFF
    Green operating lamp: OFF
    Yellow warning lamp: OFF
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Auto Adjust: not active
    463616 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    Fault Frequency: 10
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    Internal Fault ID: 185
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
    Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
    Serial number: 140425-0002-194
    Coding: 112296601000A300
    ROD: EV_HeadlRegulBasic.rod
    0055 - Function Restriction due to Implausible Message(s)
    U1112 00 [008] - -
    Fault Frequency: 10
    Reset counter: 24
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 13:47:21
    Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
    Component: RMC Nav Plus H55 0801
    Coding: 010101010141DB47082B060301020100000000
    VCID: 275C70B056BA2A72BC-8073
    Subsystem 1 - Part No: 8X0 919 884 G
    Component: P24-50-13.06 0001
    Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
    Component: DU6 Basic H43 0084
    Serial number: 9464DY0E2659005
    Subsystem 3 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
    Component: E380 BDT C7 H11 0204
    Serial number: 90349NDN0011J
    03278 - Functionality Limited due to Missing Messages
    Reset counter: 22
    Mileage: 149686 km
    Date: 2019.07.12
    Time: 12:30:24
    Bin. Bits: 00000001 10000000
    Bin. Bits: 00000000 00000000
    Component: TSG HL H03 0507
    VCID: 4998D608E0EE3C024A-801D
    Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
    Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
    Component: HDSG-Modul H03 0143
    Revision: 14003001 Serial number: 114400025
    Coding: 097205C010
    ROD: EV_HDSGAu571.rod
    VCID: 3560AAF8941648E23E-8061
    Component: TSG HR H03 0507
    Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
    Component: SCR-Stg-G2 H10 0010
    Revision: 00000000 Serial number: 140930062
    ROD: EV_RDCMA00100_008.rod
    VCID: 2B548C8042520E1258-807F
    End-------------------------(Elapsed Time: 05:07)--------------------------
    Charging system error or faulty terminal 15 relay?
  3. Likes Uwe liked this post
    New User
    Oct 2016
    How am I able to check/find terminal 15 on this vehicle?
    I do not have ODIS etc.
    "Terminal 15" is just some source of switched power.
    New User
    Oct 2016
    OK, where do you think I should start to diagnose.
    Not sure where to look.
    Quote Originally Posted by power33 View Post
    If you don't have a full set of wiring diagrams for your car then I would suggest you get a 1 hour subscription to erWin and download them (and all the other documents relevant to your car) as pdf files.
    Then with wiring diagams you can see what relay(s) and connector(s) are involved with generating the terminal 15 switched power.
  8. Likes Trade Member, Uwe liked this post
